mbpart.cpp File Reference
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/ReorderTool.hpp"
#include <iostream>
#include <sstream>
#include <cmath>
#include <cstdlib>
#include <list>
#include <ctime>
#include "moab/IntxMesh/IntxUtils.hpp"
+ Include dependency graph for mbpart.cpp:
Typedefs
typedef int PartType
Functions
int main (int argc, char *argv[])
Variables
std::string DEFAULT_TAGGEDSETS_TAG = "PARALLEL_PARTITION"
const char DEFAULT_ZOLTAN_METHOD [] = "RCB"
const char METIS_DEFAULT_METHOD [] = "ML_KWAY"
const char BRIEF_DESC [] = "Use Zoltan or Metis to partition MOAB meshes for use on parallel computers"
std::ostringstream LONG_DESC
Typedef Documentation
Definition at line 23 of file mbpart.cpp.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 51 of file mbpart.cpp.
References ProgOptions::addOpt(), BRIEF_DESC, moab::Interface::create_meshset(), DEFAULT_TAGGEDSETS_TAG, DEFAULT_ZOLTAN_METHOD, dim, ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_dimension(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), ZoltanPartitioner::include_closure(), input_file, ProgOptions::int_flag, moab::Interface::load_file(), moab::Interface::load_mesh(), LONG_DESC, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, MESHSET_SET, METIS_DEFAULT_METHOD, ZoltanPartitioner::partition_inferred_mesh(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), print_time(), moab::ReorderTool::reorder_entities(), moab::IntxUtils::ScaleToRadius(), PartitionerBase< T >::set_global_id_option(), moab::Range::size(), t, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
#ifdef MOAB_HAVE_MPI
    int err = MPI_Init( &argc, &argv );
    if( err )
        std::cerr << "MPI_Init failed.  Aborting." << std::endl;
        return 3;
#endif
    Core moab;
    Interface& mb = moab;
    std::vector< int > set_l;
#ifdef MOAB_HAVE_ZOLTAN
    bool moab_use_zoltan = false;
#endif
#ifdef MOAB_HAVE_METIS
    bool moab_use_metis = false;
#endif
    LONG_DESC << "This utility invokes the ZoltanPartitioner or MetisPartitioner component of MOAB/CGM "
                 "to partition a mesh/geometry."
              << std::endl
              << "If no partitioning method is specified, the defaults are: "
              << "for Zoltan=\"" << DEFAULT_ZOLTAN_METHOD << "\" and Metis=\"" << METIS_DEFAULT_METHOD << " method"
              << std::endl;
    ProgOptions opts( LONG_DESC.str(), BRIEF_DESC );
    int part_dim = 3;
    opts.addOpt< int >( "dimension",
                        "Specify dimension of entities to partition."
                        "  Default is  largest in file.",
                        &part_dim, ProgOptions::int_flag );
    std::string zoltan_method, parm_method, oct_method, metis_method;
    opts.addOpt< std::string >( "zoltan,z",
                                "(Zoltan) Specify Zoltan partition method.  "
                                "One of RR, RCB, RIB, HFSC, PHG, or Hypergraph (PHG and Hypergraph "
                                "are synonymous).",
                                &zoltan_method );
#ifdef MOAB_HAVE_PARMETIS
    opts.addOpt< std::string >( "parmetis,p", "(Zoltan+PARMetis) Specify PARMetis partition method.", &parm_method );
#endif  // MOAB_HAVE_PARMETIS
    opts.addOpt< std::string >( "octpart,o", "(Zoltan) Specify OctPart partition method.", &oct_method );
    bool incl_closure = false;
    opts.addOpt< void >( "include_closure,c", "Include element closure for part sets.", &incl_closure );
    bool recompute_box_rcb = false;
    opts.addOpt< void >( "recompute_rcb_box,b", "recompute box in rcb cuts", &recompute_box_rcb );
#endif  // MOAB_HAVE_ZOLTAN
    double imbal_tol = 1.03;
    opts.addOpt< double >( "imbalance,i", "Imbalance tolerance (used in PHG/Hypergraph method)", &imbal_tol );
    opts.addOpt< std::string >( "metis,m", "(Metis) Specify Metis partition method. One of ML_RB or ML_KWAY.",
                                &metis_method );
#endif  // MOAB_HAVE_METIS
    bool write_sets = true, write_tags = false;
    opts.addOpt< void >( "sets,s", "Write partition as tagged sets (Default)", &write_sets );
    opts.addOpt< void >( "tags,t", "Write partition by tagging entities", &write_tags );
    int power = -1;
    opts.addOpt< int >( "power,M", "Generate multiple partitions, in powers of 2, up to 2^(pow)", &power );
    bool reorder = false;
    opts.addOpt< void >( "reorder,R", "Reorder mesh to group entities by partition", &reorder );
    double part_geom_mesh_size = -1.0;
    bool part_surf = false;
#ifdef MOAB_HAVE_CGM
    opts.addOpt< double >( "geom,g", "(CGM) If partition geometry, specify mesh size.", &part_geom_mesh_size );
    opts.addOpt< void >( "surf,f", "(CGM) Specify if partition geometry surface.", &part_surf );
#endif  // MOAB_HAVE_CGM
    bool ghost = false;
    opts.addOpt< void >( "ghost,H", "(Zoltan) Specify if partition ghost geometry body." );
    int obj_weight = 0;
    opts.addOpt< int >( "vertex_w,v", "(Zoltan) Number of weights associated with a graph vertex." );
    int edge_weight = 0;
    opts.addOpt< int >( "edge_w,e", "(Zoltan) Number of weights associated with an edge." );
    bool moab_partition_slave   = false;
    std::string slave_file_name = "";
    opts.addOpt< std::string >( "inferred",
                                "(Zoltan) Specify inferred slave mesh file name to impose "
                                "partition based on cuts computed for original master mesh.",
                                &slave_file_name );
    bool rescale_spherical_radius = false;
    opts.addOpt< void >( "scale_sphere",
                         "(Zoltan) If the meshes are defined on a sphere, rescale radius as needed "
                         "(in combination with --inferred)",
                         &rescale_spherical_radius );
    long num_parts;
    opts.addOpt< std::vector< int > >( "set_l,l",
                                       "Load material set(s) with specified ids (comma separated) for partition" );
    opts.addRequiredArg< int >( "#parts", "Number of parts in partition" );
    std::string input_file, output_file;
    opts.addRequiredArg< std::string >( "input_file", "Mesh/geometry to partition", &input_file );
    opts.addRequiredArg< std::string >( "output_file", "File to which to write partitioned mesh/geometry",
                                        &output_file );
    bool print_time = false;
    opts.addOpt< void >( ",T", "Print CPU time for each phase.", &print_time );
    int projection_type = 0;
    opts.addOpt< int >( "project_on_sphere,p",
                        "use spherical coordinates (1) or gnomonic projection (2) for partitioning ",
                        &projection_type );
    bool partition_tagged_sets = false;
    opts.addOpt< void >( "taggedsets,x", "(Metis) Partition tagged sets.", &partition_tagged_sets );
    bool partition_tagged_ents = false;
    opts.addOpt< void >( "taggedents,y", "(Metis) Partition tagged ents.", &partition_tagged_ents );
    std::string aggregating_tag;
    opts.addOpt< std::string >( "aggregatingtag,a",
                                "(Metis) Specify aggregating tag to partion tagged sets or tagged entities.",
                                &aggregating_tag );
    std::string aggregating_bc_tag;
    opts.addOpt< std::string >( "aggregatingBCtag,B",
                                "(Metis) Specify boundary id tag name used to group cells with same boundary ids.",
                                &aggregating_bc_tag );
    std::string boundaryIds;
    std::vector< int > BCids;
    opts.addOpt< std::string >( "aggregatingBCids,I",
                                " (Metis) Specify id or ids of boundaries to be aggregated before "
                                "partitioning (all elements with same boundary id will be in the "
                                "same partition). Comma separated e.g. -I 1,2,5 ",
                                &boundaryIds );
    bool assign_global_ids = false;
    opts.addOpt< void >( "globalIds,j", "Assign GLOBAL_ID tag to entities", &assign_global_ids );
    opts.parseCommandLine( argc, argv );
    if( !zoltan_method.empty() )
        moab_use_zoltan = true;
    else
#endif
        if( !metis_method.empty() )
        moab_use_metis = true;
    else
#endif
        MB_SET_ERR( MB_FAILURE, "Specify either Zoltan or Metis partitioner type" );
    ZoltanPartitioner* zoltan_tool = NULL;
    // check if partition geometry, if it is, should get mesh size for the geometry
    if( part_geom_mesh_size != -1.0 && part_geom_mesh_size <= 0.0 )
        std::cerr << part_geom_mesh_size << ": invalid geometry partition mesh size." << std::endl << std::endl;
        opts.printHelp();
        return EXIT_FAILURE;
    if( slave_file_name.size() ) moab_partition_slave = true;
    if( moab_use_zoltan )
        if( part_geom_mesh_size < 0. )
            // partition mesh we have no ParallelComm here, so we will create one later
            zoltan_tool = new ZoltanPartitioner( &mb, NULL, false, argc, argv );
        else
            // partition geometry
            CubitStatus status = InitCGMA::initialize_cgma();
            if( CUBIT_SUCCESS != status )
                std::cerr << "CGM couldn't be initialized." << std::endl << std::endl;
                opts.printHelp();
            GeometryQueryTool* gti = GeometryQueryTool::instance();
            // no ParallelComm so far
            zoltan_tool            = new ZoltanPartitioner( &mb, NULL, false, argc, argv, gti );
#else
            std::cerr << "CGM should be configured to partition geometry." << std::endl << std::endl;
            opts.printHelp();
        zoltan_tool->set_global_id_option( assign_global_ids );
    if( zoltan_method.empty() && parm_method.empty() && oct_method.empty() ) zoltan_method = DEFAULT_ZOLTAN_METHOD;
    if( !parm_method.empty() ) zoltan_method = ZOLTAN_PARMETIS_METHOD;
    if( !oct_method.empty() ) zoltan_method = ZOLTAN_OCTPART_METHOD;
    MetisPartitioner* metis_tool = NULL;
    if( moab_use_metis && !metis_tool )
        metis_tool = new MetisPartitioner( &mb, false );
        metis_tool->set_global_id_option( assign_global_ids );
    if( ( aggregating_tag.empty() && partition_tagged_sets ) || ( aggregating_tag.empty() && partition_tagged_ents ) )
        aggregating_tag = DEFAULT_TAGGEDSETS_TAG;
    if( !write_sets && !write_tags ) write_sets = true;
    if( !boundaryIds.empty() )
        std::vector< std::string > ids;
        std::stringstream ss( boundaryIds );
        std::string item;
        while( std::getline( ss, item, ',' ) )
            ids.push_back( item );
        for( unsigned int i = 0; i < ids.size(); i++ )
            BCids.push_back( std::atoi( ids[i].c_str() ) );
    if( metis_method.empty() )
        metis_method = METIS_DEFAULT_METHOD;
    if( -1 == power )
        num_parts = opts.getReqArg< int >( "#parts" );
        power     = 1;
    else if( power < 1 || power > 18 )
        std::cerr << power << ": invalid power for multiple partitions. Expected value in [1,18]" << std::endl
                  << std::endl;
        opts.printHelp();
    else
        num_parts = 2;
    if( part_dim < 0 || part_dim > 3 )
        std::cerr << part_dim << " : invalid dimension" << std::endl << std::endl;
        opts.printHelp();
    if( imbal_tol < 0.0 )
        std::cerr << imbal_tol << ": invalid imbalance tolerance" << std::endl << std::endl;
        opts.printHelp();
    bool load_msets = false;
    if( opts.getOpt( "set_l,l", &set_l ) )
        load_msets = true;
        if( set_l.size() <= 0 )
            std::cerr << " No material set id's to load" << std::endl << std::endl;
            opts.printHelp();
    if( num_parts <= 1 )
        std::cerr << "** Please specify #parts = " << num_parts << " to be greater than 1." << std::endl << std::endl;
        opts.printHelp();
    clock_t t = clock();
    const char* options = NULL;
    ErrorCode rval;
    if( part_geom_mesh_size > 0. ) options = "FACET_DISTANCE_TOLERANCE=0.1";
    std::cout << "Loading file " << input_file << "..." << std::endl;
    if( load_msets == false )
        rval = mb.load_file( input_file.c_str(), 0, options );MB_CHK_SET_ERR( rval, "Failed to load input file: " + input_file );
    else  // load the material set(s)
        rval = mb.load_mesh( input_file.c_str(), &set_l[0], (int)set_l.size() );MB_CHK_SET_ERR( rval, "Failed to load input mesh: " + input_file );
    if( print_time )
        std::cout << "Read input file in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl;
    for( int dim = part_dim; dim >= 0; --dim )
        int n;
        rval = mb.get_number_entities_by_dimension( 0, dim, n );
        if( MB_SUCCESS == rval && 0 != n )
            part_dim = dim;
            break;
    if( part_dim < 0 )
        std::cerr << input_file << " : file does not contain any mesh entities" << std::endl;
        return 2;
    ReorderTool reorder_tool( &moab );
    for( int p = 0; p < power; p++ )
        t = clock();
            rval = zoltan_tool->partition_mesh_and_geometry(
                part_geom_mesh_size, num_parts, zoltan_method.c_str(),
                ( !parm_method.empty() ? parm_method.c_str() : oct_method.c_str() ), imbal_tol, part_dim, write_sets,
                write_tags, obj_weight, edge_weight, part_surf, ghost, projection_type, recompute_box_rcb, print_time );MB_CHK_SET_ERR( rval, "Zoltan partitioner failed." );
#endif
        if( moab_use_metis )
            rval = metis_tool->partition_mesh( num_parts, metis_method.c_str(), part_dim, write_sets, write_tags,
                                               partition_tagged_sets, partition_tagged_ents, aggregating_tag.c_str(),
                                               print_time );MB_CHK_SET_ERR( rval, "Metis partitioner failed." );
#endif
        if( print_time )
            std::cout << "Generated " << num_parts << " part partitioning in "
        if( reorder && part_geom_mesh_size < 0. )
            std::cout << "Reordering mesh for partition..." << std::endl;
            Tag tag, order;
            rval = mb.tag_get_handle( DEFAULT_TAGGEDSETS_TAG.c_str(), 1, MB_TYPE_INTEGER, tag );MB_CHK_SET_ERR( rval, "Partitioner did not create " + DEFAULT_TAGGEDSETS_TAG + " tag" );
            t = clock();
            if( write_sets )
                Range sets;
                mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets );
                rval = reorder_tool.handle_order_from_sets_and_adj( sets, order );MB_CHK_SET_ERR( rval, "Failed to calculate reordering." );
            else
                rval = reorder_tool.handle_order_from_int_tag( tag, -1, order );MB_CHK_SET_ERR( rval, "Failed to calculate reordering." );
            rval = reorder_tool.reorder_entities( order );MB_CHK_SET_ERR( rval, "Failed to perform reordering." );
            rval = mb.tag_delete( order );MB_CHK_SET_ERR( rval, "Failed to delete tag." );
            if( print_time )
                std::cout << "Reordered mesh in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds"
                          << std::endl;
        if( incl_closure )
            rval = zoltan_tool->include_closure();MB_CHK_SET_ERR( rval, "Closure inclusion failed." );
#endif
        std::ostringstream tmp_output_file;
        if( power > 1 )
            // append num_parts to output filename
            std::string::size_type idx = output_file.find_last_of( "." );
            if( idx == std::string::npos )
                tmp_output_file << output_file << "_" << num_parts;
                    tmp_output_file << ".h5m";
                else
                    std::cerr << "output file type is not specified." << std::endl;
                    return 1;
            else
                tmp_output_file << output_file.substr( 0, idx ) << "_" << num_parts << output_file.substr( idx );
        else
            tmp_output_file << output_file;
        t = clock();
        std::cout << "Saving file to " << output_file << "..." << std::endl;
            rval = mb.write_file( tmp_output_file.str().c_str() );MB_CHK_SET_ERR( rval, tmp_output_file.str() << " : failed to write file." << std::endl );
        else
            int c_size                 = output_file.length() - idx;
            const char* file_type      = NULL;
            if( output_file.compare( idx, c_size, ".occ" ) == 0 || output_file.compare( idx, c_size, ".OCC" ) == 0 )
                file_type = "OCC";
            else if( output_file.compare( idx, c_size, ".sab" ) == 0 )
                file_type = "ACIS_SAB";
            else if( output_file.compare( idx, c_size, ".sat" ) == 0 )
                file_type = "ACIS_SAT";
            else
                std::cerr << "File type for " << output_file.c_str() << " not supported." << std::endl;
                return 1;
            int num_ents_exported = 0;
            DLIList< RefEntity* > ref_entity_list;
                CubitCompat_export_solid_model( ref_entity_list, tmp_output_file.str().c_str(), file_type,
                                                num_ents_exported, CubitString( __FILE__ ) );
                std::cerr << "CGM couldn't export models." << std::endl;
                return 1;
#endif
#endif
        if( print_time )
            std::cout << "Wrote \"" << tmp_output_file.str() << "\" in " << ( clock() - t ) / (double)CLOCKS_PER_SEC
        if( moab_use_zoltan && moab_partition_slave && p == 0 )
            t = clock();
            double master_radius, slave_radius;
            if( rescale_spherical_radius )
                EntityHandle rootset = 0;
                Range masterverts;
                rval = mb.get_entities_by_dimension( rootset, 0, masterverts );MB_CHK_SET_ERR( rval, "Can't create vertices on master set" );
                double points[6];
                EntityHandle mfrontback[2] = { masterverts[0], masterverts[masterverts.size() - 1] };
                rval                       = mb.get_coords( &mfrontback[0], 2, points );MB_CHK_ERR( rval );
                const double mr1 = std::sqrt( points[0] * points[0] + points[1] * points[1] + points[2] * points[2] );
                const double mr2 = std::sqrt( points[3] * points[3] + points[4] * points[4] + points[5] * points[5] );
                master_radius    = 0.5 * ( mr1 + mr2 );
            EntityHandle slaveset;
            rval = mb.create_meshset( moab::MESHSET_SET, slaveset );MB_CHK_SET_ERR( rval, "Can't create new set" );
            rval = mb.load_file( slave_file_name.c_str(), &slaveset, options );MB_CHK_SET_ERR( rval, "Can't load slave mesh" );
                double points[6];
                Range slaveverts;
                rval = mb.get_entities_by_dimension( slaveset, 0, slaveverts );MB_CHK_SET_ERR( rval, "Can't create vertices on master set" );
                EntityHandle sfrontback[2] = { slaveverts[0], slaveverts[slaveverts.size() - 1] };
                rval                       = mb.get_coords( &sfrontback[0], 2, points );MB_CHK_ERR( rval );
                const double sr1 = std::sqrt( points[0] * points[0] + points[1] * points[1] + points[2] * points[2] );
                const double sr2 = std::sqrt( points[3] * points[3] + points[4] * points[4] + points[5] * points[5] );
                slave_radius     = 0.5 * ( sr1 + sr2 );
                // Let us rescale both master and slave meshes to a unit sphere
                rval = moab::IntxUtils::ScaleToRadius( &mb, slaveset, master_radius );MB_CHK_ERR( rval );
            rval = zoltan_tool->partition_inferred_mesh( slaveset, num_parts, part_dim, write_sets, projection_type );MB_CHK_ERR( rval );
                // rescale the slave mesh back to its original radius
                rval = moab::IntxUtils::ScaleToRadius( &mb, slaveset, slave_radius );MB_CHK_ERR( rval );
            if( print_time )
                std::cout << "Time taken to infer slave mesh partitions = " << ( clock() - t ) / (double)CLOCKS_PER_SEC
            size_t lastindex                 = slave_file_name.find_last_of( "." );
            std::string inferred_output_file = slave_file_name.substr( 0, lastindex ) + "_inferred" +
                                               slave_file_name.substr( lastindex, slave_file_name.size() );
            // Save the resulting mesh
            std::cout << "Saving inferred file to " << inferred_output_file << "..." << std::endl;
            rval = mb.write_file( inferred_output_file.c_str(), 0, 0, &slaveset, 1 );MB_CHK_SET_ERR( rval, inferred_output_file << " : failed to write file." << std::endl );
#endif
        num_parts *= 2;
    delete zoltan_tool;
#endif
    delete metis_tool;
#endif
    err = MPI_Finalize();
    assert( MPI_SUCCESS == err );
#endif
    return 0;
Variable Documentation
const char BRIEF_DESC[] = "Use Zoltan or Metis to partition MOAB meshes for use on parallel computers"
Definition at line 48 of file mbpart.cpp.
Definition at line 37 of file mbpart.cpp.
Referenced by main().
const char DEFAULT_ZOLTAN_METHOD[] = "RCB"
Definition at line 39 of file mbpart.cpp.
Definition at line 49 of file mbpart.cpp.
const char METIS_DEFAULT_METHOD[] = "ML_KWAY"
Definition at line 45 of file mbpart.cpp.
