h5varlen.cpp File Reference
#include "moab/Core.hpp"
#include "TestUtil.hpp"
#include "moab/Range.hpp"
#include <cstdlib>
#include <cstdio>
+ Include dependency graph for h5varlen.cpp:
Defines
#define CHECK_ERR_FILE(ERRCODE, FILENAME)
Functions
void test_var_length_no_data ()
void test_var_length_data ()
void test_var_length_data_big ()
void test_var_length_big_data ()
void test_var_length_opaque ()
void test_var_length_mesh_data ()
void test_var_length_default_data ()
void test_var_length_mesh_opaque ()
void test_var_length_default_opaque ()
void test_var_length_handle_tag ()
void test_huge_var_length ()
void create_mesh (Interface &mb)
void create_big_mesh (Interface &mb)
void compare_tags (const char *name, Interface &mb1, Interface &mb2)
void read_write (const char *filename, Interface &write, Interface &reader)
int main (int argc, char *argv[])
void test_var_length_data_common (const char *filename, Interface &mb1, bool opaque=false)
void calculate_big_value (Interface &moab, EntityHandle vert, size_t size, double *data)
void test_global_value_common (bool mesh_value)
void test_global_opaque_common (bool mesh_value)
void create_structured_quad_mesh (Interface &mb, int x, int y)
Variables
static bool keep_files = false
Define Documentation
#define CHECK_ERR_FILE (   ERRCODE,
  FILENAME
Value:
do        \
        if( MB_SUCCESS != ( ERRCODE ) && !keep_files ) remove( FILENAME ); \
        CHECK_ERR( ERRCODE );                                              \
        while( false )
Definition at line 46 of file h5varlen.cpp.
Function Documentation
void calculate_big_value ( Interface moab,
EntityHandle  vert,
size_t  size,
double *  data
Definition at line 195 of file h5varlen.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Interface::get_coords(), and size.
Referenced by test_var_length_big_data().
    // Make values like Fibonacci numbers, except use X and Y coords
    // rather than 0 and 1 as first two values.
    CHECK( size >= 3 );
    ErrorCode rval = moab.get_coords( &vert, 1, data );CHECK_ERR( rval );
    for( size_t j = 2; j < size; ++j )
        data[j] = data[j - 2] + data[j - 1];CHECK_ERR( rval );
void compare_tags ( const char *  name,
Interface mb1,
Interface mb2
Definition at line 625 of file h5varlen.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, MB_VARIABLE_DATA_LENGTH, size, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), and TagType.
    ErrorCode rval;
    Tag tag1, tag2;
    rval = mb1.tag_get_handle( name, 0, MB_TYPE_OPAQUE, tag1, MB_TAG_ANY );CHECK_ERR( rval );
    rval = mb2.tag_get_handle( name, 0, MB_TYPE_OPAQUE, tag2, MB_TAG_ANY );CHECK_ERR( rval );
    int size;
    CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, mb1.tag_get_length( tag1, size ) );
    CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, mb2.tag_get_length( tag2, size ) );
    TagType storage1, storage2;
    rval = mb1.tag_get_type( tag1, storage1 );CHECK_ERR( rval );
    rval = mb2.tag_get_type( tag2, storage2 );CHECK_ERR( rval );
    CHECK_EQUAL( storage1, storage2 );
    DataType type1, type2;
    rval = mb1.tag_get_data_type( tag1, type1 );CHECK_ERR( rval );
    rval = mb2.tag_get_data_type( tag2, type2 );CHECK_ERR( rval );
    const void *defval1, *defval2;
    int defsize1, defsize2;
    ErrorCode rval1 = mb1.tag_get_default_value( tag1, defval1, defsize1 );
    ErrorCode rval2 = mb2.tag_get_default_value( tag2, defval2, defsize2 );
    if( MB_SUCCESS == rval1 )
        CHECK_ERR( rval2 );
        CHECK_EQUAL( defsize1, defsize2 );
        CHECK( !memcmp( defval1, defval2, defsize1 ) );
    else if( MB_ENTITY_NOT_FOUND == rval1 || MB_TAG_NOT_FOUND == rval1 )
        CHECK_EQUAL( rval1, rval2 );
    else
        CHECK_ERR( rval1 );
void create_big_mesh ( Interface mb)
Definition at line 620 of file h5varlen.cpp.
References create_structured_quad_mesh().
Referenced by test_var_length_data_big().
    create_structured_quad_mesh( mb, 300, 300 );
void create_mesh ( Interface mb)
Definition at line 615 of file h5varlen.cpp.
    create_structured_quad_mesh( mb, 2, 2 );
void create_structured_quad_mesh ( Interface mb,
int  x,
int  y
Definition at line 588 of file h5varlen.cpp.
References CHECK_ERR, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, and MBQUAD.
Referenced by create_big_mesh(), and create_mesh().
    ErrorCode rval;
    const double z = 2.1;
    std::vector< EntityHandle > verts( ( x + 1 ) * ( y + 1 ) );
    for( int i = 0; i <= x; ++i )
        for( int j = 0; j <= y; ++j )
            double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), static_cast< double >( z ) };
            rval             = mb.create_vertex( coords, verts[i + ( x + 1 ) * j] );CHECK_ERR( rval );
    std::vector< EntityHandle > elems( x * y );
    for( int i = 0; i < x; ++i )
        for( int j = 0; j < y; ++j )
            EntityHandle conn[4] = { verts[i + ( x + 1 ) * j], verts[i + 1 + ( x + 1 ) * j],
                                     verts[i + 1 + ( x + 1 ) * ( j + 1 )], verts[i + ( x + 1 ) * ( j + 1 )] };
            rval                 = mb.create_element( MBQUAD, conn, 4, elems[i + x * j] );CHECK_ERR( rval );
int main ( int  argc,
char *  argv[]
Definition at line 53 of file h5varlen.cpp.
References moab::fail(), keep_files, RUN_TEST, test_huge_var_length(), test_var_length_big_data(), test_var_length_data(), test_var_length_data_big(), test_var_length_default_data(), test_var_length_default_opaque(), test_var_length_handle_tag(), test_var_length_mesh_data(), test_var_length_mesh_opaque(), test_var_length_no_data(), and test_var_length_opaque().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#endif
    if( argc != 1 )
        if( argc != 2 || strcmp( argv[1], "-k" ) != 0 )
            fprintf( stderr, "Usage: %s [-k]\n", argv[0] );
            abort();
        keep_files = true;
    int err_count = 0;
    err_count += RUN_TEST( test_var_length_no_data );
    err_count += RUN_TEST( test_var_length_data );
    err_count += RUN_TEST( test_var_length_big_data );
    err_count += RUN_TEST( test_var_length_opaque );
    err_count += RUN_TEST( test_var_length_mesh_data );
    err_count += RUN_TEST( test_var_length_default_data );
    err_count += RUN_TEST( test_var_length_mesh_opaque );
    err_count += RUN_TEST( test_var_length_default_opaque );
    err_count += RUN_TEST( test_var_length_handle_tag );
    err_count += RUN_TEST( test_var_length_data_big );
    err_count += RUN_TEST( test_huge_var_length );
    fail = MPI_Finalize();
#endif
    return err_count;
void read_write ( const char *  filename,
Interface write,
Interface reader
void test_global_opaque_common ( bool  mesh_value)
Definition at line 387 of file h5varlen.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, compare_tags(), create_mesh(), ErrorCode, mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_VARLEN, MB_TYPE_OPAQUE, read_write(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_by_ptr().
Referenced by test_var_length_default_opaque(), and test_var_length_mesh_opaque().
    ErrorCode rval;
    Core moab;
    Interface& mb = moab;
    create_mesh( mb );
    const char data[] = { 'J', 'A', 'S', 'O', 'N' };
    const int datalen = sizeof( data );
    CHECK_EQUAL( 5, datalen );
    // create tag
    Tag tag                 = 0;
    const void* default_val = mesh_value ? 0 : data;
    int default_val_size    = mesh_value ? 0 : datalen;
    rval                    = mb.tag_get_handle( "opaque_tag", default_val_size, MB_TYPE_OPAQUE, tag,
                                                 MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL, default_val );CHECK_ERR( rval );
    // if doing mesh tag, set it
    if( mesh_value )
        const void* ptrarr[]    = { data };
        const EntityHandle root = 0;
        rval                    = mb.tag_set_by_ptr( tag, &root, 1, ptrarr, &datalen );CHECK_ERR( rval );
    // write and read file
    Core moab2;
    Interface& mb2 = moab2;
    read_write( mesh_value ? "test_var_length_mesh_opaque.h5m" : "test_var_length_default_opaque.h5m", mb, mb2 );
    compare_tags( "opaque_tag", mb, mb2 );
    // get tag handles
    tag  = 0;
    rval = mb2.tag_get_handle( "opaque_tag", 0, MB_TYPE_OPAQUE, tag );CHECK_ERR( rval );
    // get tag data
    int tag_size = 0;
    const void* ptrs[1];
    if( mesh_value )
        rval                    = mb2.tag_get_by_ptr( tag, &root, 1, ptrs, &tag_size );CHECK_ERR( rval );
    else
        rval = mb2.tag_get_default_value( tag, ptrs[0], tag_size );CHECK_ERR( rval );
    // check size
    CHECK_EQUAL( datalen, tag_size );
    CHECK( ptrs[0] != NULL );
    // check values
    const char* tag_data = reinterpret_cast< const char* >( ptrs[0] );
    for( int i = 0; i < datalen; ++i )
        CHECK_EQUAL( data[i], tag_data[i] );
void test_global_value_common ( bool  mesh_value)
Definition at line 271 of file h5varlen.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, compare_tags(), coord_tag, create_mesh(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MBVERTEX, read_write(), size, moab::Range::size(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), and moab::Interface::type_from_handle().
Referenced by test_var_length_default_data(), and test_var_length_mesh_data().
    Core moab;
    create_mesh( mb );
    // get three vertices
    Range vertices;
    ErrorCode rval = mb.get_entities_by_type( 0, MBVERTEX, vertices );CHECK_ERR( rval );
    CHECK( vertices.size() >= 3 );
    EntityHandle handles[3];
    Range::const_iterator i = vertices.begin();
    handles[0]              = *i;
    ++i;
    handles[1] = *i;
    ++i;
    handles[2] = *i;
    ++i;
    // get vertex coordinates
    double coords[9];
    rval = mb.get_coords( handles, 3, coords );CHECK_ERR( rval );
    // create tag to hold vertex data
    Tag handle_tag       = 0;
    void* default_val    = mesh_value ? 0 : handles;
    int default_val_size = mesh_value ? 0 : 3;
    rval                 = mb.tag_get_handle( "handle_tag", default_val_size, MB_TYPE_HANDLE, handle_tag,
    // create tag to hold vertex coordinates
    Tag coord_tag    = 0;
    default_val      = mesh_value ? 0 : coords;
    default_val_size = mesh_value ? 0 : 9;
    rval             = mb.tag_get_handle( "coord_tag", default_val_size, MB_TYPE_DOUBLE, coord_tag,
                                          MB_TAG_SPARSE | MB_TAG_VARLEN | MB_TAG_EXCL, default_val );CHECK_ERR( rval );
    if( mesh_value )
        int size                = 3;
        const void* ptrarr[]    = { handles };
        rval                    = mb.tag_set_by_ptr( handle_tag, &root, 1, ptrarr, &size );CHECK_ERR( rval );
        size      = 9;
        ptrarr[0] = coords;
        rval      = mb.tag_set_by_ptr( coord_tag, &root, 1, ptrarr, &size );CHECK_ERR( rval );
    Core moab2;
    read_write( mesh_value ? "test_var_length_mesh_data.h5m" : "test_var_length_default_data.h5m", mb, mb2 );
    compare_tags( "handle_tag", mb, mb2 );
    compare_tags( "coord_tag", mb, mb2 );
    // get tag handles
    handle_tag = coord_tag = 0;
    rval                   = mb2.tag_get_handle( "handle_tag", 0, MB_TYPE_HANDLE, handle_tag );CHECK_ERR( rval );
    rval = mb2.tag_get_handle( "coord_tag", 0, MB_TYPE_DOUBLE, coord_tag );CHECK_ERR( rval );
    // get tag data
    int handle_tag_size = 0, coord_tag_size = 0;
    const void* ptrs[2];
    if( mesh_value )
        rval                    = mb2.tag_get_by_ptr( handle_tag, &root, 1, ptrs, &handle_tag_size );CHECK_ERR( rval );
        rval = mb2.tag_get_by_ptr( coord_tag, &root, 1, ptrs + 1, &coord_tag_size );CHECK_ERR( rval );
    else
        rval = mb2.tag_get_default_value( handle_tag, ptrs[0], handle_tag_size );CHECK_ERR( rval );
        rval = mb2.tag_get_default_value( coord_tag, ptrs[1], coord_tag_size );CHECK_ERR( rval );
    // check expected sizes
    CHECK_EQUAL( 3, handle_tag_size );
    CHECK_EQUAL( 9, coord_tag_size );
    CHECK( ptrs[1] != NULL );
    // check valid handles
    const EntityHandle* handle_vals = reinterpret_cast< const EntityHandle* >( ptrs[0] );
    CHECK( handle_vals[0] != 0 );
    CHECK( handle_vals[1] != 0 );
    CHECK( handle_vals[2] != 0 );
    CHECK_EQUAL( MBVERTEX, mb2.type_from_handle( handle_vals[0] ) );
    CHECK_EQUAL( MBVERTEX, mb2.type_from_handle( handle_vals[1] ) );
    CHECK_EQUAL( MBVERTEX, mb2.type_from_handle( handle_vals[2] ) );
    // check correct coordinate values
    const double* coord_vals = reinterpret_cast< const double* >( ptrs[1] );
    rval                     = mb2.get_coords( handle_vals, 3, coords );CHECK_ERR( rval );
    CHECK_REAL_EQUAL( coords[0], coord_vals[0], 1e-12 );
    CHECK_REAL_EQUAL( coords[1], coord_vals[1], 1e-12 );
    CHECK_REAL_EQUAL( coords[2], coord_vals[2], 1e-12 );
    CHECK_REAL_EQUAL( coords[3], coord_vals[3], 1e-12 );
    CHECK_REAL_EQUAL( coords[4], coord_vals[4], 1e-12 );
    CHECK_REAL_EQUAL( coords[5], coord_vals[5], 1e-12 );
    CHECK_REAL_EQUAL( coords[6], coord_vals[6], 1e-12 );
    CHECK_REAL_EQUAL( coords[7], coord_vals[7], 1e-12 );
    CHECK_REAL_EQUAL( coords[8], coord_vals[8], 1e-12 );
Definition at line 537 of file h5varlen.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, compare_tags(), create_mesh(), ErrorCode, moab::Interface::get_entities_by_handle(), keep_files, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), and moab::Interface::write_file().
Referenced by main().
    ErrorCode rval;
    Core moab1, moab2;
    Interface &mb1 = moab1, &mb2 = moab2;
    Tag tag;
    Range::const_iterator i;
    create_mesh( mb1 );
    rval = mb1.tag_get_handle( "test_tag", 0, MB_TYPE_DOUBLE, tag, MB_TAG_SPARSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval );
    // Get all entities
    Range range;
    rval = mb1.get_entities_by_handle( 0, range );CHECK_ERR( rval );
    // For each entity, if it is a vertex store its own handle
    // in its tag.  Otherwise store the element connectivity list
    // in the tag.  Skip entity sets.
    EntityHandle v1 = range[0];  // first vertex
    // huge data
    std::vector< double > dataArr;  // larger than the buffer
    int N = 2000;
    dataArr.resize( N );  // size will be 8 * N > bufferSize = 10000 set by option during writing
    for( int j = 0; j < N; j++ )
        dataArr[j] = j;
    const void* ptr = &dataArr[0];
    rval            = mb1.tag_set_by_ptr( tag, &v1, 1, &ptr, &N );CHECK_ERR( rval );
    // second vertex, do a smaller N
    v1    = range[1];
    int M = N - 5;
    ptr   = &dataArr[2];  // start with 2
    rval  = mb1.tag_set_by_ptr( tag, &v1, 1, &ptr, &M );CHECK_ERR( rval );
    // write with a smaller buffer, size controlled by option to test
    const char* writeOptions = "BUFFER_SIZE=4000;DEBUG_IO=5";
    rval                     = mb1.write_file( "test_huge_var_tag.h5m", NULL, writeOptions );CHECK_ERR( rval );
    rval = mb2.load_file( "test_huge_var_tag.h5m" );CHECK_ERR( rval );
    compare_tags( "test_tag", mb1, mb2 );
    // compare some values for the 2nd vertex
    Tag tag2;
    rval = mb2.tag_get_handle( "test_tag", tag2 );CHECK_ERR( rval );
    EntityHandle vertex2 = 2;
    int len2;
    const void* ptr2;
    rval = mb2.tag_get_by_ptr( tag2, &vertex2, 1, &ptr2, &len2 );CHECK_ERR( rval );
    CHECK_EQUAL( len2, M );
    CHECK_REAL_EQUAL( dataArr[2], ( (double*)ptr2 )[0], 0.000000001 );
    if( !keep_files ) remove( "test_huge_var_tag.h5m" );CHECK_ERR( rval );
Definition at line 207 of file h5varlen.cpp.
References moab::Range::begin(), calculate_big_value(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), compare_tags(), create_mesh(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MBVERTEX, read_write(), size, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), and moab::Interface::UNION.
    ErrorCode rval;
    Core moab1, moab2;
    Tag tag;
    create_mesh( mb1 );
    // choose 3 vertices upon which to set data
    Range range;
    rval = mb1.get_entities_by_type( 0, MBVERTEX, range );CHECK_ERR( rval );
    EntityHandle verts[3] = { range.front(), *( range.begin() += range.size() / 3 ),
                              *( range.begin() += 2 * range.size() / 3 ) };
    // set 1-millon value tag data on three vertices
    std::vector< double > data( 1000000 );
    for( int i = 0; i < 3; ++i )
        calculate_big_value( mb1, verts[i], data.size(), &data[0] );
        const void* ptr = &data[0];
        const int size  = data.size();
        rval            = mb1.tag_set_by_ptr( tag, verts + i, 1, &ptr, &size );CHECK_ERR( rval );
    read_write( "test_var_length_big_data.h5m", mb1, mb2 );
    // check 3 tagged vertices
    rval = mb2.tag_get_handle( "test_tag", 0, MB_TYPE_DOUBLE, tag );CHECK_ERR( rval );
    range.clear();
    rval = mb2.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, range, Interface::UNION );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)3, range.size() );
    // check tag values
    for( Range::const_iterator i = range.begin(); i != range.end(); ++i )
        // calculate expected value
        const EntityHandle h = *i;
        calculate_big_value( mb2, h, data.size(), &data[0] );
        // get actual value
        const void* ptr;
        int size;
        rval = mb2.tag_get_by_ptr( tag, &h, 1, &ptr, &size );CHECK_ERR( rval );
        CHECK_EQUAL( data.size(), (size_t)size );
        // compare values
        const double* act_data = reinterpret_cast< const double* >( ptr );
        int wrong_count        = 0;
        for( size_t j = 0; j < data.size(); ++j )
            if( act_data[j] != data[j] ) ++wrong_count;
        CHECK_EQUAL( 0, wrong_count );
Definition at line 181 of file h5varlen.cpp.
References create_mesh(), and test_var_length_data_common().
    Core moab;
    create_mesh( moab );
    test_var_length_data_common( "test_var_length_data.h5m", moab );
Definition at line 188 of file h5varlen.cpp.
References create_big_mesh(), and test_var_length_data_common().
    Core moab;
    create_big_mesh( moab );
    test_var_length_data_common( "test_var_length_data_big.h5m", moab );
void test_var_length_data_common ( const char *  filename,
Interface mb1,
bool  opaque = false
Definition at line 106 of file h5varlen.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), compare_tags(), moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, read_write(), size, moab::subtract(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), and moab::Interface::type_from_handle().
Referenced by test_var_length_data(), test_var_length_data_big(), and test_var_length_opaque().
    // create tag
    ErrorCode rval;
    Tag tag;
    DataType type = opaque ? MB_TYPE_OPAQUE : MB_TYPE_INTEGER;
    rval          = mb1.tag_get_handle( "test_tag", 0, type, tag, MB_TAG_EXCL | MB_TAG_VARLEN | MB_TAG_SPARSE );CHECK_ERR( rval );
    // get all entities
    Range entities;
    rval = mb1.get_entities_by_handle( 0, entities );CHECK_ERR( rval );
    // Set tag data.
    // Tag data will be list of integer data as follows:
    //   number of values (counting this value)
    //   step, 2*step, 3*step, ...
    for( Range::const_iterator i = entities.begin(); i != entities.end(); ++i )
        // generate some data to write
        int num_values   = h % 6 + 1;
        EntityType etype = mb1.type_from_handle( h );
        int step         = ( h % 2 ) ? 1 + (int)etype : -1 - (int)etype;
        std::vector< int > tag_data( num_values, num_values );
        for( int j = 1; j < num_values; ++j )
            tag_data[j] = j * step;
        // set tag data
        const void* ptrarr[] = { &tag_data[0] };
        if( opaque ) num_values *= sizeof( int );
        rval = mb1.tag_set_by_ptr( tag, &h, 1, ptrarr, &num_values );CHECK_ERR( rval );
    // write and read tag data
    Core moab;
    Interface& mb2 = moab;
    read_write( filename, mb1, mb2 );
    // get new tag handle
    tag  = 0;
    rval = mb2.tag_get_handle( "test_tag", 0, type, tag );CHECK_ERR( rval );
    // check consistency of tag values
    entities.clear();
    mb2.get_entities_by_handle( 0, entities );
    // remove sets created during read/write process
    Range sets;
    mb2.get_entities_by_type( 0, MBENTITYSET, sets );
    entities = subtract( entities, sets );
        // get data
        const void* ptrarr[] = { NULL };
        int size;
        rval = mb2.tag_get_by_ptr( tag, &*i, 1, ptrarr, &size );CHECK_ERR( rval );
        if( opaque )
            CHECK_EQUAL( (size_t)0, size % sizeof( int ) );
            size /= sizeof( int );
        const int* dataptr = reinterpret_cast< const int* >( ptrarr[0] );
        CHECK( NULL != dataptr );
        // check size
        CHECK( size > 0 );
        CHECK_EQUAL( size, dataptr[0] );
        // check other values
        if( size > 2 )
            int step = dataptr[1];
            for( int j = 2; j < size; ++j )
                CHECK_EQUAL( j * step, dataptr[j] );
Definition at line 382 of file h5varlen.cpp.
References test_global_value_common().
Definition at line 451 of file h5varlen.cpp.
References test_global_opaque_common().
Definition at line 456 of file h5varlen.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), compare_tags(), create_mesh(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_handle(), MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_HANDLE, MBENTITYSET, MBVERTEX, read_write(), size, moab::Range::size(), t, moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), moab::Interface::type_from_handle(), and moab::Interface::UNION.
    ErrorCode rval;
    Core moab1, moab2;
    Tag tag;
    create_mesh( mb1 );
    rval = mb1.tag_get_handle( "test_tag", 0, MB_TYPE_HANDLE, tag, MB_TAG_SPARSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval );
    // Get all entities
    Range range;
    size_t num_tagged_entities = 0;
    for( i = range.begin(); i != range.end(); ++i )
        EntityType type = mb1.type_from_handle( h );
        if( type == MBVERTEX )
            const int size  = 1;
            const void* ptr = &h;
            rval            = mb1.tag_set_by_ptr( tag, &h, 1, &ptr, &size );CHECK_ERR( rval );
            ++num_tagged_entities;
        else if( type != MBENTITYSET )
            int size                 = 0;
            const EntityHandle* conn = 0;
            rval                     = mb1.get_connectivity( h, conn, size );CHECK_ERR( rval );
            const void* ptr = conn;
    read_write( "test_var_length_handle_tag.h5m", mb1, mb2 );
    // check number of tagged entities
    rval = mb2.tag_get_handle( "test_tag", 0, MB_TYPE_HANDLE, tag );CHECK_ERR( rval );
    range.clear();
    for( EntityType t = MBVERTEX; t != MBENTITYSET; ++t )
        rval = mb2.get_entities_by_type_and_tag( 0, t, &tag, 0, 1, range, Interface::UNION );CHECK_ERR( rval );
    CHECK_EQUAL( num_tagged_entities, range.size() );
    // check tag values
        const void* ptr;
        int size;
        const EntityHandle* handles = reinterpret_cast< const EntityHandle* >( ptr );
        if( mb2.type_from_handle( h ) == MBVERTEX )
            CHECK_EQUAL( 1, size );
            CHECK_EQUAL( h, *handles );
        else
            int len;
            const EntityHandle* conn;
            rval = mb2.get_connectivity( h, conn, len );CHECK_ERR( rval );
            CHECK_EQUAL( len, size );
            for( int j = 0; j < len; ++j )
                CHECK_EQUAL( conn[j], handles[j] );
Definition at line 377 of file h5varlen.cpp.
Definition at line 446 of file h5varlen.cpp.
Definition at line 92 of file h5varlen.cpp.
References CHECK_ERR, compare_tags(), create_mesh(), ErrorCode, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_VARLEN, MB_TYPE_DOUBLE, read_write(), and moab::Interface::tag_get_handle().
    ErrorCode rval;
    Core moab1, moab2;
    Tag tag;
    create_mesh( mb1 );
    rval = mb1.tag_get_handle( "test_tag", 0, MB_TYPE_DOUBLE, tag, MB_TAG_EXCL | MB_TAG_VARLEN | MB_TAG_DENSE );CHECK_ERR( rval );
    read_write( "test_var_length_no_data.h5m", mb1, mb2 );
Definition at line 264 of file h5varlen.cpp.
    Core moab;
    test_var_length_data_common( "test_var_length_opaque.h5m", moab, true );
Variable Documentation
bool keep_files = false [static]
Definition at line 14 of file h5varlen.cpp.
Referenced by main(), read_write(), and test_huge_var_length().
