hypre_test.cpp File Reference
#include "moab/Core.hpp"
#include "HypreSolver.hpp"
#include <iostream>
+ Include dependency graph for hypre_test.cpp:
Functions
moab::ErrorCode GenerateTestMatrixAndVectors (int nx, int ny, int nz, moab::HypreParMatrix &A, moab::HypreParVector &sol, moab::HypreParVector &rhs, moab::HypreParVector &exactsol)
int main (int argc, char *argv[])
Function Documentation
moab::ErrorCode GenerateTestMatrixAndVectors ( int  nx,
int  ny,
int  nz,
moab::HypreParMatrix &  A,
moab::HypreParVector &  sol,
moab::HypreParVector &  rhs,
moab::HypreParVector &  exactsol
Definition at line 199 of file hypre_test.cpp.
References moab::debug, MB_SUCCESS, MPI_COMM_WORLD, rank, and size.
Referenced by main().
#ifdef DEBUG
    int debug = 1;
#else
    int debug = 0;
#endif
#ifdef MOAB_HAVE_MPI
    int size, rank;  // Number of MPI processes, My process ID
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#else
    int size  = 1;  // Serial case (not using MPI)
    int rank  = 0;
#endif
    // Set this bool to true if you want a 7-pt stencil instead of a 27 pt stencil
    bool use_7pt_stencil = false;
    const int NNZPERROW  = 27;
    int local_nrow = nx * ny * nz;            // This is the size of our subblock
    assert( local_nrow > 0 );                 // Must have something to work with
    int local_nnz  = NNZPERROW * local_nrow;  // Approximately 27 nonzeros per row (except for boundary nodes)
    int total_nrow = 0;
    MPI_Allreduce( &local_nrow, &total_nrow, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD );
    // int total_nrow = local_nrow * size; // Total number of grid points in mesh
    long long total_nnz =
        NNZPERROW * (long long)total_nrow;  // Approximately 27 nonzeros per row (except for boundary nodes)
    int start_row = local_nrow * rank;      // Each processor gets a section of a chimney stack domain
    int stop_row  = start_row + local_nrow - 1;
    // Allocate arrays that are of length local_nrow
    // Eigen::SparseMatrix<double, Eigen::RowMajor> diagMatrix(local_nrow, local_nrow);
    // diagMatrix.reserve(local_nnz);
    HYPRE_Int col[2] = { start_row, stop_row };
    A.resize( total_nrow, col );
    sol.resize( total_nrow, start_row, stop_row );
    rhs.resize( total_nrow, start_row, stop_row );
    exactsol.resize( total_nrow, start_row, stop_row );
    long long nnzglobal = 0;
    for( int iz = 0; iz < nz; iz++ )
        for( int iy = 0; iy < ny; iy++ )
            for( int ix = 0; ix < nx; ix++ )
                const int curlocalrow = iz * nx * ny + iy * nx + ix;
                const int currow      = start_row + curlocalrow;
                int nnzrow            = 0;
                std::vector< double > colvals;
                std::vector< int > indices;
                for( int sz = -1; sz <= 1; sz++ )
                    for( int sy = -1; sy <= 1; sy++ )
                        for( int sx = -1; sx <= 1; sx++ )
                            const int curlocalcol = sz * nx * ny + sy * nx + sx;
                            const int curcol      = currow + curlocalcol;
                            // Since we have a stack of nx by ny by nz domains , stacking in the z
                            // direction, we check to see if sx and sy are reaching outside of the
                            // domain, while the check for the curcol being valid is sufficient to
                            // check the z values
                            if( ( ix + sx >= 0 ) && ( ix + sx < nx ) && ( iy + sy >= 0 ) && ( iy + sy < ny ) &&
                                ( curcol >= 0 && curcol < total_nrow ) )
                                if( !use_7pt_stencil || ( sz * sz + sy * sy + sx * sx <= 1 ) )
                                {   // This logic will skip over point that are not part of a 7-pt
                                    // stencil
                                    if( curcol == currow )
                                        colvals.push_back( 27.0 );
                                    else
                                        colvals.push_back( -1.0 );
                                    indices.push_back( curcol );
                                    nnzrow++;
                        }  // end sx loop
                    }      // end sy loop
                }          // end sz loop
                int ncols = indices.size();
                A.SetValues( 1, &ncols, &currow, indices.data(), colvals.data() );
                // diagMatrix.set_row_values ( curlocalrow, indices.size(), indices.data(),
                // colvals.data() );
                nnzglobal += nnzrow;
                sol.SetValue( currow, 0.0 );
                rhs.SetValue( currow, 27.0 - ( (double)( nnzrow - 1 ) ) );
                exactsol.SetValue( currow, 1.0 );
            }  // end ix loop
        }      // end iy loop
    }          // end iz loop
    if( debug )
        cout << "Global size of the matrix: " << total_nrow << " and NNZ (estimate) = " << total_nnz
             << " NNZ (actual) = " << nnzglobal << endl;
    if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nrow << endl;
    if( debug ) cout << " rows. Global rows " << start_row << " through " << stop_row << endl;
    if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nnz << " nonzeros." << endl;
    A.FinalizeAssembly();
    sol.FinalizeAssembly();
    rhs.FinalizeAssembly();
    exactsol.FinalizeAssembly();
    // A.Print("matrix.out");
    return moab::MB_SUCCESS;
int main ( int  argc,
char *  argv[]
Definition at line 19 of file hypre_test.cpp.
References GenerateTestMatrixAndVectors(), ierr, mb, MPI_COMM_WORLD, rank, size, and tolerance.
    // double norm, d;
    int ierr = 0;
    double times[5];
    int nx = 5, ny = 5, nz = 5;
    MPI_Init( &argc, &argv );
#else
    int rank = 0;
#endif
    MPI_Comm comm = MPI_COMM_WORLD;
    moab::Core mbCore;
    moab::Interface& mb = mbCore;
    // rval = mb.load_file(example.c_str(), &euler_set, opts.c_str());
    moab::ParallelComm* pcomm = new moab::ParallelComm( &mb, comm );
    moab::HypreParMatrix A( pcomm );
    moab::HypreParVector x( pcomm ), b( pcomm ), xexact( pcomm );
#ifdef DEBUG
    if( rank == 0 )
        int junk = 0;
        cout << "Press enter to continue" << endl;
        cin >> junk;
    MPI_Barrier( MPI_COMM_WORLD );
#endif
    if( argc > 4 )
        if( rank == 0 )
            cerr << "Usage:" << endl
                 << "\t" << argv[0] << " nx ny nz" << endl
                 << "     where nx, ny and nz are the local sub-block dimensions, or" << endl;
        exit( 1 );
    else
        if( rank == 0 )
            cout << "Using command:"
                 << "\t" << argv[0] << " nx ny nz" << endl;
    times[0] = MPI_Wtime();  // Initialize it (if needed)
    if( argc == 4 )
        nx = atoi( argv[1] );
        ny = atoi( argv[2] );
        nz = atoi( argv[3] );
    GenerateTestMatrixAndVectors( nx, ny, nz, A, x, b, xexact );
    times[1]          = MPI_Wtime() - times[0];  // operator creation time
    const bool useCG  = true;                    // TODO make into command line option
    const bool useAMG = false;                   // TODO make into command line option
    int niters        = 0;
    double normr      = 0;
    int max_iter      = 150;
    double tolerance  = 1e-15;        // Set tolerance to zero to make all runs do max_iter iterations
    times[2]          = MPI_Wtime();  // reset
    moab::HypreSolver *lsSolver, *psSolver;
    if( useCG )
        lsSolver                 = new moab::HyprePCG( A );
        moab::HyprePCG* cgSolver = dynamic_cast< moab::HyprePCG* >( lsSolver );
        cgSolver->SetTol( tolerance );
        cgSolver->SetMaxIter( max_iter );
        cgSolver->SetLogging( 1 );
        cgSolver->Verbosity( 1 );
        cgSolver->SetResidualConvergenceOptions( 3, 0.0 );
    else
        lsSolver                      = new moab::HypreGMRES( A );
        moab::HypreGMRES* gmresSolver = dynamic_cast< moab::HypreGMRES* >( lsSolver );
        gmresSolver->SetTol( tolerance, normr );
        gmresSolver->SetMaxIter( max_iter );
        gmresSolver->SetLogging( 1 );
        gmresSolver->Verbosity( 5 );
        gmresSolver->SetKDim( 30 );
    if( useAMG )
        psSolver = new moab::HypreBoomerAMG( A );
        dynamic_cast< moab::HypreBoomerAMG* >( psSolver )->SetSystemsOptions( 3 );
    else
        psSolver = new moab::HypreParaSails( A );
        dynamic_cast< moab::HypreParaSails* >( psSolver )->SetSymmetry( 1 );
    if( psSolver ) lsSolver->SetPreconditioner( *psSolver );
    times[2] = MPI_Wtime() - times[2];  // solver setup time
    /* Now let us solve the linear system */
    times[3] = MPI_Wtime();  // reset
    ierr     = lsSolver->Solve( b, x );
    if( ierr ) cerr << "Error in call to CG/GMRES HYPRE Solver: " << ierr << ".\n" << endl;
    times[3] = MPI_Wtime() - times[3];  // solver time
    lsSolver->GetNumIterations( niters );
    lsSolver->GetFinalResidualNorm( normr );
    times[4] = MPI_Wtime() - times[0];
    // x.Print ( "solution.out" );
    double t4    = times[3];
    double t4min = 0.0;
    double t4max = 0.0;
    double t4avg = 0.0;
    MPI_Allreduce( &t4, &t4min, 1, MPI_DOUBLE, MPI_MIN, MPI_COMM_WORLD );
    MPI_Allreduce( &t4, &t4max, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD );
    MPI_Allreduce( &t4, &t4avg, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD );
    t4avg = t4avg / ( (double)size );
#endif
    if( rank == 0 )
    {  // Only PE 0 needs to compute and report timing results
        // double fniters = niters;
        // double fnrow = A.NNZ();
        // double fnnz = A.M();
        // double fnops_ddot = fniters * 4 * fnrow;
        // double fnops_waxpby = fniters * 6 * fnrow;
        // double fnops_sparsemv = fniters * 2 * fnnz;
        // double fnops = fnops_ddot + fnops_waxpby + fnops_sparsemv;
        std::cout << "Testing Laplace problem solver with HYPRE interface\n";
            std::cout << "\tParallelism\n";
            std::cout << "Number of MPI ranks: \t" << size << std::endl;
#else
            std::cout << "MPI not enabled\n";
#endif
        std::cout << "Dimensions (nx*ny*nz): \t(" << nx << "*" << ny << "*" << nz << ")\n";
        std::cout << "Number of iterations: \t" << niters << std::endl;
        std::cout << "Final residual: \t" << normr << std::endl;
        std::cout << "************ Performance Summary (times in sec) *************" << std::endl;
            std::cout << "\nTime Summary" << std::endl;
            std::cout << "Total             \t" << times[4] << std::endl;
            std::cout << "Operator Creation \t" << times[1] << std::endl;
            std::cout << "Solver Setup      \t" << times[2] << std::endl;
            std::cout << "HYPRE Solver      \t" << times[3] << std::endl;
            std::cout << "Avg. Solver       \t" << t4avg << std::endl;
    // Compute difference between known exact solution and computed solution
    // All processors are needed here.
    //   double residual = 0;
    //   if ((ierr = ComputeLinfError(x, xexact, &residual)))
    //     cerr << "Error in call to ComputeLinfError: " << ierr << ".\n" << endl;
    //   if (rank==0)
    //      cout << "Difference between computed and exact  = "
    //           << residual << ".\n" << endl;
    delete lsSolver;
    // Finish up
    MPI_Finalize();
#endif
    return 0;
