kd_tree_time.cpp File Reference
#include "moab/Core.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/Range.hpp"
#include <cerrno>
#include <cstdio>
#include <cstdlib>
#include <ctime>
+ Include dependency graph for kd_tree_time.cpp:
Functions
void usage (const char *argv0)
void print_file_stats (Interface &moab)
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 36 of file kd_tree_time.cpp.
References moab::AdaptiveKDTree::closest_triangle(), ErrorCode, moab::Tree::find_all_trees(), moab::Range::front(), leaf, length(), moab::Core::load_mesh(), MB_SUCCESS, moab::AdaptiveKDTree::point_search(), print_file_stats(), moab::Range::size(), t, and usage.
    double* values;
    unsigned long length;
    FILE *file, *rfile = 0;
    unsigned long count = 0;
    clock_t t;
    const char* tree_file   = 0;
    const char* point_file  = 0;
    const char* result_file = 0;
    bool query_triangles    = false;
    if( argc < 3 || argc > 7 ) usage( argv[0] );
    for( int i = 1; i < argc; ++i )
        if( !strcmp( "-t", argv[i] ) )
            query_triangles = true;
        else if( !strcmp( "-d", argv[i] ) )
            ++i;
            if( i == argc ) usage( argv[0] );
            result_file = argv[i];
        else if( !tree_file )
            tree_file = argv[i];
        else if( !point_file )
            point_file = argv[i];
        else
            char* endptr;
            count = strtol( argv[i], &endptr, 0 );
            if( *endptr || count < 1 ) usage( argv[0] );
    file = fopen( point_file, "rb" );
    if( !file )
        perror( point_file );
        return 2;
    fseek( file, 0, SEEK_END );
    length = ftell( file ) / ( 3 * sizeof( double ) );
    fseek( file, 0, SEEK_SET );
    values = new double[3 * length];
    if( length != fread( values, 3 * sizeof( double ), length, file ) )
        fprintf( stderr, "Error reading %lu points from file \"%s\"\n", length, argv[2] );
        delete[] values;
        return 2;
    fclose( file );
    if( result_file )
        rfile = fopen( result_file, "w" );
        if( !rfile )
            perror( result_file );
            delete[] values;
            return 2;
    if( !count ) count = length;
    printf( "Loading tree..." );
    fflush( stdout );
    t = clock();
    Core moab;
    ErrorCode rval = moab.load_mesh( tree_file, 0, 0 );
    if( MB_SUCCESS != rval )
        fprintf( stderr, "Failed to read file: %s\n", tree_file );
        delete[] values;
        return 2;
    printf( "%0.2f seconds\n", ( clock() - t ) / (double)CLOCKS_PER_SEC );
    fflush( stdout );
    Range range;
    AdaptiveKDTree tool( &moab );
    tool.find_all_trees( range );
    if( range.size() != 1 )
        fprintf( stderr, "%s : found %d kd-trees\n", argv[1], (int)range.size() );
        delete[] values;
        return 3;
    EntityHandle root = range.front();
    print_file_stats( moab );
    printf( "Running point queries..." );
    fflush( stdout );
    t = clock();
    EntityHandle leaf;
    double pt[3];
    for( unsigned long i = 0; i < count; ++i )
        const double* coords = values + 3 * ( i % length );
        if( query_triangles )
            rval = tool.closest_triangle( root, coords, pt, leaf );
        else
            rval = tool.point_search( coords, leaf, 0.0, 0.0, NULL, &root );
            fprintf( stderr, "Failure (ErrorCode == %d) for point %d (%f, %f, %f)\n", (int)rval,
                     (int)( count % length ), coords[0], coords[1], coords[2] );
        else if( rfile )
                fprintf( rfile, "%f %f %f %f %f %f %lu\n", coords[0], coords[1], coords[2], pt[0], pt[1], pt[2],
                         (unsigned long)leaf );
            else
                fprintf( rfile, "%f %f %f %lu\n", coords[0], coords[1], coords[2], (unsigned long)leaf );
    fflush( stdout );
    delete[] values;
    return 0;
void print_file_stats ( Interface moab)
Definition at line 17 of file kd_tree_time.cpp.
References moab::Range::clear(), ErrorCode, moab::Interface::estimated_memory_use(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), MB_SUCCESS, MBENTITYSET, MBTRI, and moab::Range::size().
Referenced by main().
    ErrorCode rval;
    int num_tri;
    Range sets;
    unsigned long long set_mem, set_am, tag_mem, tag_am;
    rval = moab.get_number_entities_by_type( 0, MBTRI, num_tri );
    if( MB_SUCCESS != rval ) num_tri = -1;
    rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );
    if( MB_SUCCESS != rval ) sets.clear();
    moab.estimated_memory_use( sets, 0, 0, &set_mem, &set_am, 0, 0, 0, 0, &tag_mem, &tag_am );
    printf( "Triangles:   %d\n", num_tri );
    printf( "Sets:        %lu\n", (unsigned long)sets.size() );
    printf( "Set storage: %llu (%llu)\n", set_mem, set_am );
    printf( "Tag storage: %llu (%llu)\n", tag_mem, tag_am );
void usage ( const char *  argv0)
Definition at line 11 of file kd_tree_time.cpp.
    fprintf( stderr, "usage: %s [-t] [-d <result_file>] <tree_file> <point_file> [<count>]\n", argv0 );
    exit( 1 );
