parmerge.cpp File Reference
#include "moab/ParallelMergeMesh.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab_mpi.h"
#include <iostream>
#include <string>
#include <cstdlib>
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include <fstream>
#include <sstream>
#include "moab/Skinner.hpp"
+ Include dependency graph for parmerge.cpp:
Defines
#define PrintInfo   false
Functions
void print_output (moab::ParallelComm *pc, moab::Core *mb, int numprocs, int myID, bool perform)
int main (int argc, char *argv[])
Define Documentation
Definition at line 21 of file parmerge.cpp.
Referenced by main().
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 48 of file parmerge.cpp.
References ErrorCode, moab::Core::get_error_string(), moab::Core::get_last_error(), moab::Core::load_mesh(), mb, MB_SUCCESS, moab::ParallelMergeMesh::merge(), MPI_COMM_WORLD, outfile, print_output(), PrintInfo, and moab::Core::write_file().
    // Check argument count
    if( argc != 4 )
        std::cerr << "Usage: " << argv[0] << " <inputfile> <outputfile> <tolerance>" << std::endl;
        return 1;
    // Check the output file extension
    std::string outfile( argv[2] );
    if( outfile.compare( outfile.size() - 4, 4, ".h5m" ) != 0 )
        std::cerr << "Invalid Parallel Output File" << std::endl;
        return 1;
    // Read in tolerance
    double epsilon;
    if( !( std::istringstream( argv[3] ) >> epsilon ) )
        std::cerr << "Unable to parse tolerance" << std::endl;
        return 1;
    // Initialize MPI
    int numprocs, myID;
    MPI_Init( &argc, &argv );
    MPI_Comm_size( MPI_COMM_WORLD, &numprocs );
    MPI_Comm_rank( MPI_COMM_WORLD, &myID );
    // Read in files from input files
    // Round robin distribution of reading meshes
    moab::Core* mb = new moab::Core();
    moab::ErrorCode rval;
    std::ifstream file( argv[1] );
    if( file.is_open() )
        std::string line;
        int count = 0;
        // Read each line
        while( file.good() )
            getline( file, line );
            if( myID == count && line != "" )
                // Read in the file
                rval = mb->load_mesh( line.c_str() );
                if( rval != moab::MB_SUCCESS )
                    std::cerr << "Error Opening Mesh File " << line << std::endl;
                    MPI_Abort( MPI_COMM_WORLD, 1 );
                    file.close();
                    return 1;
            count = ( count + 1 ) % numprocs;
        file.close();
    else
        std::cerr << "Error Opening Input File " << argv[1] << std::endl;
        return 1;
    // Get a pcomm object
    moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD );
    // Call the resolve parallel function
    moab::ParallelMergeMesh pm( pc, epsilon );
    rval = pm.merge();
        std::cerr << "Merge Failed" << std::endl;
        return 1;
    print_output( pc, mb, myID, numprocs, PrintInfo );
    // Write out the file
    rval = mb->write_file( outfile.c_str(), 0, "PARALLEL=WRITE_PART" );
        std::cerr << "Writing output file failed. Code:";
        // Temporary File error info.
        std::cerr << mb->get_error_string( rval ) << std::endl;
        std::string foo = "";
        mb->get_last_error( foo );
        std::cerr << "File Error: " << foo << std::endl;
        return 1;
    // The barrier may be necessary to stop items from being deleted when needed
    // But probably not necessary
    MPI_Barrier( MPI_COMM_WORLD );
    delete pc;
    delete mb;
    MPI_Finalize();
    return 0;
void print_output ( moab::ParallelComm pc,
moab::Core mb,
int  numprocs,
int  myID,
bool  perform
Definition at line 155 of file parmerge.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), moab::Skinner::find_skin(), moab::Core::get_entities_by_dimension(), moab::ParallelComm::get_owner(), MPI_COMM_WORLD, and skin().
    moab::Range ents, skin;
    int o_ct = 0, no_ct = 0, tmp = 0, o_tot = 0, no_tot = 0;
    if( perform )
        if( myID == 0 ) std::cout << "------------------------------------------" << std::endl;
        // Check the count of total vertices
        mb->get_entities_by_dimension( 0, 0, ents );
        for( moab::Range::iterator rit = ents.begin(); rit != ents.end(); ++rit )
            pc->get_owner( *rit, tmp );
            if( tmp == myID )
                o_ct++;
        MPI_Reduce( &o_ct, &o_tot, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
        if( myID == 0 )
            std::cout << "There are " << o_tot << " vertices." << std::endl;
        // Check the count of owned and not owned skin faces.
        // owned-not owned == total skin faces
        moab::Skinner skinner( mb );
        o_ct   = 0;
        no_ct  = 0;
        o_tot  = 0;
        no_tot = 0;
        skin.clear();
        ents.clear();
        mb->get_entities_by_dimension( 0, 3, ents );
        skinner.find_skin( 0, ents, 2, skin );
        for( moab::Range::iterator s_rit = skin.begin(); s_rit != skin.end(); ++s_rit )
            pc->get_owner( *s_rit, tmp );
            if( tmp == myID )
                o_ct++;
            else
                no_ct++;
        MPI_Reduce( &no_ct, &no_tot, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
        if( myID == 0 )
            std::cout << "There are " << o_tot << " owned skin faces." << std::endl;
            std::cout << "There are " << no_tot << " not owned skin faces." << std::endl;
            std::cout << "The difference (Global Skin Faces) is " << ( o_tot - no_tot ) << "." << std::endl;
