mpastrvpart.cpp
00001 #include "TestUtil.hpp"
00002 #include "moab/Core.hpp"
00003 #include "moab/ParallelComm.hpp"
00004 #include "moab/ProgOptions.hpp"
00005 #include "MBParallelConventions.h"
00006 #include "moab/ReadUtilIface.hpp"
00007 #include "MBTagConventions.hpp"
00008
00009 #include <sstream>
00010
00011 using namespace moab;
00012
00013 std::string example = TestDir + "unittest/io/mpasx1.642.t.2.nc";
00014
00015 void test_read_onevar_trivial();
00016 void test_read_onevar_trivial_no_mixed_elements();
00017 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN )
00018 void test_read_onevar_rcbzoltan();
00019 void test_read_onevar_rcbzoltan_no_mixed_elements();
00020 #endif
00021
00022 void test_read_mesh_parallel_trivial();
00023 void test_read_mesh_parallel_trivial_no_mixed_elements();
00024 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN )
00025 void test_read_mesh_parallel_rcbzoltan();
00026 void test_read_mesh_parallel_rcbzoltan_no_mixed_elements();
00027 #endif
00028
00029 void test_gather_onevar_on_rank0();
00030 void test_gather_onevar_on_rank1();
00031
00032 void test_multiple_loads_of_same_file();
00033 void test_multiple_loads_of_same_file_no_mixed_elements();
00034
00035 // Helper functions
00036 void read_one_cell_var( bool rcbzoltan, bool no_mixed_elements );
00037 void read_mesh_parallel( bool rcbzoltan, bool no_mixed_elements );
00038 void gather_one_cell_var( int gather_set_rank );
00039 void multiple_loads_of_same_file( bool no_mixed_elements );
00040
00041 std::string read_options;
00042 const double eps = 1e-20;
00043
00044 int main( int argc, char* argv[] )
00045 {
00046     MPI_Init( &argc, &argv );
00047     int result = 0;
00048
00049     result += RUN_TEST( test_read_onevar_trivial );
00050     result += RUN_TEST( test_read_onevar_trivial_no_mixed_elements );
00051 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN )
00052     result += RUN_TEST( test_read_onevar_rcbzoltan );
00053     result += RUN_TEST( test_read_onevar_rcbzoltan_no_mixed_elements );
00054 #endif
00055
00056     result += RUN_TEST( test_read_mesh_parallel_trivial );
00057     result += RUN_TEST( test_read_mesh_parallel_trivial_no_mixed_elements );
00058 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN )
00059     result += RUN_TEST( test_read_mesh_parallel_rcbzoltan );
00060     result += RUN_TEST( test_read_mesh_parallel_rcbzoltan_no_mixed_elements );
00061 #endif
00062
00063     result += RUN_TEST( test_gather_onevar_on_rank0 );
00064     result += RUN_TEST( test_gather_onevar_on_rank1 );
00065
00066     result += RUN_TEST( test_multiple_loads_of_same_file );
00067     result += RUN_TEST( test_multiple_loads_of_same_file_no_mixed_elements );
00068
00069     MPI_Finalize();
00070     return result;
00071 }
00072
00073 void test_read_onevar_trivial()
00074 {
00075     read_one_cell_var( false, false );
00076 }
00077
00078 void test_read_onevar_trivial_no_mixed_elements()
00079 {
00080     read_one_cell_var( false, true );
00081 }
00082
00083 void test_read_onevar_rcbzoltan()
00084 {
00085     read_one_cell_var( true, false );
00086 }
00087
00088 void test_read_onevar_rcbzoltan_no_mixed_elements()
00089 {
00090     read_one_cell_var( true, true );
00091 }
00092
00093 void test_read_mesh_parallel_trivial()
00094 {
00095     read_mesh_parallel( false, false );
00096 }
00097
00098 void test_read_mesh_parallel_trivial_no_mixed_elements()
00099 {
00100     read_mesh_parallel( false, true );
00101 }
00102
00103 void test_read_mesh_parallel_rcbzoltan()
00104 {
00105     read_mesh_parallel( true, false );
00106 }
00107
00108 void test_read_mesh_parallel_rcbzoltan_no_mixed_elements()
00109 {
00110     read_mesh_parallel( true, true );
00111 }
00112
00113 void test_gather_onevar_on_rank0()
00114 {
00115     gather_one_cell_var( 0 );
00116 }
00117
00118 void test_gather_onevar_on_rank1()
00119 {
00120     gather_one_cell_var( 1 );
00121 }
00122
00123 void test_multiple_loads_of_same_file()
00124 {
00125     multiple_loads_of_same_file( false );
00126 }
00127
00128 void test_multiple_loads_of_same_file_no_mixed_elements()
00129 {
00130     multiple_loads_of_same_file( true );
00131 }
00132
00133 // Helper functions
00134 void read_one_cell_var( bool rcbzoltan, bool no_mixed_elements )
00135 {
00136     Core moab;
00137     Interface& mb = moab;
00138
00139     read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;NO_EDGES;VARIABLE=ke";
00140     if( rcbzoltan ) read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;NO_EDGES;VARIABLE=ke";
00141
00142     if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
00143
00144     ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval );
00145
00146     // Get local edges
00147     Range local_edges;
00148     rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval );
00149     CHECK_EQUAL( (size_t)0, local_edges.size() );
00150
00151     // Get local cells
00152     Range local_cells;
00153     rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval );
00154
00155     Tag gid_tag = mb.globalId_tag();
00156
00157     std::vector< int > gids( local_cells.size() );
00158     rval = mb.tag_get_data( gid_tag, local_cells, &gids[0] );
00159     Range local_cell_gids;
00160     std::copy( gids.rbegin(), gids.rend(), range_inserter( local_cell_gids ) );
00161
00162     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00163     int procs           = pcomm->proc_config().proc_size();
00164     int rank            = pcomm->proc_config().proc_rank();
00165
00166     // Make check runs this test on two processors
00167     if( 2 == procs )
00168     {
00169         CHECK_EQUAL( (size_t)321, local_cells.size() );
00170         CHECK_EQUAL( (size_t)321, local_cell_gids.size() );
00171
00172         // Check tag for cell variable ke at timestep 0
00173         Tag ke_tag0;
00174         rval = mb.tag_get_handle( "ke0", 1, MB_TYPE_DOUBLE, ke_tag0 );CHECK_ERR( rval );
00175
00176         // Check tag for cell variable ke at timestep 1
00177         Tag ke_tag1;
00178         rval = mb.tag_get_handle( "ke1", 1, MB_TYPE_DOUBLE, ke_tag1 );CHECK_ERR( rval );
00179
00180         // Get ke0 and ke1 tag values on 3 local cells
00181         EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] };
00182         double ke0_val[3];
00183         rval = mb.tag_get_data( ke_tag0, cell_ents, 3, ke0_val );CHECK_ERR( rval );
00184         double ke1_val[3];
00185         rval = mb.tag_get_data( ke_tag1, cell_ents, 3, ke1_val );CHECK_ERR( rval );
00186
00187         if( rcbzoltan )
00188         {
00189
00190             CHECK_EQUAL( (size_t)1, local_cells.psize() );
00191             CHECK_EQUAL( (size_t)37, local_cell_gids.psize() );
00192
00193             if( 0 == rank )
00194             {
00195                 CHECK_EQUAL( 1, (int)local_cell_gids[0] );
00196                 CHECK_EQUAL( 284, (int)local_cell_gids[160] );
00197                 CHECK_EQUAL( 630, (int)local_cell_gids[320] );
00198
00199                 CHECK_REAL_EQUAL( 15.001, ke0_val[0], eps );
00200                 CHECK_REAL_EQUAL( 16.284, ke0_val[1], eps );
00201                 CHECK_REAL_EQUAL( 16.630, ke0_val[2], eps );
00202                 CHECK_REAL_EQUAL( 25.001, ke1_val[0], eps );
00203                 CHECK_REAL_EQUAL( 26.284, ke1_val[1], eps );
00204                 CHECK_REAL_EQUAL( 26.630, ke1_val[2], eps );
00205             }
00206             else if( 1 == rank )
00207             {
00208                 CHECK_EQUAL( 4, (int)local_cell_gids[0] );
00209                 CHECK_EQUAL( 341, (int)local_cell_gids[160] );
00210                 CHECK_EQUAL( 642, (int)local_cell_gids[320] );
00211
00212                 CHECK_REAL_EQUAL( 15.004, ke0_val[0], eps );
00213                 CHECK_REAL_EQUAL( 16.341, ke0_val[1], eps );
00214                 CHECK_REAL_EQUAL( 16.642, ke0_val[2], eps );
00215                 CHECK_REAL_EQUAL( 25.004, ke1_val[0], eps );
00216                 CHECK_REAL_EQUAL( 26.341, ke1_val[1], eps );
00217                 CHECK_REAL_EQUAL( 26.642, ke1_val[2], eps );
00218             }
00219         }
00220         else
00221         {
00222             CHECK_EQUAL( (size_t)1, local_cell_gids.psize() );
00223
00224             if( 0 == rank )
00225             {
00226                 CHECK_EQUAL( (size_t)1, local_cells.psize() );
00227                 CHECK_EQUAL( 1, (int)local_cell_gids[0] );
00228                 CHECK_EQUAL( 161, (int)local_cell_gids[160] );
00229                 CHECK_EQUAL( 321, (int)local_cell_gids[320] );
00230
00231                 CHECK_REAL_EQUAL( 15.001, ke0_val[0], eps );
00232                 CHECK_REAL_EQUAL( 16.161, ke0_val[1], eps );
00233                 CHECK_REAL_EQUAL( 16.321, ke0_val[2], eps );
00234                 CHECK_REAL_EQUAL( 25.001, ke1_val[0], eps );
00235                 CHECK_REAL_EQUAL( 26.161, ke1_val[1], eps );
00236                 CHECK_REAL_EQUAL( 26.321, ke1_val[2], eps );
00237             }
00238             else if( 1 == rank )
00239             {
00240                 CHECK_EQUAL( (size_t)1, local_cells.psize() );
00241                 CHECK_EQUAL( 322, (int)local_cell_gids[0] );
00242                 CHECK_EQUAL( 482, (int)local_cell_gids[160] );
00243                 CHECK_EQUAL( 642, (int)local_cell_gids[320] );
00244
00245                 CHECK_REAL_EQUAL( 16.322, ke0_val[0], eps );
00246                 CHECK_REAL_EQUAL( 16.482, ke0_val[1], eps );
00247                 CHECK_REAL_EQUAL( 16.642, ke0_val[2], eps );
00248                 CHECK_REAL_EQUAL( 26.322, ke1_val[0], eps );
00249                 CHECK_REAL_EQUAL( 26.482, ke1_val[1], eps );
00250                 CHECK_REAL_EQUAL( 26.642, ke1_val[2], eps );
00251             }
00252         }
00253     }
00254 }
00255
00256 void read_mesh_parallel( bool rcbzoltan, bool no_mixed_elements )
00257 {
00258     Core moab;
00259     Interface& mb = moab;
00260
00261     read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
00262     if( rcbzoltan )
00263         read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
00264
00265     if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
00266
00267     ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval );
00268
00269     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00270     int procs           = pcomm->proc_config().proc_size();
00271     int rank            = pcomm->proc_config().proc_rank();
00272
00273     rval = pcomm->check_all_shared_handles();CHECK_ERR( rval );
00274
00275     // Get local vertices
00276     Range local_verts;
00277     rval = mb.get_entities_by_type( 0, MBVERTEX, local_verts );CHECK_ERR( rval );
00278
00279     int verts_num = local_verts.size();
00280     if( 2 == procs )
00281     {
00282         if( rcbzoltan )
00283         {
00284             if( 0 == rank )
00285                 CHECK_EQUAL( 685, verts_num );
00286             else if( 1 == rank )
00287                 CHECK_EQUAL( 685, verts_num );  // Not owned vertices included
00288         }
00289         else
00290         {
00291             if( 0 == rank )
00292                 CHECK_EQUAL( 1120, verts_num );
00293             else if( 1 == rank )
00294                 CHECK_EQUAL( 1122, verts_num );  // Not owned vertices included
00295         }
00296     }
00297
00298     rval = pcomm->filter_pstatus( local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
00299
00300     verts_num = local_verts.size();
00301     if( 2 == procs )
00302     {
00303         if( rcbzoltan )
00304         {
00305             if( 0 == rank )
00306                 CHECK_EQUAL( 685, verts_num );
00307             else if( 1 == rank )
00308                 CHECK_EQUAL( 595, verts_num );  // Not owned vertices excluded
00309         }
00310         else
00311         {
00312             if( 0 == rank )
00313                 CHECK_EQUAL( 1120, verts_num );
00314             else if( 1 == rank )
00315                 CHECK_EQUAL( 160, verts_num );  // Not owned vertices excluded
00316         }
00317     }
00318
00319     // Get local edges
00320     Range local_edges;
00321     rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval );
00322
00323     int edges_num = local_edges.size();
00324     if( 2 == procs )
00325     {
00326         if( rcbzoltan )
00327         {
00328             if( 0 == rank )
00329                 CHECK_EQUAL( 1005, edges_num );
00330             else if( 1 == rank )
00331                 CHECK_EQUAL( 1005, edges_num );  // Not owned edges included
00332         }
00333         else
00334         {
00335             if( 0 == rank )
00336                 CHECK_EQUAL( 1438, edges_num );
00337             else if( 1 == rank )
00338                 CHECK_EQUAL( 1444, edges_num );  // Not owned edges included
00339         }
00340     }
00341
00342     rval = pcomm->filter_pstatus( local_edges, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
00343
00344     edges_num = local_edges.size();
00345     if( 2 == procs )
00346     {
00347         if( rcbzoltan )
00348         {
00349             if( 0 == rank )
00350                 CHECK_EQUAL( 1005, edges_num );
00351             else if( 1 == rank )
00352                 CHECK_EQUAL( 915, edges_num );  // Not owned edges excluded
00353         }
00354         else
00355         {
00356             if( 0 == rank )
00357                 CHECK_EQUAL( 1438, edges_num );
00358             else if( 1 == rank )
00359                 CHECK_EQUAL( 482, edges_num );  // Not owned edges excluded
00360         }
00361     }
00362
00363     // Get local cells
00364     Range local_cells;
00365     rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval );
00366
00367     int cells_num = local_cells.size();
00368     if( 2 == procs )
00369     {
00370         CHECK_EQUAL( 321, cells_num );
00371         CHECK_EQUAL( (size_t)1, local_cells.psize() );
00372     }
00373
00374     rval = pcomm->filter_pstatus( local_cells, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
00375
00376     cells_num = local_cells.size();
00377     if( 2 == procs )
00378     {
00379         CHECK_EQUAL( 321, cells_num );
00380         CHECK_EQUAL( (size_t)1, local_cells.psize() );
00381     }
00382
00383     std::cout << "proc: " << rank << " verts:" << verts_num << "\n";
00384
00385     int total_verts_num;
00386     MPI_Reduce( &verts_num, &total_verts_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
00387     if( 0 == rank )
00388     {
00389         std::cout << "total vertices: " << total_verts_num << "\n";
00390         CHECK_EQUAL( 1280, total_verts_num );
00391     }
00392
00393     std::cout << "proc: " << rank << " edges:" << edges_num << "\n";
00394
00395     int total_edges_num;
00396     MPI_Reduce( &edges_num, &total_edges_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
00397     if( 0 == rank )
00398     {
00399         std::cout << "total edges: " << total_edges_num << "\n";
00400         CHECK_EQUAL( 1920, total_edges_num );
00401     }
00402
00403     std::cout << "proc: " << rank << " cells:" << cells_num << "\n";
00404
00405     int total_cells_num;
00406     MPI_Reduce( &cells_num, &total_cells_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
00407     if( 0 == rank )
00408     {
00409         std::cout << "total cells: " << total_cells_num << "\n";
00410         CHECK_EQUAL( 642, total_cells_num );
00411     }
00412
00413 #ifdef MOAB_HAVE_HDF5_PARALLEL
00414     std::string write_options( "PARALLEL=WRITE_PART;" );
00415
00416     std::string output_file = "test_mpas";
00417     if( rcbzoltan ) output_file += "_rcbzoltan";
00418     if( no_mixed_elements ) output_file += "_no_mixed_elements";
00419     output_file += ".h5m";
00420
00421     mb.write_file( output_file.c_str(), NULL, write_options.c_str() );
00422 #endif
00423 }
00424
00425 void gather_one_cell_var( int gather_set_rank )
00426 {
00427     Core moab;
00428     Interface& mb = moab;
00429
00430     EntityHandle file_set;
00431     ErrorCode rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
00432
00433     read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS";
00434     std::ostringstream gather_set_option;
00435     gather_set_option << ";GATHER_SET=" << gather_set_rank;
00436     read_options += gather_set_option.str();
00437
00438     rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
00439
00440     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00441     int procs           = pcomm->proc_config().proc_size();
00442     int rank            = pcomm->proc_config().proc_rank();
00443
00444     // Make sure gather_set_rank is valid
00445     if( gather_set_rank < 0 || gather_set_rank >= procs ) return;
00446
00447     Range cells, cells_owned;
00448     rval = mb.get_entities_by_type( file_set, MBPOLYGON, cells );CHECK_ERR( rval );
00449
00450     // Get local owned cells
00451     rval = pcomm->filter_pstatus( cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned );CHECK_ERR( rval );
00452
00453     EntityHandle gather_set = 0;
00454     if( gather_set_rank == rank )
00455     {
00456         // Get gather set
00457         ReadUtilIface* readUtilIface;
00458         mb.query_interface( readUtilIface );
00459         rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval );
00460         assert( gather_set != 0 );
00461     }
00462
00463     Tag ke_tag0, gid_tag;
00464     rval = mb.tag_get_handle( "ke0", 1, MB_TYPE_DOUBLE, ke_tag0, MB_TAG_DENSE );CHECK_ERR( rval );
00465
00466     gid_tag = mb.globalId_tag();
00467
00468     pcomm->gather_data( cells_owned, ke_tag0, gid_tag, gather_set, gather_set_rank );
00469
00470     if( gather_set_rank == rank )
00471     {
00472         // Get gather set cells
00473         Range gather_set_cells;
00474         rval = mb.get_entities_by_type( gather_set, MBPOLYGON, gather_set_cells );CHECK_ERR( rval );
00475         CHECK_EQUAL( (size_t)642, gather_set_cells.size() );
00476         CHECK_EQUAL( (size_t)1, gather_set_cells.psize() );
00477
00478         // Check ke0 tag values on 4 gather set cells: first pentagon, last pentagon,
00479         // first hexagon and last hexagon
00480         EntityHandle cell_ents[] = { gather_set_cells[0], gather_set_cells[11], gather_set_cells[12],
00481                                      gather_set_cells[641] };
00482         double ke0_val[4];
00483         rval = mb.tag_get_data( ke_tag0, &cell_ents[0], 4, ke0_val );CHECK_ERR( rval );
00484
00485         CHECK_REAL_EQUAL( 15.001, ke0_val[0], eps );
00486         CHECK_REAL_EQUAL( 15.012, ke0_val[1], eps );
00487         CHECK_REAL_EQUAL( 16.013, ke0_val[2], eps );
00488         CHECK_REAL_EQUAL( 16.642, ke0_val[3], eps );
00489     }
00490 }
00491
00492 void multiple_loads_of_same_file( bool no_mixed_elements )
00493 {
00494     Core moab;
00495     Interface& mb = moab;
00496
00497     // Need a file set for nomesh to work right
00498     EntityHandle file_set;
00499     ErrorCode rval;
00500     rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
00501
00502     // Read first only header information, no mesh, no variable
00503     read_options = "PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL";
00504     if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
00505
00506     rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
00507
00508     // Create mesh, no variable
00509     read_options = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD="
00510                    "TRIVIAL;VARIABLE=";
00511     if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
00512
00513     rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
00514
00515     // Read variable ke at timestep 0, no mesh
00516     read_options = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE=ke;TIMESTEP=0";
00517     if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
00518
00519     rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
00520
00521     Range local_verts;
00522     rval = mb.get_entities_by_type( file_set, MBVERTEX, local_verts );CHECK_ERR( rval );
00523
00524     Range local_edges;
00525     rval = mb.get_entities_by_type( file_set, MBEDGE, local_edges );CHECK_ERR( rval );
00526
00527     Range local_cells;
00528     rval = mb.get_entities_by_type( file_set, MBPOLYGON, local_cells );CHECK_ERR( rval );
00529
00530     ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00531     int procs           = pcomm->proc_config().proc_size();
00532     int rank            = pcomm->proc_config().proc_rank();
00533
00534     // Make check runs this test on two processors
00535     if( 2 == procs )
00536     {
00537         CHECK_EQUAL( (size_t)321, local_cells.size() );
00538
00539         // Check tag for cell variable ke at timestep 0
00540         Tag ke_tag0;
00541         rval = mb.tag_get_handle( "ke0", 1, MB_TYPE_DOUBLE, ke_tag0 );CHECK_ERR( rval );
00542
00543         // Get ke0 tag values on 3 local cells
00544         EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] };
00545         double ke0_val[3];
00546         rval = mb.tag_get_data( ke_tag0, cell_ents, 3, ke0_val );CHECK_ERR( rval );
00547
00548         if( 0 == rank )
00549         {
00550             CHECK_EQUAL( (size_t)1120, local_verts.size() );
00551             CHECK_EQUAL( (size_t)1438, local_edges.size() );
00552             CHECK_EQUAL( (size_t)1, local_cells.psize() );
00553             CHECK_REAL_EQUAL( 15.001, ke0_val[0], eps );
00554             CHECK_REAL_EQUAL( 16.161, ke0_val[1], eps );
00555             CHECK_REAL_EQUAL( 16.321, ke0_val[2], eps );
00556         }
00557         else if( 1 == rank )
00558         {
00559             CHECK_EQUAL( (size_t)1122, local_verts.size() );
00560             CHECK_EQUAL( (size_t)1444, local_edges.size() );
00561             CHECK_EQUAL( (size_t)1, local_cells.psize() );
00562
00563             CHECK_REAL_EQUAL( 16.322, ke0_val[0], eps );
00564             CHECK_REAL_EQUAL( 16.482, ke0_val[1], eps );
00565             CHECK_REAL_EQUAL( 16.642, ke0_val[2], eps );
00566         }
00567     }
00568 }
