MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "ArrayMesh.hpp"
#include "PlanarDomain.hpp"
#include "IdealShapeTarget.hpp"
#include "TShapeB1.hpp"
#include "TQualityMetric.hpp"
#include "PMeanPTemplate.hpp"
#include "SteepestDescent.hpp"
#include "TerminationCriterion.hpp"
#include "InstructionQueue.hpp"
#include "MsqError.hpp"
#include "QualityAssessor.hpp"
#include "MeshWriter.hpp"
#include <cstdio>
#include <cstring>
#include <cstdlib>
Functions | |
double | dist (double *p1, double *p2) |
void | usage (const char *argv0) |
int | main (int argc, char *argv[]) |
double dist | ( | double * | p1, |
double * | p2 | ||
Definition at line 42 of file jacobi_test.cpp.
Referenced by moab::TempestRemapper::ConstructCoveringSet(), findpt_list_sort(), findpt_pass_2(), findpt_pass_3(), moab::FBEngine::getPntRayIntsct(), moab::Element::SpectralHex::ievaluate(), moab::Element::SpectralQuad::ievaluate(), MBMesquite::MsqSphere::intersect(), moab::SmoothFace::is_at_vertex(), main(), MBMesquite::MeshUtil::meshes_are_different(), moab::ElemUtil::nat_coords_trilinear_hex2(), MBMesquite::DomainUtil::non_coplanar_vertices(), overlap_test_ray_fire(), overlap_test_tracking(), moab::GeomUtil::plucker_ray_tri_intersect(), moab::SmoothFace::project_to_facet_plane(), moab::SmoothFace::project_to_facets(), moab::FindVolumeIntRegCtxt::register_intersection(), MBMesquite::PatchData::reorder(), moab::SpectralQuad::reverseEvalFcn(), moab::GQT_IntRegCtxt::set_intersection(), test_bound_box(), test_ray_fire(), tri_mid_edge_nodes_edge_center(), and moab::ReadNCDF::update().
{ double d1 = p1[0] - p2[0]; double d2 = p1[1] - p2[1]; double d3 = p1[2] - p2[2]; return sqrt( d1 * d2 * d3 ); }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 56 of file jacobi_test.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::InstructionQueue::add_quality_assessor(), conn, dist(), MBMesquite::VertexMover::do_jacobi_optimization(), eps, fixed, MBMesquite::inner(), mesh, MBMesquite::outer(), MBMesquite::QUADRILATERAL, MBMesquite::IQInterface::run_instructions(), MBMesquite::InstructionQueue::set_master_quality_improver(), usage, MBMesquite::PatchSetUser::use_element_on_vertex_patch(), MBMesquite::MeshWriter::write_vtk(), and MBMesquite::PlanarDomain::XY.
{ const char* initial_mesh_file = 0; const char* final_mesh_file = 0; for( int i = 1; i < argc; ++i ) { if( !strcmp( argv[i], "-f" ) ) { ++i; if( i == argc ) usage( argv[0] ); final_mesh_file = argv[i]; } else if( !strcmp( argv[i], "-i" ) ) { ++i; if( i == argc ) usage( argv[0] ); initial_mesh_file = argv[i]; } else usage( argv[i] ); } // create mesh const int intervals = 3; const double perturb = 0.3; const int nvtx = ( intervals + 1 ) * ( intervals + 1 ); double coords[nvtx * 3]; double exp_coords[nvtx * 3]; int fixed[nvtx]; for( int i = 0; i < nvtx; ++i ) { double* c = coords + 3 * i; double* e = exp_coords + 3 * i; int row = i / ( intervals + 1 ); int col = i % ( intervals + 1 ); double xdelta, ydelta; if( row > 0 && row < intervals && col > 0 && col < intervals ) { fixed[i] = 0; xdelta = row % 2 ? -perturb : 0; ydelta = col % 2 ? perturb : -perturb; } else { fixed[i] = 1; xdelta = ydelta = 0.0; } c[0] = col + xdelta; c[1] = row + ydelta; c[2] = 0.0; e[0] = col; e[1] = row; e[2] = 0.0; } const int nquad = intervals * intervals; unsigned long conn[nquad * 4]; for( int i = 0; i < nquad; ++i ) { unsigned long* c = conn + 4 * i; int row = i / intervals; int col = i % intervals; int n0 = ( intervals + 1 ) * row + col; c[0] = n0; c[1] = n0 + 1; c[2] = n0 + intervals + 2; c[3] = n0 + intervals + 1; } MsqPrintError err( std::cerr ); ArrayMesh mesh( 3, nvtx, coords, fixed, nquad, QUADRILATERAL, conn ); PlanarDomain zplane( PlanarDomain::XY ); if( initial_mesh_file ) { MeshWriter::write_vtk( &mesh, initial_mesh_file, err ); if( err ) { fprintf( stderr, "%s: failed to write file\n", initial_mesh_file ); return 1; } } // do optimization const double eps = 0.01; IdealShapeTarget w; TShapeB1 mu; TQualityMetric metric( &w, &mu ); PMeanPTemplate func( 1.0, &metric ); SteepestDescent solver( &func ); solver.use_element_on_vertex_patch(); solver.do_jacobi_optimization(); TerminationCriterion inner, outer; inner.add_absolute_vertex_movement( 0.5 * eps ); outer.add_absolute_vertex_movement( 0.5 * eps ); QualityAssessor qa( &metric ); InstructionQueue q; q.add_quality_assessor( &qa, err ); q.set_master_quality_improver( &solver, err ); q.add_quality_assessor( &qa, err ); MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &zplane ); q.run_instructions( &mesh_and_domain, err ); if( err ) return 2; if( final_mesh_file ) { MeshWriter::write_vtk( &mesh, final_mesh_file, err ); if( err ) { fprintf( stderr, "%s: failed to write file\n", final_mesh_file ); return 1; } } // check final vertex positions int invalid = 0; for( int i = 0; i < nvtx; ++i ) { if( dist( coords + 3 * i, exp_coords + 3 * i ) > eps ) { ++invalid; printf( "Vertex %d at (%f,%f,%f), expected at (%f,%f,%f)\n", i, coords[3 * i], coords[3 * i + 1], coords[3 * i + 2], exp_coords[3 * i], exp_coords[3 * i + 1], exp_coords[3 * i + 2] ); } } return invalid ? 2 : 0; }
void usage | ( | const char * | argv0 | ) |
Definition at line 50 of file jacobi_test.cpp.
{ fprintf( stderr, "Usage: %s [-i <init_vtk_file>] [-f <final_vtk_file>]\n", argv0 ); exit( 1 ); }
