quality.cpp File Reference
#include "CLArgs.hpp"
#include "QualityAssessor.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "SizeMetric.hpp"
#include "TQualityMetric.hpp"
#include "IdealShapeTarget.hpp"
#include "TShapeNB1.hpp"
#include "InstructionQueue.hpp"
#include "MsqError.hpp"
#include "MeshImpl.hpp"
#include "ElementMaxQM.hpp"
#include "domain.hpp"
#include <vector>
#include <algorithm>
+ Include dependency graph for mesquite/quality.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 22 of file mesquite/quality.cpp.
References add_domain_args(), CLArgs::add_optional_arg(), MBMesquite::InstructionQueue::add_quality_assessor(), CLArgs::add_required_arg(), args, CLArgs::int_flag(), mesh, CLArgs::parse_options(), CLArgs::print_usage(), process_domain_args(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), CLArgs::ArgIBase::seen(), size, CLArgs::toggle_flag(), CLArgs::ArgTemplate< T >::value(), CLArgs::IntRangeArg::value(), and MBMesquite::MeshImpl::write_vtk().
    int two;
    CLArgs::ToggleArg freeonly;
    CLArgs::IntRangeArg histogram( &two );
    CLArgs args( "msqquality", "Assess mesh quality",
                 "Caculate various quality metrics for a mesh,"
                 "and optinally export a VTK file for which quality "
                 "values are stored as attribute data." );
    args.int_flag( 'H', "ints", "Print histograms with specified number of intervals", &histogram );
    args.toggle_flag( 'f', "Assess quality only for elements with at least one free vertex", &freeonly );
    args.add_required_arg( "input_file" );
    args.add_optional_arg( "output_file" );
    add_domain_args( args );
    std::vector< std::string > files;
    if( !args.parse_options( argc, argv, files, std::cerr ) )
        args.print_usage( std::cerr );
        return 1;
    MsqError err;
    MeshImpl mesh;
    mesh.read_vtk( files.front().c_str(), err );
    if( err )
        std::cerr << err << std::endl << "Failed to read file: " << files.front() << std::endl;
        return 2;
    MeshDomain* domain = process_domain_args( &mesh );
    QualityAssessor qa( true, freeonly.value(), "INVERTED" );
    IdealWeightInverseMeanRatio imr;
    SizeMetric size;
    IdealShapeTarget tc;
    TShapeNB1 tm;
    TQualityMetric tmp( &tc, &tm );
    ElementMaxQM max_tmp( &tmp );
    int intervals = histogram.seen() ? histogram.value() : 0;
    qa.add_quality_assessment( &imr, intervals, 0.0, "InverseMeanRatio" );
    qa.add_quality_assessment( &size, intervals, 0.0, "Size" );
    qa.add_quality_assessment( &max_tmp, intervals, 0.0, "TMP_Shape" );
    qa.tag_fixed_elements( "FIXED_ELEMS" );
    //  QuadLagrangeShape quad;
    //  TriLagrangeShape tri;
    //  TetLagrangeShape tet;
    InstructionQueue q;
    //  q.set_mapping_function( &quad );
    //  q.set_mapping_function( &tri );
    //  q.set_mapping_function( &tet );
    q.add_quality_assessor( &qa, err );
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, domain );
    q.run_instructions( &mesh_and_domain, err );
    delete domain;
    if( err )
        std::cerr << err << std::endl;
        return 3;
    if( files.size() > 1 )
        mesh.write_vtk( files[1].c_str(), err );
        if( err )
            std::cerr << err << std::endl << "Failed to write file: " << files[1] << std::endl;
            return 2;
    return 0;
