MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected], [email protected], [email protected], 00024 [email protected], [email protected], [email protected] 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3 00028 // -*- 00029 // 00030 // SUMMARY: 00031 // USAGE: 00032 // 00033 // ORIG-DATE: 19-Feb-02 at 10:57:52 00034 // LAST-MOD: 10-Feb-04 at 22:44:58 by Thomas Leurent 00035 // 00036 // 00037 // DESCRIPTION: 00038 // ============ 00039 /*! \file main.cpp 00040 00041 describe main.cpp here 00042 00043 */ 00044 // DESCRIP-END. 00045 // 00046 00047 #include "Mesquite.hpp" 00048 #include "MsqIMesh.hpp" 00049 #include "MeshImpl.hpp" 00050 #include "MsqError.hpp" 00051 #include "InstructionQueue.hpp" 00052 #include "TerminationCriterion.hpp" 00053 #include "QualityAssessor.hpp" 00054 #include "PlanarDomain.hpp" 00055 #include "MeshWriter.hpp" 00056 #include "TestUtil.hpp" 00057 00058 // algorithms 00059 #include "IdealWeightInverseMeanRatio.hpp" 00060 #include "EdgeLengthQualityMetric.hpp" 00061 #include "LPtoPTemplate.hpp" 00062 #include "FeasibleNewton.hpp" 00063 #include "ConjugateGradient.hpp" 00064 #include "SmartLaplacianSmoother.hpp" 00065 00066 #include <iostream> 00067 using std::cerr; 00068 using std::cout; 00069 using std::endl; 00070 00071 #include "iBase.h" 00072 00073 using namespace MBMesquite; 00074 00075 std::string default_file_name = TestDir + "unittest/mesquite/3D/vtk/large_box_hex_1000.vtk"; 00076 00077 void usage() 00078 { 00079 cout << "main [-N] [filename]" << endl; 00080 cout << " -N : Use native representation instead of TSTT implementation\n"; 00081 cout << " If no file name is specified, will use \"" << default_file_name << '"' << endl; 00082 exit( 1 ); 00083 } 00084 00085 // Construct a MeshTSTT from the file 00086 Mesh* get_imesh_mesh( const char* file_name ); 00087 00088 // Construct a MeshImpl from the file 00089 Mesh* get_native_mesh( const char* file_name ); 00090 00091 // Run FeasibleNewton solver 00092 int run_global_smoother( Mesh* mesh, MsqError& err ); 00093 00094 // Run SmoothLaplacian solver 00095 int run_local_smoother( Mesh* mesh, MsqError& err ); 00096 00097 int main( int argc, char* argv[] ) 00098 { 00099 MBMesquite::MsqPrintError err( cout ); 00100 00101 // command line arguments 00102 const char* file_name = 0; 00103 bool use_native = false, opts_done = false; 00104 for( int arg = 1; arg < argc; ++arg ) 00105 { 00106 if( !opts_done && argv[arg][0] == '-' ) 00107 { 00108 if( !strcmp( argv[arg], "-N" ) ) 00109 use_native = true; 00110 else if( !strcmp( argv[arg], "--" ) ) 00111 opts_done = true; 00112 else 00113 usage(); 00114 } 00115 else if( !file_name ) 00116 file_name = argv[arg]; 00117 else 00118 usage(); 00119 } 00120 if( !file_name ) 00121 { 00122 file_name = default_file_name.c_str(); 00123 cout << "No file specified: using default: " << default_file_name << endl; 00124 } 00125 00126 // Try running a global smoother on the mesh 00127 Mesh* mesh = use_native ? get_native_mesh( file_name ) : get_imesh_mesh( file_name ); 00128 if( !mesh ) 00129 { 00130 std::cerr << "Failed to load input file. Aborting." << std::endl; 00131 return 1; 00132 } 00133 00134 MeshWriter::write_vtk( mesh, "original.vtk", err ); 00135 if( err ) return 1; 00136 cout << "Wrote \"original.vtk\"" << endl; 00137 run_global_smoother( mesh, err ); 00138 if( err ) return 1; 00139 00140 // Try running a local smoother on the mesh 00141 mesh = use_native ? get_native_mesh( file_name ) : get_imesh_mesh( file_name ); 00142 if( !mesh ) 00143 { 00144 std::cerr << "Failed to load input file. Aborting." << std::endl; 00145 return 1; 00146 } 00147 00148 run_local_smoother( mesh, err ); 00149 if( err ) return 1; 00150 00151 return 0; 00152 } 00153 00154 int run_global_smoother( Mesh* mesh, MsqError& err ) 00155 { 00156 double OF_value = 0.0001; 00157 00158 // creates an intruction queue 00159 InstructionQueue queue1; 00160 00161 // creates a mean ratio quality metric ... 00162 IdealWeightInverseMeanRatio* mean_ratio = new IdealWeightInverseMeanRatio( err ); 00163 if( err ) return 1; 00164 mean_ratio->set_averaging_method( QualityMetric::SUM, err ); 00165 if( err ) return 1; 00166 00167 // ... and builds an objective function with it 00168 LPtoPTemplate* obj_func = new LPtoPTemplate( mean_ratio, 1, err ); 00169 if( err ) return 1; 00170 00171 // creates the feas newt optimization procedures 00172 FeasibleNewton* pass1 = new FeasibleNewton( obj_func ); 00173 pass1->use_global_patch(); 00174 if( err ) return 1; 00175 00176 QualityAssessor stop_qa( mean_ratio ); 00177 00178 // **************Set stopping criterion**************** 00179 TerminationCriterion tc_inner; 00180 tc_inner.add_absolute_vertex_movement( OF_value ); 00181 if( err ) return 1; 00182 TerminationCriterion tc_outer; 00183 tc_outer.add_iteration_limit( 1 ); 00184 pass1->set_inner_termination_criterion( &tc_inner ); 00185 pass1->set_outer_termination_criterion( &tc_outer ); 00186 00187 queue1.add_quality_assessor( &stop_qa, err ); 00188 if( err ) return 1; 00189 00190 // adds 1 pass of pass1 to mesh_set1 00191 queue1.set_master_quality_improver( pass1, err ); 00192 if( err ) return 1; 00193 00194 queue1.add_quality_assessor( &stop_qa, err ); 00195 if( err ) return 1; 00196 00197 // launches optimization on mesh_set 00198 queue1.run_instructions( mesh, err ); 00199 if( err ) return 1; 00200 00201 MeshWriter::write_vtk( mesh, "feasible-newton-result.vtk", err ); 00202 if( err ) return 1; 00203 cout << "Wrote \"feasible-newton-result.vtk\"" << endl; 00204 00205 // print_timing_diagnostics( cout ); 00206 return 0; 00207 } 00208 00209 int run_local_smoother( Mesh* mesh, MsqError& err ) 00210 { 00211 double OF_value = 0.0001; 00212 00213 // creates an intruction queue 00214 InstructionQueue queue1; 00215 00216 // creates a mean ratio quality metric ... 00217 IdealWeightInverseMeanRatio* mean_ratio = new IdealWeightInverseMeanRatio( err ); 00218 if( err ) return 1; 00219 mean_ratio->set_averaging_method( QualityMetric::SUM, err ); 00220 if( err ) return 1; 00221 00222 // ... and builds an objective function with it 00223 LPtoPTemplate* obj_func = new LPtoPTemplate( mean_ratio, 1, err ); 00224 if( err ) return 1; 00225 00226 // creates the smart laplacian optimization procedures 00227 SmartLaplacianSmoother* pass1 = new SmartLaplacianSmoother( obj_func ); 00228 00229 QualityAssessor stop_qa( mean_ratio ); 00230 00231 // **************Set stopping criterion**************** 00232 TerminationCriterion tc_inner; 00233 tc_inner.add_absolute_vertex_movement( OF_value ); 00234 TerminationCriterion tc_outer; 00235 tc_outer.add_iteration_limit( 1 ); 00236 pass1->set_inner_termination_criterion( &tc_inner ); 00237 pass1->set_outer_termination_criterion( &tc_outer ); 00238 00239 queue1.add_quality_assessor( &stop_qa, err ); 00240 if( err ) return 1; 00241 00242 // adds 1 pass of pass1 to mesh_set 00243 queue1.set_master_quality_improver( pass1, err ); 00244 if( err ) return 1; 00245 00246 queue1.add_quality_assessor( &stop_qa, err ); 00247 if( err ) return 1; 00248 00249 // launches optimization on mesh_set 00250 queue1.run_instructions( mesh, err ); 00251 if( err ) return 1; 00252 00253 MeshWriter::write_vtk( mesh, "smart-laplacian-result.vtk", err ); 00254 if( err ) return 1; 00255 cout << "Wrote \"smart-laplacian-result.vtk\"" << endl; 00256 00257 // print_timing_diagnostics( cout ); 00258 return 0; 00259 } 00260 00261 Mesh* get_imesh_mesh( const char* file_name ) 00262 { 00263 int ierr; 00264 iMesh_Instance imesh_mesh = 0; 00265 iMesh_newMesh( NULL, &imesh_mesh, &ierr, 0 ); 00266 if( iBase_SUCCESS != ierr ) 00267 { 00268 return 0; 00269 } 00270 00271 iBase_EntitySetHandle root_set; 00272 iMesh_getRootSet( imesh_mesh, &root_set, &ierr ); 00273 if( iBase_SUCCESS != ierr ) 00274 { 00275 iMesh_dtor( imesh_mesh, &ierr ); 00276 return 0; 00277 } 00278 00279 iMesh_load( imesh_mesh, root_set, file_name, 0, &ierr, strlen( file_name ), 0 ); 00280 if( iBase_SUCCESS != ierr ) 00281 { 00282 std::cerr << file_name << ": failed to load file." << std::endl; 00283 iMesh_dtor( imesh_mesh, &ierr ); 00284 return 0; 00285 } 00286 00287 iBase_TagHandle fixed_tag; 00288 iMesh_getTagHandle( imesh_mesh, "fixed", &fixed_tag, &ierr, strlen( "fixed" ) ); 00289 if( iBase_SUCCESS != ierr ) 00290 { 00291 iMesh_dtor( imesh_mesh, &ierr ); 00292 return 0; 00293 } 00294 00295 MsqError err; 00296 Mesh* result = new MBMesquite::MsqIMesh( imesh_mesh, root_set, iBase_REGION, err, &fixed_tag ); 00297 if( MSQ_CHKERR( err ) ) 00298 { 00299 delete result; 00300 cerr << err << endl; 00301 return 0; 00302 } 00303 00304 return result; 00305 } 00306 00307 Mesh* get_native_mesh( const char* file_name ) 00308 { 00309 MsqError err; 00310 MeshImpl* mesh = new MeshImpl; 00311 mesh->read_vtk( file_name, err ); 00312 if( err ) 00313 { 00314 cerr << err << endl; 00315 exit( 3 ); 00316 } 00317 00318 return mesh; 00319 }
