MOAB: Mesh Oriented datABase
(version 5.1.1)
Modules | |
Entity Set Operators | |
Functions | |
void | iMesh_getNumOfType (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_type, int *num_type, int *err) |
Get the number of entities of specified type in the instance or set. | |
void | iMesh_getNumOfTopo (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_topology, int *num_topo, int *err) |
Get the number of entities of specified topology in instance or set. | |
void | iMesh_createEntSet (iMesh_Instance instance, const int isList, iBase_EntitySetHandle *entity_set_created, int *err) |
Create an entity set. | |
void | iMesh_destroyEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set, int *err) |
Destroy an entity set. | |
void | iMesh_isList (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, int *is_list, int *err) |
Return whether a specified set is ordered or unordered. | |
void | iMesh_getNumEntSets (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int num_hops, int *num_sets, int *err) |
void | iMesh_getEntSets (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int num_hops, iBase_EntitySetHandle **contained_set_handles, int *contained_set_handles_allocated, int *contained_set_handles_size, int *err) |
void | iMesh_addEntToSet (iMesh_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err) |
Add an entity to a set. | |
void | iMesh_rmvEntFromSet (iMesh_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err) |
Remove an entity from a set. | |
void | iMesh_addEntArrToSet (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err) |
Add an array of entities to a set. | |
void | iMesh_rmvEntArrFromSet (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err) |
Remove an array of entities from a set. | |
void | iMesh_addEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set_to_add, iBase_EntitySetHandle entity_set_handle, int *err) |
Add an entity set to a set. | |
void | iMesh_rmvEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set_to_remove, iBase_EntitySetHandle entity_set_handle, int *err) |
Remove an entity set from a set. | |
void | iMesh_isEntContained (iMesh_Instance instance, iBase_EntitySetHandle containing_entity_set, iBase_EntityHandle contained_entity, int *is_contained, int *err) |
Return whether an entity is contained in another set. | |
void | iMesh_isEntArrContained (iMesh_Instance instance, iBase_EntitySetHandle containing_entity_set, const iBase_EntityHandle *entity_handles, int num_entity_handles, int **is_contained, int *is_contained_allocated, int *is_contained_size, int *err) |
Return whether entities are contained in a set. | |
void | iMesh_isEntSetContained (iMesh_Instance instance, const iBase_EntitySetHandle containing_entity_set, const iBase_EntitySetHandle contained_entity_set, int *is_contained, int *err) |
Return whether an entity set is contained in another set. |
void iMesh_addEntArrToSet | ( | iMesh_Instance | instance, |
const iBase_EntityHandle * | entity_handles, | ||
int | entity_handles_size, | ||
iBase_EntitySetHandle | entity_set, | ||
int * | err | ||
[in] | instance | iMesh instance handle |
[in] | entity_handles | Array of entities being added |
[in] | entity_handles_size | Number of entities in entity_handles array |
[in] | entity_set | Pointer to the set being added to |
[out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 1050 of file iMesh_MOAB.cpp.
References CHKERR, CONST_HANDLE_ARRAY_PTR, ENTITY_HANDLE, iBase_SUCCESS, MOABI, and RETURN.
{ const EntityHandle *ents = CONST_HANDLE_ARRAY_PTR(entity_handles); ErrorCode result = MOABI->add_entities(ENTITY_HANDLE(entity_set), ents, entity_handles_size); CHKERR(result,"iMesh_addEntArrToSet:ERROR adding entities in EntitySet."); RETURN(iBase_SUCCESS); }
void iMesh_addEntSet | ( | iMesh_Instance | instance, |
iBase_EntitySetHandle | entity_set_to_add, | ||
iBase_EntitySetHandle | entity_set_handle, | ||
int * | err | ||
Add an entity set to a set (Cycles in Set-Inclusion and Parent-Child structures.)
[in] | entity_set_to_add | The entity set being added |
[in] | entity_set_handle | Pointer to the set being added to |
Definition at line 1093 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ERROR, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MOABI, and RETURN.
{ if (!entity_set_to_add || !entity_set_handle) ERROR(iBase_INVALID_ARGUMENT, "iMesh_addEntSet: ERROR invalid argument"); EntityHandle to_add = ENTITY_HANDLE(entity_set_to_add); ErrorCode result = MOABI->add_entities(ENTITY_HANDLE(entity_set_handle), &to_add, 1); CHKERR(result,"iMesh_addEntSet:ERROR adding entitysets."); RETURN(iBase_SUCCESS); }
void iMesh_addEntToSet | ( | iMesh_Instance | instance, |
iBase_EntityHandle | entity_handle, | ||
int * | err | ||
[in] | entity_handle | The entity being added |
Definition at line 1064 of file iMesh_MOAB.cpp.
References iMesh_addEntArrToSet.
{ iMesh_addEntArrToSet(instance, &entity_handle, 1, entity_set, err); }
void iMesh_createEntSet | ( | iMesh_Instance | instance, |
const int | isList, | ||
iBase_EntitySetHandle * | entity_set_created, | ||
int * | err | ||
Create an entity set, either ordered (isList=1) or unordered (isList=0). Unordered entity sets can contain a given entity or set only once.
An entity set in iMesh supports managing its contained members in one of two modes. When an entitiy set is first created, the caller is required to indicate which mode of membership the set will support. The two modes that are supported are a) order-preserving (isList=1) or b) duplicate-preventing (isList=0).
For order-preserving membership, the implementation will permit duplicate entities. However, the implementation will guarantee that the order in which entities are added to the set will be the same as the order in which they are queried by the various methods that return the entities of a set. This order preserving guarantee holds across removals. However, it does not hold across removals followed by re-additions of the previously removed entities. This kind of an entity set behaves like an STL vector or STL list and is created by setting isList=1 when creating an entity set.
For duplicate-preventing membership, the implementation will guarantee that duplicate entities are prevented. Any attempts to add duplicate entities to such a set will be detected, prevented and silently ignored by the implementation. This kind of entity set behaves like an STL set and is created by setting isList=0 when creating an entity set.
Finally, all of the above comments apply only to entity members of an entity set and do not apply to the entity set members. Order-preserving and duplicate preventing behavior for entity set members is unspecified. Each implementation may behave differently for entity set members. This design was chosen because we could not identify any use cases where order-preserving behavior for set members was necessary. However, if users encounter situations where such behavior is desirable or necessary, then the ITAPS development team can certainly consider adjusting the interface specification to support it.
[in] | isList | If non-zero, an ordered list is created, otherwise an unordered set is created. |
[out] | entity_set_created | Entity set created by function |
Definition at line 974 of file iMesh_MOAB.cpp.
References CHKERR, iBase_SUCCESS, MESHSET_ORDERED, MESHSET_SET, MOABI, and RETURN.
{ // create the entity set EntityHandle meshset; ErrorCode result; if (isList) result = MOABI->create_meshset(MESHSET_ORDERED, meshset); else result = MOABI->create_meshset(MESHSET_SET, meshset); CHKERR(result,"iMesh_createEntSet: ERROR creating a entityset instance"); // return EntitySet_Handle *entity_set_created = (iBase_EntitySetHandle)meshset; RETURN(iBase_SUCCESS); }
void iMesh_destroyEntSet | ( | iMesh_Instance | instance, |
int * | err | ||
[in] | entity_set | Entity set to be destroyed |
Definition at line 994 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, iBase_SUCCESS, MOABI, and RETURN.
{ EntityHandle set = ENTITY_HANDLE(entity_set); ErrorCode result = MOABI->delete_entities(&set, 1); CHKERR(result, "iMesh_destroyEntSet: couldn't delete the set."); RETURN(iBase_SUCCESS); }
void iMesh_getEntSets | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set_handle, | ||
const int | num_hops, | ||
iBase_EntitySetHandle ** | contained_set_handles, | ||
int * | contained_set_handles_allocated, | ||
int * | contained_set_handles_size, | ||
int * | err | ||
Get the entity sets contained in a set or interface.
[in] | entity_set_handle | Entity set being queried |
[in] | num_hops | Maximum hops from entity_set_handle to contained set, not inclusive of the contained set Indirection in Set-Inclusion and Parent-Child structures) |
[in,out] | contained_set_handles | Pointer to array of set handles returned Array pointer, allocated and occupied sizes argument trio) |
[in,out] | contained_set_handles_allocated | Pointer to allocated length of |
[out] | contained_set_handles_size | Pointer to occupied length of |
Definition at line 1031 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, ENTITY_HANDLE, iBase_SUCCESS, MOABI, and RETURN.
{ std::vector<EntityHandle> sets; ErrorCode rval = MOABI->get_contained_meshsets( ENTITY_HANDLE(entity_set_handle), sets, std::max( num_hops+1, 0 ) ); CHKERR(rval, "iMesh_entitysetGetEntitySets: problem getting entities by type."); ALLOC_CHECK_ARRAY_NOFAIL(contained_entset_handles, sets.size() ); std::copy( sets.begin(), sets.end(), (EntityHandle*)*contained_entset_handles ); *contained_entset_handles_size = sets.size(); RETURN(iBase_SUCCESS); }
void iMesh_getNumEntSets | ( | iMesh_Instance | instance, |
int * | num_sets, | ||
int * | err | ||
Get the number of entity sets contained in a set or interface.
[in] | num_hops | Maximum hops from entity_set_handle to contained set, not inclusive of the contained set. Indirection in Set-Inclusion and Parent-Child structures) |
[out] | num_sets | Pointer to the number of sets returned from function |
Definition at line 1018 of file iMesh_MOAB.cpp.
{ ErrorCode rval = MOABI->num_contained_meshsets( ENTITY_HANDLE(entity_set_handle), num_sets, std::max(0,num_hops+1) ); CHKERR(rval, "iMesh_entitysetGetNumberEntitySets:ERROR getting number of entitysets."); RETURN(iBase_SUCCESS); }
void iMesh_getNumOfTopo | ( | iMesh_Instance | instance, |
const int | entity_topology, | ||
int * | num_topo, | ||
int * | err | ||
Get the number of entities with the specified topology in the instance or set. If entity set handle is root set, return information for instance, otherwise for set. Value of entity topology must be from the iMesh_EntityTopology enumeration. If iMesh_ALL_TOPOLOGIES is specified, total number of entities (excluding entity sets) is returned.
[in] | entity_topology | Topology of entity requested |
[out] | num_topo | Pointer to number of entities, returned from function |
Definition at line 451 of file iMesh_MOAB.cpp.
References iMesh_getNumOfTopoRec.
{ iMesh_getNumOfTopoRec(instance, entity_set_handle, entity_topology, false, num_topo, err); }
void iMesh_getNumOfType | ( | iMesh_Instance | instance, |
const int | entity_type, | ||
int * | num_type, | ||
int * | err | ||
Get the number of entities with the specified type in the instance or set. If entity set handle is root set, return information for instance, otherwise for set. Value of entity type must be from the iBase_EntityType enumeration. If iBase_ALL_TYPES is specified, total number of entities (excluding entity sets) is returned.
[in] | entity_type | Type of entity requested |
[out] | num_type | Pointer to number of entities, returned from function |
Definition at line 442 of file iMesh_MOAB.cpp.
References iMesh_getNumOfTypeRec.
{ iMesh_getNumOfTypeRec(instance, entity_set_handle, entity_type, false, num_type, err); }
void iMesh_isEntArrContained | ( | iMesh_Instance | instance, |
iBase_EntitySetHandle | containing_entity_set, | ||
int | num_entity_handles, | ||
int ** | is_contained, | ||
int * | is_contained_allocated, | ||
int * | is_contained_size, | ||
int * | err | ||
[in] | containing_entity_set | Entity set being queried |
[in] | entity_handles | List of entities for which to check containment. |
[in] | num_entity_handles | Size of entity_handles array of entities to be checked. |
[in,out] | is_contained | One value for each input entity, 1 if contained in set, zero otherwise. Array pointer, allocated and occupied sizes argument trio) |
[in,out] | is_contained_allocated | Allocated size of is_contained array |
[out] | is_contained_size | Occupied size of is_contained array |
Definition at line 1135 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, ENTITY_HANDLE, iBase_SUCCESS, MOABI, and RETURN.
{ EntityHandle set = ENTITY_HANDLE(containing_set); ALLOC_CHECK_ARRAY_NOFAIL(is_contained, num_entity_handles); *is_contained_size = num_entity_handles; if (containing_set) { for (int i = 0; i < num_entity_handles; ++i) { EntityHandle h = ENTITY_HANDLE(entity_handles[i]); (*is_contained)[i] = MOABI->contains_entities( set, &h, 1 ); } } else { std::fill( *is_contained, (*is_contained)+num_entity_handles, 1 ); } RETURN(iBase_SUCCESS); }
void iMesh_isEntContained | ( | iMesh_Instance | instance, |
iBase_EntityHandle | contained_entity, | ||
int * | is_contained, | ||
int * | err | ||
Return whether an entity is contained (*is_contained=1) or not contained (*is_contained=0) in another set
[in] | contained_entity | Entity potentially contained in containing_entity_set |
[out] | is_contained | Pointer to flag returned from function |
Definition at line 1124 of file iMesh_MOAB.cpp.
References iMesh_isEntArrContained.
{ int junk1 = 1, junk2 = 1; iMesh_isEntArrContained( instance, containing_entity_set, &contained_entity, 1, &is_contained, &junk1, &junk2, err ); }
void iMesh_isEntSetContained | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | containing_entity_set, | ||
const iBase_EntitySetHandle | contained_entity_set, | ||
int * | err | ||
Return whether a set is contained (*is_contained=1) or not contained (*is_contained=0) in another set
[in] | contained_entity_set | Entity set potentially contained in containing_entity_set |
Definition at line 1161 of file iMesh_MOAB.cpp.
References iMesh_isEntContained.
{ iMesh_isEntContained(instance, containing_entity_set, reinterpret_cast<iBase_EntityHandle>(contained_entity_set), is_contained, err); }
void iMesh_isList | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set, | ||
int * | is_list, | ||
int * | err | ||
Return whether a specified set is ordered (*is_list=1) or unordered (*is_list=0)
[in] | entity_set | Entity set being queried |
[out] | is_list | Pointer to flag returned from function |
Definition at line 1004 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, iBase_SUCCESS, MESHSET_ORDERED, MOABI, and RETURN.
{ unsigned int options; ErrorCode result = MOABI->get_meshset_options(ENTITY_HANDLE(entity_set), options); CHKERR(result,"iMesh_isList: couldn't query set."); if (options & MESHSET_ORDERED) *is_list = true; else *is_list = false; RETURN(iBase_SUCCESS); }
void iMesh_rmvEntArrFromSet | ( | iMesh_Instance | instance, |
int * | err | ||
[in] | entity_handles | Array of entities being remove |
[in] | entity_set | Pointer to the set being removed from |
Definition at line 1071 of file iMesh_MOAB.cpp.
{ const EntityHandle *ents = CONST_HANDLE_ARRAY_PTR(entity_handles); ErrorCode result = MOABI->remove_entities (ENTITY_HANDLE(entity_set), ents, entity_handles_size); CHKERR(result,"iMesh_rmvEntArrFromSet:ERROR removing entities in EntitySet."); RETURN(iBase_SUCCESS); }
void iMesh_rmvEntFromSet | ( | iMesh_Instance | instance, |
int * | err | ||
[in] | entity_handle | The entity being removed |
Definition at line 1085 of file iMesh_MOAB.cpp.
References iMesh_rmvEntArrFromSet.
{ iMesh_rmvEntArrFromSet(instance, &entity_handle, 1, entity_set, err); }
void iMesh_rmvEntSet | ( | iMesh_Instance | instance, |
iBase_EntitySetHandle | entity_set_to_remove, | ||
int * | err | ||
[in] | entity_set_to_remove | The entity set being removed |
[in] | entity_set_handle | Pointer to the set being removed from |
Definition at line 1108 of file iMesh_MOAB.cpp.
{ if (!entity_set_to_remove || !entity_set_handle) ERROR(iBase_INVALID_ARGUMENT, "iMesh_rmvEntSet: ERROR invalid argument"); EntityHandle to_remove = ENTITY_HANDLE(entity_set_to_remove); ErrorCode result = MOABI->remove_entities (ENTITY_HANDLE(entity_set_handle), &to_remove, 1); CHKERR(result,"iMesh_rmvEntSet:ERROR removing entitysets in EntitySet."); RETURN(iBase_SUCCESS); }
