MOAB: Mesh Oriented datABase
(version 5.1.1)
Functions | |
void | iMesh_subtract (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err) |
Subtract contents of one entity set from another. | |
void | iMesh_intersect (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err) |
Intersect contents of one entity set with another. | |
void | iMesh_unite (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err) |
Unite contents of one entity set with another. |
void iMesh_intersect | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set_1, | ||
const iBase_EntitySetHandle | entity_set_2, | ||
iBase_EntitySetHandle * | result_entity_set, | ||
int * | err | ||
[in] | instance | iMesh instance handle |
[in] | entity_set_1 | Entity set being intersected with another |
[in] | entity_set_2 | Entity set being intersected with another |
[out] | result_entity_set | Pointer to entity set returned from function |
[out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 2449 of file iMesh_MOAB.cpp.
References CHKERR, entities, ENTITY_HANDLE, ERROR, iBase_SUCCESS, iMesh_isList, MB_SUCCESS, MESHSET_ORDERED, MESHSET_SET, MOABI, and RETURN.
{ EntityHandle temp_set; EntityHandle set1 = ENTITY_HANDLE(entity_set_1), set2 = ENTITY_HANDLE(entity_set_2); int isList1=0, isList2=0; iMesh_isList(instance, entity_set_1, &isList1, err); if (*err != iBase_SUCCESS) return; iMesh_isList(instance, entity_set_2, &isList2, err); if (*err != iBase_SUCCESS) return; ErrorCode result; if (isList1 && isList2) result = MOABI->create_meshset(MESHSET_ORDERED, temp_set); else result = MOABI->create_meshset(MESHSET_SET, temp_set); if (MB_SUCCESS != result) ERROR(result, "iMesh_intersect: couldn't create result set."); if (!entity_set_1 && !entity_set_2) { // intersecting the root set with itself, so get everything... Range entities; result = MOABI->get_entities_by_handle(0, entities); if (MB_SUCCESS == result) result = MOABI->add_entities(temp_set, entities); // ...but not the newly-created set! if (MB_SUCCESS == result) result = MOABI->remove_entities(temp_set, &temp_set, 1); } else if (!entity_set_1) { result = MOABI->unite_meshset(temp_set, set2); } else if (!entity_set_2) { result = MOABI->unite_meshset(temp_set, set1); } else { if (isList1 && isList2) { // ITAPS has very specific rules about the behavior of intersection on // list-type sets. Since MOAB doesn't (and likely will never) work // exactly this way, we implement our own algorithm here. #ifdef MOAB_HAVE_UNORDERED_MAP typedef MOAB_UNORDERED_MAP_NS::unordered_map<EntityHandle, size_t> lookup_t; #else typedef std::map<EntityHandle, size_t> lookup_t; #endif // First, build a lookup table for the second set. lookup_t lookup; { std::vector<EntityHandle> contents2; result = MOABI->get_entities_by_handle(set2, contents2); CHKERR(result,"iMesh_intersect: ERROR intersect failed."); for (std::vector<EntityHandle>::iterator i = contents2.begin(); i != contents2.end(); ++i) { #ifdef MOAB_HAVE_UNORDERED_MAP lookup_t::iterator j = lookup.find(*i); #else lookup_t::iterator j = lookup.lower_bound(*i); #endif if (j != lookup.end() && j->first == *i) ++j->second; else lookup.insert(j, lookup_t::value_type(*i, 1)); } } // Then, iterate over the contents of the first set and check for // their existence in the second set. std::vector<EntityHandle> contents1; result = MOABI->get_entities_by_handle(set1, contents1); CHKERR(result,"iMesh_intersect: ERROR intersect failed."); std::vector<EntityHandle>::iterator w = contents1.begin(); for (std::vector<EntityHandle>::iterator i = contents1.begin(); i != contents1.end(); ++i) { lookup_t::iterator j = lookup.find(*i); if (j != lookup.end() && j->second) { --j->second; *w = *i; ++w; } } result = MOABI->add_entities(temp_set, &contents1[0], w - contents1.begin()); } else { result = MOABI->unite_meshset(temp_set, set1); if (MB_SUCCESS == result) result = MOABI->intersect_meshset(temp_set, set2); } } CHKERR(result,"iMesh_intersect: ERROR intersect failed."); *result_entity_set = (iBase_EntitySetHandle)temp_set; RETURN(iBase_SUCCESS); }
void iMesh_subtract | ( | iMesh_Instance | instance, |
int * | err | ||
[in] | entity_set_1 | Entity set from which other set is being subtracted |
[in] | entity_set_2 | Entity set being subtracted from other set |
Definition at line 2400 of file iMesh_MOAB.cpp.
{ EntityHandle temp_set; EntityHandle set1 = ENTITY_HANDLE(entity_set_1), set2 = ENTITY_HANDLE(entity_set_2); int isList1=0, isList2=0; iMesh_isList(instance, entity_set_1, &isList1, err); if (*err != iBase_SUCCESS) return; iMesh_isList(instance, entity_set_2, &isList2, err); if (*err != iBase_SUCCESS) return; ErrorCode result; if (isList1 && isList2) result = MOABI->create_meshset(MESHSET_ORDERED, temp_set); else result = MOABI->create_meshset(MESHSET_SET, temp_set); if (MB_SUCCESS != result) ERROR(result, "iMesh_subtract: couldn't create result set."); // if the second set is the root set, the result is always the empty set if (entity_set_2) { if (!entity_set_1) { // subtracting from the root set, so get everything first... Range entities; result = MOABI->get_entities_by_handle(0,entities); if (MB_SUCCESS == result) result = MOABI->add_entities(temp_set, entities); // ...but not the newly-created set! if (MB_SUCCESS == result) result = MOABI->remove_entities(temp_set, &temp_set, 1); } else result = MOABI->unite_meshset(temp_set, set1); if (MB_SUCCESS == result) result = MOABI->subtract_meshset(temp_set, set2); } CHKERR(result, "iMesh_subtract: ERROR subtract failed."); *result_entity_set = (iBase_EntitySetHandle)temp_set; RETURN(iBase_SUCCESS); }
void iMesh_unite | ( | iMesh_Instance | instance, |
int * | err | ||
[in] | entity_set_1 | Entity set being united with another |
[in] | entity_set_2 | Entity set being united with another |
Definition at line 2555 of file iMesh_MOAB.cpp.
{ EntityHandle temp_set; EntityHandle set1 = ENTITY_HANDLE(entity_set_1), set2 = ENTITY_HANDLE(entity_set_2); int isList1=0, isList2=0; iMesh_isList(instance, entity_set_1, &isList1, err); if (*err != iBase_SUCCESS) return; iMesh_isList(instance, entity_set_2, &isList2, err); if (*err != iBase_SUCCESS) return; ErrorCode result; if (isList1 && isList2) result = MOABI->create_meshset(MESHSET_ORDERED, temp_set); else result = MOABI->create_meshset(MESHSET_SET, temp_set); if (MB_SUCCESS != result) ERROR(result, "iMesh_unite: couldn't create result set."); if (entity_set_1 && entity_set_2) { result = MOABI->unite_meshset(temp_set, set1); if (MB_SUCCESS == result) result = MOABI->unite_meshset(temp_set, set2); } else { // uniting with the root set, so get everything... Range entities; result = MOABI->get_entities_by_handle(0, entities); if (MB_SUCCESS == result) result = MOABI->add_entities(temp_set, entities); // ...but not the newly-created set! if (MB_SUCCESS == result) result = MOABI->remove_entities(temp_set, &temp_set, 1); } CHKERR(result,"iMesh_unite: ERROR unite failed."); *result_entity_set = (iBase_EntitySetHandle)temp_set; RETURN(iBase_SUCCESS); }
