MOAB: Mesh Oriented datABase
(version 5.1.1)
Functions | |
void | iMesh_getVtxArrCoords (iMesh_Instance instance, const iBase_EntityHandle *vertex_handles, const int vertex_handles_size, const int storage_order, double **coords, int *coords_allocated, int *coords_size, int *err) |
Get coordinates of specified vertices. | |
void | iMesh_setVtxArrCoords (iMesh_Instance instance, const iBase_EntityHandle *vertex_handles, const int vertex_handles_size, const int storage_order, const double *new_coords, const int new_coords_size, int *err) |
Set coordinates for an array of vertices. | |
void | iMesh_createVtxArr (iMesh_Instance instance, const int num_verts, const int storage_order, const double *new_coords, const int new_coords_size, iBase_EntityHandle **new_vertex_handles, int *new_vertex_handles_allocated, int *new_vertex_handles_size, int *err) |
Create an array of new vertices at specified coordinates. | |
void | iMesh_setVtxCoord (iMesh_Instance instance, iBase_EntityHandle vertex_handle, const double x, const double y, const double z, int *err) |
void | iMesh_createVtx (iMesh_Instance instance, const double x, const double y, const double z, iBase_EntityHandle *new_vertex_handle, int *err) |
void | iMesh_getVtxCoord (iMesh_Instance instance, const iBase_EntityHandle vertex_handle, double *x, double *y, double *z, int *err) |
void iMesh_createVtx | ( | iMesh_Instance | instance, |
const double | x, | ||
const double | y, | ||
const double | z, | ||
iBase_EntityHandle * | new_vertex_handle, | ||
int * | err | ||
Create a new vertex at specified coordinates.
[in] | instance | iMesh instance handle |
[in] | x | x coordinate of new vertex |
[in] | y | y coordinate of new vertex |
[in] | z | z coordinate of new vertex |
[out] | new_vertex_handle | Pointer to new vertex handles returned from |
[out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 1847 of file iMesh_MOAB.cpp.
References moab::dum, iBase_BLOCKED, iMesh_createVtxArr, and MOABI.
{ int dum = 1; const double xyz[3] = {x, y, z}; int geom_dim; MOABI->get_dimension(geom_dim); iMesh_createVtxArr(instance, 1, iBase_BLOCKED, xyz, geom_dim, &new_vertex_handle, &dum, &dum, err); }
void iMesh_createVtxArr | ( | iMesh_Instance | instance, |
const int | num_verts, | ||
const int | storage_order, | ||
const double * | new_coords, | ||
const int | new_coords_size, | ||
iBase_EntityHandle ** | new_vertex_handles, | ||
int * | new_vertex_handles_allocated, | ||
int * | new_vertex_handles_size, | ||
int * | err | ||
Create an array of new vertices at specified coordinates. Value of storage_order must be either iBase_INTERLEAVED or iBase_BLOCKED.
[in] | num_verts | Number of new vertices to be created |
[in] | storage_order | Storage order of coordinates in new_coords array (see iBase_StorageOrder) |
[in] | new_coords | Array of coordinates of new vertices. Should be G*num_verts in length where G is geometric dimension of the mesh. |
[in] | new_coords_size | Number of coordinates in new_coords array, should |
[in,out] | new_vertex_handles | Pointer to array of new vertex handles Array pointer, allocated and occupied sizes argument trio) |
[in,out] | new_vertex_handles_allocated | Pointer to allocated size of |
[out] | new_vertex_handles_size | Pointer to occupied size of |
Definition at line 1364 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, CHKERR, ERROR, HANDLE_ARRAY_PTR, iBase_INTERLEAVED, iBase_INVALID_ARGUMENT, iBase_SUCCESS, KEEP_ARRAY, MOABI, and RETURN.
{ int geom_dim; MOABI->get_dimension(geom_dim); if (new_coords_size != geom_dim*num_verts) { ERROR(iBase_INVALID_ARGUMENT, "iMesh_createVtxArr: Didn't get the right # coordinates."); } // if there aren't any elements in the array, allocate it ALLOC_CHECK_ARRAY(new_vertex_handles, num_verts); // make the entities EntityHandle *new_verts = HANDLE_ARRAY_PTR(*new_vertex_handles); if (storage_order == iBase_INTERLEAVED) { if (3 == geom_dim) { for (int i = 0; i < num_verts; i++) { ErrorCode result = MOABI->create_vertex(&new_coords[3*i], new_verts[i]); CHKERR(result, "iMesh_createVtxArr: couldn't create vertex."); } } else { double tmp[3] = {0, 0, 0}; for (int i = 0; i < num_verts; i++) { for (int j = 0; j < geom_dim; j++) tmp[j] = new_coords[geom_dim*i + j]; ErrorCode result = MOABI->create_vertex(tmp, new_verts[i]); CHKERR(result, "iMesh_createVtxArr: couldn't create vertex."); } } } else { double tmp[3] = {0, 0, 0}; for (int i = 0; i < num_verts; i++) { for (int j = 0; j < geom_dim; j++) tmp[j] = new_coords[j*num_verts + i]; ErrorCode result = MOABI->create_vertex(tmp, new_verts[i]); CHKERR(result, "iMesh_createVtxArr: couldn't create vertex."); } } KEEP_ARRAY(new_vertex_handles); RETURN(iBase_SUCCESS); }
void iMesh_getVtxArrCoords | ( | iMesh_Instance | instance, |
const iBase_EntityHandle * | vertex_handles, | ||
const int | vertex_handles_size, | ||
double ** | coords, | ||
int * | coords_allocated, | ||
int * | coords_size, | ||
int * | err | ||
Get coordinates of specified vertices. Coordinates are returned in the storage order indicated by the storage_order argument.
[in] | vertex_handles | Array of mesh vertex handles whose coordinates are being requested |
[in] | vertex_handles_size | Number of vertices in vertex_handles array |
[in] | storage_order | Requested storage order of returned coordinates (see iBase_StorageOrder) |
[in,out] | coords | Pointer to array of coordinates returned from function Array pointer, allocated and occupied sizes argument trio) |
[in,out] | coords_allocated | Pointer to allocated size of coords array |
[out] | coords_size | Pointer to occupied size of coords array |
Definition at line 484 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, CHKERR, CONST_HANDLE_ARRAY_PTR, iBase_INTERLEAVED, iBase_SUCCESS, KEEP_ARRAY, MOABI, and RETURN.
{ int geom_dim; MOABI->get_dimension(geom_dim); // make sure we can hold them all ALLOC_CHECK_ARRAY(coords, geom_dim*vertex_handles_size); // now get all the coordinates // coords will come back interleaved by default ErrorCode result; if (storage_order == iBase_INTERLEAVED) { if (3 == geom_dim) { result = MOABI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles), vertex_handles_size, *coords); } else { std::vector<double> dum_coords(3*vertex_handles_size); result = MOABI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles), vertex_handles_size, &dum_coords[0]); for (int i = 0; i < vertex_handles_size; i++) { for (int j = 0; j < geom_dim; j++) (*coords)[geom_dim*i + j] = dum_coords[3*i + j]; } } } else { std::vector<double> dum_coords(3*vertex_handles_size); result = MOABI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles), vertex_handles_size, &dum_coords[0]); CHKERR(result,"iMesh_getVtxArrCoords: problem getting vertex coords"); for (int i = 0; i < vertex_handles_size; i++) { for (int j = 0; j < geom_dim; j++) (*coords)[i + vertex_handles_size*j] = dum_coords[3*i + j]; } } KEEP_ARRAY(coords); RETURN(iBase_SUCCESS); }
void iMesh_getVtxCoord | ( | iMesh_Instance | instance, |
const iBase_EntityHandle | vertex_handle, | ||
double * | x, | ||
double * | y, | ||
double * | z, | ||
int * | err | ||
Get coordinates of specified vertex.
[in] | vertex_handle | Mesh vertex being queried |
[out] | x | Pointer to x coordinate returned from function |
[out] | y | Pointer to y coordinate returned from function |
[out] | z | Pointer to z coordinate returned from function |
Definition at line 2345 of file iMesh_MOAB.cpp.
References moab::dum, iBase_BLOCKED, iBase_SUCCESS, and iMesh_getVtxArrCoords.
{ int order = iBase_BLOCKED; double xyz[3] = {0}, *tmp_xyz = xyz; int dum = 3; iMesh_getVtxArrCoords(instance, &vertex_handle, 1, order, &tmp_xyz, &dum, &dum, err); if (iBase_SUCCESS == *err) { *x = xyz[0]; *y = xyz[1]; *z = xyz[2]; } }
void iMesh_setVtxArrCoords | ( | iMesh_Instance | instance, |
int * | err | ||
Set coordinates for an array of vertices. Specified storage order must be either iBase_INTERLEAVED or iBase_BLOCKED, and indicates order of x, y, and z coordinates in coordinate array.
[in] | vertex_handles | Array of vertex handles |
[in] | vertex_handles_size | Number of vertex handles in array |
[in] | storage_order | Storage order of coordinates in coordinate array |
[in] | new_coords | Coordinate array |
[in] | new_coords_size | Size of coordinate array; should be |
Definition at line 1316 of file iMesh_MOAB.cpp.
References CHKENUM, CHKERR, CONST_HANDLE_ARRAY_PTR, ERROR, iBase_INTERLEAVED, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MB_SUCCESS, MOABI, and RETURN.
{ CHKENUM(storage_order, iBase_StorageOrder, iBase_INVALID_ARGUMENT); int geom_dim; MOABI->get_dimension(geom_dim); if (new_coords_size != geom_dim*vertex_handles_size) { ERROR(iBase_INVALID_ARGUMENT, "iMesh_setVtxArrCoords: Didn't get the right # coordinates."); } ErrorCode result = MB_SUCCESS, tmp_result; if (storage_order == iBase_INTERLEAVED) { if (3 == geom_dim) { result = MOABI->set_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles), vertex_handles_size, new_coords); } else { const EntityHandle *verts = CONST_HANDLE_ARRAY_PTR(vertex_handles); double dummy[3] = {0, 0, 0}; for (int i = 0; i < vertex_handles_size; i++) { for (int j = 0; j < geom_dim; j++) dummy[j] = new_coords[geom_dim*i + j]; tmp_result = MOABI->set_coords(&verts[i], 1, dummy); if (MB_SUCCESS != tmp_result) result = tmp_result; } } } else { const EntityHandle *verts = CONST_HANDLE_ARRAY_PTR(vertex_handles); double dummy[3] = {0, 0, 0}; for (int i = 0; i < vertex_handles_size; i++) { for (int j = 0; j < geom_dim; j++) dummy[j] = new_coords[i + vertex_handles_size*j]; tmp_result = MOABI->set_coords(&verts[i], 1, dummy); if (MB_SUCCESS != tmp_result) result = tmp_result; } } CHKERR(result, "iMesh_setVtxArrCoords: problem setting coordinates."); RETURN(iBase_SUCCESS); }
void iMesh_setVtxCoord | ( | iMesh_Instance | instance, |
int * | err | ||
Set coordinates for a vertex.
[in] | vertex_handle | vertex handle being set |
[in] | x | x coordinate being set |
[in] | y | y coordinate being set |
[in] | z | z coordinate being set |
Definition at line 1833 of file iMesh_MOAB.cpp.
References iBase_BLOCKED, iMesh_setVtxArrCoords, and MOABI.
{ const double xyz[3] = {x, y, z}; int geom_dim; MOABI->get_dimension(geom_dim); iMesh_setVtxArrCoords(instance, &vertex_handle, 1, iBase_BLOCKED, xyz, geom_dim, err); }
