MOAB: Mesh Oriented datABase  (version 5.1.1)
Initialization
+ Collaboration diagram for Initialization:
Functions
void iMesh_newMesh (const char *options, iMesh_Instance *instance, int *err, int options_len)
 Construct a new iMesh instance.
void iMesh_dtor (iMesh_Instance instance, int *err)
 Destroy an iMesh instance.
void iMesh_load (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const char *name, const char *options, int *err, int name_len, int options_len)
 Load a mesh from a file.
void iMesh_save (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const char *name, const char *options, int *err, const int name_len, int options_len)
 Save a mesh to a file.
void iMesh_getRootSet (iMesh_Instance instance, iBase_EntitySetHandle *root_set, int *err)
 Get handle of the root set for this instance.
void iMesh_getGeometricDimension (iMesh_Instance instance, int *geom_dim, int *err)
 Get the geometric dimension of mesh represented in this instance.
void iMesh_setGeometricDimension (iMesh_Instance instance, int geom_dim, int *err)
 Set geometric dimension of vertex coordinates.
void iMesh_getDfltStorage (iMesh_Instance instance, int *order, int *err)
 Get the default storage order used by this implementation.
Function Documentation
void iMesh_dtor ( iMesh_Instance  instance,
int *  err
Parameters:
[in]instanceiMesh instance handle
[out]errReturned Error status (see iBase_ErrorType)
Definition at line 315 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, and MBIMESHI.
    delete MBIMESHI;
    *err = iBase_SUCCESS;
void iMesh_getDfltStorage ( iMesh_Instance  instance,
int *  order,
int *  err
Get the default storage order used by this implementation. Value returned is a member of the iBase_StorageOrder enumeration.
Parameters:
[out]orderPointer to storage order returned from function (
See also:
iBase_StorageOrder)
Parameters:
Definition at line 404 of file iMesh_MOAB.cpp.
References iBase_BLOCKED, iBase_SUCCESS, and RETURN.
void iMesh_getGeometricDimension ( iMesh_Instance  instance,
int *  geom_dim,
int *  err
Parameters:
[out]geom_dimPointer to dimension returned from this function
Definition at line 388 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, MOABI, and RETURN.
    MOABI->get_dimension(*geom_dim);
    RETURN(iBase_SUCCESS);
void iMesh_getRootSet ( iMesh_Instance  instance,
iBase_EntitySetHandle root_set,
int *  err
Get handle of the root set for this instance. All mesh entities in this instance can be accessed from this set.
Parameters:
[out]root_setPointer to set handle returned from function
Definition at line 380 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, and RETURN.
    *root_set = 0;
      //return CAST_TO_VOID(MOABI->get_root_set());
void iMesh_load ( iMesh_Instance  instance,
const char *  name,
const char *  options,
int *  err,
int  name_len,
int  options_len
Load a mesh from a file. If entity set is specified, loaded mesh is added to that set; specify root set if that is not desired.
Parameters:
[in]entity_set_handleSet to which loaded mesh will be added, otherwise root
[in]nameFile name from which mesh is to be loaded
[in]optionsPointer to implementation-specific options string (Option Strings)
[in]name_lenLength of the file name character string (String Length Arguments)
[in]options_lenLength of the options character string (String Length Arguments)
Definition at line 321 of file iMesh_MOAB.cpp.
References CHKERR, create_int_ents(), eatwhitespace(), filename, filter_options(), iBase_SUCCESS, MBENTITYSET, MBIMESHI, MOABI, RETURN, and moab::subtract().
      // get filename, option & null-terminate
    std::string filename(name, name_len);
    eatwhitespace(filename);
    std::string opts = filter_options(options, options+options_len);
    Range orig_ents;
    ErrorCode result = MOABI->get_entities_by_handle( 0, orig_ents );
    CHKERR(result,"Internal error");
    const EntityHandle* file_set = 0;
    if (handle != 0 /*root_set*/) {
      const iBase_EntitySetHandle* ptr = &handle;
      file_set = reinterpret_cast<const EntityHandle*>(ptr);
    result = MOABI->load_file(filename.c_str(), file_set, opts.c_str());
    CHKERR(result, "iMesh_load:ERROR loading a mesh.");
      // create interior edges/faces if requested
    if (MBIMESHI->AdjTable[5] || MBIMESHI->AdjTable[10]) {
      Range set_ents;
      result = MOABI->get_entities_by_handle(0, set_ents);
      CHKERR(result,"");
      Range sets;
      result = MOABI->get_entities_by_type(0, MBENTITYSET, sets);
      CHKERR(result,"");
      set_ents = subtract( set_ents, sets );
      set_ents = subtract( set_ents, orig_ents );
      result = create_int_ents(MBIMESHI, set_ents, file_set);
      CHKERR(result,"");
void iMesh_newMesh ( const char *  options,
int *  err,
int  options_len
Parameters:
[in]options_lenLength of the character string pointed to by options (String Length Arguments)
Definition at line 272 of file iMesh_MOAB.cpp.
References filter_options(), iBase_FAILURE, iBase_SUCCESS, MB_NOT_IMPLEMENTED, MB_SUCCESS, and MBiMesh::set_last_error().
    std::string tmp_options = filter_options(options, options+options_len);
    FileOptions opts(tmp_options.c_str());
    MBiMesh **mbi = reinterpret_cast<MBiMesh**>(instance);
    *mbi = NULL;
    ErrorCode result = opts.get_null_option("PARALLEL");
    if (MB_SUCCESS == result) {
#ifdef MOAB_HAVE_MPI
      int flag = 1;
      int retval = MPI_Initialized(&flag);
      if (MPI_SUCCESS != retval || !flag) {
        int argc = 0;
        char **argv = NULL;
          // mpi not initialized yet - initialize here
        retval = MPI_Init(&argc, &argv);
        assert(MPI_SUCCESS == retval);
      *mbi = new (std::nothrow) MBiMesh(NULL);
#else
        //mError->set_last_error( "PARALLEL option not valid, this instance"
        //                        " compiled for serial execution.\n" );
      *err = (*mbi)->set_last_error(MB_NOT_IMPLEMENTED,
                                    "Not configured with parallel support");
      return;
#endif
    else {
    if (NULL == *mbi) {
      *err = iBase_FAILURE;
      return;
void iMesh_save ( iMesh_Instance  instance,
const char *  name,
int *  err,
const int  name_len,
int  options_len
Save a mesh to a file. If entity set is specified, save only the mesh contained in that set.
Parameters:
[in]entity_set_handleEntity set being saved
[in]nameFile name to which mesh is to be saved
Definition at line 362 of file iMesh_MOAB.cpp.
References CHKERR, eatwhitespace(), ENTITY_HANDLE, filename, filter_options(), iBase_SUCCESS, MOABI, and RETURN.
      // get filename & attempt to NULL-terminate
    std::string filename( name, name_len );
    EntityHandle set = ENTITY_HANDLE(handle);
    ErrorCode result = MOABI->write_file(filename.c_str(), NULL, opts.c_str(),
                                       &set, 1);
    CHKERR(result, "iMesh_save:ERROR saving a mesh.");
void iMesh_setGeometricDimension ( iMesh_Instance  instance,
int  geom_dim,
int *  err
Set the geometric dimension of the mesh. Note: An application should not expect this function to succeed unless the mesh instance is empty. An empty mesh instance is any mesh instance in which there are no vertex entities.
Parameters:
[in]geom_dimRequested geometric dimension.
Definition at line 395 of file iMesh_MOAB.cpp.
References CHKERR, iBase_SUCCESS, MOABI, and RETURN.
    ErrorCode rval = MOABI->set_dimension(geom_dim);
    CHKERR(rval,"iMesh_setGeometricDimension: failed");
