gqt_findvol_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "moab/GeomQueryTool.hpp"
#include "moab/GeomTopoTool.hpp"
+ Include dependency graph for gqt_findvol_test.cpp:
Classes
struct  FindVolTestResult
Defines
#define IS_BUILDING_MB
Functions
void find_volume_tests ()
int main ()
ErrorCode id_lookup (EntityHandle eh, int &id)
Variables
CoreMBI
GeomTopoToolGTT
GeomQueryToolGQT
Tag id_tag = 0
const std::string input_file = "unittest/find_vol_test_geom.h5m"
Define Documentation
Definition at line 4 of file gqt_findvol_test.cpp.
Function Documentation
Definition at line 101 of file gqt_findvol_test.cpp.
References CHECK, FindVolTestResult::dir, ErrorCode, moab::GeomQueryTool::find_volume(), moab::GeomTopoTool::get_one_vol_root(), GQT, GTT, id_lookup(), MB_CHK_SET_ERR_CONT, MB_ENTITY_NOT_FOUND, num_tests, FindVolTestResult::pnt, FindVolTestResult::resultA, FindVolTestResult::resultB, and test.
Referenced by main().
    ErrorCode rval;
    const struct FindVolTestResult tests[] = {
        // one point unambiguously placed in each volume
        // and the implicit complement
        { { -0.1, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 2, 4 },   // 1
        { { 0.6, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 3, 4 },    // 2
        { { 3.0, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 1, -1 },   // 3
        { { -5.0, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 0, -1 },  // 4
        // Point on the negative side of the geometry
        { { -5.0, 0.0, 0.0 }, { 1.0, 0.0, 0.0 }, 0, -1 },   // 5
        { { -5.0, 0.0, 0.0 }, { -1.0, 0.0, 0.0 }, 0, -1 },  // 6
        // Point on the positive side of the geometry
        { { 10.0, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 0, -1 },   // 7
        { { 10.0, 0.0, 0.0 }, { -1.0, 0.0, 0.0 }, 0, -1 },  // 8
        { { 10.0, 0.0, 0.0 }, { 1.0, 0.0, 0.0 }, 0, -1 },   // 9
        // Point between the volumes
        { { 1.5, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 0, 4 },    // 10
        { { 1.5, 0.0, 0.0 }, { -1.0, 0.0, 0.0 }, 4, -1 },  // 11
        { { 1.5, 0.0, 0.0 }, { 1.0, 0.0, 0.0 }, 4, -1 },   // 12
        { { 1.5, 0.0, 0.0 }, { 0.0, 1.0, 0.0 }, 0, -1 },   // 13
        // Point in the overlap of vols 2 & 3
        { { 0.4, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 2, 3 },   // 14
        { { 0.4, 0.0, 0.0 }, { -1.0, 0.0, 0.0 }, 2, 3 },  // 15
        { { 0.4, 0.0, 0.0 }, { 1.0, 0.0, 0.0 }, 2, 3 },   // 16
        // Point in Vol 3 w/ different directions applied
        { { 0.6, 0.0, 0.0 }, { 0.0, 0.0, 0.0 }, 3, 4 },   // 17
        { { 0.6, 0.0, 0.0 }, { -1.0, 0.0, 0.0 }, 3, 4 },  // 18
        { { 0.6, 0.0, 0.0 }, { 1.0, 0.0, 0.0 }, 3, 4 },   // 19
        // Point on surface of volume 1 w/ tangent direction
        { { 3.0, 0.5, 0.0 }, { 1.0, 0.0, 0.0 }, 1, -1 },   // 20
        { { 3.0, 0.5, 0.0 }, { -1.0, 0.0, 0.0 }, 1, -1 },  // 21
        // Point on surface of volume 1 w/ non-tangent direction
        { { 3.0, 0.5, 0.0 }, { 0.0, 1.0, 0.0 }, 1, -1 },   // 22
        { { 3.0, 0.5, 0.0 }, { 0.0, -1.0, 0.0 }, 4, -1 },  // 23
        // Checks that the neg ray distance doesn't affect results
        // Location: Positive Y Surface of Volume 2
        { { 0.6, 0.25000000000001, 0.0 }, { 0.0, 1.0, 0.0 }, 4, 0 },    // 24
        { { 0.6, 0.25000000000001, 0.0 }, { 0.0, -1.0, 0.0 }, 4, -1 },  // 25
        // ON-SURFACE POINT TESTS (not checked using PIV loop)
        // Point on surface of volume 1 w/ random directions
        { { 3.0, 0.5, 0.0 }, { 0.0, 0.0, 0.0 }, 1, 4 },  // 26
        // Point on surface of volume 2 w/ random directions
        { { 0.6, 0.23, 0.0 }, { 0.0, 0.0, 0.0 }, 3, 4 }  // 27
    int num_tests = sizeof( tests ) / sizeof( FindVolTestResult );
    EntityHandle volume_found;
    int vol_id;
    bool using_find_volume_slow = GTT->get_one_vol_root() == 0;
    // Skip the last two tests
    if( using_find_volume_slow )
        std::cout << "Skipping last two tests when"
                  << "using find_volume_slow (PIV loop)" << std::endl;
        num_tests -= 2;
    for( int i = 1; i < num_tests + 1; i++ )
        const FindVolTestResult& test = tests[i - 1];
        const double* direction = NULL;
        if( test.dir[0] != 0.0 || test.dir[1] != 0.0 || test.dir[2] != 0.0 )
            direction = test.dir;
        // if we're testing a random direction, run the test many times
        int num_repeats = direction ? 1 : 100;
        for( int j = 0; j < num_repeats; j++ )
            rval = GQT->find_volume( test.pnt, volume_found, direction );
            // if not found, we will check later
            if( rval != MB_ENTITY_NOT_FOUND )
                MB_CHK_SET_ERR_CONT( rval, "Failed in find_volume" );
            rval = id_lookup( volume_found, vol_id );MB_CHK_SET_ERR_CONT( rval, "Failed in id lookup" );
            std::cout << "Test " << i << ". Volume found id: " << vol_id << "\n";
            // make sure at least one of these checks passed
            CHECK( vol_id == test.resultA || vol_id == test.resultB );
            // reset result and id for safety
            volume_found = 0;
            vol_id       = -1;
        }  // repeat loop
    }      // test loop
ErrorCode id_lookup ( EntityHandle  eh,
int &  id
Definition at line 51 of file gqt_findvol_test.cpp.
References ErrorCode, id_tag, MB_CHK_SET_ERR, MB_SUCCESS, and MBI.
Referenced by find_volume_tests().
    ErrorCode rval;
    if( !id_tag )
        id_tag = MBI->globalId_tag();
    rval = MBI->tag_get_data( id_tag, &eh, 1, (void*)&id );MB_CHK_SET_ERR( rval, "Failed to lookup volume id" );
    return MB_SUCCESS;
int main ( )
Definition at line 25 of file gqt_findvol_test.cpp.
References moab::GeomTopoTool::construct_obb_trees(), ErrorCode, find_volume_tests(), GQT, GTT, moab::GeomQueryTool::initialize(), input_file, MB_CHK_SET_ERR, MBI, and RUN_TEST.
    MBI            = new Core();
    ErrorCode rval = MBI->load_file( input_file.c_str() );MB_CHK_SET_ERR( rval, "Failed to load test file" );
    GTT = new GeomTopoTool( MBI );
    GQT = new GeomQueryTool( GTT );
    // initialize the rest of the GQT
    GQT->initialize();
    int result = 0;
    // with no global OBB tree (will defer to find_volume_slow)
    result += RUN_TEST( find_volume_tests );
    // build OBBs with one-vol tree
    GTT->construct_obb_trees( true );
    // using the global OBB tree
    return result;
Variable Documentation
Definition at line 21 of file gqt_findvol_test.cpp.
Definition at line 15 of file gqt_findvol_test.cpp.
