h5regression.cpp File Reference
#include "moab/Core.hpp"
#include "TestUtil.hpp"
#include "moab/Range.hpp"
#include "moab/ReadUtilIface.hpp"
#include "WriteHDF5.hpp"
#include "moab/FileOptions.hpp"
#include <algorithm>
#include <iostream>
#include <sstream>
#include <cstdlib>
#include <cmath>
+ Include dependency graph for h5regression.cpp:
Functions
void test_write_invalid_elem ()
void test_write_read_many_tags ()
int main (int argc, char *argv[])
Variables
const char filename [] = "bad.h5m"
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 25 of file h5regression.cpp.
References moab::fail(), RUN_TEST, test_write_invalid_elem(), and test_write_read_many_tags().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#else
    argv[0] = argv[argc - argc];  // warning in serial
#endif
    int exitval = 0;
    exitval += RUN_TEST( test_write_invalid_elem );
    exitval += RUN_TEST( test_write_read_many_tags );
    fail = MPI_Finalize();
#endif
    return exitval;
Definition at line 46 of file h5regression.cpp.
References CHECK, CHECK_ERR, ErrorCode, filename, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_SUCCESS, mbcore, MBTRI, moab::Interface::query_interface(), and moab::WriteHDF5::write_file().
Referenced by main().
    Core mbcore;
    Interface& moab         = mbcore;
    ReadUtilIface* readtool = 0;
    ErrorCode rval;
    rval = moab.query_interface( readtool );CHECK_ERR( rval );
    CHECK( readtool != 0 );
    // create two nodes
    EntityHandle first_node;
    std::vector< double* > coords;
    rval = readtool->get_node_coords( 3, 2, 1, first_node, coords );CHECK_ERR( rval );
    // Cppcheck warning (false positive): variable coords is assigned a value that is never used
    coords[0][0] = coords[0][1] = 0.0;
    coords[1][0] = coords[1][1] = 0.0;
    coords[2][0] = coords[2][1] = 0.0;
    // create a triangle with an invalid node handle for its
    // third vertex
    EntityHandle tri;
    EntityHandle* conn = 0;
    rval               = readtool->get_element_connect( 1, 3, MBTRI, 1, tri, conn );CHECK_ERR( rval );
    conn[0] = first_node;      // valid
    conn[1] = first_node + 1;  // valid
    conn[2] = first_node + 2;  // invalid
    // try to write the file (should fail)
    WriteHDF5 writer( &moab );
    FileOptions opts( 0 );
    rval = writer.write_file( filename, true, opts, 0, 0, std::vector< std::string >() );
    CHECK( MB_SUCCESS != rval );
Definition at line 81 of file h5regression.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, filename, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbcore, size, t, moab::Interface::tag_delete(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), TagType, and moab::Interface::write_file().
    const int N = 200;
    Core mbcore;
    Interface& mb = mbcore;
    ErrorCode rval;
    double coords[3] = { 0, 0, 0 };
    EntityHandle node;
    rval = mb.create_vertex( coords, node );CHECK_ERR( rval );
    // create a lot of tags
    std::vector< Tag > tags;
    for( int i = 0; i < N; ++i )
        Tag t;
        std::ostringstream name( "IntTag" );
        name << i;
        rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t,
                                  ( i % 2 ? MB_TAG_SPARSE : MB_TAG_DENSE ) | MB_TAG_EXCL, &i );CHECK_ERR( rval );
        tags.push_back( t );
    // write the file
    rval = mb.write_file( filename, "MOAB" );CHECK_ERR( rval );
    // clear moab instance
    rval = mb.delete_mesh();CHECK_ERR( rval );
        rval = mb.tag_delete( tags[i] );CHECK_ERR( rval );
    // read the file
    rval = mb.load_file( filename );CHECK_ERR( rval );
    remove( filename );
    // check that we have the expected tags
        Tag t;
        name << i;
        rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t );CHECK_ERR( rval );
        TagType storage;
        rval = mb.tag_get_type( t, storage );CHECK_ERR( rval );
        CHECK_EQUAL( ( i % 2 ) ? MB_TAG_SPARSE : MB_TAG_DENSE, storage );
        DataType type;
        rval = mb.tag_get_data_type( t, type );CHECK_ERR( rval );
        CHECK_EQUAL( MB_TYPE_INTEGER, type );
        int size;
        rval = mb.tag_get_length( t, size );CHECK_ERR( rval );
        CHECK_EQUAL( 1, size );
        int def;
        rval = mb.tag_get_default_value( t, &def );CHECK_ERR( rval );
        CHECK_EQUAL( i, def );
Variable Documentation
const char filename[] = "bad.h5m"
Definition at line 20 of file h5regression.cpp.
