intx_imesh.cpp
00001 /*
00002  *  This program updates a manufactured tracer field from time T0 to time T1, in parallel.
00003  *  Input: arrival mesh, already distributed on processors, and a departure position for
00004  *  each vertex, saved in a tag DP
00005  */
00006 #include <string>
00007 #include <iostream>
00008 #include "moab/Core.hpp"
00009 #include "moab/IntxMesh/Intx2MeshOnSphere.hpp"
00010 #include "moab/IntxMesh/IntxUtils.hpp"
00011
00012 #include "moab_mpi.h"
00013 #include "iMeshP.h"
00014 #include "MBiMesh.hpp"
00015
00016 #define IMESH_ASSERT( ierr ) \
00017     if( ( ierr ) != 0 ) std::cout << "iMesh Assert: \n";
00018 #define IMESH_NULL 0
00019
00020 extern "C" void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_set, int* ierr );
00021
00022 int main( int argc, char* argv[] )
00023 {
00024     MPI_Init( &argc, &argv );
00025
00026     iMesh_Instance imesh;
00027     iMeshP_PartitionHandle partn;
00028     int ierr, num_sets;
00029
00030     iBase_EntitySetHandle root;
00031     imesh = IMESH_NULL;
00032     iMesh_newMesh( 0, &imesh, &ierr, 0 );
00033     IMESH_ASSERT( ierr );
00034     iMesh_getRootSet( imesh, &root, &ierr );
00035     IMESH_ASSERT( ierr );
00036
00037     iMeshP_createPartitionAll( imesh, MPI_COMM_WORLD, &partn, &ierr );
00038     int rank, size;
00039     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00040     MPI_Comm_size( MPI_COMM_WORLD, &size );
00041     IMESH_ASSERT( ierr );
00042
00043     const char options[] = " moab:PARALLEL=READ_PART "
00044                            " moab:PARTITION=PARALLEL_PARTITION "
00045                            " moab:PARALLEL_RESOLVE_SHARED_ENTS "
00046                            " moab:PARTITION_DISTRIBUTE ";
00047     const char* filename = "HN16DP.h5m";  // the file should have the dp tag already
00048
00049     if( 0 == rank ) std::cout << "Load in parallel the file: " << filename << std::endl;
00050     iMeshP_loadAll( imesh, partn, root, filename, options, &ierr, strlen( filename ), strlen( options ) );
00051     IMESH_ASSERT( ierr );
00052
00053     iMesh_getNumEntSets( imesh, IMESH_NULL, 1, &num_sets, &ierr );
00054     IMESH_ASSERT( ierr );
00055     std::cout << "There's " << num_sets << " entity sets here on process rank " << rank << std::endl;
00056
00057     iBase_EntitySetHandle euler_set;
00058
00059     iMesh_createEntSet( imesh, 0, &euler_set, &ierr );
00060     IMESH_ASSERT( ierr );
00061
00062     iBase_EntityHandle* cells = NULL;
00063     int ents_alloc            = 0;
00064     int ents_size             = 0;
00065
00066     iMesh_getEntities( imesh, root, iBase_FACE, iMesh_ALL_TOPOLOGIES, &cells, &ents_alloc, &ents_size, &ierr );
00067     IMESH_ASSERT( ierr );
00068
00069     iMesh_addEntArrToSet( imesh, cells, ents_size, euler_set, &ierr );
00070     IMESH_ASSERT( ierr );
00071
00072     update_tracer( imesh, euler_set, &ierr );
00073     IMESH_ASSERT( ierr );
00074
00075     // write everything
00076     const char* out_name      = "out.h5m";
00077     const char optionswrite[] = " moab:PARALLEL=WRITE_PART ";
00078     iMeshP_saveAll( imesh, partn, euler_set, out_name, optionswrite, &ierr, strlen( out_name ),
00079                     strlen( optionswrite ) );
00080     IMESH_ASSERT( ierr );
00081
00082     if( 0 == rank ) std::cout << "Done\n";
00083     MPI_Finalize();
00084
00085     return 0;
00086 }
