MOAB: Mesh Oriented datABase
(version 5.1.1)
Functions | |
void | iMesh_setEntSetData (iMesh_Instance instance, iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, const void *tag_value, const int tag_value_size, int *err) |
Set a tag value of arbitrary type on an entity set. | |
void | iMesh_setEntSetIntData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const int tag_value, int *err) |
void | iMesh_setEntSetDblData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const double tag_value, int *err) |
void | iMesh_setEntSetEHData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const iBase_EntityHandle tag_value, int *err) |
void | iMesh_setEntSetESHData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const iBase_EntitySetHandle tag_value, int *err) |
Set a tag value of entity set handle type on an. | |
void | iMesh_getEntSetData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, void *tag_value, int *tag_value_allocated, int *tag_value_size, int *err) |
Get the value of a tag of arbitrary type on an entity set. | |
void | iMesh_getEntSetIntData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, int *out_data, int *err) |
void | iMesh_getEntSetDblData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, double *out_data, int *err) |
void | iMesh_getEntSetEHData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, iBase_EntityHandle *out_data, int *err) |
void | iMesh_getEntSetESHData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, iBase_EntitySetHandle *out_data, int *err) |
Get the value of a tag of entity set handle type on an. |
void iMesh_getEntSetData | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set_handle, | ||
const iBase_TagHandle | tag_handle, | ||
void * | tag_value, | ||
int * | tag_value_allocated, | ||
int * | tag_value_size, | ||
int * | err | ||
Get the value of a tag of arbitrary type on an entity set. Tag data is returned back as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However because this function supports data of arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
[in] | instance | iMesh instance handle |
[in] | entity_set_handle | Entity set on which tag is being set |
[in] | tag_handle | Tag being set on an entity set |
[in,out] | tag_value | Pointer to tag data array being queried Array pointer, allocated and occupied sizes argument trio) |
[in,out] | tag_value_allocated | Pointer allocated size, in bytes, of tag_value array. |
[out] | tag_value_size | Pointer to occupied size, in bytes, of tag_value array. |
[out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 1725 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_TAG_ARRAY, CHKERR, ENTITY_HANDLE, iBase_SUCCESS, KEEP_ARRAY, MOABI, RETURN, and TAG_HANDLE.
{ EntityHandle eh = ENTITY_HANDLE(entity_set_handle); Tag tag = TAG_HANDLE(tag_handle); int tag_size; ErrorCode result = MOABI->tag_get_bytes(tag, tag_size); CHKERR(result, "iMesh_getEntSetData: couldn't get tag size."); ALLOC_CHECK_TAG_ARRAY(tag_value, tag_size); result = MOABI->tag_get_data(tag, &eh, 1, *static_cast<void**>(tag_value)); CHKERR(result, "iMesh_getEntSetData didn't succeed."); KEEP_ARRAY(tag_value); RETURN(iBase_SUCCESS); }
void iMesh_getEntSetDblData | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | entity_set, | ||
double * | out_data, | ||
int * | err | ||
Get the value of a tag of double type on an entity set.
[in] | entity_set | Entity set on which tag is being set |
[out] | out_data | Pointer to tag value returned from function |
Definition at line 1761 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_getEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_DOUBLE); void *tag_ptr = out_data; int tag_size = sizeof(double); iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr, &tag_size, &tag_size, err); }
void iMesh_getEntSetEHData | ( | iMesh_Instance | instance, |
iBase_EntityHandle * | out_data, | ||
int * | err | ||
Get the value of a tag of entity handle type on an entity set.
Definition at line 1773 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_HANDLE, and iMesh_getEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_ENTITY_HANDLE); void *tag_ptr = out_data; int tag_size = sizeof(EntityHandle); iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr, &tag_size, &tag_size, err); }
void iMesh_getEntSetESHData | ( | iMesh_Instance | instance, |
iBase_EntitySetHandle * | out_data, | ||
int * | err | ||
entity set Get the value of a tag of entity set handle type on an entity set.
Definition at line 1785 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_SET_HANDLE, and iMesh_getEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_ENTITY_SET_HANDLE); void *tag_ptr = out_data; int tag_size = sizeof(EntityHandle); iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr, &tag_size, &tag_size, err); }
void iMesh_getEntSetIntData | ( | iMesh_Instance | instance, |
int * | out_data, | ||
int * | err | ||
Get the value of a tag of integer type on an entity set.
Definition at line 1749 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_getEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_INTEGER); void *tag_ptr = out_data; int dum_size = sizeof(int); iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr, &dum_size, &dum_size, err); }
void iMesh_setEntSetData | ( | iMesh_Instance | instance, |
const void * | tag_value, | ||
const int | tag_value_size, | ||
int * | err | ||
Set a tag value of arbitrary type on an entity set. The tag data is passed as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications are free to use this function to set data of any type, not just iBase_BYTES. However, in all cases, the size specified by tag_value_size is always in terms of bytes.
[in] | tag_value | Pointer to tag data being set on entity set |
[in] | tag_value_size | Size in bytes of tag data |
Definition at line 1664 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, iBase_SUCCESS, MOABI, RETURN, and TAG_HANDLE.
{ ErrorCode result; EntityHandle set = ENTITY_HANDLE(entity_set_handle); result = MOABI->tag_set_data(TAG_HANDLE(tag_handle), &set, 1, tag_value); CHKERR(result, "iMesh_setEntSetData: error"); RETURN(iBase_SUCCESS); }
void iMesh_setEntSetDblData | ( | iMesh_Instance | instance, |
const double | tag_value, | ||
int * | err | ||
Set a tag value of double type on an entity set.
[in] | tag_value | Tag value being set on entity set |
Definition at line 1690 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_setEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_DOUBLE); iMesh_setEntSetData(instance, entity_set, tag_handle, &tag_value, sizeof(double), err); }
void iMesh_setEntSetEHData | ( | iMesh_Instance | instance, |
const iBase_EntityHandle | tag_value, | ||
int * | err | ||
Set a tag value of entity handle type on an entity set.
Definition at line 1701 of file iMesh_MOAB.cpp.
References CHKNONEMPTY, CHKTAGTYPE, iBase_ENTITY_HANDLE, and iMesh_setEntSetData.
{ // XXX: decide how best to handle validating entity handles as tag data CHKNONEMPTY(); CHKTAGTYPE(tag_handle, iBase_ENTITY_HANDLE); iMesh_setEntSetData(instance, entity_set, tag_handle, &tag_value, sizeof(iBase_EntityHandle), err); }
void iMesh_setEntSetESHData | ( | iMesh_Instance | instance, |
const iBase_EntitySetHandle | tag_value, | ||
int * | err | ||
entity set Set a tag value of entity set handle type on an entity set.
Definition at line 1714 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_SET_HANDLE, and iMesh_setEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_ENTITY_SET_HANDLE); iMesh_setEntSetData(instance, entity_set, tag_handle, &tag_value, sizeof(iBase_EntitySetHandle), err); }
void iMesh_setEntSetIntData | ( | iMesh_Instance | instance, |
const int | tag_value, | ||
int * | err | ||
Set a tag value of integer type on an entity set.
Definition at line 1679 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_setEntSetData.
{ CHKTAGTYPE(tag_handle, iBase_INTEGER); iMesh_setEntSetData(instance, entity_set, tag_handle, &tag_value, sizeof(int), err); }
