iRel.h
00001 #ifndef _ITAPS_iRel
00002 #define _ITAPS_iRel
00003
00004 /***************************************************************************/ /**
00005        * \ingroup
00006        *VersionNumbers
00007        * \brief Compile time
00008        *version number
00009        *digits
00010        *
00011        * iRel maintains a
00012        *major, minor and
00013        *patch digit in its
00014        *version number.
00015        * Technically
00016        *speaking, there is
00017        *not much practical
00018        *value in patch digit
00019        * for an interface
00020        *specification. A
00021        *patch release is
00022        *typically only used
00023        * for bug fix
00024        *releases. Although
00025        *it is rare,
00026        *sometimes a bug fix
00027        * necessitates an API
00028        *change. So, we
00029        *define a patch digit
00030        *for iRel.
00031        ******************************************************************************/
00032 #define IREL_VERSION_MAJOR 1
00033 #define IREL_VERSION_MINOR 1
00034 #define IREL_VERSION_PATCH 0
00035
00036 /***************************************************************************/ /**
00037        * \ingroup
00038        *VersionNumbers
00039        * \brief Maintain
00040        *backward
00041        *compatibility with
00042        *old version symbol
00043        *names
00044        ******************************************************************************/
00045 #define IREL_MAJOR_VERSION IREL_VERSION_MAJOR
00046 #define IREL_MINOR_VERSION IREL_VERSION_MINOR
00047 #define IREL_PATCH_VERSION IREL_VERSION_PATCH
00048
00049 /***************************************************************************/ /**
00050        * \ingroup
00051        *VersionNumbers
00052        * \brief Version
00053        *Comparison
00054        *
00055        * Evaluates to true
00056        *at CPP time if the
00057        *version of iRel
00058        *currently being
00059        * compiled is greater
00060        *than or equal to the
00061        *version specified.
00062        ******************************************************************************/
00063 #define IREL_VERSION_GE( Maj, Min, Pat ) ITAPS_VERSION_GE( Maj, Min, Pat )
00064
00065 /***************************************************************************/ /**
00066        * \ingroup
00067        *VersionNumbers
00068        * \brief Compose
00069        *string represention
00070        *of the iRel version
00071        *number
00072        ******************************************************************************/
00073 #define IREL_VERSION_STRING ITAPS_VERSION_STRING_( iRel )
00074
00075 /***************************************************************************/ /**
00076        * \ingroup
00077        *VersionNumbers
00078        * \brief Compose a
00079        *symbol name derived
00080        *from the current
00081        *iRel version number.
00082        ******************************************************************************/
00083 #define IREL_VERSION_TAG ITAPS_VERSION_TAG_( iRel )
00084
00085 /***************************************************************************/ /**
00086        * \ingroup
00087        *VersionNumbers
00088        * \brief Define
00089        *iRel_create symbol
00090        *such that it depends
00091        *on version number.
00092        *
00093        * Note: We ran into
00094        *problems with this
00095        *as it influences or
00096        *is influenced by
00097        * fortran name
00098        *mangling and so
00099        *breaks fortran
00100        *compilation. So,
00101        *this is currently
00102        *disabled.
00103        ******************************************************************************/
00104 #define IREL_CREATE_NAME__( A, B, C ) A##_##B##_##C
00105 #define IREL_CREATE_NAME_( A, B, C )  IREL_CREATE_NAME__( A, B, C )
00106 #define IREL_CREATE_NAME( A )         IREL_CREATE_NAME_( A, IREL_VERSION_MAJOR, IREL_VERSION_MINOR )
00107 /*
00108 #undef  iRel_create
00109 #define iRel_create IREL_CREATE_NAME(iRel_create)
00110 */
00111
00112 #include "iBase.h"
00113 #include "iRel_protos.h"
00114
00115 #ifdef __cplusplus
00116 extern "C" {
00117 #endif
00118
00119 typedef void* iRel_Instance;
00120 typedef struct iRel_PairHandle_Private* iRel_PairHandle;
00121
00122 /***************************************************************************/ /**
00123        * \brief  \enum
00124        *IfaceType Enumerator
00125        *specifying interface
00126        *types
00127        *
00128        * Enumerator
00129        *specifying interface
00130        *types.  This
00131        *enumeration is
00132        * necessary because
00133        *functions to get
00134        *entities of a given
00135        *dimension are part
00136        *of the higher-level
00137        *interfaces (e.g.
00138        *iGeom, iMesh)
00139        *instead of iBase.
00140        ******************************************************************************/
00141 enum iRel_IfaceType
00142 {
00143     iRel_IfaceType_MIN = 0,
00144     /**< facilitates iteration over all values */
00145     iRel_IGEOM_IFACE = iRel_IfaceType_MIN,
00146     /**< description unavailable */
00147     iRel_IMESH_IFACE,
00148     /**< description unavailable */
00149     iRel_IFIELD_IFACE,
00150     /**< description unavailable */
00151     iRel_IREL_IFACE,
00152     /**< description unavailable */
00153     iRel_FBIGEOM_IFACE,
00154     /**< description unavailable */
00155     iRel_IfaceType_MAX = iRel_FBIGEOM_IFACE
00156     /**< facilitates iteration over all values */
00157 };
00158
00159 /***************************************************************************/ /**
00160        * \brief  \enum
00161        *RelationType
00162        *Enumerator
00163        *specifying relation
00164        *types
00165        *
00166        * Enumerator
00167        *specifying relation
00168        *types.  A relation
00169        *has two types, one
00170        * for each side of
00171        *the relation.
00172        ******************************************************************************/
00173 enum iRel_RelationType
00174 {
00175     iRel_RelationType_MIN = 0,
00176     /**< facilitates iteration over all values */
00177     iRel_ENTITY = iRel_RelationType_MIN,
00178     /**< description unavailable */
00179     iRel_SET,
00180     /**< description unavailable */
00181     iRel_BOTH,
00182     /**< description unavailable */
00183     iRel_RelationType_MAX = iRel_BOTH
00184     /**< facilitates iteration over all values */
00185 };
00186
00187 /***************************************************************************/ /**
00188        * \brief  \enum
00189        *RelationStatus
00190        *Enumerator
00191        *specifying relation
00192        *status
00193        *
00194        * Enumerator
00195        *specifying relation
00196        *status.  A relation
00197        *has two statuses,
00198        *one for each side of
00199        *the relation.
00200        *Allowed values of
00201        *this enumeration
00202        *are: It is an error
00203        *to request relations
00204        *from a side that
00205        *does not have
00206        * iRel_ACTIVE status.
00207        ******************************************************************************/
00208 enum iRel_RelationStatus
00209 {
00210     iRel_RelationStatus_MIN = 0,
00211     /**< facilitates iteration over all values */
00212     iRel_ACTIVE = iRel_RelationType_MIN,
00213     /**< the relation on this side is active and up to date */
00214     iRel_INACTIVE,
00215     /**< the relation on this side is inactive, and may be out of date */
00216     iRel_NOTEXIST,
00217     /**< the relation on this side is not stored */
00218     iRel_RelationStatus_MAX = iRel_NOTEXIST
00219     /**< facilitates iteration over all values */
00220 };
00221
00222 /***************************************************************************/ /**
00223        * \brief Get the
00224        *error type returned
00225        *from the last iRel
00226        *function
00227        *
00228        * Get the error type
00229        *returned from the
00230        *last iRel function.
00231        *Value returned is a
00232        *member of the
00233        *iBase_ErrorType
00234        *enumeration.
00235        ******************************************************************************/
00236 void iRel_getErrorType( iRel_Instance instance,
00237                         /**< [in] iRel instance handle */
00238                         int* error_type
00239                         /**< [out] Error type returned from last iRel function */
00240 );
00241
00242 /***************************************************************************/ /**
00243        * \brief Get a
00244        *description of the
00245        *error returned from
00246        *the last iRel
00247        *function
00248        *
00249        * Get a description
00250        *of the error
00251        *returned from the
00252        *last iRel function
00253        ******************************************************************************/
00254 void iRel_getDescription( iRel_Instance instance,
00255                           /**< [in] iRel instance handle */
00256                           char* descr,
00257                           /**< [inout] Pointer to a character string to be filled with a
00258                           description of the error from the last iRel function */
00259                           int descr_len
00260                           /**< [in] Length of the character string pointed to by descr */
00261 );
00262
00263 /***************************************************************************/ /**
00264        * \brief Create a new
00265        *iRel instance
00266        *
00267        * Create a new iRel
00268        *instance.  Currently
00269        *no options are
00270        *implemented.
00271        ******************************************************************************/
00272 void iRel_create( const char* options,
00273                   /**< const Options for the implementation */
00274                   iRel_Instance* instance,
00275                   /**< [in] iRel instance handle */
00276                   int* err,
00277                   /**< [out] Returned Error status (see iBase_ErrorType) */
00278                   const int options_len
00279                   /**< [in] Length of options string */
00280 );
00281
00282 /***************************************************************************/ /**
00283        * \brief Destroy the
00284        *interface object
00285        *
00286        * Calls destructor on
00287        *interface object
00288        ******************************************************************************/
00289 void iRel_destroy( iRel_Instance instance,
00290                    /**< [in] iRel instance handle */
00291                    int* err
00292                    /**< [out] Returned Error status (see iBase_ErrorType) */
00293 );
00294
00295 /***************************************************************************/ /**
00296        * \brief Create a
00297        *relation pair
00298        *between two
00299        *interfaces
00300        *
00301        * Creates a relation
00302        *pair between two
00303        *interfaces, passing
00304        * back a handle to
00305        *the pair.  It is an
00306        *error to create a
00307        *relation pair having
00308        *both sides
00309        *iRel_NOTEXIST.  If a
00310        *relation pair has a
00311        *side with status
00312        * iRel_NOTEXIST, the
00313        *relation for that
00314        *side is never
00315        *stored, and the
00316        *status cannot change
00317        *over the life of the
00318        *relation pair.
00319        ******************************************************************************/
00320 void iRel_createPair( iRel_Instance instance,
00321                       /**< [in] iRel instance handle */
00322                       iBase_Instance iface1,
00323                       /**< [in] 1st interface object in the relation pair */
00324                       const int ent_or_set1,
00325                       /**< [in] This relation relates entities, sets, or both from 1st
00326                       interface object */
00327                       const int iface_type1,
00328                       /**< [in] Type of 1st interface */
00329                       const int irel_status1,
00330                       /**< [in] The status of 1st side */
00331                       iBase_Instance iface2,
00332                       /**< [in] 2nd interface object in the relation pair */
00333                       const int ent_or_set2,
00334                       /**< [in] This relation relates entities, sets, or both from 2nd
00335                       interface object */
00336                       const int iface_type2,
00337                       /**< [in] Type of 2nd interface */
00338                       const int irel_status2,
00339                       /**< [in] The status of 2nd side */
00340                       iRel_PairHandle* pair,
00341                       /**< [out] Pointer to relation pair handle, returned from function */
00342                       int* err
00343                       /**< [out] Returned Error status (see iBase_ErrorType) */
00344 );
00345
00346 /***************************************************************************/ /**
00347        * \brief Get
00348        *information for this
00349        *relation handle
00350        *
00351        * Get information
00352        *about the interfaces
00353        *and relation type
00354        *for this relation.
00355        *Relation type for
00356        *each side is passed
00357        *back as integers,
00358        * but values will be
00359        *from RelationType
00360        *enumeration.
00361        ******************************************************************************/
00362 void iRel_getPairInfo( iRel_Instance instance,
00363                        /**< [in] iRel instance handle */
00364                        iRel_PairHandle pair,
00365                        /**< [in] handle of relation pair being queried */
00366                        iBase_Instance* iface1,
00367                        /**< [out] Side 1 instance for this relation */
00368                        int* ent_or_set1,
00369                        /**< [out] relation type for side 1 of this relation */
00370                        int* iface_type1,
00371                        /**< [out] Interface type for side 1 of this relation */
00372                        int* irel_status1,
00373                        /**< [out] The status of the first side of this relation */
00374                        iBase_Instance* iface2,
00375                        /**< [out] Side 2 instance for this relation */
00376                        int* ent_or_set2,
00377                        /**< [out] Relation type for side 2 of this relation */
00378                        int* iface_type2,
00379                        /**< [out] Interface type for side 2 of this relation */
00380                        int* irel_status2,
00381                        /**< [out] Status of the 2nd side of this relation */
00382                        int* err
00383                        /**< [out] Returned Error status (see iBase_ErrorType) */
00384 );
00385
00386 /***************************************************************************/ /**
00387        * \brief Change the
00388        *relation type
00389        *
00390        * Change the type of
00391        *one or both sides of
00392        *a relation.  Only
00393        *changes that result
00394        *in no lost
00395        *information are
00396        *allowed, e.g.
00397        *changing a type from
00398        *SET to BOTH or vice
00399        *versa.
00400        ******************************************************************************/
00401 void iRel_changePairType( iRel_Instance instance,
00402                           /**< [in] iRel instance handle */
00403                           iRel_PairHandle pair,
00404                           /**< [in] Relation pair handle being changed */
00405                           int ent_or_set1,
00406                           /**< [in] The new type of side 1 of this relation pair */
00407                           int ent_or_set2,
00408                           /**< [in] The new type of side 2 of this relation pair */
00409                           int* err
00410                           /**< [out] Returned Error status (see iBase_ErrorType) */
00411 );
00412
00413 /***************************************************************************/ /**
00414        * \brief Change the
00415        *relation status
00416        *
00417        * Change the status
00418        *of one or both sides
00419        *of a relation.  It
00420        *is an error to
00421        * change the status
00422        *of both sides to
00423        *iRel_NOTEXIST.  If a
00424        *side is changed to
00425        * iRel_NOTEXIST, it
00426        *will no longer be
00427        *changeable back to
00428        *iRel_ACTIVE or
00429        * iRel_INACTIVE.
00430        *Changing a side from
00431        *iRel_INACTIVE to
00432        *iRel_ACTIVE implies
00433        *a traversal of all
00434        *related entities on
00435        *the other side, to
00436        *recover the
00437        *relations on the
00438        *side being changed.
00439        *Changing both sides
00440        *from iRel_ACTIVE to
00441        *something else is an
00442        *error, since in that
00443        *case neither will be
00444        *able to be updated
00445        *to iRel_ACTIVE.
00446        ******************************************************************************/
00447 void iRel_changePairStatus( iRel_Instance instance,
00448                             /**< [in] iRel instance handle */
00449                             iRel_PairHandle pair,
00450                             /**< [in] Relation pair handle being changed */
00451                             int irel_status1,
00452                             /**< [in] The new status of side 1 of this relation pair */
00453                             int irel_status2,
00454                             /**< [in] The new status of side 2 of this relation pair */
00455                             int* err
00456                             /**< [out] Returned Error status (see iBase_ErrorType) */
00457 );
00458
00459 /***************************************************************************/ /**
00460        * \brief Destroy a
00461        *relation pair
00462        *
00463        * Destroy the
00464        *relation pair
00465        *corresponding to the
00466        *handle input
00467        ******************************************************************************/
00468 void iRel_destroyPair( iRel_Instance instance,
00469                        /**< [in] iRel instance handle */
00470                        iRel_PairHandle pair,
00471                        /**< [in] Handle of relation pair to destroy */
00472                        int* err
00473                        /**< [out] Returned Error status (see iBase_ErrorType) */
00474 );
00475
00476 /***************************************************************************/ /**
00477        * \brief Get
00478        *relations containing
00479        *specified interface
00480        *
00481        * Get relations
00482        *containing the
00483        *specified interface
00484        ******************************************************************************/
00485 void iRel_findPairs( iRel_Instance instance,
00486                      /**< [in] iRel instance handle */
00487                      iBase_Instance iface,
00488                      /**< [in] Specified interface */
00489                      iRel_PairHandle** pairs,
00490                      /**< [inout] Pointer to array holding returned relation pairs
00491                      containing specified interface */
00492                      int* pairs_allocated,
00493                      /**< [inout] Pointer to allocated size of relation pairs list */
00494                      int* pairs_size,
00495                      /**< [out] Pointer to occupied size of relation pairs list */
00496                      int* err
00497                      /**< [out] Returned Error status (see iBase_ErrorType) */
00498 );
00499
00500 /***************************************************************************/ /**
00501        * \brief Set a
00502        *relation between two
00503        *entities
00504        *
00505        * Set a relation
00506        *between an entity
00507        *and several
00508        *entities. It is an
00509        *error to set a
00510        *relation on a pair
00511        *with both sides not
00512        *iRel_ACTIVE.
00513        ******************************************************************************/
00514 void iRel_setEntEntRelation( iRel_Instance instance,
00515                              /**< [in] iRel instance handle */
00516                              iRel_PairHandle pair,
00517                              /**< [in] Relation pair handle being queried */
00518                              iBase_EntityHandle ent1,
00519                              /**< [in] 1st entity of relation being set */
00520                              iBase_EntityHandle ent2,
00521                              /**< [in] 2nd entity of relation being set */
00522                              int* err
00523                              /**< [out] Returned Error status (see iBase_ErrorType) */
00524 );
00525
00526 /***************************************************************************/ /**
00527        * \brief Set a
00528        *relation between an
00529        *entity and an entity
00530        *set
00531        *
00532        * Description
00533        *unavailable.
00534        ******************************************************************************/
00535 void iRel_setEntSetRelation( iRel_Instance instance,
00536                              /**< [in] iRel instance handle */
00537                              iRel_PairHandle pair,
00538                              /**< [in] Relation pair handle being queried */
00539                              iBase_EntityHandle ent1,
00540                              /**< [in] entity of relation being set */
00541                              iBase_EntitySetHandle entset2,
00542                              /**< [in] entity set of relation being set */
00543                              int* err
00544                              /**< [out] Returned Error status (see iBase_ErrorType) */
00545 );
00546
00547 /***************************************************************************/ /**
00548        * \brief Set a
00549        *relation between an
00550        *entity set an an
00551        *entity
00552        *
00553        * Description
00554        *unavailable.
00555        ******************************************************************************/
00556 void iRel_setSetEntRelation( iRel_Instance instance,
00557                              /**< [in] iRel instance handle */
00558                              iRel_PairHandle pair,
00559                              /**< [in] Relation pair handle being queried */
00560                              iBase_EntitySetHandle entset1,
00561                              /**< [in] entity set of relation being set */
00562                              iBase_EntityHandle ent2,
00563                              /**< [in] entity of relation being set */
00564                              int* err
00565                              /**< [out] Returned Error status (see iBase_ErrorType) */
00566 );
00567
00568 /***************************************************************************/ /**
00569        * \brief Set a
00570        *relation between two
00571        *entity sets
00572        *
00573        * Description
00574        *unavailable. Set a
00575        *relation between an
00576        *entity and several
00577        *entities.  It is an
00578        *error to set a
00579        *relation on a pair
00580        *with both sides not
00581        *iRel_ACTIVE.
00582        ******************************************************************************/
00583 void iRel_setSetSetRelation( iRel_Instance instance,
00584                              /**< [in] iRel instance handle */
00585                              iRel_PairHandle pair,
00586                              /**< [in] Relation pair handle being queried */
00587                              iBase_EntitySetHandle entset1,
00588                              /**< [in] 1st entity set of relation being set */
00589                              iBase_EntitySetHandle entset2,
00590                              /**< [in] 2nd entity set of relation being set */
00591                              int* err
00592                              /**< [out] Returned Error status (see iBase_ErrorType) */
00593 );
00594
00595 /***************************************************************************/ /**
00596        * \brief Set
00597        *relations between
00598        *arrays of entities
00599        *pairwise,
00600        * ent_array_1[i]<->ent_array_2[i]
00601        *
00602        * Set relations
00603        *between arrays of
00604        *entities pairwise,
00605        * ent_array_1[i]<->ent_array_2[i].
00606        *If either array
00607        * contains sets and
00608        *that side of the
00609        *relation is
00610        *'both'-type, set
00611        *relations for
00612        *individual entities
00613        *in those sets too.
00614        *It is an error to
00615        * set a relation on a
00616        *pair with both sides
00617        *not iRel_ACTIVE.
00618        ******************************************************************************/
00619 void iRel_setEntArrEntArrRelation( iRel_Instance instance,
00620                                    /**< [in] iRel instance handle */
00621                                    iRel_PairHandle pair,
00622                                    /**< [in] Relation pair handle being queried */
00623                                    iBase_EntityHandle* ent_array_1,
00624                                    /**< [in] 1st array of entities of relation being set */
00625                                    int num_ent1,
00626                                    /**< [in] Number of entities in 1st array */
00627                                    iBase_EntityHandle* ent_array_2,
00628                                    /**< [in] 2nd array of entities of relation being set */
00629                                    int num_ent2,
00630                                    /**< [in] Number of entities in 2nd array */
00631                                    int* err
00632                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00633 );
00634
00635 /***************************************************************************/ /**
00636        * \brief Set
00637        *relations between
00638        *arrays of entity
00639        *sets and entities
00640        *
00641        * Description
00642        *unavailable.
00643        ******************************************************************************/
00644 void iRel_setSetArrEntArrRelation( iRel_Instance instance,
00645                                    /**< [in] iRel instance handle */
00646                                    iRel_PairHandle pair,
00647                                    /**< [in] Relation pair handle being queried */
00648                                    iBase_EntitySetHandle* entset_array_1,
00649                                    /**< [in] 1st array of entities of relation being set */
00650                                    int num_set1,
00651                                    /**< [in] Number of entity sets in 1st array */
00652                                    iBase_EntityHandle* ent_array_2,
00653                                    /**< [in] 2nd array of entities of relation being set */
00654                                    int num_ent2,
00655                                    /**< [in] Number of entities in 2nd array */
00656                                    int* err
00657                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00658 );
00659
00660 /***************************************************************************/ /**
00661        * \brief Set
00662        *relations between
00663        *arrays of entities
00664        *and entity sets
00665        *
00666        * Description
00667        *unavailable.
00668        ******************************************************************************/
00669 void iRel_setEntArrSetArrRelation( iRel_Instance instance,
00670                                    /**< [in] iRel instance handle */
00671                                    iRel_PairHandle pair,
00672                                    /**< [in] Relation pair handle being queried */
00673                                    iBase_EntityHandle* ent_array_1,
00674                                    /**< [in] 1st array of entities of relation being set */
00675                                    int num_ent1,
00676                                    /**< [in] Number of entities in 1st array */
00677                                    iBase_EntitySetHandle* entset_array_2,
00678                                    /**< [in] 2nd array of entities of relation being set */
00679                                    int num_set2,
00680                                    /**< [in] Number of entity sets in 2nd array */
00681                                    int* err
00682                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00683 );
00684
00685 /***************************************************************************/ /**
00686        * \brief Set
00687        *relations between
00688        *arrays of entity
00689        *sets pairwise,
00690        * ent_array_1[i]<->ent_array_2[i]
00691        *
00692        * Set relations
00693        *between arrays of
00694        *entities pairwise,
00695        * ent_array_1[i]<->ent_array_2[i].
00696        *If either array
00697        * contains sets and
00698        *that side of the
00699        *relation is
00700        *'both'-type, set
00701        *relations for
00702        *individual entities
00703        *in those sets too.
00704        *It is an error to
00705        * set a relation on a
00706        *pair with both sides
00707        *not iRel_ACTIVE.
00708        ******************************************************************************/
00709 void iRel_setSetArrSetArrRelation( iRel_Instance instance,
00710                                    /**< [in] iRel instance handle */
00711                                    iRel_PairHandle pair,
00712                                    /**< [in] Relation pair handle being queried */
00713                                    iBase_EntitySetHandle* entset_array_1,
00714                                    /**< [in] 1st array of entities of relation being set */
00715                                    int num_set1,
00716                                    /**< [in] Number of entities in 1st array */
00717                                    iBase_EntitySetHandle* entset_array_2,
00718                                    /**< [in] 2nd array of entities of relation being set */
00719                                    int num_set2,
00720                                    /**< [in] Number of entities in 2nd array */
00721                                    int* err
00722                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00723 );
00724
00725 /***************************************************************************/ /**
00726        * \brief Get entity
00727        *related to specified
00728        *entity and relation
00729        *handle
00730        *
00731        * Get entity related
00732        *to specified entity
00733        *and relation handle.
00734        *Also returns whether
00735        *the related entity
00736        *is an entity or a
00737        *set.  It is an error
00738        *to get a relation
00739        *for a side with
00740        *status
00741        *iRel_NOTEXIST.
00742        ******************************************************************************/
00743 void iRel_getEntEntRelation( iRel_Instance instance,
00744                              /**< [in] iRel instance handle */
00745                              iRel_PairHandle pair,
00746                              /**< [in] Relation pair handle being queried */
00747                              iBase_EntityHandle ent1,
00748                              /**< [in] 1st entity of relation being queried */
00749                              int switch_order,
00750                              /**< [in] 1st entity is related to 1st interface (=0) or 2nd interface
00751                              (=1) of relation pair */
00752                              iBase_EntityHandle* ent2,
00753                              /**< [out] Pointer to entity related to ent1 */
00754                              int* err
00755                              /**< [out] Returned Error status (see iBase_ErrorType) */
00756 );
00757
00758 /***************************************************************************/ /**
00759        * \brief Get entity
00760        *set related to
00761        *specified entity and
00762        *relation handle
00763        *
00764        * Description
00765        *unavailable.
00766        ******************************************************************************/
00767 void iRel_getEntSetRelation( iRel_Instance instance,
00768                              /**< [in] iRel instance handle */
00769                              iRel_PairHandle pair,
00770                              /**< [in] Relation pair handle being queried */
00771                              iBase_EntityHandle ent1,
00772                              /**< [in] entity of relation being queried */
00773                              int switch_order,
00774                              /**< [in] 1st entity is related to 1st interface (=0) or 2nd interface
00775                              (=1) of relation pair */
00776                              iBase_EntitySetHandle* entset2,
00777                              /**< [out] Pointer to entity set related to ent1 */
00778                              int* err
00779                              /**< [out] Returned Error status (see iBase_ErrorType) */
00780 );
00781
00782 /***************************************************************************/ /**
00783        * \brief Get entity
00784        *related to specified
00785        *entity set and
00786        *relation handle
00787        *
00788        * Description
00789        *unavailable.
00790        ******************************************************************************/
00791 void iRel_getSetEntRelation( iRel_Instance instance,
00792                              /**< [in] iRel instance handle */
00793                              iRel_PairHandle pair,
00794                              /**< [in] Relation pair handle being queried */
00795                              iBase_EntitySetHandle entset1,
00796                              /**< [in] entity set of relation being queried */
00797                              int switch_order,
00798                              /**< [in] 1st entity is related to 1st interface (=0) or 2nd interface
00799                              (=1) of relation pair */
00800                              iBase_EntityHandle* ent2,
00801                              /**< [out] Pointer to entity related to entset1 */
00802                              int* err
00803                              /**< [out] Returned Error status (see iBase_ErrorType) */
00804 );
00805
00806 /***************************************************************************/ /**
00807        * \brief Get entity
00808        *set related to
00809        *specified entity set
00810        *and relation handle
00811        *
00812        * Description
00813        *unavailable.
00814        ******************************************************************************/
00815 void iRel_getSetSetRelation( iRel_Instance instance,
00816                              /**< [in] iRel instance handle */
00817                              iRel_PairHandle pair,
00818                              /**< [in] Relation pair handle being queried */
00819                              iBase_EntitySetHandle entset1,
00820                              /**< [in] 1st entity set of relation being queried */
00821                              int switch_order,
00822                              /**< [in] 1st entity is related to 1st interface (=0) or 2nd interface
00823                              (=1) of relation pair */
00824                              iBase_EntitySetHandle* entset2,
00825                              /**< [out] Pointer to entity set related to entset1 */
00826                              int* err
00827                              /**< [out] Returned Error status (see iBase_ErrorType) */
00828 );
00829
00830 /***************************************************************************/ /**
00831        * \brief Get entity
00832        *iterator related to
00833        *specified entity set
00834        *and relation handle.
00835        *
00836        * Description
00837        *unavailable.
00838        ******************************************************************************/
00839 void iRel_getEntSetIterRelation( iRel_Instance instance,
00840                                  /**< [in] iRel instance handle */
00841                                  iRel_PairHandle pair,
00842                                  /**< [in] Relation pair handle being queried */
00843                                  iBase_EntityHandle ent1,
00844                                  /**< [in] ent1 1st entity set of relation being queried */
00845                                  int switch_order,
00846                                  /**< [in] 1st entity is related to 1st interface (=0) or 2nd interface
00847                                  (=1) of relation pair */
00848                                  iBase_EntityIterator* entIter,
00849                                  /**< [out] Returned entity iterator */
00850                                  int* err
00851                                  /**< [out] Returned Error status (see iBase_ErrorType) */
00852 );
00853
00854 /***************************************************************************/ /**
00855        * \brief Get entities
00856        *related to those in
00857        *specified array and
00858        *relation, pairwise
00859        *
00860        * Get entities
00861        *related to those in
00862        *specified array and
00863        *relation, pairwise.
00864        * Returns sets or
00865        *entities, depending
00866        *on relation type and
00867        *entities in
00868        * ent_array_1.  It is
00869        *an error to get a
00870        *relation for a side
00871        *with status
00872        * iRel_NOTEXIST.
00873        ******************************************************************************/
00874 void iRel_getEntArrEntArrRelation( iRel_Instance instance,
00875                                    /**< [in] iRel instance handle */
00876                                    iRel_PairHandle pair,
00877                                    /**< [in] Relation pair handle being queried */
00878                                    iBase_EntityHandle* ent_array_1,
00879                                    /**< [in] Array of entities whose relations are being queried */
00880                                    int ent_array_1_size,
00881                                    /**< [in] Number of entities in ent_array_1 */
00882                                    int switch_order,
00883                                    /**< [in] Entities in ent_array_1 are related with 1st (=0) or 2nd (=1)
00884                                    interface of this relation pair */
00885                                    iBase_EntityHandle** ent_array_2,
00886                                    /**< [inout] Pointer to array of entity handles returned from function */
00887                                    int* ent_array_2_allocated,
00888                                    /**< [inout] Pointer to allocated size of ent_array_2 */
00889                                    int* ent_array_2_size,
00890                                    /**< [out] Pointer to occupied size of ent_array_2 */
00891                                    int* err
00892                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00893 );
00894
00895 /***************************************************************************/ /**
00896        * \brief Get entity
00897        *sets related to
00898        *entities in
00899        *specified array and
00900        *relation, pairwise
00901        *
00902        * Description
00903        *unavailable.
00904        ******************************************************************************/
00905 void iRel_getEntArrSetArrRelation( iRel_Instance instance,
00906                                    /**< [in] iRel instance handle */
00907                                    iRel_PairHandle pair,
00908                                    /**< [in] Relation pair handle being queried */
00909                                    iBase_EntityHandle* ent_array_1,
00910                                    /**< [in] Array of entities whose relations are being queried */
00911                                    int ent_array_1_size,
00912                                    /**< [in] Number of entities in ent_array_1 */
00913                                    int switch_order,
00914                                    /**< [in] Entities in ent_array_1 are related with 1st (=0) or 2nd (=1)
00915                                    interface of this relation pair */
00916                                    iBase_EntitySetHandle** entset_array_2,
00917                                    /**< [inout] Pointer to array of entity set handles returned from function */
00918                                    int* entset_array_2_allocated,
00919                                    /**< [inout] Pointer to allocated size of entset_array_2 */
00920                                    int* entset_array_2_size,
00921                                    /**< [out] Pointer to occupied size of entset_array_2 */
00922                                    int* err
00923                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00924 );
00925
00926 /***************************************************************************/ /**
00927        * \brief Get entities
00928        *related to entity
00929        *sets in specified
00930        *array and relation,
00931        * pairwise
00932        *
00933        * Description
00934        *unavailable.
00935        ******************************************************************************/
00936 void iRel_getSetArrEntArrRelation( iRel_Instance instance,
00937                                    /**< [in] iRel instance handle */
00938                                    iRel_PairHandle pair,
00939                                    /**< [in] Relation pair handle being queried */
00940                                    iBase_EntitySetHandle* entset_array_1,
00941                                    /**< [in] Array of entity sets whose relations are being queried */
00942                                    int entset_array_1_size,
00943                                    /**< [in] Number of entity sets in entset_array_1 */
00944                                    int switch_order,
00945                                    /**< [in] Entities in ent_array_1 are related with 1st (=0) or 2nd (=1)
00946                                    interface of this relation pair */
00947                                    iBase_EntityHandle** ent_array_2,
00948                                    /**< [inout] Pointer to array of entity handles returned from function */
00949                                    int* ent_array_2_allocated,
00950                                    /**< [inout] Pointer to allocated size of ent_array_2 */
00951                                    int* ent_array_2_size,
00952                                    /**< [out] Pointer to occupied size of ent_array_2 */
00953                                    int* err
00954                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00955 );
00956
00957 /***************************************************************************/ /**
00958        * \brief Get entity
00959        *sets related to
00960        *entity sets in
00961        *specified array and
00962        *relation, pairwise
00963        *
00964        * Description
00965        *unavailable.
00966        ******************************************************************************/
00967 void iRel_getSetArrSetArrRelation( iRel_Instance instance,
00968                                    /**< [in] iRel instance handle */
00969                                    iRel_PairHandle pair,
00970                                    /**< [in] Relation pair handle being queried */
00971                                    iBase_EntitySetHandle* entset_array_1,
00972                                    /**< [in] Array of entity sets whose relations are being queried */
00973                                    int entset_array_1_size,
00974                                    /**< [in] Number of entity sets in entset_array_1 */
00975                                    int switch_order,
00976                                    /**< [in] Entities in ent_array_1 are related with 1st (=0) or 2nd (=1)
00977                                    interface of this relation pair */
00978                                    iBase_EntitySetHandle** entset_array_2,
00979                                    /**< [inout] Pointer to array of entity handles returned from function */
00980                                    int* entset_array_2_allocated,
00981                                    /**< [inout] Pointer to allocated size of entset_array_2 */
00982                                    int* entset_array_2_size,
00983                                    /**< [out] Pointer to occupied size of entset_array_2 */
00984                                    int* err
00985                                    /**< [out] Returned Error status (see iBase_ErrorType) */
00986 );
00987
00988 /***************************************************************************/ /**
00989        * \brief Get entity
00990        *iterators related to
00991        *entity sets in
00992        *specified array and
00993        * relation.
00994        *
00995        * Description
00996        *unavailable.
00997        ******************************************************************************/
00998 void iRel_getEntArrSetIterArrRelation( iRel_Instance instance,
00999                                        /**< [in] iRel instance handle */
01000                                        iRel_PairHandle pair,
01001                                        /**< [in] Relation pair handle being queried */
01002                                        iBase_EntityHandle* ent_array_1,
01003                                        /**< [in] Array of entities whose relations are being queried */
01004                                        int ent_array_1_size,
01005                                        /**< [in] Number of entities in ent_array_1 */
01006                                        int switch_order,
01007                                        /**< [in] Entities in ent_array_1 are related with 1st (=0) or 2nd (=1)
01008                                        interface of this relation pair */
01009                                        iBase_EntityIterator** entiter,
01010                                        /**< [inout] Pointer to array of entity iterator handles returned from
01011                                        function */
01012                                        int* entiter_allocated,
01013                                        /**< [inout] Pointer to allocated size of entiter */
01014                                        int* entiter_size,
01015                                        /**< [out] Pointer to occupied size of entiter */
01016                                        int* err
01017                                        /**< [out] Returned Error status (see iBase_ErrorType) */
01018 );
01019
01020 /***************************************************************************/ /**
01021        * \brief Remove a
01022        *relation from an
01023        *entity
01024        *
01025        * Remove a relation
01026        *from an entity
01027        ******************************************************************************/
01028 void iRel_rmvEntRelation( iRel_Instance instance,
01029                           /**< [in] iRel instance handle */
01030                           iRel_PairHandle pair,
01031                           /**< [in] Relation pair handle being queried */
01032                           iBase_EntityHandle ent,
01033                           /**< [in] entity of relation being removed */
01034                           int switch_order,
01035                           /**< [in] entity is related to 1st interface (=0) or 2nd interface
01036                           (=1) of relation pair */
01037                           int* err
01038                           /**< [out] Returned Error status (see iBase_ErrorType) */
01039 );
01040
01041 /***************************************************************************/ /**
01042        * \brief Remove a
01043        *relation from an
01044        *entity set
01045        *
01046        * Remove a relation
01047        *from an entity set
01048        ******************************************************************************/
01049 void iRel_rmvSetRelation( iRel_Instance instance,
01050                           /**< [in] iRel instance handle */
01051                           iRel_PairHandle pair,
01052                           /**< [in] Relation pair handle being queried */
01053                           iBase_EntitySetHandle set,
01054                           /**< [in] entity set of relation being removed */
01055                           int switch_order,
01056                           /**< [in] entity set is related to 1st interface (=0) or 2nd interface
01057                           (=1) of relation pair */
01058                           int* err
01059                           /**< [out] Returned Error status (see iBase_ErrorType) */
01060 );
01061
01062 /***************************************************************************/ /**
01063        * \brief Remove a
01064        *relation from an
01065        *array of entities
01066        *
01067        * Remove a relation
01068        *from an array of
01069        *entities
01070        ******************************************************************************/
01071 void iRel_rmvEntArrRelation( iRel_Instance instance,
01072                              /**< [in] iRel instance handle */
01073                              iRel_PairHandle pair,
01074                              /**< [in] Relation pair handle being queried */
01075                              iBase_EntityHandle* ent_array_1,
01076                              /**< [in] Array of entities of relation being removed */
01077                              int num_ent1,
01078                              /**< [in] Number of entities in array */
01079                              int switch_order,
01080                              /**< [in] entities are related to 1st interface (=0) or 2nd interface
01081                              (=1) of relation pair */
01082                              int* err
01083                              /**< [out] Returned Error status (see iBase_ErrorType) */
01084 );
01085
01086 /***************************************************************************/ /**
01087        * \brief Remove a
01088        *relation from an
01089        *array of entity sets
01090        *
01091        * Remove a relation
01092        *from an array of
01093        *entity sets
01094        ******************************************************************************/
01095 void iRel_rmvSetArrRelation( iRel_Instance instance,
01096                              /**< [in] iRel instance handle */
01097                              iRel_PairHandle pair,
01098                              /**< [in] Relation pair handle being queried */
01099                              iBase_EntitySetHandle* entset_array_1,
01100                              /**< [in] Array of entity sets of relation being removed */
01101                              int num_entset1,
01102                              /**< [in] Number of entity sets in array */
01103                              int switch_order,
01104                              /**< [in] entity sets are related to 1st interface (=0) or 2nd interface
01105                              (=1) of relation pair */
01106                              int* err
01107                              /**< [out] Returned Error status (see iBase_ErrorType) */
01108 );
01109
01110 /***************************************************************************/ /**
01111        * \brief Infer
01112        *relations between
01113        *entities in
01114        *specified pair of
01115        *interfaces
01116        *
01117        * Infer relations
01118        *between entities in
01119        *specified pair of
01120        *interfaces.  The
01121        * criteria used to
01122        *infer these
01123        *relations depends on
01124        *the interfaces in
01125        * the pair, the iRel
01126        *implementation, and
01127        *the source of the
01128        *data in those
01129        * interfaces.
01130        ******************************************************************************/
01131 void iRel_inferAllRelations( iRel_Instance instance,
01132                              /**< [in] iRel instance handle */
01133                              iRel_PairHandle pair,
01134                              /**< [in] Relation pair handle being queried */
01135                              int* err
01136                              /**< [out] Returned Error status (see iBase_ErrorType) */
01137 );
01138
01139 /***************************************************************************/ /**
01140        * \brief Infer
01141        *relations and
01142        *relation type
01143        *between entities in
01144        *specified pair of
01145        *interfaces
01146        *
01147        * Infer relations
01148        *between entities in
01149        *specified pair of
01150        *interfaces, and the
01151        * relation type used
01152        *by this iRel
01153        *implementation.  The
01154        *criteria used to
01155        * infer these
01156        *relations depends on
01157        *the interfaces in
01158        *the pair, the iRel
01159        * implementation, and
01160        *the source of the
01161        *data in those
01162        *interfaces.
01163        ******************************************************************************/
01164 void iRel_inferAllRelationsAndType( iRel_Instance instance,
01165                                     /**< [in] iRel instance handle */
01166                                     iRel_PairHandle* pair,
01167                                     /**< [in] Relation pair handle created by implementation */
01168                                     int* err
01169                                     /**< [out] Returned Error status (see iBase_ErrorType) */
01170 );
01171
01172 /***************************************************************************/ /**
01173        * \brief Infer
01174        *relations
01175        *corresponding to
01176        *specified entity and
01177        *relation pair
01178        *
01179        * Infer relations
01180        *corresponding to
01181        *specified entity and
01182        *relation pair.  The
01183        * criteria used to
01184        *infer these
01185        *relations depends on
01186        *the interfaces in
01187        * the pair, the iRel
01188        *implementation, and
01189        *the source of the
01190        *data in those
01191        * interfaces.
01192        ******************************************************************************/
01193 void iRel_inferEntRelations( iRel_Instance instance,
01194                              /**< [in] iRel instance handle */
01195                              iRel_PairHandle pair,
01196                              /**< [in] Relation pair handle being queried */
01197                              iBase_EntityHandle entity,
01198                              /**< [in] Entity whose relations are being inferred */
01199                              int iface_no,
01200                              /**< [in] Entity corresponds to 1st (=0) or 2nd (=1) interface in
01201                              relation pair */
01202                              int* err
01203                              /**< [out] Returned Error status (see iBase_ErrorType) */
01204 );
01205
01206 /***************************************************************************/ /**
01207        * \brief Brief
01208        *unavailable
01209        *
01210        * Description
01211        *unavailable
01212        ******************************************************************************/
01213 void iRel_inferSetRelations( iRel_Instance instance,
01214                              /**< [in] iRel instance handle */
01215                              iRel_PairHandle pair,
01216                              /**< [in] description unknown */
01217                              iBase_EntitySetHandle entity_set,
01218                              /**< [in] description unknown */
01219                              int iface_no,
01220                              /**< [in] description unknown */
01221                              int* err
01222                              /**< [out] Returned Error status (see iBase_ErrorType) */
01223 );
01224
01225 /***************************************************************************/ /**
01226        * \brief Infer
01227        *relations
01228        *corresponding to
01229        *specified entities
01230        *and relation pair
01231        *
01232        * Infer relations
01233        *corresponding to
01234        *specified entities
01235        *and relation pair.
01236        * The criteria used
01237        *to infer these
01238        *relations depends on
01239        *the interfaces in
01240        * the pair, the iRel
01241        *implementation, and
01242        *the source of the
01243        *data in those
01244        * interfaces.
01245        ******************************************************************************/
01246 void iRel_inferEntArrRelations( iRel_Instance instance,
01247                                 /**< [in] iRel instance handle */
01248                                 iRel_PairHandle pair,
01249                                 /**< [in] Relation pair handle being queried */
01250                                 iBase_EntityHandle* entities,
01251                                 /**< [in] Array of entities whose relation are being inferred */
01252                                 int entities_size,
01253                                 /**< [in] Number of entities in array */
01254                                 int iface_no,
01255                                 /**< [in] Entities correspond to 1st (=0) or 2nd (=1) interface in
01256                                 relation pair */
01257                                 int* err
01258                                 /**< [out] Returned Error status (see iBase_ErrorType) */
01259 );
01260
01261 /***************************************************************************/ /**
01262        * \brief Brief
01263        *unavailable
01264        *
01265        * Description
01266        *unavailable
01267        ******************************************************************************/
01268 void iRel_inferSetArrRelations( iRel_Instance instance,
01269                                 /**< [in] iRel instance handle */
01270                                 iRel_PairHandle pair,
01271                                 /**< [in] description unknown */
01272                                 iBase_EntitySetHandle* entity_sets,
01273                                 /**< [in] description unknown */
01274                                 int entities_size,
01275                                 /**< [in] description unknown */
01276                                 int iface_no,
01277                                 /**< [in] description unknown */
01278                                 int* err
01279                                 /**< [out] Returned Error status (see iBase_ErrorType) */
01280 );
01281
01282 /** \mainpage The ITAPS Relations Interface iRel
01283  *
01284  * Each ITAPS interface encapsulates functionality that "belongs"
01285  * together, for example mesh or geometric model functionality.  In
01286  * some cases, however, data in several of these interfaces need to
01287  * be related together.  For example, a collection of mesh faces
01288  * should be related to the geometric model face which they
01289  * discretize.  The ITAPS Relations interface accomplishes this in a
01290  * way which allows the lower-level interfaces to remain
01291  * independent.
01292  *
01293  * iRel defines relations as pairwise relations between entities
01294  * or entity sets.  Related entities can be in the same or different
01295  * interfaces.  A given relation is created for a given pair of
01296  * interfaces and returned in the form of a \em Relation \em Handle.
01297  * After a specific relation pair has been created, concrete
01298  * relations for that pair can be assigned and retrieved for
01299  * specific entities using set and get functions on the iRel
01300  * interface.  A given interface instance can appear in one or many
01301  * relation pairs, each identified by the relation pair handle.
01302  *
01303  * \section Types Relation Types
01304  *
01305  * Relations are also distinguished by a pair of relation types.
01306  * For each interface in a relation pair, a corresponding type
01307  * indicates whether the relation applies to entities, entity sets,
01308  * or both entities and sets in the corresponding interface in the
01309  * pair.  If only one of the interfaces in a given pair has a
01310  * 'both'-type, entities and entity sets in that
01311  * interface are each related to either entities or sets in the other
01312  * interface in the pair.  If both of the sides of a relation are of
01313  * 'both'-type, entities and sets on one side of a relation point to
01314  * sets on the other side.
01315  *
01316  * \section Status Relation Status
01317  *
01318  * Relations are also distinguished by a pair of relation statuses.
01319  * For each interface in a relation pair, a corresponding status indicates
01320  * whether the relation on that side is kept up to date, or stored at all.
01321  * Allowable values for status are iRel_ACTIVE, iRel_INACTIVE, and iRel_NOTEXIST,
01322  * defined in the iRel_RelationStatus enumeration.  Status for a given side
01323  * can be changed from iRel_ACTIVE to iRel_INACTIVE and vice versa, or from
01324  * either of those to iRel_NOTEXIST.  However, once changed to iRel_NOTEXIST
01325  * (or created that way), a side cannot be changed back to the other two.
01326  * Changing a side to be iRel_INACTIVE can be used when frequent changes to
01327  * the underlying entities are being made, e.g. during adaptive mesh refinement.
01328  * Changing from iRel_INACTIVE to iRel_ACTIVE implies a traversal of all entities
01329  * on the iRel_ACTIVE side to recover which entities on the iRel_INACTIVE side
01330  * must have their relations updated.
01331  *
01332  * \section ArgOrder Argument Order
01333  *
01334  * Many functions in the iRel interface take as input two entities,
01335  * or two lists of entities, along with a relation pair handle.  For
01336  * these functions, the entities or lists are assumed to be in the
01337  * same order as the interfaces used to create that relation pair.
01338  * For example, if a relation pair is created by calling:
01339  * \code
01340  * iRel_createRelation(instance, iface1, ent_or_set1, type1,
01341  *                     iface2, ent_or_set2, type2,
01342  *                     &relation_handle, &ierr)
01343  * \endcode
01344  * and relations set by calling
01345  * \code
01346  * iRel_setEntEntRelation(instance, relation_handle,
01347  *                        ent1, is_set1, ent2, is_set2, &ierr)
01348  * \endcode
01349  * it is assumed that ent1 is contained in iface1 and ent2 in
01350  * iface2.
01351  *
01352  * For functions taking only one entity or list as input, and
01353  * returning an entity or list, an additional argument indicates
01354  * whether the input entity or list belongs to the first or second
01355  * interface in that relation pair.
01356  *
01357  */
01358
01359 #ifdef __cplusplus
01360 } /* extern "C" */
01361 #endif
01362
01363 #endif /* #ifndef _ITAPS_iRel */
