intx_rll_cs_sphere_test.cpp File Reference
+ Include dependency graph for intx_rll_cs_sphere_test.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 11 of file intx_rll_cs_sphere_test.cpp.
References moab::Interface::create_meshset(), ErrorCode, moab::Intx2Mesh::FindMaxEdges(), moab::IntxUtils::fix_degenerate_quads(), moab::Intx2Mesh::intersect_meshes(), moab::Interface::load_file(), mb, MB_SUCCESS, MESHSET_SET, moab::IntxAreaUtils::positive_orientation(), moab::R, moab::Intx2Mesh::set_error_tolerance(), moab::IntxRllCssphere::set_radius(), STRINGIFY, and moab::Interface::write_mesh().
    // check command line arg// Euler grid is red, arrival, Lagrangian is blue, departure
    // will will keep the
    const char* filename_mesh1 = STRINGIFY( MESHDIR ) "/mbcslam/outRLLMesh.g";
    const char* filename_mesh2 = STRINGIFY( MESHDIR ) "/mbcslam/outCSMesh.g";
    double R                   = 1.;  // input
    double epsrel              = 1.e-8;
    const char* newFile        = "intx.vtk";
    if( argc == 6 )
        filename_mesh1 = argv[1];
        filename_mesh2 = argv[2];
        R              = atof( argv[3] );
        epsrel         = atof( argv[4] );
        newFile        = argv[5];
    else
        printf( "Usage: %s <mesh_filename1> <mesh_filename2> <radius> <epsrel> <newFile>\n", argv[0] );
        if( argc != 1 ) return 1;
        printf( "No files specified.  Defaulting to: %s  %s  %f %g %s\n", filename_mesh1, filename_mesh2, R, epsrel,
                newFile );
    // read meshes in 2 file sets
    Core moab;
    Interface* mb = &moab;  // global
    EntityHandle sf1, sf2;
    ErrorCode rval = mb->create_meshset( MESHSET_SET, sf1 );
    if( MB_SUCCESS != rval ) return 1;
    rval = mb->create_meshset( MESHSET_SET, sf2 );
    rval = mb->load_file( filename_mesh1, &sf1 );
    rval = mb->load_file( filename_mesh2, &sf2 );
    EntityHandle outputSet;
    rval = mb->create_meshset( MESHSET_SET, outputSet );
    // IntxUtils
    rval = IntxUtils::fix_degenerate_quads( mb, sf1 );
    IntxAreaUtils areaAdaptor;
    rval = areaAdaptor.positive_orientation( mb, sf1, R );
    rval = areaAdaptor.positive_orientation( mb, sf2, R );
    /*// set the edge tags on all elements sf1
    rval = set_edge_type_flag(mb, sf1); // form all edges, and set on them type 1 if constant
    latitude
    // add them to the set after this, just so we have them
    if (MB_SUCCESS != rval)
      return 1;*/
    IntxRllCssphere worker( mb );
    worker.set_error_tolerance( R * epsrel );
    // worker.SetEntityType(moab::MBQUAD);
    worker.set_radius( R );
    // worker.enable_debug();
    rval = worker.FindMaxEdges( sf1, sf2 );
    rval = worker.intersect_meshes( sf1, sf2, outputSet );
    // compute total area with 2 methods
    if( MB_SUCCESS != rval ) std::cout << " failed to intersect meshes\n";
    rval = mb->write_mesh( newFile, &outputSet, 1 );
    return 0;
