imoab_remap.cpp File Reference
#include "moab/MOABConfig.h"
#include "moab/iMOAB.h"
#include "TestUtil.hpp"
#include "moab/CpuTimer.hpp"
#include "moab/ProgOptions.hpp"
#include <iostream>
#include <iomanip>
+ Include dependency graph for imoab_remap.cpp:
Defines
#define CHECKIERR(ierr, message)
#define ENABLE_ATMLND_COUPLING
Functions
int main (int argc, char *argv[])
Define Documentation
#define CHECKIERR (   ierr,
  message
Value:
if( 0 != ( ierr ) )            \
        printf( "%s", message );   \
        return 1;                  \
Definition at line 15 of file imoab_remap.cpp.
Referenced by main().
Definition at line 22 of file imoab_remap.cpp.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 24 of file imoab_remap.cpp.
References ProgOptions::addOpt(), atmFilename, CHECKIERR, DENSE_DOUBLE, DENSE_INTEGER, ErrCode, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_GetDoubleTagStorage(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_WriteMesh(), MPI_COMM_WORLD, and ProgOptions::parseCommandLine().
    ErrCode ierr;
    std::string atmFilename, ocnFilename, lndFilename, mapFilename;
    atmFilename = TestDir + "unittest/wholeATM_T.h5m";
    ocnFilename = TestDir + "unittest/recMeshOcn.h5m";
#ifdef ENABLE_ATMLND_COUPLING
    lndFilename = TestDir + "unittest/wholeLnd.h5m";
#endif
    // mapFilename = TestDir + "unittest/outCS5ICOD5_map.nc";
    ProgOptions opts;
    opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename );
    opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename );
    opts.addOpt< std::string >( "land,l", "land mesh filename (target)", &lndFilename );
#endif
    bool gen_baseline = false;
    opts.addOpt< void >( "genbase,g", "generate baseline 1", &gen_baseline );
    bool no_test_against_baseline = false;
    opts.addOpt< void >( "no_testbase,t", "do not test against baseline 1", &no_test_against_baseline );
    std::string baseline = TestDir + "unittest/baseline1.txt";
    opts.parseCommandLine( argc, argv );
        std::cout << " atm file: " << atmFilename << "\n ocn file: " << ocnFilename
                  << "\n lnd file: " << lndFilename
#endif
                  << "\n";
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
    MPI_Comm comm = MPI_COMM_WORLD;
#endif
     * MOAB needs to be initialized; A MOAB instance will be created, and will be used by each
     * application in this framework. There is no parallel context yet.
    ierr = iMOAB_Initialize( argc, argv );
    CHECKIERR( ierr, "failed to initialize MOAB" );
    int atmAppID, ocnAppID, lndAppID, atmocnAppID, atmlndAppID, lndatmAppID;
    iMOAB_AppID atmPID    = &atmAppID;
    iMOAB_AppID ocnPID    = &ocnAppID;
    iMOAB_AppID lndPID    = &lndAppID;
    iMOAB_AppID atmocnPID = &atmocnAppID;
    iMOAB_AppID atmlndPID = &atmlndAppID;
    iMOAB_AppID lndatmPID = &lndatmAppID;
     * Each application has to be registered once. A mesh set and a parallel communicator will be
     * associated with each application. A unique application id will be returned, and will be used
     * for all future mesh operations/queries.
    int atmCompID = 10, ocnCompID = 20, lndCompID = 30, atmocnCompID = 100, atmlndCompID = 102, lndatmCompID = 103;
    ierr = iMOAB_RegisterApplication( "ATM-APP",
                                      &comm,
#endif
                                      &atmCompID, atmPID );
    CHECKIERR( ierr, "failed to register application1" );
    ierr = iMOAB_RegisterApplication( "OCN-APP",
                                      &comm,
#endif
                                      &ocnCompID, ocnPID );
    CHECKIERR( ierr, "failed to register application2" );
    ierr = iMOAB_RegisterApplication( "LND-APP",
                                      &comm,
#endif
                                      &lndCompID, lndPID );
    CHECKIERR( ierr, "failed to register application3" );
#endif
    ierr = iMOAB_RegisterApplication( "ATM-OCN-CPL",
                                      &comm,
#endif
                                      &atmocnCompID, atmocnPID );
    CHECKIERR( ierr, "failed to register application4" );
    ierr = iMOAB_RegisterApplication( "ATM-LND-CPL",
                                      &comm,
#endif
                                      &atmlndCompID, atmlndPID );
    CHECKIERR( ierr, "failed to register application5" );
    ierr = iMOAB_RegisterApplication( "LND-ATM-CPL",
                                      &comm,
#endif
                                      &lndatmCompID, lndatmPID );
#endif
    const char* read_opts = "";
    int num_ghost_layers  = 0;
     * Loading the mesh is a parallel IO operation. Ghost layers can be exchanged too, and default
     * MOAB sets are augmented with ghost elements. By convention, blocks correspond to MATERIAL_SET
     * sets, side sets with NEUMANN_SET sets, node sets with DIRICHLET_SET sets. Each element and
     * vertex entity should have a GLOBAL ID tag in the file, which will be available for visible
     * entities
    ierr = iMOAB_LoadMesh( atmPID, atmFilename.c_str(), read_opts, &num_ghost_layers );
    CHECKIERR( ierr, "failed to load mesh" );
    ierr = iMOAB_LoadMesh( ocnPID, ocnFilename.c_str(), read_opts, &num_ghost_layers );
    ierr = iMOAB_LoadMesh( lndPID, lndFilename.c_str(), read_opts, &num_ghost_layers );
#endif
    int nverts[3], nelem[3];
     * Each process in the communicator will have access to a local mesh instance, which will
     * contain the original cells in the local partition and ghost entities. Number of vertices,
     * primary cells, visible blocks, number of sidesets and nodesets boundary conditions will be
     * returned in size 3 arrays, for local, ghost and total numbers.
    ierr = iMOAB_GetMeshInfo( atmPID, nverts, nelem, 0, 0, 0 );
    CHECKIERR( ierr, "failed to get mesh info" );
    printf( "Atmosphere Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] );
    ierr = iMOAB_GetMeshInfo( ocnPID, nverts, nelem, 0, 0, 0 );
    printf( "Ocean Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] );
    ierr = iMOAB_GetMeshInfo( lndPID, nverts, nelem, 0, 0, 0 );
    printf( "Land Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] );
#endif
     * The 2 tags used in this example exist in the file, already.
     * If a user needs a new tag, it can be defined with the same call as this one
     * this method, iMOAB_DefineTagStorage, will return a local index for the tag.
     * The name of the tag is case sensitive.
     * This method is collective.
    // int disc_orders[2] = {1, 1};
    // const char* disc_methods[2] = {"fv", "fv"};
    // const char* dof_tag_names[2] = {"GLOBAL_ID", "GLOBAL_ID"};
    int disc_orders[3]  = { 4, 1, 1 };
    int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0;
    const std::string disc_methods[3]        = { "cgll", "fv", "pcloud" };
    const std::string dof_tag_names[3]       = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" };
    const std::string weights_identifiers[3] = { "scalar", "scalar_pointcloud", "scalar_conservative" };
    const std::string bottomTempField            = "a2oTbot";
    const std::string bottomTempFieldATM         = "a2oTbotATM";
    const std::string bottomTempProjectedField   = "a2oTbot_proj";
    const std::string bottomTempProjectedNCField = "a2oTbot_projnocons";
    // Attributes for tag data storage
    int tagIndex[4];
    // int entTypes[2] = {1, 1}; /* both on elements; */
    int tagTypes[2]  = { DENSE_DOUBLE, DENSE_DOUBLE };
    int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/;
    ierr = iMOAB_DefineTagStorage( atmPID, bottomTempField.c_str(), &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
    CHECKIERR( ierr, "failed to define the field tag on ATM" );
    ierr = iMOAB_DefineTagStorage( atmPID, bottomTempFieldATM.c_str(), &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
    ierr =
        iMOAB_DefineTagStorage( ocnPID, bottomTempProjectedField.c_str(), &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] );
    CHECKIERR( ierr, "failed to define the field tag on OCN" );
    ierr =
        iMOAB_DefineTagStorage( ocnPID, bottomTempProjectedNCField.c_str(), &tagTypes[1], &ocnCompNDoFs, &tagIndex[2] );
    ierr =
        iMOAB_DefineTagStorage( lndPID, bottomTempProjectedField.c_str(), &tagTypes[1], &ocnCompNDoFs, &tagIndex[3] );
    CHECKIERR( ierr, "failed to define the field tag on LND" );
#endif
    /* Next compute the mesh intersection on the sphere between the source (ATM) and target (OCN)
     * meshes */
    ierr = iMOAB_ComputeMeshIntersectionOnSphere( atmPID, ocnPID, atmocnPID );
    CHECKIERR( ierr, "failed to compute mesh intersection between ATM and OCN" );
    /* Next compute the mesh intersection on the sphere between the source (ATM) and target (LND)
     * meshes */
    ierr = iMOAB_ComputePointDoFIntersection( atmPID, lndPID, atmlndPID );
    CHECKIERR( ierr, "failed to compute point-cloud mapping ATM-LND" );
    /* Next compute the mesh intersection on the sphere between the source (LND) and target (ATM)
     * meshes */
    ierr = iMOAB_ComputePointDoFIntersection( lndPID, atmPID, lndatmPID );
    CHECKIERR( ierr, "failed to compute point-cloud mapping LND-ATM" );
#endif
    /* We have the mesh intersection now. Let us compute the remapping weights */
    fNoConserve = 0;
    /* Compute the weights to preoject the solution from ATM component to OCN compoenent */
    ierr = iMOAB_ComputeScalarProjectionWeights( atmocnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(),
                                                 &disc_orders[0], disc_methods[1].c_str(), &disc_orders[1], &fNoBubble,
                                                 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve,
                                                 &fValidate, dof_tag_names[0].c_str(), dof_tag_names[1].c_str() );
    CHECKIERR( ierr, "failed to compute remapping projection weights for ATM-OCN scalar "
                     "non-conservative field" );
    // Let us now write the map file to disk and then read it back to test the I/O API in iMOAB
#ifdef MOAB_HAVE_NETCDF
        const std::string atmocn_map_file_name = "atm_ocn_map.nc";
        ierr =
            iMOAB_WriteMappingWeightsToFile( atmocnPID, weights_identifiers[0].c_str(), atmocn_map_file_name.c_str() );
        CHECKIERR( ierr, "failed to write map file to disk" );
        const std::string intx_from_file_identifier = "map-from-file";
        // use old reader, coupler PID is -1
        int dummyCpl     = -1;
        int dummy_rowcol = -1;
        int dummyType    = 0;
        ierr             = iMOAB_LoadMappingWeightsFromFile( atmocnPID, &dummyCpl, &dummy_rowcol, &dummyType,
                                                             intx_from_file_identifier.c_str(), atmocn_map_file_name.c_str() );
        CHECKIERR( ierr, "failed to load map file from disk" );
#endif
    fValidate = 0;
    /* Compute the weights to preoject the solution from ATM component to LND compoenent */
    ierr = iMOAB_ComputeScalarProjectionWeights( atmlndPID, weights_identifiers[1].c_str(), disc_methods[0].c_str(),
                                                 &disc_orders[0], disc_methods[2].c_str(), &disc_orders[2], &fNoBubble,
                                                 &fValidate, dof_tag_names[0].c_str(), dof_tag_names[2].c_str() );
    CHECKIERR( ierr, "failed to compute remapping projection weights for ATM-LND scalar "
    ierr = iMOAB_ComputeScalarProjectionWeights( lndatmPID, weights_identifiers[1].c_str(), disc_methods[2].c_str(),
                                                 &disc_orders[2], disc_methods[0].c_str(), &disc_orders[0], &fNoBubble,
                                                 &fValidate, dof_tag_names[2].c_str(), dof_tag_names[0].c_str() );
    CHECKIERR( ierr, "failed to compute remapping projection weights for LND-ATM scalar "
#endif
    fNoConserve = 0;
    ierr = iMOAB_ComputeScalarProjectionWeights( atmocnPID, weights_identifiers[2].c_str(), disc_methods[0].c_str(),
    CHECKIERR( ierr, "failed to compute remapping projection weights for scalar conservative field" );
    /* We have the remapping weights now. Let us apply the weights onto the tag we defined
       on the srouce mesh and get the projection on the target mesh */
    ierr = iMOAB_ApplyScalarProjectionWeights( atmocnPID, weights_identifiers[0].c_str(), bottomTempField.c_str(),
                                               bottomTempProjectedNCField.c_str() );
    CHECKIERR( ierr, "failed to apply projection weights for scalar non-conservative field" );
    ierr = iMOAB_ApplyScalarProjectionWeights( atmocnPID, weights_identifiers[2].c_str(), bottomTempField.c_str(),
                                               bottomTempProjectedField.c_str() );
    CHECKIERR( ierr, "failed to apply projection weights for scalar conservative field" );
    if( gen_baseline )
        // get temp field on ocean, from conservative, the global ids, and dump to the baseline file
        // first get GlobalIds from ocn, and fields:
        CHECKIERR( ierr, "failed to get ocn mesh info" );
        std::vector< int > gidElems;
        gidElems.resize( nelem[2] );
        std::vector< double > tempElems;
        tempElems.resize( nelem[2] );
        // get global id storage
        const std::string GidStr = "GLOBAL_ID";  // hard coded too
        int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0;
        // we should not have to define global id tag, it is always defined
        ierr = iMOAB_DefineTagStorage( ocnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd );
        CHECKIERR( ierr, "failed to define global id tag" );
        int ent_type = 1;
        ierr         = iMOAB_GetIntTagStorage( ocnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] );
        CHECKIERR( ierr, "failed to get global ids" );
        ierr =
            iMOAB_GetDoubleTagStorage( ocnPID, bottomTempProjectedField.c_str(), &nelem[2], &ent_type, &tempElems[0] );
        CHECKIERR( ierr, "failed to get temperature field" );
        std::fstream fs;
        fs.open( baseline.c_str(), std::fstream::out );
        fs << std::setprecision( 15 );  // maximum precision for doubles
        for( int i = 0; i < nelem[2]; i++ )
            fs << gidElems[i] << " " << tempElems[i] << "\n";
        fs.close();
    if( !no_test_against_baseline )
        int ent_type = 1;
        ierr =
        int err_code = 1;
        check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code );
        if( 0 == err_code ) std::cout << " passed baseline test 1\n";
    ierr = iMOAB_ApplyScalarProjectionWeights( atmlndPID, weights_identifiers[1].c_str(), bottomTempField.c_str(),
    CHECKIERR( ierr, "failed to apply projection weights for ATM-LND scalar field" );
    ierr = iMOAB_ApplyScalarProjectionWeights( lndatmPID, weights_identifiers[1].c_str(),
                                               bottomTempProjectedField.c_str(), bottomTempFieldATM.c_str() );
    CHECKIERR( ierr, "failed to apply projection weights for LND-ATM scalar field" );
#endif
     * the file can be written in parallel, and it will contain additional tags defined by the user
     * we may extend the method to write only desired tags to the file
        // free allocated data
        char outputFileAtmTgt[] = "fIntxAtmTarget.h5m";
#endif
        char outputFileOcnTgt[] = "fIntxOcnTarget.h5m";
        char outputFileLndTgt[] = "fIntxLndTarget.h5m";
#endif
        char writeOptions[] = "";
        // Write out all the component meshes to disk for verification
        ierr = iMOAB_WriteMesh( ocnPID, outputFileOcnTgt, writeOptions );
        CHECKIERR( ierr, "failed to write OCN mesh and data" );
        ierr = iMOAB_WriteMesh( lndPID, outputFileLndTgt, writeOptions );
        CHECKIERR( ierr, "failed to write LND mesh and data" );
        ierr = iMOAB_WriteMesh( atmPID, outputFileAtmTgt, writeOptions );
        CHECKIERR( ierr, "failed to write ATM mesh and data" );
#endif
     * deregistering application will delete all mesh entities associated with the application and
     * will free allocated tag storage.
    ierr = iMOAB_DeregisterApplication( lndPID );
    CHECKIERR( ierr, "failed to de-register application3" );
#endif
    ierr = iMOAB_DeregisterApplication( ocnPID );
    CHECKIERR( ierr, "failed to de-register application2" );
    ierr = iMOAB_DeregisterApplication( atmPID );
    CHECKIERR( ierr, "failed to de-register application1" );
     * this method will delete MOAB instance
    ierr = iMOAB_Finalize();
    CHECKIERR( ierr, "failed to finalize MOAB" );
    MPI_Finalize();
#endif
    return 0;
