partcheck.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/Skinner.hpp"
#include "moab/CN.hpp"
#include <iostream>
#include <sstream>
#include <limits>
#include <string>
#include <ctime>
#include "moab_mpi.h"
+ Include dependency graph for partcheck.cpp:
Functions
static void usage (const char *argv0)
static const char * defstr (const char *mode)
static void help (const char *argv0)
int check_parallel_read (Interface &mb, ParallelComm *pcomm, bool shared_ents)
int main (int argc, char *argv[])
Variables
const char PARTTAG [] = "PARALLEL_PARTITION"
const char READ_DEL_OPT [] = "READ_DELETE"
const char BCAST_DEL_OPT [] = "BCAST_DELETE"
const char READ_PART_OPT [] = "READ_PART"
const char *const DEFAULT_MODE = READ_PART_OPT
const char USAGE [] = " [-v <n>] [-R] [-p <parttag>[=val]] [-D|-B|-P] <input_file>"
Function Documentation
int check_parallel_read ( Interface mb,
ParallelComm pcomm,
bool  shared_ents
Definition at line 202 of file partcheck.cpp.
References moab::Range::all_of_dimension(), moab::Range::back(), moab::Range::begin(), dim, moab::CN::Dimension(), moab::Range::empty(), moab::Range::end(), error_count, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::ParallelComm::partition_sets(), moab::ParallelComm::rank(), moab::subtract(), and moab::Interface::type_from_handle().
Referenced by main().
    int error_count = 0;
    const Range& parts = pcomm->partition_sets();
    if( parts.empty() ) std::cout << "No parts for process " << pcomm->rank() << std::endl;
    // get all entities from parts
    Range part_ents;
    for( Range::iterator i = parts.begin(); i != parts.end(); ++i )
        mb.get_entities_by_handle( *i, part_ents );
    int dim = 3;
    if( part_ents.empty() )
        std::cout << "No partitioned entities for process " << pcomm->rank() << std::endl;
    else
        dim = CN::Dimension( mb.type_from_handle( part_ents.back() ) );
        if( !part_ents.all_of_dimension( dim ) )
            std::cout << "Partitioned ents of mixed dimension for process " << pcomm->rank() << std::endl;
    Range all_ents;
    mb.get_entities_by_dimension( 0, dim, all_ents );
    if( !subtract( all_ents, part_ents ).empty() )
        std::cerr << "Process " << pcomm->rank() << " has entities of dimension " << dim
                  << " that are not contained in any part" << std::endl;
        ++error_count;
    if( dim == 0 )
        std::cout << "Skipping further tests because mesh is vertex-partitioned" << std::endl;
        return error_count;
    Range part_verts;
    mb.get_connectivity( part_ents, part_verts );
    Range all_verts;
    mb.get_entities_by_dimension( 0, 0, all_verts );
    if( !subtract( all_verts, part_verts ).empty() )
        std::cerr << "Process " << pcomm->rank() << " has vertices "
                  << " that are not contained in any partitioned element" << std::endl;
        ++error_count;
    // if (!shared_ents) {
    //  std::cout << "Skipping further tests because shared entities were not resolved" <<
    //  std::endl; return error_count;
    return error_count;
static const char* defstr ( const char *  mode) [static]
Definition at line 29 of file partcheck.cpp.
References DEFAULT_MODE.
Referenced by help().
    static const char s[] = " (default)";
    int len               = ( mode == DEFAULT_MODE ) ? 0 : sizeof( s ) - 1;
    return s + len;
static void help ( const char *  argv0) [static]
Definition at line 36 of file partcheck.cpp.
References BCAST_DEL_OPT, defstr(), PARTTAG, READ_DEL_OPT, READ_PART_OPT, and USAGE.
    std::cout << "Usage: " << argv0 << USAGE << std::endl
              << "  -v  : debug output level (DEBUG_IO option)" << std::endl
              << "  -R  : do not resolve shared entities" << std::endl
              << "  -p  : partition tag, with optional '=' value" << std::endl
              << "          (default = \"" << PARTTAG << "\")" << std::endl
              << "  -D  : read mode as \"" << READ_DEL_OPT << "\"" << defstr( READ_DEL_OPT ) << std::endl
              << "  -B  : read mode as \"" << BCAST_DEL_OPT << "\"" << defstr( READ_DEL_OPT ) << std::endl
              << "  -P  : read mode as \"" << READ_PART_OPT << "\"" << defstr( READ_PART_OPT ) << std::endl;
    exit( 0 );
int main ( int  argc,
char *  argv[]
Definition at line 53 of file partcheck.cpp.
References BCAST_DEL_OPT, moab::ParallelComm::check_all_shared_handles(), check_parallel_read(), moab::ParallelComm::comm(), DEFAULT_MODE, ErrorCode, moab::Interface::get_error_string(), moab::ParallelComm::get_id(), help(), input_file, moab::Interface::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, PARTTAG, moab::ParallelComm::rank(), READ_DEL_OPT, READ_PART_OPT, t, and usage.
    const char* read_mode_opt  = DEFAULT_MODE;
    const char* part_tag_opt   = PARTTAG;
    bool resolve_shared        = true;
    const char* input_file     = 0;
    const char* debug_flag_str = 0;
    bool no_more_flags         = false;
    MPI_Init( &argc, &argv );
    // process command line arguments
    for( int i = 1; i < argc; ++i )
        if( !no_more_flags && argv[i][0] == '-' )
            const char* opts = argv[i] + 1;
            for( int j = 0; opts[j]; ++j )
                switch( opts[j] )
                    case '-':
                        no_more_flags = true;
                        break;
                    case 'v':
                        if( ++i == argc ) usage( argv[0] );
                        debug_flag_str = argv[i];
                        break;
                    case 'R':
                        resolve_shared = false;
                        break;
                    case 'p':
                        part_tag_opt = argv[i];
                        break;
                    case 'D':
                        read_mode_opt = READ_DEL_OPT;
                        break;
                    case 'B':
                        read_mode_opt = BCAST_DEL_OPT;
                        break;
                    case 'P':
                        read_mode_opt = READ_PART_OPT;
                        break;
                    case 'h':
                        help( argv[0] );
                        break;
                    default:
                        usage( argv[0] );
        else if( !input_file )
            input_file = argv[i];
        else
            usage( argv[0] );
    if( !input_file )
        std::cerr << argv[0] << ": no input file specified" << std::endl;
        usage( argv[0] );
    // build options string
    std::ostringstream opts;
    opts << "PARALLEL=" << read_mode_opt;
    std::string part_opt( part_tag_opt );
    size_t p = part_opt.find_last_of( '=' );
    if( p == std::string::npos )
        opts << ";PARTITION=" << part_opt;
    else
        char* endptr = 0;
        long n       = strtol( part_opt.c_str() + p + 1, &endptr, 0 );
        if( *endptr || p == part_opt.size() - 1 )
            std::cerr << "Warning: partition tag option contains an '=' followed "
                         "         by a non-integer value.  Assuming tag name is "
                      << part_opt << "\"" << std::endl;
        else
            opts << ";PARTITION=" << part_opt.substr( 0, p );
            opts << ";PARTITION_VAL=" << n;
    if( resolve_shared )
        opts << ";PARALLEL_RESOLVE_SHARED_ENTS";
    if( debug_flag_str )
        char* endptr = 0;
        long n       = strtol( debug_flag_str, &endptr, 0 );
        if( *endptr || n < 0 || !*debug_flag_str ) usage( argv[0] );
        opts << ";DEBUG_IO=" << n;
    Core moab;
    Interface& mb       = moab;
    ParallelComm* pcomm = new ParallelComm( &mb, MPI_COMM_WORLD );
    if( pcomm->rank() == 0 )
        std::cout << "Loading file: \"" << input_file << "\" with options \"" << opts.str() << '"' << std::endl;
    opts << ";PARALLEL_COMM=" << pcomm->get_id();
    clock_t init_time = clock();
    ErrorCode rval    = mb.load_file( input_file, 0, opts.str().c_str() );
    if( MB_SUCCESS != rval )
        std::cerr << input_file << " : file read failed (" << mb.get_error_string( rval ) << ")" << std::endl;
        return 1;
    clock_t t = clock();
    double sec;
    if( t < init_time )
        sec =
            ( std::numeric_limits< clock_t >::max() - init_time ) / (double)CLOCKS_PER_SEC + t / (double)CLOCKS_PER_SEC;
    else
        sec = ( t - init_time ) / (double)CLOCKS_PER_SEC;
    double allsec;
    MPI_Reduce( &sec, &allsec, 1, MPI_DOUBLE, MPI_MAX, 0, pcomm->comm() );
        std::cout << "Read completed in " << allsec << " seconds" << std::endl;
    int result = check_parallel_read( mb, pcomm, resolve_shared );
    if( MB_SUCCESS != pcomm->check_all_shared_handles( false ) ) ++result;
    MPI_Finalize();
    return result;
static void usage ( const char *  argv0) [static]
Definition at line 23 of file partcheck.cpp.
References USAGE.
    std::cerr << "Usage: " << argv0 << USAGE << std::endl << "       " << argv0 << " -h" << std::endl;
    exit( 1 );
Variable Documentation
const char BCAST_DEL_OPT[] = "BCAST_DELETE"
Definition at line 17 of file partcheck.cpp.
Referenced by help(), and main().
const char* const DEFAULT_MODE = READ_PART_OPT
Definition at line 19 of file partcheck.cpp.
const char PARTTAG[] = "PARALLEL_PARTITION"
Definition at line 15 of file partcheck.cpp.
const char READ_DEL_OPT[] = "READ_DELETE"
Definition at line 16 of file partcheck.cpp.
const char READ_PART_OPT[] = "READ_PART"
Definition at line 18 of file partcheck.cpp.
const char USAGE[] = " [-v <n>] [-R] [-p <parttag>[=val]] [-D|-B|-P] <input_file>"
Definition at line 21 of file partcheck.cpp.
Referenced by help(), and usage().
