MOAB: Mesh Oriented datABase
(version 5.1.1)
Functions | |
void | iMesh_initEntArrIter (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int requested_entity_type, const int requested_entity_topology, const int requested_array_size, const int resilient, iBase_EntityArrIterator *entArr_iterator, int *err) |
Initialize an array iterator over specified entity type, topology, and size. | |
void | iMesh_getNextEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, int *has_data, int *err) |
Get entities contained in array iterator and increment iterator. | |
void | iMesh_resetEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, int *err) |
Reset the array iterator. | |
void | iMesh_endEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, int *err) |
Destroy the specified array iterator. | |
void | iMesh_initEntIter (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int requested_entity_type, const int requested_entity_topology, const int resilient, iBase_EntityIterator *entity_iterator, int *err) |
Initialize an iterator over specified entity type, topology, and size. | |
void | iMesh_getNextEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, iBase_EntityHandle *entity_handle, int *has_data, int *err) |
Get entity corresponding to an iterator and increment iterator. | |
void | iMesh_resetEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, int *err) |
Reset the iterator. | |
void | iMesh_endEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, int *err) |
Destroy the specified iterator. | |
void | iMesh_stepEntIter (iMesh_Instance instance, iBase_EntityIterator ent_iterator, int step_length, int *at_end, int *err) |
Step the iterator a specified number of entities. | |
void | iMesh_initEntArrIterRec (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int requested_entity_type, const int requested_entity_topology, const int requested_array_size, const int resilient, const int recursive, iBase_EntityArrIterator *entArr_iterator, int *err) |
Initialize an array iterator over specified entity type, topology, and size, with an optional recursive flag. |
void iMesh_endEntArrIter | ( | iMesh_Instance | instance, |
iBase_EntityArrIterator | entArr_iterator, | ||
int * | err | ||
[in] | instance | iMesh instance handle |
[in] | entArr_iterator | Iterator which gets destroyed |
[out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 581 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, and RETURN.
{ delete entArr_iterator; RETURN(iBase_SUCCESS); }
void iMesh_endEntIter | ( | iMesh_Instance | instance, |
iBase_EntityIterator | entity_iterator, | ||
int * | err | ||
[in] | entity_iterator | Iterator which gets destroyed |
Definition at line 2321 of file iMesh_MOAB.cpp.
References iMesh_endEntArrIter.
{ iMesh_endEntArrIter(instance, reinterpret_cast<iBase_EntityArrIterator>(entity_iterator), err); }
void iMesh_getNextEntArrIter | ( | iMesh_Instance | instance, |
iBase_EntityHandle ** | entity_handles, | ||
int * | entity_handles_allocated, | ||
int * | entity_handles_size, | ||
int * | has_data, | ||
int * | err | ||
Get the entities corresponding to an array iterator (e.g. dereference the array iterator), and increment the iterator. The dereferenced value(s) are returned in entity_handles. If the iterator is at the end of the iteration, the dereferenced value(s) are undefined and has_data will be returned with a value of zero. Otherwise, has_data will be returned with a non-zero value.
Method: getEntArrNextIter[]
[in] | entArr_iterator | Iterator being queried |
[in,out] | entity_handles | Pointer to array of entity handles contained in current value of iterator Array pointer, allocated and occupied sizes argument trio) |
[in,out] | entity_handles_allocated | Pointer to allocated size of entity_handles |
[out] | entity_handles_size | Pointer to occupied size of entity_handles |
[out] | has_data | Pointer to a flag indicating if the value(s) returned in entity_handles are valid. A non-zero value indicates the value(s) are valid. A zero value indicates the value(s) are NOT valid. |
Definition at line 555 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, iBase_EntityArrIterator_Private::array_size(), iBase_EntityArrIterator_Private::get_entities(), iBase_SUCCESS, MOABI, and RETURN.
{ // check the size of the destination array ALLOC_CHECK_ARRAY_NOFAIL(entity_handles, entArr_iterator->array_size()); entArr_iterator->get_entities( dynamic_cast<Core*>(MOABI), (EntityHandle*)*entity_handles, *entity_handles_size ); *has_data = (*entity_handles_size != 0); RETURN(iBase_SUCCESS); }
void iMesh_getNextEntIter | ( | iMesh_Instance | instance, |
iBase_EntityHandle * | entity_handle, | ||
int * | err | ||
Get the entity corresponding to an iterator (that is, dereference the iterator), and increment the iterator. The dereferenced value is returned in 'entity_handle'. If the iterator is at the end of the iteration, the dereferenced value will be undefined and 'has_data' will have a value of zero. Otherwise, 'has_data' will have a non-zero value.
[in] | entity_iterator | Iterator being queried |
[out] | entity_handle | Pointer to an entity handle corresponding to the current value of iterator just prior to the call. |
[out] | has_data | Pointer to a flag indicating if the value returned in entity_handle is valid. A non-zero value indicates the value is valid. A zero value indicates the value is NOT valid. |
Definition at line 2301 of file iMesh_MOAB.cpp.
References iMesh_getNextEntArrIter.
{ int eh_size = 1; iMesh_getNextEntArrIter(instance, reinterpret_cast<iBase_EntityArrIterator>(entity_iterator), &entity_handle, &eh_size, &eh_size, is_end, err); }
void iMesh_initEntArrIter | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set_handle, | ||
const int | requested_entity_type, | ||
const int | requested_entity_topology, | ||
const int | requested_array_size, | ||
const int | resilient, | ||
iBase_EntityArrIterator * | entArr_iterator, | ||
int * | err | ||
Initialize an array iterator over specified entity type, topology, and size, for a specified set or instance. Iterator returned can be used as input to functions returning entities for the iterator. If all entities of a specified type and/or topology are to be iterated, specify iBase_ALL_TYPES or iMesh_ALL_TOPOLOGIES, respectively. Specified type or topology must be a value in the iBase_EntityType or iMesh_EntityTopology enumerations, respectively.
Method: initEntArrIter[]
[in] | entity_set_handle | Entity set being iterated |
[in] | requested_entity_type | Type of entity to iterate |
[in] | requested_entity_topology | Topology of entity to iterate |
[in] | requested_array_size | Size of chunks of handles returned for each value of the iterator |
[in] | resilient | If zero, return a non-resilient iterator. Otherwise, a resilient iterator (Resilient and Non-Resilient Iterators) |
[out] | entArr_iterator | Pointer to iterator returned from function |
Definition at line 538 of file iMesh_MOAB.cpp.
References iMesh_initEntArrIterRec.
{ iMesh_initEntArrIterRec(instance, entity_set_handle, requested_entity_type, requested_entity_topology, requested_array_size, resilient, false, entArr_iterator, err); }
void iMesh_initEntArrIterRec | ( | iMesh_Instance | instance, |
const int | recursive, | ||
int * | err | ||
Initialize an array iterator over specified entity type, topology, and size, for a specified set or instance. Iterator returned can be used as input to functions returning entities for the iterator. If all entities of a specified type and/or topology are to be iterated, specify iBase_ALL_TYPES or iMesh_ALL_TOPOLOGIES, respectively. Specified type or topology must be a value in the iBase_EntityType or iMesh_EntityTopology enumerations, respectively. If recursive is true, entities are retrieved recursively through contained (but not child) sets.
[in] | recursive | If non-zero, entities retrieved recursively |
Definition at line 3047 of file iMesh_MOAB.cpp.
References CHKENUM, CHKERR, ENTITY_HANDLE, ERROR, iBase_ALL_TYPES, iBase_BAD_TYPE_AND_TOPO, iBase_INVALID_ENTITY_TOPOLOGY, iBase_INVALID_ENTITY_TYPE, iBase_NOT_SUPPORTED, iBase_REGION, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_SEPTAHEDRON, MB_SUCCESS, mb_topology_table, MESHSET_ORDERED, MOABI, and RETURN.
{ CHKENUM(requested_entity_type, iBase_EntityType, iBase_INVALID_ENTITY_TYPE); CHKENUM(requested_entity_topology, iMesh_EntityTopology, iBase_INVALID_ENTITY_TOPOLOGY); if (resilient) ERROR(iBase_NOT_SUPPORTED, "reslient iterators not supported"); EntityType req_type = mb_topology_table[requested_entity_topology]; if (requested_entity_topology != iMesh_ALL_TOPOLOGIES) { if (requested_entity_type != iBase_ALL_TYPES) { if (requested_entity_topology != iMesh_SEPTAHEDRON && requested_entity_type != CN::Dimension(req_type)) ERROR(iBase_BAD_TYPE_AND_TOPO, "type and topology are inconsistant"); // Special-case handling for septahedra since we don't support them else if (requested_entity_topology == iMesh_SEPTAHEDRON && requested_entity_type != iBase_REGION) ERROR(iBase_BAD_TYPE_AND_TOPO, "type and topology are inconsistant"); } } ErrorCode result; unsigned flags; result = MOABI->get_meshset_options( ENTITY_HANDLE(entity_set_handle), flags ); CHKERR(result,"Invalid entity set handle"); if (flags & MESHSET_ORDERED) *entArr_iterator = new MBListIter( (iBase_EntityType)requested_entity_type, (iMesh_EntityTopology)requested_entity_topology, ENTITY_HANDLE(entity_set_handle), requested_array_size, recursive ); else *entArr_iterator = new MBRangeIter( (iBase_EntityType)requested_entity_type, (iMesh_EntityTopology)requested_entity_topology, ENTITY_HANDLE(entity_set_handle), requested_array_size, recursive ); result = (*entArr_iterator)->reset( MOABI ); if (MB_SUCCESS != result) delete *entArr_iterator; CHKERR(result, "iMesh_initEntArrIter: ERROR getting entities of proper type or topology." ); RETURN(iBase_SUCCESS); }
void iMesh_initEntIter | ( | iMesh_Instance | instance, |
iBase_EntityIterator * | entity_iterator, | ||
int * | err | ||
Initialize an iterator over specified entity type, topology, and size, for a specified set or instance. Iterator returned can be used as input to functions returning the entity for the iterator. If all entities of a specified type and/or topology are to be iterated, specify iBase_ALL_TYPES or iMesh_ALL_TOPOLOGIES, respectively. Specified type or topology must be a value in the iBase_EntityType or iMesh_EntityTopology enumerations, respectively.
Note: This function will fail and return an error if the caller passes a combination of entity_type and entity_topology that are not consistent.
[out] | entity_iterator | Pointer to iterator returned from function |
Definition at line 2287 of file iMesh_MOAB.cpp.
{ iMesh_initEntArrIterRec(instance, entity_set_handle, requested_entity_type, requested_entity_topology, 1, resilient, false, reinterpret_cast<iBase_EntityArrIterator*>(entity_iterator), err); }
void iMesh_resetEntArrIter | ( | iMesh_Instance | instance, |
int * | err | ||
Method: resetEntArrIter[]
[in] | entArr_iterator | Iterator to reset |
Definition at line 573 of file iMesh_MOAB.cpp.
References CHKERR, iBase_SUCCESS, MOABI, iBase_EntityArrIterator_Private::reset(), and RETURN.
void iMesh_resetEntIter | ( | iMesh_Instance | instance, |
int * | err | ||
Reset the iterator.
Reset the iterator
[in] | entity_iterator | Iterator to reset |
Definition at line 2313 of file iMesh_MOAB.cpp.
References iMesh_resetEntArrIter.
{ iMesh_resetEntArrIter(instance, reinterpret_cast<iBase_EntityArrIterator>(entity_iterator), err); }
void iMesh_stepEntIter | ( | iMesh_Instance | instance, |
iBase_EntityIterator | ent_iterator, | ||
int | step_length, | ||
int * | at_end, | ||
int * | err | ||
Step the iterator a specified number of entities. If this number is greater than the number of entities left in the iterator, the iterator is placed at the end and at_end is returned non-zero; otherwise at_end is returned zero.
[in] | ent_iterator | Iterator being queried |
[in] | step_length | Number of entities to step the iterator |
[out] | at_end | Non-zero if iterator is at the end of the iteration |
Definition at line 3007 of file iMesh_MOAB.cpp.
References iMesh_stepEntArrIter.
{ iMesh_stepEntArrIter(instance, reinterpret_cast<iBase_EntityArrIterator>(ent_iterator), step_length, at_end, err); }
