quads_to_tris.cpp
00001 // Brandon Smith
00002 // January 20, 2009
00003
00004 /*
00005    loop over all surface meshsets
00006      get all quads of surface meshset
00007      loop over all quads
00008        make tris from quad
00009        add tris to the surface meshset
00010        remove quad from surface meshset
00011        delete quad
00012      end loop
00013    end loop
00014 */
00015
00016 #include "quads_to_tris.hpp"
00017 #include "moab/CartVect.hpp"
00018 using namespace moab;
00019
00020 // Generic function to create two tris from a quad. This can be improved later.
00021 ErrorCode make_tris_from_quad( Interface* MBI,
00022                                EntityHandle quad,  /* input */
00023                                EntityHandle& tri0, /* output */
00024                                EntityHandle& tri1 /* output */ )
00025 {
00026
00027     // get connectivity (ordered counterclockwise for 2D elements in MOAB)
00028     ErrorCode result;
00029     const EntityHandle* quad_conn;
00030     int n_verts = 0;
00031     result      = MBI->get_connectivity( quad, quad_conn, n_verts );
00032     assert( 4 == n_verts );
00033     assert( MB_SUCCESS == result );
00034
00035     // find length of diagonals
00036     std::vector< CartVect > coords( n_verts );
00037     result = MBI->get_coords( quad_conn, n_verts, coords[0].array() );
00038     if( MB_SUCCESS != result ) return result;
00039     CartVect diagA  = coords[0] - coords[2];
00040     double lenA_sqr = diagA.length_squared();
00041     CartVect diagB  = coords[1] - coords[3];
00042     double lenB_sqr = diagB.length_squared();
00043
00044     // choose the shortest diagonal
00045     EntityHandle tri0_conn[3], tri1_conn[3];
00046     if( lenA_sqr < lenB_sqr )
00047     {
00048         tri0_conn[0] = quad_conn[0];
00049         tri0_conn[1] = quad_conn[1];
00050         tri0_conn[2] = quad_conn[2];
00051         tri1_conn[0] = quad_conn[0];
00052         tri1_conn[1] = quad_conn[2];
00053         tri1_conn[2] = quad_conn[3];
00054     }
00055     else
00056     {
00057         tri0_conn[0] = quad_conn[0];
00058         tri0_conn[1] = quad_conn[1];
00059         tri0_conn[2] = quad_conn[3];
00060         tri1_conn[0] = quad_conn[1];
00061         tri1_conn[1] = quad_conn[2];
00062         tri1_conn[2] = quad_conn[3];
00063     }
00064
00065     // make tris from quad
00066     result = MBI->create_element( MBTRI, tri0_conn, 3, tri0 );
00067     assert( MB_SUCCESS == result );
00068     result = MBI->create_element( MBTRI, tri1_conn, 3, tri1 );
00069     assert( MB_SUCCESS == result );
00070
00071     return MB_SUCCESS;
00072 }
00073
00074 ErrorCode make_tris_from_quads( Interface* MBI, const Range& quads, Range& tris )
00075 {
00076     tris.clear();
00077     for( Range::const_iterator i = quads.begin(); i != quads.end(); ++i )
00078     {
00079         EntityHandle tri0, tri1;
00080         ErrorCode result = make_tris_from_quad( MBI, *i, tri0, tri1 );
00081         assert( MB_SUCCESS == result );
00082         if( MB_SUCCESS != result ) return result;
00083         tris.insert( tri0 );
00084         tris.insert( tri1 );
00085     }
00086     return MB_SUCCESS;
00087 }
00088
00089 ErrorCode quads_to_tris( Interface* MBI, EntityHandle input_meshset )
00090 {
00091
00092     // create a geometry tag to find the surfaces with
00093     ErrorCode result;
00094     Tag geom_tag, id_tag;
00095     result = MBI->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, MB_TAG_DENSE | MB_TAG_CREAT );
00096     if( MB_SUCCESS != result ) return result;
00097
00098     // create an id tag to find the surface id with
00099     id_tag = MBI->globalId_tag();
00100
00101     // get all surface meshsets
00102     Range surface_meshsets;
00103     int dim           = 2;
00104     void* input_dim[] = { &dim };
00105     result = MBI->get_entities_by_type_and_tag( input_meshset, MBENTITYSET, &geom_tag, input_dim, 1, surface_meshsets );
00106     assert( MB_SUCCESS == result );
00107     std::cout << surface_meshsets.size() << " surfaces found." << std::endl;
00108
00109     // ******************************************************************
00110     // Loop over every surface meshset and grab each surface's quads.
00111     // ******************************************************************
00112     for( Range::iterator i = surface_meshsets.begin(); i != surface_meshsets.end(); ++i )
00113     {
00114
00115         // get the surface id of the surface meshset
00116         int surf_id = 0;
00117         result      = MBI->tag_get_data( id_tag, &( *i ), 1, &surf_id );
00118         assert( MB_SUCCESS == result );
00119         std::cout << "  Surface " << surf_id << " has ";
00120
00121         // get all quads of the surface
00122         Range quads;
00123         result = MBI->get_entities_by_type( *i, MBQUAD, quads );
00124         assert( MB_SUCCESS == result );
00125         std::cout << quads.size() << " quads." << std::endl;
00126
00127         // ******************************************************************
00128         // For each quad, make two triangles then delete the quad.
00129         // ******************************************************************
00130         for( Range::iterator j = quads.begin(); j != quads.end(); ++j )
00131         {
00132
00133             // make the tris
00134             EntityHandle tri0 = 0, tri1 = 0;
00135             result = make_tris_from_quad( MBI, *j, tri0, tri1 );
00136             assert( MB_SUCCESS == result );
00137
00138             // add all the tris to the same surface meshset as the quads were inside.
00139             result = MBI->add_entities( *i, &tri0, 1 );
00140             if( MB_SUCCESS != result ) std::cout << "result=" << result << std::endl;
00141             assert( MB_SUCCESS == result );
00142             result = MBI->add_entities( *i, &tri1, 1 );
00143             assert( MB_SUCCESS == result );
00144
00145             // remove the quad from the surface meshset
00146             result = MBI->remove_entities( *i, &( *j ), 1 );
00147             assert( MB_SUCCESS == result );
00148
00149             // delete the quad
00150             result = MBI->delete_entities( &( *j ), 1 );
00151             assert( MB_SUCCESS == result );
00152
00153         }  // end quad loop
00154     }      // end surface meshset loop
00155     return MB_SUCCESS;
00156 }
