hexes_to_gmsh.c
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2006 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 /* Example file for using mhdf interface for reading MOAB native file foramt
00017  *
00018  * Requires libmhdf from MOAB source and HDF5 library
00019  *
00020  * Reads:
00021  *  - all node coordinates
00022  *  - a single group of hexahedral elements
00023  *  - GLOBAL_ID tag if present
00024  * and writes as Gmsh file version 1.0.
00025  *
00026  * Does not contain examples for reading meshsets or
00027  * reading polygon or polyhedron elements.
00028  *
00029  * A simple exorcise:
00030  *    Clean up handling of variable number of dimensions by reading
00031  *    node coordinate data one dimension at a time using
00032  *    mhdf_readNodeCoord
00033  *
00034  * A more complex exorcise:
00035  *    Read meshsets with MATERIAL_SET tag, which MOAB uses to
00036  *    represent element blocks, and assign appropriate element
00037  *    block for each hex in Gmsh file.
00038  *    Hint: look for and read MATERIAL_SET tag first to get list of entities
00039  *          then read set contents for sets with that tag
00040  *          then match hex file ids to lists of set contents
00041  *    Be careful of the mhdf_SET_RANGE_BIT for each set when reading set
00042  *    contents.
00043  */
00044
00045 #include <stdlib.h>
00046 #include <stdio.h>
00047 #include <assert.h>
00048 #include <string.h>
00049
00050 /* mhdf API */
00051 #include "mhdf.h"
00052 /* need constants for native types (e.g. H5T_NATIVE_UINT)*/
00053 #include <H5Tpublic.h>
00054
00055 /* Macro to check return status from mhdf calls.  Exit on error. */
00056 #define CHK_ERR( A )                                             \
00057     do                                                           \
00058     {                                                            \
00059         if( mhdf_isError( A ) )                                  \
00060         {                                                        \
00061             fprintf( stderr, "Error: %s\n", mhdf_message( A ) ); \
00062             exit( 2 );                                           \
00063         }                                                        \
00064     } while( 0 )
00065
00066 int main( int argc, char* argv[] )
00067 {
00068     /* input file */
00069     const char* filename;
00070     mhdf_FileHandle file;
00071     mhdf_Status status;
00072     mhdf_Status* const sptr = &status;
00073     hid_t handle; /* generic handle used to refer to any data block in file */
00074
00075     /* output file */
00076     const char* gmsh_filename;
00077     FILE* gmsh;
00078     unsigned gmsh_type;            /* hexahedral element type number */
00079     double x, y, z;                /* temp storage of node coordinates */
00080     unsigned node_offset, node_id; /* temporary values */
00081     unsigned* connectivity;        /* temporary value */
00082
00083     /* node data */
00084     long numnode;       /* total number of nodes */
00085     long nodestart;     /* file id of first node in list */
00086     int dimension;      /* coordinate values per node */
00087     double* nodecoords; /* interleaved node coordinates */
00088     unsigned* nodeids;  /* GLOBAL_ID value for nodes */
00089     int have_nodeids = 0;
00090
00091     /* hex data */
00092     char* hexgroup = NULL;     /* name of element group containing hexes */
00093     long numhex;               /* total number of hexahedral elements */
00094     long hexstart;             /* file id of first hex in group */
00095     int nodes_per_hex;         /* length of connectivity list for a hex */
00096     unsigned* hexconnectivity; /* hex connectivity data */
00097     unsigned* hexids;          /* GLOBAL_ID value for hexes */
00098     int have_hexids = 0;
00099
00100     /* list of element groups in file */
00101     char** elem_groups;
00102     unsigned num_elem_groups;
00103     char namebuffer[64];
00104
00105     /* tag data for accessing GLOBAL_ID */
00106     int tagsize;                   /* number of values for each entity */
00107     int ts, td, tg;                /* unused tag properties */
00108     int havesparse, havedense;     /* Boolean values */
00109     enum mhdf_TagDataType tagtype; /* base data type of tag */
00110     hid_t sparse_handle[2];        /* handle pair for sparse tag data */
00111     unsigned* sparse_entities;     /* temp storage of sparse tag file ids */
00112     unsigned* sparse_ids;          /* temp storage of GLOBAL_ID values in spasre tag */
00113     long junk, numtag;             /* number of entities for which tag data is available */
00114     long fileid, globalid;         /* temporary values */
00115     long ncount = 0, hcount = 0;   /* temporary count of number of tag values */
00116
00117     /* iteration */
00118     long i;
00119     int j;
00120     unsigned k;
00121
00122     /* process CL args (expect input .h5m file and output .gmsh file name) */
00123     if( argc != 3 )
00124     {
00125         fprintf( stderr, "Usage: %s <input_file> <output_file>\n", argv[0] );
00126         return 1;
00127     }
00128     filename      = argv[1];
00129     gmsh_filename = argv[2];
00130
00131     /* Open the file */
00132     file = mhdf_openFile( filename, 0, 0, sptr );CHK_ERR( sptr );
00133
00134     /* Read node coordinates. */
00135     handle = mhdf_openNodeCoords( file, &numnode, &dimension, &nodestart, sptr );CHK_ERR( sptr );
00136     nodecoords = (double*)malloc( dimension * numnode * sizeof( double ) );
00137     mhdf_readNodeCoords( handle, 0, numnode, nodecoords, sptr );CHK_ERR( sptr );
00138     mhdf_closeData( file, handle, sptr );CHK_ERR( sptr );
00139
00140     /* Find first element group containing hexahedra */
00141     elem_groups = mhdf_getElemHandles( file, &num_elem_groups, sptr );CHK_ERR( sptr );
00142     for( k = 0; k < num_elem_groups; ++k )
00143     {
00144         mhdf_getElemTypeName( file, elem_groups[k], namebuffer, sizeof( namebuffer ), sptr );CHK_ERR( sptr );
00145         if( !hexgroup && !strcmp( mdhf_HEX_TYPE_NAME, namebuffer ) )
00146             hexgroup = strdup( elem_groups[k] );
00147         else
00148             printf( "Skipping element group '%s' containing element of type '%s'\n", elem_groups[k], namebuffer );
00149     }
00150     free( elem_groups );
00151
00152     if( !hexgroup )
00153     {
00154         fprintf( stderr, "No Hexahedra defined in file\n" );
00155         return 4;
00156     }
00157
00158     /* Read Hexahedron connectivity */
00159     handle = mhdf_openConnectivity( file, hexgroup, &nodes_per_hex, &numhex, &hexstart, sptr );CHK_ERR( sptr );
00160     hexconnectivity = (unsigned*)malloc( numhex * nodes_per_hex * sizeof( unsigned ) );
00161     mhdf_readConnectivity( handle, 0, numhex, H5T_NATIVE_UINT, hexconnectivity, sptr );CHK_ERR( sptr );
00162     mhdf_closeData( file, handle, sptr );CHK_ERR( sptr );
00163     /* Note: hex connectivity list contains file-space node IDs, which are
00164              the nodes in the sequence they are read from the file, with
00165              the first node having an ID of 'nodestart' */
00166
00167     /* Check for "GLOBAL_ID" tag */
00168     nodeids = (unsigned*)malloc( numnode * sizeof( unsigned ) );
00169     hexids  = (unsigned*)malloc( numhex * sizeof( unsigned ) );
00170     mhdf_getTagInfo( file, "GLOBAL_ID", &tagtype, &tagsize, &ts, &td, &tg, &havesparse, sptr );
00171
00172     /* If have GLOBAL_ID tag, try to read values for nodes and hexes */
00173     if( !mhdf_isError( sptr ) )
00174     {
00175         /* Check that the tag contains what we expect */
00176         if( tagtype != mhdf_INTEGER || tagsize != 1 )
00177         {
00178             fprintf( stderr, "ERROR: Invalid data type for 'GLOBAL_ID' tag.\n" );
00179             exit( 3 );
00180         }
00181
00182         /* Check for and read dense-format tag data for nodes */
00183         havedense = mhdf_haveDenseTag( file, "GLOBAL_ID", mhdf_node_type_handle(), sptr );CHK_ERR( sptr );
00184         if( havedense )
00185         {
00186             handle = mhdf_openDenseTagData( file, "GLOBAL_ID", mhdf_node_type_handle(), &numtag, sptr );CHK_ERR( sptr );
00187             assert( numtag == numnode );
00188             mhdf_readDenseTag( handle, 0, numtag, H5T_NATIVE_UINT, nodeids, sptr );CHK_ERR( sptr );
00189             mhdf_closeData( file, handle, sptr );CHK_ERR( sptr );
00190             have_nodeids = 1;
00191         }
00192         /* Check for and read dense-format tag data for hexes */
00193         havedense = mhdf_haveDenseTag( file, "GLOBAL_ID", hexgroup, sptr );CHK_ERR( sptr );
00194         if( havedense )
00195         {
00196             handle = mhdf_openDenseTagData( file, "GLOBAL_ID", hexgroup, &numtag, sptr );CHK_ERR( sptr );
00197             assert( numtag == numhex );
00198             mhdf_readDenseTag( handle, 0, numtag, H5T_NATIVE_UINT, hexids, sptr );CHK_ERR( sptr );
00199             mhdf_closeData( file, handle, sptr );CHK_ERR( sptr );
00200             have_hexids = 1;
00201         }
00202         /* Check for and read sparse-format tag data */
00203         if( havesparse )
00204         {
00205             mhdf_openSparseTagData( file, "GLOBAL_ID", &numtag, &junk, sparse_handle, sptr );CHK_ERR( sptr );
00206             sparse_entities = (unsigned*)malloc( numtag * sizeof( unsigned ) );
00207             mhdf_readSparseTagEntities( sparse_handle[0], 0, numtag, H5T_NATIVE_UINT, sparse_entities, sptr );CHK_ERR( sptr );
00208             sparse_ids = (unsigned*)malloc( numtag * sizeof( unsigned ) );
00209             mhdf_readSparseTagValues( sparse_handle[1], 0, numtag, H5T_NATIVE_UINT, sparse_ids, sptr );CHK_ERR( sptr );
00210             mhdf_closeData( file, sparse_handle[0], sptr );CHK_ERR( sptr );
00211             mhdf_closeData( file, sparse_handle[1], sptr );CHK_ERR( sptr );
00212
00213             /* Set hex and node ids from sparse tag data */
00214             for( i = 0; i < numtag; ++i )
00215             {
00216                 fileid   = sparse_entities[i];
00217                 globalid = sparse_ids[i];
00218                 if( fileid >= nodestart && fileid - nodestart < numnode )
00219                 {
00220                     nodeids[fileid - nodestart] = globalid;
00221                     ++ncount;
00222                 }
00223                 else if( fileid >= hexstart && fileid - hexstart < numhex )
00224                 {
00225                     hexids[fileid - hexstart] = globalid;
00226                     ++hcount;
00227                 }
00228             }
00229             free( sparse_ids );
00230             free( sparse_entities );
00231
00232             /* make sure there was an ID for each node and each hex */
00233             if( ncount == numnode ) have_nodeids = 1;
00234             if( hcount == numhex ) have_hexids = 1;
00235
00236         } /* end have sparse tag for GLOBAL_ID */
00237     }     /* end have GLOBAL_ID tag */
00238
00239     /* done with input file */
00240     free( hexgroup );
00241     mhdf_closeFile( file, sptr );CHK_ERR( sptr );
00242
00243     /* if no GLOBAL_ID, just use incrementing values */
00244     if( !have_nodeids )
00245         for( i = 0; i < numnode; ++i )
00246             nodeids[i] = i + 1;
00247     if( !have_hexids )
00248         for( i = 0; i < numhex; ++i )
00249             hexids[i] = i + 1;
00250
00251     /* write out as gmesh file version 1.0 */
00252
00253     /* get gmsh type for hexahedrons */
00254     if( nodes_per_hex == 8 )
00255         gmsh_type = 5;
00256     else if( nodes_per_hex == 27 )
00257         gmsh_type = 12;
00258     else
00259     {
00260         fprintf( stderr, "Cannot store %d node hex in gmsh file.\n", nodes_per_hex );
00261         exit( 4 );
00262     }
00263
00264     /* open file */
00265     gmsh = fopen( gmsh_filename, "w" );
00266
00267     /* Write node data.  If dimension is less than 3,
00268        write zero for other coordinate values.  In the
00269        (highly unlikely) case that dimension is greater
00270        than three, disregard higher-dimension coordinate
00271        values. */
00272     fprintf( gmsh, "$NOD\n" );
00273     fprintf( gmsh, "%lu\n", numnode );
00274     for( i = 0; i < numnode; ++i )
00275     {
00276         x = nodecoords[dimension * i];
00277         y = z = 0.0;
00278         if( dimension > 1 )
00279         {
00280             y = nodecoords[dimension * i + 1];
00281             if( dimension > 2 )
00282             {
00283                 z = nodecoords[dimension * i + 2];
00284             }
00285         }
00286         fprintf( gmsh, "%u %f %f %f\n", nodeids[i], x, y, z );
00287     }
00288
00289     /* Write element connectivity data */
00290     fprintf( gmsh, "$ENDNOD\n$ELM\n" );
00291     fprintf( gmsh, "%lu\n", numhex );
00292     for( i = 0; i < numhex; ++i )
00293     {
00294         fprintf( gmsh, "%u %u 1 1 %d", hexids[i], gmsh_type, nodes_per_hex );
00295         /* connectivity list for this hex */
00296         connectivity = hexconnectivity + i * nodes_per_hex;
00297         for( j = 0; j < nodes_per_hex; ++j )
00298         {
00299             /* get offset in node list from file id */
00300             node_offset = connectivity[j] - nodestart;
00301             /* get node id from ID list */
00302             node_id = nodeids[node_offset];
00303             fprintf( gmsh, " %u", node_id );
00304         }
00305         fprintf( gmsh, "\n" );
00306     }
00307     fprintf( gmsh, "$ENDELM\n" );
00308     fclose( gmsh );
00309     return 0;
00310 }
