MOAB: Mesh Oriented datABase  (version 5.1.1)
h5file_test.cpp File Reference
#include <stdio.h>
#include <math.h>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include <iostream>
#include <sstream>
+ Include dependency graph for h5file_test.cpp:
Defines
#define filename   "h5test.h5m"
#define tagname   "foo/\\/\\"
#define bitname   "bar\n"
#define intname   "int tag"
#define dblname   " dbl "
#define handlename   "hanlde"
Functions
void create ()
bool compare ()
void moab_error (const char *function)
int main (int argc, char *argv[])
EntityHandle vtx (double x, double y, double z)
EntityHandle pent (EntityHandle *vtx_list, int i1, int i2, int i3, int i4, int i5)
EntityHandle make_set (unsigned int options, EntityHandle *entities, size_t num_entities, bool reverse, int id)
bool compare_conn (std::vector< EntityHandle > &conn1, std::vector< EntityHandle > &conn2)
bool compare_sets (int id, const char *tag_name=0)
bool compare_tags (EntityHandle dod[])
Variables
const int FACE_SET_ID = 1101
const int VERTEX_SET_ID = 1102
const int REGION_SET_ID = 1103
const int EMPTY_SET_ID = 1100
const int SET_SET_ID = 1105
Interfaceiface
Define Documentation
Definition at line 34 of file h5file_test.cpp.
Referenced by compare(), and create().
Definition at line 36 of file h5file_test.cpp.
Referenced by compare_tags(), and create().
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Examples:
DeformMeshRemap.cpp, LoadPartial.cpp, and ReduceExchangeTags.cpp.
Definition at line 24 of file h5file_test.cpp.
Referenced by base_name(), ExodusTest::check_mesh(), do_file(), do_ray_fire_test(), exp_1_init(), get_cut_cube_example(), get_hex_3d_part_example(), get_homogenious_example(), get_part_example_quad(), get_part_example_tri(), get_sphere_cube_example(), get_sphere_cylinder_example(), iMesh_load(), iMesh_save(), moab::ReadCGNS::load_file(), moab::ReadTemplate::load_file(), moab::ReadTetGen::load_file(), main(), mesh_size_test(), moab::ReadTetGen::open_file(), parse_options(), read_write(), read_write_file(), reference(), save_entset_test(), TargetReadWriteTest::setUp(), DomainClassifierTest::setUp(), signal_handler(), split_test_across(), test_correct_ghost(), BoundedCylinderDomainTest::test_create_curve_from_mesh(), test_eul_check_across_files(), test_eul_check_append(), test_eul_check_T(), test_eul_check_timestep(), test_fv_check_T(), test_gcrm_check_vars(), test_homme_check_T(), test_mpas_check_vars(), test_native_read(), ExodusTest::test_read(), test_read_and_ghost_after(), test_read_with_ghost(), test_read_with_ghost_no_augment(), test_read_with_thin_ghost_layer(), test_sets_fileids(), test_tags_retrieval(), test_var_length_parallel(), ExodusTest::test_write(), test_write_invalid_elem(), test_write_read_many_tags(), verdict_test1(), MBMesquite::MeshWriter::write_eps_triangle(), MBMesquite::TerminationCriterion::write_iterations(), and MBMesquite::TerminationCriterion::write_mesh_steps().
Definition at line 37 of file h5file_test.cpp.
Definition at line 35 of file h5file_test.cpp.
Function Documentation
bool compare ( )
Definition at line 753 of file h5file_test.cpp.
References moab::Range::begin(), bitname, moab::Range::clear(), compare_conn(), compare_sets(), compare_tags(), conn, EMPTY_SET_ID, FACE_SET_ID, moab::Interface::get_connectivity(), GLOBAL_ID_TAG_NAME, iface, MB_SUCCESS, MB_TYPE_BIT, MBHEX, MBPOLYHEDRON, moab_error(), REGION_SET_ID, SET_SET_ID, size, moab::Range::size(), moab::Interface::tag_get_handle(), tagname, and VERTEX_SET_ID.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::choose_best_split(), moab::find_map_values(), moab::find_tag_values(), main(), and moab::ReadRTT::split_string().
  Range range;
  EntityHandle hex[2];
  EntityHandle dod[2];
  Tag elemtag;
  Range::iterator iter;
  // get tag
  if (MB_SUCCESS != iface->tag_get_handle( bitname, 2, MB_TYPE_BIT, elemtag ))
    moab_error( "tag_get_handle" );
  // get two hexes
  char two = '\002';
  const void* tarray[] = { &two };
      get_entities_by_type_and_tag( 0, MBHEX, &elemtag, tarray, 1, range ))
    moab_error( "get_entities_by_type_and_tag" );
  if (range.size() != 2)
    fprintf( stderr, "Expected 2 Hexes.  Got %lu\n", (unsigned long)range.size() );
    exit( 1 );
  iter = range.begin();
  hex[0] = *iter;
  hex[1] = *++iter;
  // get two polyhedra
  range.clear();
  char one = '\001';
  const void* oarray[] = { &one };
      get_entities_by_type_and_tag( 0, MBPOLYHEDRON, &elemtag, oarray, 1, range ))
    fprintf( stderr, "Expected 2 Polyhedra.  Got %lu\n", (unsigned long)range.size() );
    exit( 1 );
  dod[0] = *iter;
  dod[1] = *++iter;
  // compare hexes
  std::vector<EntityHandle> conn[2];
  if (MB_SUCCESS != iface->get_connectivity( hex  , 1, conn[0] ) ||
      MB_SUCCESS != iface->get_connectivity( hex+1, 1, conn[1] ))
    moab_error( "get_connectivity" );
  if (!compare_conn( conn[0], conn[1] ))
    return false;
  // compare polyhedra
  std::vector<EntityHandle> face[2];
  conn[0].clear(); conn[1].clear();
  if (MB_SUCCESS != iface->get_connectivity( dod  , 1, conn[0], false ) ||
      MB_SUCCESS != iface->get_connectivity( dod+1, 1, conn[1], false ))
  if (conn[0].size() != 12 || conn[1].size() != 12)
    fprintf(stderr, "Expected two dodecahedrons.  Got polyhedrons with "
                    "%lu and %lu faces respectively.\n",
                    (unsigned long)conn[0].size(), (unsigned long)conn[1].size() );
    return false;
  for (int i = 0; i < 12; ++i )
    face[0].clear(); face[1].clear();
    if (MB_SUCCESS != iface->get_connectivity( &conn[0][i], 1, face[0], false) ||
        MB_SUCCESS != iface->get_connectivity( &conn[1][i], 1, face[1], false))
    if (!compare_conn( face[0], face[1] ))
      return false;
  // compare sets
  if (!compare_sets( VERTEX_SET_ID, tagname ) ||
      !compare_sets( FACE_SET_ID ) ||
      !compare_sets( REGION_SET_ID ) ||
      !compare_sets( EMPTY_SET_ID ) ||
      !compare_sets( SET_SET_ID, GLOBAL_ID_TAG_NAME ))
    return false;
  // check tags
  if (!compare_tags( dod ))
    return false;
  return true;
bool compare_conn ( std::vector< EntityHandle > &  conn1,
std::vector< EntityHandle > &  conn2
Definition at line 399 of file h5file_test.cpp.
References moab::Interface::get_coords(), iface, MB_SUCCESS, MB_TYPE_INTEGER, moab_error(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and tagname.
Referenced by compare().
  unsigned i;
  if (conn1.size() != conn2.size() || conn1.size() == 0)
    fprintf(stderr, "Error comparing connectivity: sizes %lu and %lu\n",
                     (unsigned long)conn1.size(), (unsigned long)conn2.size());
    return false;
  std::vector<double> coords[2];
  coords[0].resize( 3*conn1.size() ); coords[1].resize( 3*conn2.size() );
  if (MB_SUCCESS != iface->get_coords( &conn1[0], conn1.size(), &coords[0][0] ) ||
      MB_SUCCESS != iface->get_coords( &conn2[0], conn2.size(), &coords[1][0] ) ||
      coords[0].size() != coords[1].size())
    moab_error( "get_coords" );
  std::vector<double>::iterator citer1 = coords[0].begin(), citer2 = coords[1].begin();
  for (i = 0; i < conn1.size(); i++)
    double x1 = *(citer1++), y1 = *(citer1++), z1 = *(citer1++);
    double x2 = *(citer2++), y2 = *(citer2++), z2 = *(citer2++);
    if (x1 != x2 || y1 != y2 || z1 != z2)
      fprintf( stderr, "Vertex coords don't match: ( %f, %f, %f ) and ( %f, %f, %f )\n",
        x1, y1, z1, x2, y2, z2 );
      return false;
  std::vector<int> tags[2];
  tags[0].resize( conn1.size() ); tags[1].resize( conn2.size() );
  Tag tag;
  if (MB_SUCCESS != iface->tag_get_handle( tagname, 1, MB_TYPE_INTEGER, tag ))
  if (MB_SUCCESS != iface->tag_get_data( tag, &conn1[0], conn1.size(), &tags[0][0] ) ||
      MB_SUCCESS != iface->tag_get_data( tag, &conn2[0], conn2.size(), &tags[1][0] ))
    moab_error( "tag_get_data" );
  std::vector<int>::iterator titer1 = tags[0].begin(), titer2 = tags[1].begin();
    int t1 = *(titer1++);
    int t2 = *(titer2++);
    if (t1 != t2)
      fprintf( stderr, "Vertex tags don't match: %d != %d\n", t1, t2 );
      return false;
  return true;
bool compare_sets ( int  id,
const char *  tag_name = 0
Definition at line 460 of file h5file_test.cpp.
References moab::Range::begin(), moab::CN::EntityTypeName(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), moab::Interface::globalId_tag(), id_tag, iface, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, MBMAXTYPE, MESHSET_ORDERED, MESHSET_SET, MESHSET_TRACK_OWNER, moab_error(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), and moab::Interface::type_from_handle().
  bool ok;
  ErrorCode rval;
  // get sets
  Tag id_tag = iface->globalId_tag();
  Range range;
  const void* tag_data[] = { &id };
  rval = iface->get_entities_by_type_and_tag( 0, MBENTITYSET, &id_tag, tag_data, 1, range );
  if (MB_ENTITY_NOT_FOUND == rval || range.size() != 2)
    fprintf(stderr, "Could not find set with id %d pair in file\n", id );
    return false;
  else if (MB_SUCCESS != rval)
  EntityHandle set1 = *range.begin();
  EntityHandle set2 = *++range.begin();
  // Compare set descriptions
  unsigned opt1=0, opt2=0;
  rval = iface->get_meshset_options( set1, opt1 );
  if (MB_SUCCESS != rval) moab_error( "get_meshset_options for set1 failed" );
  rval = iface->get_meshset_options( set2, opt2 );
  if (MB_SUCCESS != rval) moab_error( "get_meshset_options for set2 failed" );
  if (opt1 != opt2)
    fprintf(stderr, "Sets with id %d do not have matching options.\n"
                    "Set 1: track_owner=%s set=%s ordered=%s\n"
                    "Set 2: track_owner=%s set=%s ordered=%s\n",
                    id,
                    opt1 & MESHSET_TRACK_OWNER ? "yes" : "no",
                    opt1 & MESHSET_SET         ? "yes" : "no",
                    opt1 & MESHSET_ORDERED     ? "yes" : "no",
                    opt2 & MESHSET_TRACK_OWNER ? "yes" : "no",
                    opt2 & MESHSET_SET         ? "yes" : "no",
                    opt2 & MESHSET_ORDERED     ? "yes" : "no" );
    return false;
  // Compare set contents
  // First check if same number of entities.
  // Then select from three possible methods to compare set contents
  //  o If caller gave us a tag to use, compare entities by tag value
  //  o If set is ordered, compare entity types in order
  //  o Otherwise compare counts of entity types in sets
  std::vector<EntityHandle> list1, list2;
  rval = iface->get_entities_by_handle( set1, list1 );
  if (MB_SUCCESS != rval) moab_error( "get_entities_by_handle for set1 failed" );
  rval = iface->get_entities_by_handle( set2, list2 );
  if (MB_SUCCESS != rval) moab_error( "get_entities_by_handle for set2 failed" );
  if (list1.size() != list2.size())
    fprintf(stderr, "Sets with id %d do not have the same number of entities.\n"
                    "Set 1 : %u  Set 2 : %u\n",
                    id, (unsigned)list1.size(), (unsigned)list2.size() );
    return false;
  if (tag_name) // compare contents using tag value
    Tag tag;
    if (MB_SUCCESS != iface->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tag, MB_TAG_ANY ))
      fprintf(stderr, "Could not find tag \"%s\" in file.\n", tag_name);
      return false;
      // Make sure tag is integer type
    DataType type;
    if (MB_SUCCESS != iface->tag_get_data_type( tag, type ))
      moab_error( "tag_get_data_type" );
    if (MB_TYPE_INTEGER != type && MB_TYPE_OPAQUE != type)
      moab_error( "compare_sets" );
    std::vector<int> data1( list1.size() ), data2( list2.size() );
    if (MB_SUCCESS != iface->tag_get_data( tag, &list1[0], list1.size(), &data1[0] )
     || MB_SUCCESS != iface->tag_get_data( tag, &list2[0], list2.size(), &data2[0] ))
      moab_error("tag_get_data");
    if (!(opt1 & MESHSET_ORDERED))
      std::sort( data1.begin(), data1.end() );
      std::sort( data2.begin(), data2.end() );
    for (unsigned i = 0; i < data1.size(); ++i)
      if (data1[i] != data2[i])
        fprintf( stderr, "Entities in sets with id %d do not have matching tag values.\n", id );
        return false;
  else if (opt1 & MESHSET_ORDERED) // compare types of each entity in set
    ok = true;
    for (unsigned i = 0; i < list1.size(); ++i)
      if (iface->type_from_handle(list1[i]) != iface->type_from_handle(list2[i]))
        fprintf(stderr, "Entities at position %u in ordered sets with id %d\n"
                        "have different types.\n", i, id );
        ok = false;
    if (!ok)
      return false;
  else // compare count of entity types in each set
    unsigned counts1[MBMAXTYPE], counts2[MBMAXTYPE];
    memset( counts1, 0, MBMAXTYPE * sizeof(unsigned) );
    memset( counts2, 0, MBMAXTYPE * sizeof(unsigned) );
      counts1[iface->type_from_handle(list1[i])]++;
      counts2[iface->type_from_handle(list2[i])]++;
    ok = true;
    for (int j = 0; j < MBMAXTYPE; ++j)
      if (counts1[j] != counts2[j])
        fprintf(stderr, "Sets with id %d have differing numbers of %s: %u and %u\n",
                id, CN::EntityTypeName((EntityType)j), counts1[j], counts2[j] );
        ok = false;
    if (!ok)
      return false;
    // Compare set parent/child links using global id
  ok = true;
  const char* words[] = { "children", "parents" };
  std::vector<EntityHandle> adj1, adj2;
  for (unsigned two = 0; two < 2; ++two)
    adj1.clear(); adj2.clear();
    if (two)
      if (MB_SUCCESS != iface->get_parent_meshsets(set1, adj1) ||
          MB_SUCCESS != iface->get_parent_meshsets(set2, adj2))
        moab_error( "get_parent_meshsets" );
    else
      if (MB_SUCCESS != iface->get_child_meshsets(set1, adj1) ||
          MB_SUCCESS != iface->get_child_meshsets(set2, adj2))
        moab_error( "get_child_meshsets" );
    if (adj1.size() != adj2.size())
      fprintf(stderr, "Sets with id %d have different number of %s: %u and %u\n",
        id, words[two], (unsigned)adj1.size(), (unsigned)adj2.size() );
      ok = false;
      continue;
    std::vector<int> ids1(adj1.size()), ids2(adj2.size());
    unsigned i;
    for (i = 0; i < adj1.size(); ++i)
      rval = iface->tag_get_data( id_tag, &adj1[i], 1, &ids1[i] );
      if (MB_TAG_NOT_FOUND == rval)
        ids1[i] = 0;
      rval = iface->tag_get_data( id_tag, &adj2[i], 1, &ids2[i] );
        ids2[i] = 0;
    std::sort( ids1.begin(), ids1.end() );
    std::sort( ids2.begin(), ids2.end() );
    for (i = 0; i < ids1.size(); ++i)
      if (ids1[i] != ids2[i])
        fprintf(stderr, "Sets with id %d have non-matching %s\n", id, words[two] );
        ok = false;
        break;
  return ok;
bool compare_tags ( EntityHandle  dod[])
Definition at line 656 of file h5file_test.cpp.
References conn, dblname, moab::Interface::get_connectivity(), handlename, iface, intname, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TAG_STORE, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBHEX, MBPOLYHEDRON, moab_error(), moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), and moab::Interface::type_from_handle().
Referenced by compare(), test_global_opaque_common(), test_global_value_common(), test_var_length_big_data(), test_var_length_data_common(), test_var_length_handle_tag(), and test_var_length_no_data().
  Tag tag;
    // Get integer tag handle and characterstics
  if (MB_SUCCESS != iface->tag_get_handle( intname, 2, MB_TYPE_INTEGER, tag, MB_TAG_SPARSE|MB_TAG_STORE ))
    moab_error( "tag_get_handle(intname)" );
    // integer tag should not have a default value
  int idata[4];
  if (MB_ENTITY_NOT_FOUND != iface->tag_get_default_value( tag, idata )) {
    fprintf( stderr, "tag_get_default_value() for nonexistant default integer tag value did not fail correctly.\n");
    return false;
    // check data for integer tag on both dodecahedrons
  if (MB_SUCCESS != iface->tag_get_data( tag, dod, 2, idata ))
    moab_error( "tag_get_data(itag)" );
  if (idata[0] != (int)0xDEADBEEF || idata[1] != (int)0xDEFACED ||
      idata[2] != idata[0]   || idata[3] != idata[1]) {
    fprintf( stderr, "Incorrect values for integer tag data.\n" );
    return false;
    // Get double tag handle and characterstics
  if (MB_SUCCESS != iface->tag_get_handle( dblname, 1, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE|MB_TAG_STORE ))
    moab_error( "tag_get_handle(dblname)" );
    // check default value of double tag
  double ddata[2];
  if (MB_SUCCESS != iface->tag_get_default_value( tag, ddata ))
    moab_error( "tag_get_default_value" );
  if (ddata[0] != 3.14159) {
    fprintf( stderr, "incorrect default value for double tag.\n");
    return false;
    // check data for double tag on both dodecahedrons
  if (MB_SUCCESS != iface->tag_get_data( tag, dod, 2, ddata ))
    moab_error( "tag_get_data()" );
  if (ddata[0] != .333 || ddata[0] != ddata[1]) {
    fprintf( stderr, "Incorrect values for double tag data.\n" );
    return false;
    // Get handle tag handle and characterstics
  if (MB_SUCCESS != iface->tag_get_handle( handlename, 3, MB_TYPE_HANDLE, tag, MB_TAG_SPARSE|MB_TAG_STORE ))
    moab_error( "tag_get_handle(handlename)" );
    // check default value of handle tag
    // default value will not change after tag is created.  As we
    // do multiple iterations of save/restore, we shouldn't expect
    // the dodecahedron handles to point to the most recent two.
  EntityHandle hdata[6];
  if (MB_SUCCESS != iface->tag_get_default_value( tag, hdata ))
  if (iface->type_from_handle(hdata[0]) != MBHEX ||
      hdata[2] != 0 ||
      iface->type_from_handle(hdata[1]) != MBPOLYHEDRON) {
    fprintf( stderr, "incorrect default value for handle tag '%s'\n",handlename);
    return false;
    // check global value for handle tag
    // global value should be changed each time a new global is read,
    // so expect one of the two dodecahedrons in the last slot.
  const EntityHandle root = 0;
  if (MB_SUCCESS != iface->tag_get_data( tag, &root, 1, hdata ))
    moab_error( "tag_get_data(mesh)" );
  if (iface->type_from_handle(hdata[1]) != MBHEX ||
      hdata[0] != 0 ||
      (hdata[2] != dod[0] && hdata[2] != dod[1])) {
    fprintf( stderr, "incorrect global/mesh value for handle tag.\n");
    return false;
    // check data on each dodecahedron
  const EntityHandle *conn;
  int len;
  if (MB_SUCCESS != iface->tag_get_data( tag, dod, 2, hdata ))
  if (MB_SUCCESS != iface->get_connectivity( dod[0], conn, len ))
  if (memcmp(conn, hdata, 3*sizeof(EntityHandle))) {
    fprintf( stderr, "Incorrect values for handle tag data.\n" );
    return false;
  if (MB_SUCCESS != iface->get_connectivity( dod[1], conn, len ))
  if (memcmp(conn, hdata+3, 3*sizeof(EntityHandle))) {
    return false;
  return true;
void create ( )
Definition at line 237 of file h5file_test.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_parent_child(), moab::Interface::add_parent_meshset(), b, bitname, moab::Interface::create_element(), dblname, EMPTY_SET_ID, FACE_SET_ID, MBMesquite::faces, handlename, iface, intname, make_set(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBHEX, MBPOLYHEDRON, MESHSET_ORDERED, MESHSET_SET, MESHSET_TRACK_OWNER, moab_error(), pent(), REGION_SET_ID, SET_SET_ID, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), tagname, VERTEX_SET_ID, vtx(), and z.
Referenced by main(), and moab::WriteNC::write_file().
  // Create dodecahedron
  // radius
  const double r = 50.;
  // center
  const double x = 0., y = 0., z = 0.;
  // length of edge of inscribed cube
  const double cube = r * (2.0 / sqrt( 3.0 ));
  // length of dodecahedron edge
  const double edge = cube * (2.0 / (1.0  + sqrt( 5.0 )));
  // distance of projection of a dodecahedron vertex to
  // closest edge of inscribed cube
  const double p = (cube - edge) / 2.0;
  // closest face of inscribed cube
  const double d = sqrt( edge*edge - cube*cube / 4 - p );
  // coordinate values
  const double c = cube / 2.0;
  const double a = c + d;
  const double b = edge / 2.0;
  // list of vertex handles
  EntityHandle vertices[20];
  // list of pentagon handles
  EntityHandle faces[12];
  // Dodecahedron handle
  EntityHandle dodec;
  // Inscribed Hex handle
  EntityHandle hex;
  // Create vertices if inscribed cube
  vertices[ 0] = vtx( x-c, y+c, z+c );
  vertices[ 1] = vtx( x+c, y+c, z+c );
  vertices[ 2] = vtx( x+c, y-c, z+c );
  vertices[ 3] = vtx( x-c, y-c, z+c );
  vertices[ 4] = vtx( x-c, y+c, z-c );
  vertices[ 5] = vtx( x+c, y+c, z-c );
  vertices[ 6] = vtx( x+c, y-c, z-c );
  vertices[ 7] = vtx( x-c, y-c, z-c );
  // Create inscribed hex
  if (MB_SUCCESS != iface->create_element( MBHEX, vertices, 8, hex ))
    moab_error( "create_element" );
  // Create vertices, 2 "above" each face of inscribed cube
  // +z face
  vertices[ 8] = vtx( x-b, y  , z+a );
  vertices[ 9] = vtx( x+b, y  , z+a );
  // +x face
  vertices[10] = vtx( x+a, y+b, z   );
  vertices[11] = vtx( x+a, y-b, z   );
  // -z face
  vertices[12] = vtx( x-b, y  , z-a );
  vertices[13] = vtx( x+b, y  , z-a );
  // -x face
  vertices[14] = vtx( x-a, y+b, z   );
  vertices[15] = vtx( x-a, y-b, z   );
  // +y face
  vertices[16] = vtx( x  , y+a, z+b );
  vertices[17] = vtx( x  , y+a, z-b );
  // -y face
  vertices[18] = vtx( x  , y-a, z+b );
  vertices[19] = vtx( x  , y-a, z-b );
  // Create petagons
  faces[ 0] = pent( vertices,  0,  8,  9,  1, 16 );
  faces[ 1] = pent( vertices,  3, 18,  2,  9,  8 );
  faces[ 2] = pent( vertices,  2, 11, 10,  1,  9 );
  faces[ 3] = pent( vertices,  2, 18, 19,  6, 11 );
  faces[ 4] = pent( vertices,  1, 10,  5, 17, 16 );
  faces[ 5] = pent( vertices,  5, 10, 11,  6, 13 );
  faces[ 6] = pent( vertices,  4, 17,  5, 13, 12 );
  faces[ 7] = pent( vertices,  7, 12, 13,  6, 19 );
  faces[ 8] = pent( vertices,  4, 12,  7, 15, 14 );
  faces[ 9] = pent( vertices,  0, 16, 17,  4, 14 );
  faces[10] = pent( vertices,  3, 15,  7, 19, 18 );
  faces[11] = pent( vertices,  0, 14, 15,  3,  8 );
  if (MB_SUCCESS != iface->create_element( MBPOLYHEDRON, faces, 12, dodec ))
  // Create a dense tag
  int zero = 0;
  Tag tag;
  if (MB_SUCCESS != iface->tag_get_handle( tagname, 1, MB_TYPE_INTEGER, tag, MB_TAG_DENSE|MB_TAG_EXCL, &zero ))
  // Put dense tag on all vertices.
  for (int i = 0; i < 20; ++i)
    if (MB_SUCCESS != iface->tag_set_data( tag, vertices + i, 1, &i ))
      moab_error( "tag_set_data" );
  // Create bit tag
  Tag tag2;
  if (MB_SUCCESS != iface->tag_get_handle( bitname, 2, MB_TYPE_BIT, tag2, MB_TAG_EXCL ))
  // Set tag to 0 on Hex
  char two = '\002';
  if (MB_SUCCESS != iface->tag_set_data( tag2, &hex, 1, &two ))
  // set tag to 1 on dodecahedron
  char one  = '\001';
  if (MB_SUCCESS != iface->tag_set_data( tag2, &dodec, 1, &one ))
  // Create an integer array tag and set some values on the dodecahedron
  Tag itag;
  if (MB_SUCCESS != iface->tag_get_handle( intname, 2, MB_TYPE_INTEGER, itag, MB_TAG_SPARSE|MB_TAG_EXCL ))
    moab_error( "tag_get_handle(MB_TYPE_INT)" );
  int idata[] = { static_cast<int>(0xDEADBEEF), static_cast<int>(0xDEFACED) };
  if (MB_SUCCESS != iface->tag_set_data( itag, &dodec, 1, idata ))
    moab_error( "tag_set_data(itag)" );
  // Create a double tag with a non-zero default value, and set on dodecahedron
  Tag dtag;
  double ddef = 3.14159;
  if (MB_SUCCESS != iface->tag_get_handle( dblname, 1, MB_TYPE_DOUBLE, dtag, MB_TAG_DENSE|MB_TAG_EXCL, &ddef ))
    moab_error( "tag_get_handle(dtag)" );
  double dval = 0.333;
  if (MB_SUCCESS != iface->tag_set_data( dtag, &dodec, 1, &dval ))
    moab_error( "tag_set_data(dtag)" );
  // Create a tag containing entity handles, with default values
  Tag htag;
  EntityHandle hdef[] = { hex, dodec, 0 };
  if (MB_SUCCESS != iface->tag_get_handle( handlename, 3, MB_TYPE_HANDLE, htag, MB_TAG_SPARSE|MB_TAG_EXCL, hdef ))
    moab_error( "tag_get_handle(htag)" );
  // Set global (mesh) value for tag
  EntityHandle hgbl[] = { 0, hex, dodec };
  if (MB_SUCCESS != iface->tag_set_data( htag, &root, 1, hgbl ))
    moab_error( "tag_set_data(hgbl)" );
  // Store first three entiries of dodec connectivity on dodec
  EntityHandle hval[] = { faces[0], faces[1], faces[2] };
  if (MB_SUCCESS != iface->tag_set_data( htag, &dodec, 1, hval ))
  // create some sets
  EntityHandle face_set, vertex_set, region_set, empty_set;
  EntityHandle regions[] = { dodec, hex };
  const unsigned empty_flags = MESHSET_ORDERED|MESHSET_TRACK_OWNER;
  face_set   = make_set( MESHSET_SET,     faces,    12, false, FACE_SET_ID    );
  vertex_set = make_set( MESHSET_ORDERED, vertices, 20, true,  VERTEX_SET_ID  );
  region_set = make_set( MESHSET_SET,     regions,   2, false, REGION_SET_ID  );
  empty_set  = make_set( empty_flags,     0,         0, true,  EMPTY_SET_ID   );
  EntityHandle sets[] = {face_set, vertex_set, region_set, empty_set};
  make_set( MESHSET_ORDERED, sets,      4, false, SET_SET_ID     );
  // create some set parent-child links
  if (MB_SUCCESS != iface->add_parent_child( face_set, vertex_set))
    moab_error( "add_parent_child" );
  if (MB_SUCCESS != iface->add_child_meshset( region_set, face_set ))
    moab_error( "add_child_meshset" );
  if (MB_SUCCESS != iface->add_parent_meshset( vertex_set, region_set ))
    moab_error( "add_parent_meshet" );
int main ( int  argc,
char *  argv[]
Definition at line 53 of file h5file_test.cpp.
References compare(), create(), moab::Interface::delete_mesh(), filename, moab::Interface::get_last_error(), iface, moab::Interface::load_file(), MB_SUCCESS, moab_error(), and moab::Interface::write_file().
  ErrorCode rval;
  std::string msg;
  std::string read_opt;
  std::string write_opt("DEBUG_BINIO");
  for (int i = 1; i < argc; ++i) {
    long val;
    char* endptr;
    if (argv[i][0] == '-' && (argv[i][1] == 'r' || argv[i][1] == 'w')
        && i+1 < argc && (val = strtol(argv[i+1],&endptr,0)) >= 0 && !*endptr)
      std::string& s = argv[i][1] == 'r' ? read_opt : write_opt;
      std::ostringstream str;
      str << "DEBUG_IO=" << val;
      if (s.empty())
        s = str.str();
      else {
        s += ';';
        s += str.str();
      ++i;
    else
      std::cerr << "Usage: " << argv[0] << " [-r <n>] [-w <n>]" << std::endl;
      return 1;
  iface = new Core();
  // create a dodecahedron and inscribed hex
  fprintf( stderr, "creating... " );
  create();
  // write out the dodecahedron
  fprintf( stderr, "writing... " );
  rval = iface->write_file( filename, 0, write_opt.c_str() );
    fprintf( stderr, "Failed to write \"%s\"\n", filename );
    if (MB_SUCCESS == iface->get_last_error( msg ))
      fprintf( stderr, "%s\n", msg.c_str() );
    delete iface;
    return 1;
  // Read back in as a copy of the original
  fprintf( stderr, "reading... " );
  rval = iface->load_file( filename, 0, read_opt.c_str() );
    fprintf( stderr, "Failed to read \"%s\"\n", filename );
    delete iface;
    return 1;
  // Compare the two.
  fprintf( stderr, "comparing... " );
  if (!compare())
    fprintf(stderr, "Comparison failed.\n");
    delete iface;
    return 1;
  fprintf( stderr, "success!\n" );
  // Write both the original and copy to a file
    delete iface;
    return 1;
  // Delete the mesh
  fprintf( stderr, "clearing db... " );
  rval = iface->delete_mesh();
    moab_error( "delete_mesh" );
  // Read the two dodecahedrons from the file
    delete iface;
    return 1;
  // Compare them
  if (!compare())
    delete iface;
    return 1;
  // Delete the mesh
  fprintf( stderr, "cleaning up... " );
  // Clean up the file.
  remove( filename );
  fprintf( stderr, "done.\n" );
  delete iface;
  return 0;
EntityHandle make_set ( unsigned int  options,
EntityHandle entities,
bool  reverse,
int  id
Definition at line 206 of file h5file_test.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::Interface::globalId_tag(), id_tag, iface, MB_SUCCESS, moab_error(), and moab::Interface::tag_set_data().
Referenced by create().
  EntityHandle handle;
  if (MB_SUCCESS != iface->create_meshset( options, handle ))
    moab_error( "create_meshset" );
  if (reverse)
    for (int i = (int)num_entities - 1; i >= 0; --i)
      if (MB_SUCCESS != iface->add_entities( handle, entities + i, 1 ))
        moab_error( "add_entities" );
  else
    if (MB_SUCCESS != iface->add_entities( handle, entities, num_entities ))
  ErrorCode rval;
  if (MB_SUCCESS != iface->tag_set_data( id_tag, &handle, 1, &id ))
  return handle;
void moab_error ( const char *  function)
Definition at line 845 of file h5file_test.cpp.
References moab::Interface::get_last_error(), iface, and MB_SUCCESS.
Referenced by compare(), compare_conn(), compare_sets(), compare_tags(), create(), main(), make_set(), pent(), and vtx().
  std::string msg;
  fprintf( stderr, "%s() failed.\n", str );
  delete iface;
  exit( 1 );
EntityHandle pent ( EntityHandle vtx_list,
int  i1,
int  i2,
int  i3,
int  i4,
int  i5
Definition at line 187 of file h5file_test.cpp.
References conn, moab::Interface::create_element(), iface, MB_SUCCESS, MBPOLYGON, and moab_error().
  const EntityHandle conn[5] = { vtx_list[i1],
                                   vtx_list[i2],
                                   vtx_list[i3],
                                   vtx_list[i4],
                                   vtx_list[i5] };
  EntityHandle result;
  if (MB_SUCCESS != iface->create_element( MBPOLYGON, conn, 5, result ))
  return result;
EntityHandle vtx ( double  x,
double  y,
double  z
Definition at line 178 of file h5file_test.cpp.
References moab::Interface::create_vertex(), iface, MB_SUCCESS, and moab_error().
Referenced by check_one_layer(), PatchDataTest::check_sub_patch(), create(), moab::ReadCGM::create_surface_facets(), MBMesquite::derivatives_at_mid_edge(), DistTestMetric::evaluate(), MBMesquite::ElementQM::evaluate_with_indices(), DistTestMetric::evaluate_with_indices(), exp_1_init(), MBMesquite::ElementQM::get_element_evaluations(), get_slaved_coords(), horseshoe(), moab::BSPTreePoly::is_valid(), mb_skin_adjacent_surf_patches(), MBMesquite::next_vertex(), parabolic_squash(), PartMap::part_from_coords(), quarter_annulus(), moab::ReadVtk::read_vertices(), scale(), moab::BSPTreePoly::VertexUse::set_vertex(), smooth_mesh(), test_entity_copy_parts(), MsqVertexTest::test_flags(), test_ghost_elements(), MsqMeshEntityTest::test_hex_vertices(), MsqVertexTest::test_hex_vertices(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), MBMesquite::DomainClassifier::test_valid_classification(), MBMesquite::MeshImpl::vtk_read_polydata(), MBMesquite::MeshImpl::vtk_read_rectilinear_grid(), MBMesquite::MeshImpl::vtk_read_structured_grid(), MBMesquite::MeshImpl::vtk_read_structured_points(), MBMesquite::MeshImpl::vtk_read_unstructured_grid(), LinearMappingFunctionTest::xi_at_edges(), and LinearMappingFunctionTest::xi_at_faces().
  const double p[3] = { x, y, z };
  if (MB_SUCCESS != iface->create_vertex( p, result ))
      moab_error( "create_vertex" );
  return result;
Variable Documentation
Definition at line 42 of file h5file_test.cpp.
Definition at line 39 of file h5file_test.cpp.
Definition at line 45 of file h5file_test.cpp.
Definition at line 41 of file h5file_test.cpp.
Definition at line 43 of file h5file_test.cpp.
Definition at line 40 of file h5file_test.cpp.
