h5partial.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "TestRunner.hpp"
#include "ReadHDF5.hpp"
#include "MBTagConventions.hpp"
#include "moab/FileOptions.hpp"
#include <vector>
#include <cstdlib>
#include <iostream>
#include <algorithm>
#include <limits>
+ Include dependency graph for h5partial.cpp:
Defines
#define READ_OPTS   "BUFFER_SIZE=256"
Enumerations
enum  GatherTestMode { GATHER_SETS, GATHER_CONTENTS, GATHER_NONE }
Functions
static void test_read_nothing_common (bool non_existant)
static void test_read_nodes_common (int num_read_sets, bool blocked_coordinate_io)
static void test_read_handle_tag_common (bool var_len)
void create_mesh (bool create_element_sets, bool create_vertex_sets, bool tag_elements_with_id, bool tag_vertices_with_id, const char *adj_elem_tag_name=0, bool var_len_adj_elems=false)
int identify_set (Interface &mb, const Range &verts)
int identify_set (Interface &mb, EntityHandle set)
static Tag check_tag (Interface &mb, const char *name, TagType storage, DataType type, int size)
void test_gather_sets_common (bool contained_sets, GatherTestMode mode, bool no_parent_containing_sets=false)
void test_gather_sets_ranged (bool contained_sets, GatherTestMode mode, bool no_parent_containing_sets=false)
void test_read_empty_set ()
 Read a set containing no entities.
void test_read_non_existant_set ()
 Specify ID that doesn't exist in file.
void test_read_one_set_nodes ()
 Read in the nodes contained in a set.
void test_read_one_set_nodes_blocked ()
void test_read_one_set_elems ()
 Read in the elems contained in a set.
void test_read_one_set_polyhedra ()
 Read in the polyhedra contained in a set.
void test_read_set_sets ()
void test_read_two_sets_nodes ()
 Read in the nodes contained in a sets.
void test_read_two_sets_elems ()
 Read in the elems contained in a sets.
void test_read_child_sets_only ()
void test_read_child_set_contents ()
void test_read_no_child_sets ()
void test_read_contained_sets_only ()
void test_read_contained_set_contents ()
void test_read_no_contained_sets ()
void test_read_containing_sets ()
void test_read_adjacencies ()
 Test reading of explicit adjacencies.
void test_read_double_tag ()
 Test reading of sparse double tag data.
void test_read_opaque_tag ()
 Test reading of sparse opaque tag data.
void test_read_handle_tag ()
 Test reading of sparse handle tag data.
void test_var_len_tag ()
 Test reading of variable-length tag data.
void test_read_tagged_elems ()
void test_read_tagged_nodes ()
void test_read_sides ()
void test_read_ids ()
void test_read_partial_ids ()
int main (int argc, char *argv[])
static void vtx_coords (int set_id, int j, int num_sets, double coords[3])
static void check_children (bool contents, GatherTestMode mode, Interface &mb, int id, Tag id_tag, EntityHandle file)
static void check_num_verts (Interface &mb, Tag tag, int id, int num_vtx)
void write_id_test_file ()
Variables
const char TEST_FILE [] = "partial.h5m"
const char ID_TAG_NAME [] = "test_id_tag"
const int MBQUAD_INT = 20
const int NUM_SETS = 10
const int SET_WIDTH = ( MBQUAD_INT + NUM_SETS - 1 ) / NUM_SETS
const char LOGICAL_NAME [] = "logical"
const char CENTROID_NAME [] = "centroid"
const char * set_read_opts [] = { "SETS", "CONTENTS", "NONE" }
const int expected_ids [] = { 2, 4, 6, 8, 10, 12, 14, 16, 18 }
const int expected_vols [] = { 3, 7, 10 }
Define Documentation
Enumeration Type Documentation
Enumerator:
GATHER_SETS
GATHER_CONTENTS
GATHER_NONE
Definition at line 51 of file h5partial.cpp.
Function Documentation
static void check_children ( bool  contents,
Interface mb,
int  id,
Tag  id_tag,
EntityHandle  file
) [static]
Definition at line 949 of file h5partial.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, children, moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::find(), moab::Range::front(), GATHER_CONTENTS, GATHER_NONE, moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MBEDGE, MBENTITYSET, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by test_gather_sets_common().
    // Increase number of expected sets by one if contents is true because
    // we always read immediately contained (depth 1) sets.
    const int exp_num_sets  = ( mode == GATHER_NONE ) ? 1 + contents : id;
    const int exp_num_edges = ( mode == GATHER_CONTENTS ) ? id : 1;
    ErrorCode rval;
    Range range;
    rval = mb.get_entities_by_type( 0, MBEDGE, range );CHECK_ERR( rval );
    CHECK_EQUAL( exp_num_edges, (int)range.size() );
    range.clear();
    rval = mb.get_entities_by_type( 0, MBENTITYSET, range );CHECK_ERR( rval );
    Range::iterator it = range.find( file );
    CHECK( it != range.end() );
    range.erase( it );
    CHECK_EQUAL( exp_num_sets, (int)range.size() );
    EntityHandle set;
    const void* val[] = { &id };
    range.clear();
    rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &id_tag, val, 1, range );CHECK_ERR( rval );
    CHECK_EQUAL( 1, (int)range.size() );
    set = range.front();
    if( mode == GATHER_NONE )
        range.clear();
        rval = mb.get_entities_by_type( set, MBEDGE, range );CHECK_ERR( rval );
        return;
    for( int i = id; i > 0; --i )
        int act_id;
        rval = mb.tag_get_data( id_tag, &set, 1, &act_id );CHECK_ERR( rval );
        CHECK_EQUAL( i, act_id );
        range.clear();
        if( mode == GATHER_CONTENTS || i == id )
            const EntityHandle* conn;
            int len;
            rval = mb.get_connectivity( range.front(), conn, len );CHECK_ERR( rval );
            CHECK_EQUAL( 2, len );
            double coords[3];
            rval = mb.get_coords( conn + 1, 1, coords );CHECK_ERR( rval );
            CHECK_EQUAL( i, (int)coords[0] );
        else
            CHECK( range.empty() );
        std::vector< EntityHandle > children;
        if( contents )
            rval = mb.get_entities_by_type( set, MBENTITYSET, children );
        else
            rval = mb.get_child_meshsets( set, children );CHECK_ERR( rval );
        if( i == 1 )
            CHECK( children.empty() );
        else
            CHECK_EQUAL( 1, (int)children.size() );
            set = children[0];
static void check_num_verts ( Interface mb,
Tag  tag,
int  id,
int  num_vtx
) [static]
Definition at line 1192 of file h5partial.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MBENTITYSET, MBVERTEX, and moab::Range::size().
Referenced by test_read_containing_sets().
    ErrorCode rval;
    Range range;
    rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, val, 1, range );CHECK_ERR( rval );
    EntityHandle set = range.front();
    range.clear();
    rval = mb.get_entities_by_type( set, MBVERTEX, range );CHECK_ERR( rval );
    CHECK_EQUAL( num_vtx, (int)range.size() );
Tag check_tag ( Interface mb,
const char *  name,
TagType  storage,
DataType  type,
int  size
) [static]
Definition at line 610 of file h5partial.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, MB_VARIABLE_DATA_LENGTH, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), and TagType.
Referenced by test_read_double_tag(), test_read_handle_tag_common(), and test_read_opaque_tag().
    Tag tag;
    ErrorCode rval = mb.tag_get_handle( name, size, type, tag );CHECK_ERR( rval );
    TagType storage1;
    rval = mb.tag_get_type( tag, storage1 );CHECK_ERR( rval );
    CHECK_EQUAL( storage, storage1 );
    DataType type1;
    rval = mb.tag_get_data_type( tag, type1 );CHECK_ERR( rval );
    CHECK_EQUAL( type, type1 );
    int size1;
    rval = mb.tag_get_length( tag, size1 );
    if( size <= 0 )
    {  // variable-length tag
        CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval );
    else
        CHECK_ERR( rval );
        CHECK_EQUAL( size, size1 );
    return tag;
void create_mesh ( bool  create_element_sets,
const char *  adj_elem_tag_name = 0,
bool  var_len_adj_elems = false
Create a regular MBQUAD_INT^2 element quad mesh with regularly spaced coordinates in the range [1,100]. Group elements into 10 vertical strips MBQUAD_INT/10 elements wide. Tag elements, vertices and/or sets with ID in [1,10] stored in ID_TAG_NAME tag. Write new mesh to TEST_FILE.
Definition at line 387 of file h5partial.cpp.
References moab::Interface::add_entities(), CENTROID_NAME, CHECK_ERR, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), ErrorCode, id_tag, ID_TAG_NAME, LOGICAL_NAME, mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBQUAD, MBQUAD_INT, NUM_SETS, SET_WIDTH, moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    // create tags
    Tag logical_tag, centroid_tag, id_tag;
    rval = mb.tag_get_handle( ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval );
    rval =
        mb.tag_get_handle( LOGICAL_NAME, 2 * sizeof( int ), MB_TYPE_OPAQUE, logical_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( rval );
    rval = mb.tag_get_handle( CENTROID_NAME, 3, MB_TYPE_DOUBLE, centroid_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( rval );
    EntityHandle sets[NUM_SETS];
    if( create_element_sets || create_vertex_sets )
        for( int i = 0; i < NUM_SETS; ++i )
            rval = mb.create_meshset( MESHSET_ORDERED, sets[i] );CHECK_ERR( rval );
            int id = i + 1;
            rval   = mb.tag_set_data( id_tag, &sets[i], 1, &id );CHECK_ERR( rval );
    // create elements
    EntityHandle verts[MBQUAD_INT + 1][MBQUAD_INT + 1], quads[MBQUAD_INT][MBQUAD_INT];
    for( int i = 0; i <= MBQUAD_INT; ++i )
        for( int j = 0; j <= MBQUAD_INT; ++j )
            double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), 0 };
            rval             = mb.create_vertex( coords, verts[j][i] );CHECK_ERR( rval );
            int logical[2] = { i, j };
            rval           = mb.tag_set_data( logical_tag, &verts[j][i], 1, logical );CHECK_ERR( rval );
            rval = mb.tag_set_data( centroid_tag, &verts[j][i], 1, coords );CHECK_ERR( rval );
            int id = ( i - 1 ) / SET_WIDTH + 1;  // Note: assumes SET_WIDTH > 1
            if( tag_vertices_with_id )
                rval = mb.tag_set_data( id_tag, &verts[j][i], 1, &id );CHECK_ERR( rval );
            if( create_vertex_sets )
                rval = mb.add_entities( sets[id - 1], &verts[j][i], 1 );CHECK_ERR( rval );
                // Some vertices are shared by quads in different sets.
                // put such vertices in both sets.
                int id2 = i / SET_WIDTH + 1;
                if( id2 != id && id2 <= NUM_SETS )
                    rval = mb.add_entities( sets[id2 - 1], &verts[j][i], 1 );CHECK_ERR( rval );
    for( int i = 0; i < MBQUAD_INT; ++i )
        for( int j = 0; j < MBQUAD_INT; ++j )
            EntityHandle conn[4] = { verts[j][i], verts[j][i + 1], verts[j + 1][i + 1], verts[j + 1][i] };
            rval                 = mb.create_element( MBQUAD, conn, 4, quads[j][i] );CHECK_ERR( rval );
            rval           = mb.tag_set_data( logical_tag, &quads[j][i], 1, logical );CHECK_ERR( rval );
            double centroid[3] = { i + 0.5, j + 0.5, 0 };
            rval               = mb.tag_set_data( centroid_tag, &quads[j][i], 1, centroid );CHECK_ERR( rval );
            int id = i / SET_WIDTH + 1;
            if( tag_elements_with_id )
                rval = mb.tag_set_data( id_tag, &quads[j][i], 1, &id );CHECK_ERR( rval );
            if( create_element_sets )
                rval = mb.add_entities( sets[id - 1], &quads[j][i], 1 );CHECK_ERR( rval );
    if( adj_elem_tag_name && !var_len_adj_elems )
        Tag handle_tag;
        rval = mb.tag_get_handle( adj_elem_tag_name, 4, MB_TYPE_HANDLE, handle_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( rval );
                EntityHandle val[4] = { ( i > 0 && j > 0 ) ? quads[j - 1][i - 1] : 0,
                                        ( i > 0 && j < MBQUAD_INT ) ? quads[j][i - 1] : 0,
                                        ( i < MBQUAD_INT && j < MBQUAD_INT ) ? quads[j][i] : 0,
                                        ( i < MBQUAD_INT && j > 0 ) ? quads[j - 1][i] : 0 };
                rval = mb.tag_set_data( handle_tag, &verts[j][i], 1, val );CHECK_ERR( rval );
    else if( adj_elem_tag_name && var_len_adj_elems )
        Tag handle_tag;
        rval = mb.tag_get_handle( adj_elem_tag_name, 0, MB_TYPE_HANDLE, handle_tag,
                                  MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval );
                EntityHandle val[4];
                int num = 0;
                if( i > 0 && j > 0 ) val[num++] = quads[j - 1][i - 1];
                if( i > 0 && j < MBQUAD_INT ) val[num++] = quads[j][i - 1];
                if( i < MBQUAD_INT && j < MBQUAD_INT ) val[num++] = quads[j][i];
                if( i < MBQUAD_INT && j > 0 ) val[num++] = quads[j - 1][i];
                const void* ptr = val;
                rval            = mb.tag_set_by_ptr( handle_tag, &verts[j][i], 1, &ptr, &num );CHECK_ERR( rval );
    rval = mb.write_file( TEST_FILE, "MOAB" );CHECK_ERR( rval );
int identify_set ( Interface mb,
const Range verts
Definition at line 501 of file h5partial.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::end(), ErrorCode, moab::Interface::get_coords(), MBQUAD_INT, SET_WIDTH, and moab::Range::size().
Referenced by identify_set(), test_read_one_set_elems(), test_read_tagged_elems(), test_read_tagged_nodes(), and test_read_two_sets_elems().
    const int COL = SET_WIDTH + 1;
    CHECK_EQUAL( ( 1 + MBQUAD_INT ) * COL, (int)verts.size() );
    // Get X range of vertices
    int min_x = std::numeric_limits< int >::max();
    int max_x = std::numeric_limits< int >::min();
    for( Range::const_iterator i = verts.begin(); i != verts.end(); ++i )
        double coords[3];
        ErrorCode rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval );
        // Expect whole-valued coorindates
        int int_x = (int)coords[0];
        CHECK( fabs( coords[0] - (double)int_x ) < 1e-12 );
        if( int_x < min_x ) min_x = int_x;
        if( int_x > max_x ) max_x = int_x;
    CHECK( max_x - min_x < COL );
    // Calculate ID (return value) from coordinate range)
    const int ID = min_x / SET_WIDTH + 1;
    // Now verify that all vertices correctly form a grid
    EntityHandle grid[MBQUAD_INT + 1][COL];
    memset( grid, 0, sizeof( grid ) );
        double coords[3];
        int x = (int)coords[0] - ( ID - 1 ) * SET_WIDTH, y = (int)coords[1];
        CHECK( fabs( coords[1] - (double)y ) < 1e-12 );
        CHECK( fabs( coords[2] ) < 1e-12 );
        CHECK( y >= 0 && y <= MBQUAD_INT );
        CHECK_EQUAL( (EntityHandle)0, grid[y][x] );
        grid[y][x] = *i;
    return ID;
EntityHandle  set
int main ( int  argc,
char *  argv[]
Definition at line 180 of file h5partial.cpp.
References moab::fail(), REGISTER_TEST, RUN_TESTS, test_read_adjacencies(), test_read_child_set_contents(), test_read_child_sets_only(), test_read_contained_set_contents(), test_read_contained_sets_only(), test_read_containing_sets(), test_read_double_tag(), test_read_empty_set(), test_read_handle_tag(), test_read_ids(), test_read_no_child_sets(), test_read_no_contained_sets(), test_read_non_existant_set(), test_read_one_set_elems(), test_read_one_set_nodes(), test_read_one_set_nodes_blocked(), test_read_one_set_polyhedra(), test_read_opaque_tag(), test_read_partial_ids(), test_read_set_sets(), test_read_sides(), test_read_tagged_elems(), test_read_tagged_nodes(), test_read_two_sets_elems(), test_read_two_sets_nodes(), and test_var_len_tag().
void test_gather_sets_common ( bool  contained_sets,
bool  no_parent_containing_sets = false
Definition at line 1024 of file h5partial.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), CHECK, check_children(), CHECK_ERR, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, id_tag, ID_TAG_NAME, INT, moab::Interface::load_file(), mb, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBEDGE, MESHSET_SET, READ_OPTS, set_read_opts, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
Referenced by test_read_child_set_contents(), test_read_child_sets_only(), test_read_contained_set_contents(), test_read_contained_sets_only(), test_read_no_child_sets(), and test_read_no_contained_sets().
    ErrorCode rval;
    Core instance;
    Interface& mb = instance;
    Tag id_tag;
    // Create a string of edges from [0,INT] along the X axis each 1 unit in length.
    // Create a set for edge edge containing the edge and make it the parent of the
    // set containing the previous (closer to origin) edge.  Assign each set an
    // ID that is the X coordinate of the larger of the two vertices of the edge
    // contained in the set.
    const int INT = 64;
    EntityHandle verts[INT + 1], edges[INT], sets[INT];
    double coords[] = { 0, 0, 0 };
    rval            = mb.create_vertex( coords, verts[0] );CHECK_ERR( rval );
    for( int i = 0; i < INT; ++i )
        const int id = i + 1;
        coords[0]    = id;
        rval         = mb.create_vertex( coords, verts[id] );CHECK_ERR( rval );
        rval = mb.create_element( MBEDGE, verts + i, 2, edges[i] );CHECK_ERR( rval );
        rval = mb.create_meshset( MESHSET_SET, sets[i] );CHECK_ERR( rval );
        rval = mb.add_entities( sets[i], edges + i, 1 );CHECK_ERR( rval );
        rval = mb.tag_set_data( id_tag, sets + i, 1, &id );CHECK_ERR( rval );
        if( i > 0 )
            if( contents )
                rval = mb.add_entities( sets[i], sets + ( i - 1 ), 1 );
            else
                rval = mb.add_child_meshset( sets[i], sets[i - 1] );CHECK_ERR( rval );
    // Write the data
    EntityHandle file;
    std::string opt( READ_OPTS );
    if( contents )
        opt += ";CHILDREN=NONE;SETS=";
    else
        opt += ";SETS=NONE;CHILDREN=";
    opt += set_read_opts[mode];
    if( no_parent_containing_sets ) opt += ";NO_SET_CONTAINING_PARENTS";
    const int test_ids[]   = { 2, 7, INT / 3 - 1, INT / 2 + 1, INT - 3 };
    const int num_test_ids = sizeof( test_ids ) / sizeof( int );
    for( int i = 0; i < num_test_ids; ++i )
        CHECK( test_ids[i] <= INT );
        rval = mb.delete_mesh();CHECK_ERR( rval );
        rval = mb.create_meshset( MESHSET_SET, file );CHECK_ERR( rval );
        rval = mb.load_file( TEST_FILE, 0, opt.c_str(), ID_TAG_NAME, test_ids + i, 1 );CHECK_ERR( rval );
        rval = mb.tag_get_handle( ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag );CHECK_ERR( rval );
        check_children( contents, mode, mb, test_ids[i], id_tag, file );
void test_gather_sets_ranged ( bool  contained_sets,
Definition at line 1090 of file h5partial.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_mesh(), moab::Range::end(), ErrorCode, GATHER_CONTENTS, GATHER_NONE, GATHER_SETS, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MBVERTEX, MESHSET_SET, READ_OPTS, read_sets(), set_read_opts, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
    ErrorCode rval;
    Core instance;
    Range verts;
    Tag id_tag;
    // create four groups of vertices, where all vertices in the same group
    // have the same x-coordinate
    const int NUM_GRP_VTX = 20;
    const int NUM_GRP     = 4;
    EntityHandle sets[NUM_GRP];
    for( int i = 0; i < NUM_GRP; ++i )
        double coords[3 * NUM_GRP_VTX];
        for( int j = 0; j < NUM_GRP_VTX; ++j )
            coords[3 * j]     = i;
            coords[3 * j + 1] = j;
            coords[3 * j + 2] = 0;
        rval = mb.create_vertices( coords, NUM_GRP_VTX, verts );CHECK_ERR( rval );
        rval = mb.add_entities( sets[i], verts );CHECK_ERR( rval );
        int id = i + 1;
    // place two of the sets inside the others
    if( contents )
        rval = mb.add_entities( sets[0], &sets[1], 1 );CHECK_ERR( rval );
        rval = mb.add_entities( sets[2], &sets[3], 1 );CHECK_ERR( rval );
    else
        rval = mb.add_child_meshset( sets[0], sets[1] );CHECK_ERR( rval );
        rval = mb.add_child_meshset( sets[2], sets[3] );CHECK_ERR( rval );
    // Write the data
    // Read the data
    if( contents )
    else
    if( no_parent_containing_sets ) opt += ";NO_PARENT_CONTAINING_SETS";
    EntityHandle file;
    const int read_id = 3;
    rval = mb.load_file( TEST_FILE, &file, opt.c_str(), ID_TAG_NAME, &read_id, 1 );CHECK_ERR( rval );
    // get any sets that were read it
    Range read_sets;
    rval = mb.get_entities_by_type( file, MBENTITYSET, read_sets );CHECK_ERR( rval );
    // count number of vertices in each group
    int counts[NUM_GRP];
    memset( counts, 0, sizeof( counts ) );
    verts.clear();
    rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
    for( Range::iterator it = verts.begin(); it != verts.end(); ++it )
        double coords[3];
        rval = mb.get_coords( &*it, 1, coords );CHECK_ERR( rval );
        int i = (int)( coords[0] + 1e-12 );
        CHECK( i >= 0 && i < NUM_GRP );
        counts[i]++;
    // check expected counts
    CHECK_EQUAL( 0, counts[0] );
    CHECK_EQUAL( 0, counts[1] );
    CHECK_EQUAL( NUM_GRP_VTX, counts[2] );
    switch( mode )
        case GATHER_NONE:
            CHECK_EQUAL( 0, counts[3] );
            CHECK_EQUAL( 1 + contents, (int)read_sets.size() );
            break;
        case GATHER_SETS:
            CHECK_EQUAL( 2, (int)read_sets.size() );
            break;
        case GATHER_CONTENTS:
            CHECK_EQUAL( NUM_GRP_VTX, counts[3] );
            break;
Definition at line 1241 of file h5partial.cpp.
References moab::Interface::add_adjacencies(), moab::Interface::add_entities(), moab::Range::back(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, moab::Range::front(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), h1, id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBEDGE, MBHEX, MESHSET_SET, READ_OPTS, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
Referenced by main().
    ErrorCode rval;
    Core instance;
    // create four hexes sharing an edge
    EntityHandle verts[3][3][2], hexes[2][2];
    for( int k = 0; k < 2; ++k )
        for( int j = 0; j < 3; ++j )
            for( int i = 0; i < 3; ++i )
                double coords[] = { static_cast< double >( i ), static_cast< double >( j ),
                                    static_cast< double >( k ) };
                rval            = mb.create_vertex( coords, verts[i][j][k] );CHECK_ERR( rval );
    for( int j = 0; j < 2; ++j )
        for( int i = 0; i < 2; ++i )
            EntityHandle conn[] = { verts[i][j][0], verts[i + 1][j][0], verts[i + 1][j + 1][0], verts[i][j + 1][0],
                                    verts[i][j][1], verts[i + 1][j][1], verts[i + 1][j + 1][1], verts[i][j + 1][1] };
            rval                = mb.create_element( MBHEX, conn, 8, hexes[i][j] );CHECK_ERR( rval );
    // create two duplicate edges that connect the vertices common to all four hexes
    EntityHandle edge_conn[2] = { verts[1][1][0], verts[1][1][1] };
    EntityHandle edges[2];
    rval = mb.create_element( MBEDGE, edge_conn, 2, edges[0] );CHECK_ERR( rval );
    rval = mb.create_element( MBEDGE, edge_conn, 2, edges[1] );CHECK_ERR( rval );
    // mark one edge as adjacent to the left two hexes and the
    // other as adjacent to the right two
    rval = mb.add_adjacencies( edges[0], hexes[0], 2, true );CHECK_ERR( rval );
    rval = mb.add_adjacencies( edges[1], hexes[1], 2, true );CHECK_ERR( rval );
    // create two sets containing the front two and the rear two
    // hexes, respectively.
    EntityHandle sets[2];
    rval = mb.create_meshset( MESHSET_SET, sets[0] );CHECK_ERR( rval );
    rval = mb.create_meshset( MESHSET_SET, sets[1] );CHECK_ERR( rval );
    EntityHandle set1[4] = { hexes[0][0], hexes[1][0], edges[0], edges[1] };
    EntityHandle set2[4] = { hexes[0][1], hexes[1][1], edges[0], edges[1] };
    rval                 = mb.add_entities( sets[0], set1, 4 );CHECK_ERR( rval );
    rval = mb.add_entities( sets[1], set2, 4 );CHECK_ERR( rval );
    // assign IDs to sets
    Tag id_tag;
    int ids[2] = { 1, 2 };
    rval       = mb.tag_set_data( id_tag, sets, 2, ids );CHECK_ERR( rval );
    // write mesh
    // read mesh
    rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, 1 );CHECK_ERR( rval );
    // expect two hexes and two edges
    Range range;
    rval = mb.get_entities_by_type( 0, MBHEX, range );CHECK_ERR( rval );
    CHECK_EQUAL( 2, (int)range.size() );
    EntityHandle h1 = range.front(), h2 = range.back();
    range.clear();
    // expecte each edge to have one of the hexes
    range.clear();
    rval = mb.get_adjacencies( &h1, 1, 1, false, range );CHECK_ERR( rval );
    EntityHandle e1 = range.front();
    range.clear();
    rval = mb.get_adjacencies( &h2, 1, 1, false, range );CHECK_ERR( rval );
    EntityHandle e2 = range.front();
    CHECK( e1 != e2 );
For any set selected to be read by either explicit designation, containing read entities, or contained in an explcitly designated set, any child sets are also read. Check that here.
Definition at line 108 of file h5partial.cpp.
References GATHER_SETS, test_gather_sets_common(), and test_gather_sets_ranged().
For any set selected to be read by either explicit designation, containing read entities, or contained in an explcitly designated set, any contained sets are also read. Check that here.
Definition at line 127 of file h5partial.cpp.
Read in the sets contained in a set. Should read all sets containing read elements or nodes and all sets that are contained the the specified "read" set. Test the former here.
Definition at line 1210 of file h5partial.cpp.
References CHECK_ERR, check_num_verts(), create_mesh(), ErrorCode, id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TYPE_INTEGER, MBQUAD_INT, NUM_SETS, READ_OPTS, SET_WIDTH, moab::Interface::tag_get_handle(), and TEST_FILE.
    // create mesh decomposed by elements but create
    // sets containing all vertices of decomposed elements
    // such that adjacent sets share vertices.
    create_mesh( false, true, false, false );
    ErrorCode rval;
    Core instance;
    // read some sets
    const int ids[]    = { 1, 5, 9 };
    const int num_sets = sizeof( ids ) / sizeof( int );
    rval               = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, num_sets );CHECK_ERR( rval );
    Tag id_tag;
    // expect all sets adjacent to the specified sets because
    // they share vertices.
    Range verts;
    for( int i = 0; i < num_sets; ++i )
        if( ids[i] > 1 ) check_num_verts( mb, id_tag, ids[i] - 1, MBQUAD_INT + 1 );
        check_num_verts( mb, id_tag, ids[i], ( MBQUAD_INT + 1 ) * ( SET_WIDTH + 1 ) );
        if( ids[i] < NUM_SETS ) check_num_verts( mb, id_tag, ids[i] + 1, MBQUAD_INT + 1 );
Definition at line 640 of file h5partial.cpp.
References moab::Range::begin(), CENTROID_NAME, CHECK, CHECK_ERR, CHECK_REAL_EQUAL, check_tag(), create_mesh(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TYPE_DOUBLE, MBVERTEX, READ_OPTS, moab::Interface::tag_get_data(), and TEST_FILE.
    ErrorCode rval;
    Core moab;
    create_mesh( true, false, false, false );
    int ids[2] = { 1, 4 };
    rval       = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, ids, 2 );CHECK_ERR( rval );
    Tag tag = check_tag( mb, CENTROID_NAME, MB_TAG_DENSE, MB_TYPE_DOUBLE, 3 );
    Range verts;
    CHECK( !verts.empty() );
    for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
        double coords[3], data[3];
        rval = mb.tag_get_data( tag, &*i, 1, data );CHECK_ERR( rval );
        CHECK_REAL_EQUAL( coords[0], data[0], 1e-12 );
        CHECK_REAL_EQUAL( coords[1], data[1], 1e-12 );
        CHECK_REAL_EQUAL( coords[2], data[2], 1e-12 );
Definition at line 61 of file h5partial.cpp.
References test_read_nothing_common().
Definition at line 159 of file h5partial.cpp.
References test_read_handle_tag_common().
Referenced by main(), and test_native_read().
static void test_read_handle_tag_common ( bool  var_len) [static]
Definition at line 691 of file h5partial.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, check_tag(), create_mesh(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TYPE_HANDLE, MBVERTEX, READ_OPTS, moab::Interface::tag_get_by_ptr(), TEST_FILE, and moab::Interface::UNION.
Referenced by test_read_handle_tag(), and test_var_len_tag().
    ErrorCode rval;
    Core moab;
    const char tag_name[] = "VTX_ADJ";
    create_mesh( true, false, false, false, tag_name, var_len );
    int ids[2] = { 7, 10 };
    Tag tag = check_tag( mb, tag_name, MB_TAG_DENSE, MB_TYPE_HANDLE, var_len ? 0 : 4 );
    Range verts;
        std::vector< EntityHandle > adj, val;
        rval = mb.get_adjacencies( &*i, 1, 2, false, adj, Interface::UNION );CHECK_ERR( rval );
        CHECK( !adj.empty() );
        int num;
        const void* ptr;
        rval = mb.tag_get_by_ptr( tag, &*i, 1, &ptr, &num );CHECK_ERR( rval );
        if( var_len )
            CHECK( num > 0 );
            CHECK( num < 5 );
        else
            CHECK_EQUAL( 4, num );
        val.clear();
        const EntityHandle* dat = (const EntityHandle*)ptr;
        for( const EntityHandle* end = dat + num; dat != end; ++dat )
            if( *dat ) val.push_back( *dat );
        CHECK_EQUAL( adj.size(), val.size() );
        std::sort( adj.begin(), adj.end() );
        std::sort( val.begin(), val.end() );
        CHECK( adj == val );
void test_read_ids ( )
Definition at line 1445 of file h5partial.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, ID_TAG_NAME, moab::ReadHDF5::read_tag_values(), TEST_FILE, and write_id_test_file().
    write_id_test_file();
    Core moab;
    ReadHDF5 reader( &moab );
    FileOptions opts( "" );
    ErrorCode rval;
    std::vector< int > values;
    rval = reader.read_tag_values( TEST_FILE, ID_TAG_NAME, opts, values );
    remove( TEST_FILE );CHECK_ERR( rval );
    std::sort( values.begin(), values.end() );
    std::vector< int > expected( expected_ids, expected_ids + sizeof( expected_ids ) / sizeof( int ) );
    CHECK_EQUAL( expected, values );
void test_read_nodes_common ( int  num_read_sets,
) [static]
Definition at line 289 of file h5partial.cpp.
References moab::Interface::add_entities(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::find(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_dimension(), id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MESHSET_SET, moab::Range::pop_front(), READ_OPTS, size, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, vtx_coords(), and moab::Interface::write_file().
Referenced by test_read_one_set_nodes(), test_read_one_set_nodes_blocked(), and test_read_two_sets_nodes().
    ErrorCode rval;
    Core moab;
    // create 1000 nodes
    const int num_sets = 2 * num_read_sets;
    std::vector< EntityHandle > verts( 1000 );
    std::vector< std::vector< EntityHandle > > set_verts( num_sets );
    for( size_t i = 0; i < verts.size(); ++i )
        double coords[3];
        int j = i % num_sets;
        vtx_coords( j + 1, set_verts[j].size(), num_sets, coords );
        rval = mb.create_vertex( coords, verts[i] );
        set_verts[j].push_back( verts[i] );CHECK_ERR( rval );
    // create two sets, each containing half of the nodes
    std::vector< EntityHandle > sets( num_sets );
        rval = mb.add_entities( sets[i], &set_verts[i][0], set_verts[i].size() );CHECK_ERR( rval );
    // tag both sets
    Tag id_tag;
    std::vector< int > values( num_sets );
        values[i] = i + 1;
    rval = mb.tag_set_data( id_tag, &sets[0], num_sets, &values[0] );CHECK_ERR( rval );
    // write file
    // now read back in only the specified number of sets
    std::string opts( READ_OPTS );
    if( !opts.empty() ) opts += ';';
    if( blocked )
        opts += "BLOCKED_COORDINATE_IO=yes";
    else
        opts += "BLOCKED_COORDINATE_IO=no";
    values.resize( num_read_sets );
    for( int i = 0; i < num_read_sets; ++i )
        values[i] = 2 * ( i + 1 );
    EntityHandle file_set;
    rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
    rval = mb.load_file( TEST_FILE, &file_set, opts.c_str(), ID_TAG_NAME, &values[0], num_read_sets );CHECK_ERR( rval );
    int count, expected = 0;
    rval = mb.get_number_entities_by_dimension( 0, 0, count );CHECK_ERR( rval );
        if( i % 2 ) expected += set_verts[i].size();
    CHECK_EQUAL( expected, count );
    Range sets2;
    rval = mb.get_entities_by_type( 0, MBENTITYSET, sets2 );CHECK_ERR( rval );
    CHECK_EQUAL( 1 + num_read_sets, (int)sets2.size() );
    Range::iterator it = sets2.find( file_set );
    CHECK( it != sets2.end() );
    sets2.erase( it );
    while( !sets2.empty() )
        EntityHandle set = sets2.pop_front();
        int id;
        rval = mb.tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval );
        CHECK( std::find( values.begin(), values.end(), id ) != values.end() );
        CHECK( id > 0 );
        CHECK( (unsigned)id <= set_verts.size() );
        std::vector< EntityHandle > verts2;
        rval = mb.get_entities_by_handle( set, verts2 );CHECK_ERR( rval );
        CHECK_EQUAL( set_verts[id - 1].size(), verts2.size() );
        for( size_t i = 0; i < verts2.size(); ++i )
            double exp_coords[3], coords[3];
            vtx_coords( id, i, num_sets, exp_coords );
            rval = mb.get_coords( &verts2[i], 1, coords );CHECK_ERR( rval );
            CHECK_REAL_EQUAL( exp_coords[0], coords[0], 1e-12 );
            CHECK_REAL_EQUAL( exp_coords[1], coords[1], 1e-12 );
            CHECK_REAL_EQUAL( exp_coords[2], coords[2], 1e-12 );
Definition at line 67 of file h5partial.cpp.
void test_read_nothing_common ( bool  non_existant) [static]
Definition at line 223 of file h5partial.cpp.
References moab::Interface::add_entities(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_mesh(), moab::Range::end(), ErrorCode, moab::Range::find(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_ENTITY_NOT_FOUND, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MBVERTEX, MESHSET_SET, READ_OPTS, moab::Range::size(), t, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
Referenced by test_read_empty_set(), and test_read_non_existant_set().
    ErrorCode rval;
    Core moab;
    // create a few nodes to write to file
    std::vector< double > coords( 3000 );
    Range verts;
    rval = mb.create_vertices( &coords[0], coords.size() / 3, verts );CHECK_ERR( rval );
    // create three entity sets
    EntityHandle sets[3];
    rval = mb.create_meshset( MESHSET_ORDERED, sets[2] );CHECK_ERR( rval );
    // put all vertices into two of the sets
    rval = mb.add_entities( sets[0], verts );CHECK_ERR( rval );
    rval = mb.add_entities( sets[2], verts );CHECK_ERR( rval );
    // tag all three sets
    Tag id_tag;
    int ids[3] = { 5, 7, 9 };
    rval       = mb.tag_set_data( id_tag, sets, 3, ids );CHECK_ERR( rval );
    // write mesh
    // now read back in only the empty set
    int id = non_existant ? 8 : 7;
    rval = mb.load_file( TEST_FILE, &file_set, READ_OPTS, ID_TAG_NAME, &id, 1 );
    if( non_existant )
        CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
        return;
    else
        CHECK_ERR( rval );
    // the file should contain exactly two sets (the specified one and the new
    // file set, and nothing else.)
    for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t )
        int count = -1;
        rval      = mb.get_number_entities_by_type( 0, t, count );CHECK_ERR( rval );
        CHECK_EQUAL( 0, count );
    Range setrange;
    rval = mb.get_entities_by_type( 0, MBENTITYSET, setrange );CHECK_ERR( rval );
    CHECK_EQUAL( ( non_existant ? 1 : 2 ), (int)setrange.size() );
    CHECK( setrange.find( file_set ) != setrange.end() );
Definition at line 558 of file h5partial.cpp.
References CHECK_EQUAL, CHECK_ERR, create_mesh(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::get_entities_by_type(), ID_TAG_NAME, identify_set(), moab::Interface::load_file(), mb, MBVERTEX, NUM_SETS, READ_OPTS, and TEST_FILE.
    ErrorCode rval;
    Core moab;
    for( int id = 1; id <= NUM_SETS; ++id )
        rval = mb.load_file( TEST_FILE, 0, READ_OPTS, ID_TAG_NAME, &id, 1 );CHECK_ERR( rval );
        Range verts;
        int act_id = identify_set( mb, verts );
        CHECK_EQUAL( id, act_id );
Definition at line 73 of file h5partial.cpp.
References test_read_nodes_common().
    test_read_nodes_common( 1, false );
Definition at line 79 of file h5partial.cpp.
    test_read_nodes_common( 1, true );
Definition at line 779 of file h5partial.cpp.
References moab::Interface::add_entities(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_SUCCESS, MB_TAG_EXCL, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBHEX, MBPOLYHEDRON, MBTRI, READ_OPTS, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, moab::Interface::UNION, and moab::Interface::write_file().
    ErrorCode rval;
    Core instance;
    // create a 2x2x1 block of hexes, splitting each hex face
    // into two triangles to form an 12-sided polyhedron
    EntityHandle verts[18], hexes[4];
    double coords[18][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 2, 0, 0 }, { 0, 1, 0 }, { 1, 1, 0 }, { 2, 1, 0 },
                             { 0, 0, 1 }, { 1, 0, 1 }, { 2, 0, 1 }, { 0, 1, 1 }, { 1, 1, 1 }, { 2, 1, 1 },
                             { 0, 0, 2 }, { 1, 0, 2 }, { 2, 0, 2 }, { 0, 1, 2 }, { 1, 1, 2 }, { 2, 1, 2 } };
    int hexconn[4][8]    = { { 0, 1, 4, 3, 6, 7, 10, 9 },
                          { 1, 2, 5, 4, 7, 8, 11, 10 },
                          { 6, 7, 10, 9, 12, 13, 16, 15 },
                          { 7, 8, 11, 10, 13, 14, 17, 16 } };
    for( int i = 0; i < 18; ++i )
        rval = mb.create_vertex( coords[i], verts[i] );CHECK_ERR( rval );
    for( int i = 0; i < 4; ++i )
        EntityHandle conn[8];
        for( int j = 0; j < 8; ++j )
            conn[j] = verts[hexconn[i][j]];
        rval = mb.create_element( MBHEX, conn, 8, hexes[i] );CHECK_ERR( rval );
    Tag tri_tag;
    rval = mb.tag_get_handle( "tris", 2, MB_TYPE_HANDLE, tri_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval );
    std::vector< EntityHandle > quads;
    EntityHandle tris[12], poly[4];
        quads.clear();
        rval = mb.get_adjacencies( &hexes[i], 1, 2, true, quads );CHECK_ERR( rval );
        CHECK_EQUAL( 6, (int)quads.size() );
        for( int j = 0; j < 6; ++j )
            rval = mb.tag_get_data( tri_tag, &quads[j], 1, tris + 2 * j );
            if( MB_SUCCESS == rval ) continue;
            CHECK_EQUAL( MB_TAG_NOT_FOUND, rval );
            int len;
            rval = mb.get_connectivity( quads[j], conn, len );CHECK_ERR( rval );
            CHECK_EQUAL( 4, len );
            EntityHandle tri_conn[2][3] = { { conn[0], conn[1], conn[2] }, { conn[2], conn[3], conn[0] } };
            rval                        = mb.create_element( MBTRI, tri_conn[0], 3, tris[2 * j] );CHECK_ERR( rval );
            rval = mb.create_element( MBTRI, tri_conn[1], 3, tris[2 * j + 1] );CHECK_ERR( rval );
            rval = mb.tag_set_data( tri_tag, &quads[j], 1, tris + 2 * j );CHECK_ERR( rval );
        rval = mb.create_element( MBPOLYHEDRON, tris, 12, poly[i] );CHECK_ERR( rval );
    Range all_tri;
    rval = mb.get_entities_by_type( 0, MBTRI, all_tri );CHECK_ERR( rval );
    CHECK_EQUAL( 40, (int)all_tri.size() );
    rval = mb.delete_entities( hexes, 4 );CHECK_ERR( rval );
    rval = mb.delete_entities( &quads[0], quads.size() );CHECK_ERR( rval );
    rval = mb.create_meshset( 0, sets[0] );CHECK_ERR( rval );
    rval = mb.add_entities( sets[0], poly, 2 );CHECK_ERR( rval );
    rval = mb.create_meshset( 0, sets[1] );CHECK_ERR( rval );
    rval = mb.add_entities( sets[1], poly + 2, 2 );CHECK_ERR( rval );
    Tag id_tag;
    int ids[2] = { 2, 3 };
    Range rpoly;
    rval = mb.get_entities_by_type( 0, MBPOLYHEDRON, rpoly );CHECK_ERR( rval );
    CHECK_EQUAL( 2, (int)rpoly.size() );
    Range polyverts;
    rval = mb.get_adjacencies( rpoly, 0, false, polyverts, Interface::UNION );CHECK_ERR( rval );
    CHECK_EQUAL( 12, (int)polyverts.size() );
    for( Range::iterator it = polyverts.begin(); it != polyverts.end(); ++it )
        double coords2[3];
        rval = mb.get_coords( &*it, 1, coords2 );CHECK_ERR( rval );
        CHECK( coords2[0] > -1e-12 && coords2[0] - 2 < 1e-12 );
        CHECK( coords2[1] > -1e-12 && coords2[1] - 1 < 1e-12 );
        CHECK( coords2[2] > -1e-12 && coords2[2] - 1 < 1e-12 );
Definition at line 666 of file h5partial.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, CHECK_REAL_EQUAL, check_tag(), create_mesh(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), ID_TAG_NAME, moab::Interface::load_file(), LOGICAL_NAME, mb, MB_TAG_DENSE, MB_TYPE_OPAQUE, MBVERTEX, READ_OPTS, moab::Interface::tag_get_data(), and TEST_FILE.
    ErrorCode rval;
    Core moab;
    Tag tag = check_tag( mb, LOGICAL_NAME, MB_TAG_DENSE, MB_TYPE_OPAQUE, 2 * sizeof( int ) );
    Range verts;
        double coords[3];
        int data[2];
        CHECK_REAL_EQUAL( coords[0], (double)data[0], 1e-12 );
        CHECK_REAL_EQUAL( coords[1], (double)data[1], 1e-12 );
Definition at line 1462 of file h5partial.cpp.
References CHECK_ERR, ErrorCode, GEOM_DIMENSION_TAG_NAME, GLOBAL_ID_TAG_NAME, moab::ReadHDF5::read_tag_values(), TEST_FILE, and write_id_test_file().
    const int three                = 3;
    ReaderIface::IDTag vols        = { GEOM_DIMENSION_TAG_NAME, &three, 1 };
    ReaderIface::SubsetList subset = { &vols, 1, 0, 0 };
    Core moab;
    ErrorCode rval;
    rval = reader.read_tag_values( TEST_FILE, GLOBAL_ID_TAG_NAME, opts, values, &subset );
Read in the sets contained in a set. Should read all sets containing read elements or nodes and all sets that are contained the the specified "read" set. Test the later here.
Definition at line 881 of file h5partial.cpp.
References moab::Interface::add_entities(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::Interface::delete_mesh(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::find(), moab::Range::front(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), id_tag, ID_TAG_NAME, moab::Interface::load_file(), mb, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MESHSET_SET, READ_OPTS, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
    ErrorCode rval;
    Core instance;
    Tag id_tag;
    // create sets and assign an ID to each
    const int len = 5;
    EntityHandle set[2 * len + 2];
    for( int i = 0; i < 2 * len + 2; ++i )
        rval = mb.create_meshset( MESHSET_SET, set[i] );CHECK_ERR( rval );
        int id = i + 1;
        rval   = mb.tag_set_data( id_tag, set + i, 1, &id );CHECK_ERR( rval );
    // make set containment as follows (values are assigned IDs):
    int cont_ids[2][len] = { { 3, 4, 5, 9, 10 }, { 6, 7, 8, 11, 12 } };
        EntityHandle contents[len] = { set[cont_ids[i][0] - 1], set[cont_ids[i][1] - 1], set[cont_ids[i][2] - 1],
                                       set[cont_ids[i][3] - 1], set[cont_ids[i][4] - 1] };
        rval                       = mb.add_entities( set[i], contents, len );CHECK_ERR( rval );
        EntityHandle file;
        int id = i + 1;
        rval   = mb.load_file( TEST_FILE, &file, READ_OPTS ";SETS=NONE", ID_TAG_NAME, &id, 1 );CHECK_ERR( rval );
        // check that the total number of sets read is as expected
        Range sets;
        rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval );
        Range::iterator it = sets.find( file );
        if( it != sets.end() ) sets.erase( it );
        CHECK_EQUAL( len + 1, (int)sets.size() );
        // check that we read in the set specified by ID to the reader
        sets.clear();
        const void* data[] = { &id };
        rval               = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &id_tag, data, 1, sets );CHECK_ERR( rval );
        CHECK_EQUAL( 1, (int)sets.size() );
        // check that it contains the expected sets
        EntityHandle owner = sets.front();
        sets.clear();
        rval = mb.get_entities_by_type( owner, MBENTITYSET, sets );CHECK_ERR( rval );
        CHECK_EQUAL( len, (int)sets.size() );
        std::vector< int > expected( cont_ids[i], cont_ids[i] + len );
        std::vector< int > actual( len );
        rval = mb.tag_get_data( id_tag, sets, &actual[0] );CHECK_ERR( rval );
        std::sort( expected.begin(), expected.end() );
        std::sort( actual.begin(), actual.end() );
        CHECK( expected == actual );
void test_read_sides ( )
Definition at line 1325 of file h5partial.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), id_tag, ID_TAG_NAME, INT, moab::Interface::load_file(), MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBEDGE, MBQUAD, MBVERTEX, MESHSET_SET, READ_OPTS, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, moab::Interface::UNION, and moab::Interface::write_file().
    ErrorCode rval;
    Core instance;
    // create 4x4 grid of quads with edges
    const int INT = 4;
    EntityHandle verts[INT + 1][INT + 1];
    for( int j = 0; j <= INT; ++j )
        for( int i = 0; i <= INT; ++i )
            rval             = mb.create_vertex( coords, verts[INT - j][i] );CHECK_ERR( rval );
    EntityHandle quads[INT][INT];
    for( int j = 0; j < INT; ++j )
            EntityHandle conn[4] = { verts[INT - j][i], verts[INT - j][i + 1], verts[INT - j - 1][i + 1],
                                     verts[INT - j - 1][i] };
            rval                 = mb.create_element( MBQUAD, conn, 4, quads[INT - j - 1][i] );CHECK_ERR( rval );
    Range edges;
    rval = mb.get_adjacencies( &quads[0][0], INT * INT, 1, true, edges, Interface::UNION );CHECK_ERR( rval );
    CHECK_EQUAL( 40, (int)edges.size() );
    // group quads into two sets
    rval = mb.add_entities( sets[0], quads[0], INT );CHECK_ERR( rval );
    rval = mb.add_entities( sets[1], quads[1], INT );CHECK_ERR( rval );
    rval = mb.add_entities( sets[0], quads[2], INT );CHECK_ERR( rval );
    rval = mb.add_entities( sets[1], quads[3], INT );CHECK_ERR( rval );
    // assign IDS
    Tag id_tag;
    int ids[2] = { 4, 5 };
    // write mesh
    // read first set back in
    int count;
    rval = mb.get_number_entities_by_type( 0, MBVERTEX, count );CHECK_ERR( rval );
    CHECK_EQUAL( ( INT + 1 ) * INT, count );
    rval = mb.get_number_entities_by_type( 0, MBQUAD, count );CHECK_ERR( rval );
    CHECK_EQUAL( INT * INT / 2, count );
    rval = mb.get_number_entities_by_type( 0, MBEDGE, count );CHECK_ERR( rval );
    CHECK_EQUAL( 2 * ( INT + 1 ) + INT * INT, count );
    // check edges adjacent to each quad
    Range elems;
    rval = mb.get_entities_by_type( 0, MBQUAD, elems );CHECK_ERR( rval );
    for( Range::iterator it = elems.begin(); it != elems.end(); ++it )
        edges.clear();
        rval = mb.get_adjacencies( &*it, 1, 1, false, edges );CHECK_ERR( rval );
        CHECK_EQUAL( 4, (int)edges.size() );
Definition at line 738 of file h5partial.cpp.
References CHECK_EQUAL, CHECK_ERR, create_mesh(), ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), ID_TAG_NAME, identify_set(), moab::Interface::load_file(), mb, MBQUAD, MBQUAD_INT, MBVERTEX, NUM_SETS, READ_OPTS, and TEST_FILE.
    ErrorCode rval;
    Core moab;
    create_mesh( false, false, true, false );
    int id = 5;
    Range verts;
    int id2 = identify_set( mb, verts );
    CHECK_EQUAL( id, id2 );
    int elems;
    rval = mb.get_number_entities_by_type( 0, MBQUAD, elems );CHECK_ERR( rval );
    CHECK_EQUAL( MBQUAD_INT * MBQUAD_INT / NUM_SETS, elems );
Definition at line 758 of file h5partial.cpp.
    ErrorCode rval;
    Core moab;
    create_mesh( false, false, false, true );
    int id = 1;  // NOTE: this test will only succeed for ID == 1
    Range verts;
    int elems;
Definition at line 578 of file h5partial.cpp.
References moab::Range::back(), CHECK, CHECK_EQUAL, CHECK_ERR, create_mesh(), moab::Interface::create_meshset(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::find(), moab::Range::front(), moab::Interface::get_entities_by_type(), ID_TAG_NAME, identify_set(), moab::Interface::load_file(), mb, MBENTITYSET, MESHSET_SET, READ_OPTS, moab::Range::size(), and TEST_FILE.
    ErrorCode rval;
    Core moab;
    int ids[2] = { 2, 8 };
    rval = mb.load_file( TEST_FILE, &file_set, READ_OPTS, ID_TAG_NAME, ids, 2 );CHECK_ERR( rval );
    Range sets;
    CHECK_EQUAL( 3, (int)sets.size() );
    Range::iterator it = sets.find( file_set );
    CHECK( it != sets.end() );
    sets.erase( it );
    int id1 = identify_set( mb, sets.front() );
    int id2 = identify_set( mb, sets.back() );
    if( id1 == ids[0] )
        CHECK_EQUAL( ids[1], id2 );
    else
        CHECK_EQUAL( ids[1], id1 );
        CHECK_EQUAL( ids[0], id2 );
Definition at line 97 of file h5partial.cpp.
    test_read_nodes_common( 2, false );
void test_var_len_tag ( )
Definition at line 165 of file h5partial.cpp.
static void vtx_coords ( int  set_id,
int  j,
int  num_sets,
double  coords[3]
) [static]
Definition at line 281 of file h5partial.cpp.
Referenced by test_read_nodes_common().
    int i     = num_sets * j + set_id;
    coords[0] = i;
    coords[1] = i + 0.25;
    coords[2] = i + 0.5;
Definition at line 1401 of file h5partial.cpp.
References CHECK_ERR, moab::Interface::create_meshset(), dim, ErrorCode, expected_vols, GEOM_DIMENSION_TAG_NAME, moab::Interface::globalId_tag(), ID_TAG_NAME, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MESHSET_SET, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TEST_FILE, and moab::Interface::write_file().
Referenced by test_read_ids(), and test_read_partial_ids().
    Core moab;
    ErrorCode rval;
    // create 12 entity sets
    EntityHandle sets[12];
    for( int i = 0; i < 12; ++i )
    // create tag handles
    Tag id = 0, gid = 0, dim = 0;
    mb.tag_get_handle( ID_TAG_NAME, 1, MB_TYPE_INTEGER, id, MB_TAG_SPARSE | MB_TAG_EXCL );
    mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dim, MB_TAG_SPARSE | MB_TAG_EXCL );
    gid = mb.globalId_tag();
    // set ID tag on first 10 sets
    rval = mb.tag_set_data( id, sets, sizeof( expected_ids ) / sizeof( int ), expected_ids );CHECK_ERR( rval );
    // set geom dim on all sets, only three of them have dim == 3
    int num_vol = sizeof( expected_vols ) / sizeof( int );
    int dims[12], ids[12];
    int v = 0;
        dims[i] = i % 3 + 1;
        if( dims[i] == 3 )
            if( v < num_vol )
                ids[i] = expected_vols[v++];
            else
                ids[i] = expected_vols[0];
        else
            ids[i] = 100;
    rval = mb.tag_set_data( gid, sets, 12, ids );CHECK_ERR( rval );
    rval = mb.tag_set_data( dim, sets, 12, dims );CHECK_ERR( rval );
Variable Documentation
const char CENTROID_NAME[] = "centroid"
Definition at line 32 of file h5partial.cpp.
Referenced by create_mesh(), and test_read_double_tag().
const int expected_ids[] = { 2, 4, 6, 8, 10, 12, 14, 16, 18 }
Definition at line 1398 of file h5partial.cpp.
const int expected_vols[] = { 3, 7, 10 }
Definition at line 1399 of file h5partial.cpp.
Referenced by write_id_test_file().
const char LOGICAL_NAME[] = "logical"
Definition at line 31 of file h5partial.cpp.
Referenced by create_mesh(), and test_read_opaque_tag().
const char* set_read_opts[] = { "SETS", "CONTENTS", "NONE" }
Definition at line 1023 of file h5partial.cpp.
Referenced by test_gather_sets_common(), and test_gather_sets_ranged().
Definition at line 30 of file h5partial.cpp.
Referenced by create_mesh(), identify_set(), and test_read_containing_sets().
