MOAB: Mesh Oriented datABase
(version 5.1.1)
00001 #ifndef GET_FILE_OPTIONS_H 00002 #define GET_FILE_OPTIONS_H 00003 00004 #include "moab/Core.hpp" 00005 00006 namespace moab 00007 { 00008 00009 // Check first character for a '-'. 00010 // Return true if one is found. False otherwise. 00011 bool check_for_flag( const char* str ) 00012 { 00013 if( str[0] == '-' ) 00014 return true; 00015 else 00016 return false; 00017 } 00018 00019 // New get_file_options() function with added possibilities for mbcoupler_test. 00020 ErrorCode get_file_options( int argc, char** argv, std::vector< std::string >& meshFiles, std::string& interpTag, 00021 std::string& gNormTag, std::string& ssNormTag, std::vector< const char* >& ssTagNames, 00022 std::vector< const char* >& ssTagValues, std::string& readOpts, std::string& outFile, 00023 std::string& writeOpts, std::string& dbgFile, bool& help ) 00024 { 00025 // Initialize some of the outputs to null values indicating not present 00026 // in the argument list. 00027 gNormTag = ""; 00028 ssNormTag = ""; 00029 readOpts = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;PARALLEL_" 00030 "RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;CPUTIME"; 00031 outFile = ""; 00032 writeOpts = "PARALLEL=WRITE_PART;CPUTIME"; 00033 dbgFile = ""; 00034 std::string defaultDbgFile = argv[0]; // The executable name will be the default debug output file. 00035 00036 // These will indicate if we've gotten our required parameters at the end of parsing. 00037 bool haveMeshes = false; 00038 bool haveInterpTag = false; 00039 00040 // Loop over the values in argv pulling out an parsing each one 00041 int npos = 1; 00042 00043 if( argc > 1 && argv[1] == std::string( "-h" ) ) 00044 { 00045 help = true; 00046 return MB_SUCCESS; 00047 } 00048 00049 while( npos < argc ) 00050 { 00051 if( argv[npos] == std::string( "-meshes" ) ) 00052 { 00053 // Parse out the mesh filenames 00054 npos++; 00055 int numFiles = 2; 00056 meshFiles.resize( numFiles ); 00057 for( int i = 0; i < numFiles; i++ ) 00058 { 00059 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00060 meshFiles[i] = argv[npos++]; 00061 else 00062 { 00063 std::cerr << " ERROR - missing correct number of mesh filenames" << std::endl; 00064 return MB_FAILURE; 00065 } 00066 } 00067 00068 haveMeshes = true; 00069 } 00070 else if( argv[npos] == std::string( "-itag" ) ) 00071 { 00072 // Parse out the interpolation tag 00073 npos++; 00074 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00075 interpTag = argv[npos++]; 00076 else 00077 { 00078 std::cerr << " ERROR - missing <interp_tag>" << std::endl; 00079 return MB_FAILURE; 00080 } 00081 00082 haveInterpTag = true; 00083 } 00084 else if( argv[npos] == std::string( "-gnorm" ) ) 00085 { 00086 // Parse out the global normalization tag 00087 npos++; 00088 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00089 gNormTag = argv[npos++]; 00090 else 00091 { 00092 std::cerr << " ERROR - missing <gnorm_tag>" << std::endl; 00093 return MB_FAILURE; 00094 } 00095 } 00096 else if( argv[npos] == std::string( "-ssnorm" ) ) 00097 { 00098 // Parse out the subset normalization tag and selection criteria 00099 npos++; 00100 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00101 ssNormTag = argv[npos++]; 00102 else 00103 { 00104 std::cerr << " ERROR - missing <ssnorm_tag>" << std::endl; 00105 return MB_FAILURE; 00106 } 00107 00108 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00109 { 00110 char* opts = argv[npos++]; 00111 char sep1[1] = { ';' }; 00112 char sep2[1] = { '=' }; 00113 bool end_vals_seen = false; 00114 std::vector< char* > tmpTagOpts; 00115 00116 // first get the options 00117 for( char* i = strtok( opts, sep1 ); i; i = strtok( 0, sep1 ) ) 00118 { 00119 tmpTagOpts.push_back( i ); 00120 } 00121 00122 // parse out the name and val or just name. 00123 for( unsigned int j = 0; j < tmpTagOpts.size(); j++ ) 00124 { 00125 char* e = strtok( tmpTagOpts[j], sep2 ); 00126 ssTagNames.push_back( e ); 00127 e = strtok( 0, sep2 ); 00128 if( e != NULL ) 00129 { 00130 // We have a value 00131 if( end_vals_seen ) 00132 { 00133 // ERROR we should not have a value after none are seen 00134 std::cerr << " ERROR - new value seen after end of values in " 00135 "<ssnorm_selection>" 00136 << std::endl; 00137 return MB_FAILURE; 00138 } 00139 // Otherwise get the value string from e and convert it to an int 00140 int* valp = new int; 00141 *valp = atoi( e ); 00142 ssTagValues.push_back( (const char*)valp ); 00143 } 00144 else 00145 { 00146 // Otherwise there is no '=' so push a null on the list 00147 end_vals_seen = true; 00148 ssTagValues.push_back( (const char*)0 ); 00149 } 00150 } 00151 } 00152 else 00153 { 00154 std::cerr << " ERROR - missing <ssnorm_selection>" << std::endl; 00155 return MB_FAILURE; 00156 } 00157 } 00158 else if( argv[npos] == std::string( "-ropts" ) ) 00159 { 00160 // Parse out the mesh file read options 00161 npos++; 00162 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00163 readOpts = argv[npos++]; 00164 else 00165 { 00166 std::cerr << " ERROR - missing <roptions>" << std::endl; 00167 return MB_FAILURE; 00168 } 00169 } 00170 else if( argv[npos] == std::string( "-outfile" ) ) 00171 { 00172 // Parse out the output file name 00173 npos++; 00174 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00175 outFile = argv[npos++]; 00176 else 00177 { 00178 std::cerr << " ERROR - missing <out_file>" << std::endl; 00179 return MB_FAILURE; 00180 } 00181 } 00182 else if( argv[npos] == std::string( "-wopts" ) ) 00183 { 00184 // Parse out the output file write options 00185 npos++; 00186 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00187 writeOpts = argv[npos++]; 00188 else 00189 { 00190 std::cerr << " ERROR - missing <woptions>" << std::endl; 00191 return MB_FAILURE; 00192 } 00193 } 00194 else if( argv[npos] == std::string( "-dbgout" ) ) 00195 { 00196 // Parse out the debug output file name. 00197 // If no name then use the default. 00198 npos++; 00199 if( ( npos < argc ) && ( !check_for_flag( argv[npos] ) ) ) 00200 dbgFile = argv[npos++]; 00201 else 00202 dbgFile = defaultDbgFile; 00203 } 00204 else 00205 { 00206 // Unrecognized parameter. Skip it and move along. 00207 std::cerr << " ERROR - Unrecognized parameter:" << argv[npos] << std::endl; 00208 std::cerr << " Skipping..." << std::endl; 00209 npos++; 00210 } 00211 } 00212 00213 if( !haveMeshes ) 00214 { 00215 meshFiles.resize( 2 ); 00216 meshFiles[0] = std::string( TestDir + "/64bricks_1khex.h5m" ); 00217 meshFiles[1] = std::string( TestDir + "/64bricks_12ktet.h5m" ); 00218 std::cout << "Mesh files not entered; using default files " << meshFiles[0] << " and " << meshFiles[1] 00219 << std::endl; 00220 } 00221 00222 if( !haveInterpTag ) 00223 { 00224 interpTag = "vertex_field"; 00225 std::cout << "Interpolation field name not given, using default of " << interpTag << std::endl; 00226 } 00227 00228 #ifdef MOAB_HAVE_HDF5 00229 if( 1 == argc ) 00230 { 00231 std::cout << "No arguments given; using output file dum.h5m." << std::endl; 00232 outFile = "dum.h5m"; 00233 } 00234 #endif 00235 00236 return MB_SUCCESS; 00237 } 00238 } // namespace moab 00239 00240 #endif // GET_FILE_OPTIONS_H
