read_cgm_group_test.cpp
00001 #include <iostream>
00002 #include "moab/Interface.hpp"
00003 #ifndef IS_BUILDING_MB
00004 #define IS_BUILDING_MB
00005 #endif
00006 #include "TestUtil.hpp"
00007 #include "Internals.hpp"
00008 #include "moab/Core.hpp"
00009 #include "MBTagConventions.hpp"
00010 #include "InitCGMA.hpp"
00011 #include "GeometryQueryTool.hpp"
00012
00013 using namespace moab;
00014
00015 #define CHKERR( A )        \
00016     do        \
00017     {        \
00018         if( MB_SUCCESS != ( A ) )        \
00019         {        \
00020             std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
00021             return A;        \
00022         }        \
00023     } while( false )
00024
00025 #ifdef HAVE_OCC_STEP
00026 std::string input_cylcube = TestDir + "unittest/io/cylcube.stp";
00027 #else
00028 std::string input_cylcube = TestDir + "unittest/io/cylcube.sat";
00029 #endif
00030
00031 // Function used to load the test file
00032 void read_file( Interface* moab, const char* input_file );
00033
00034 // Function for getting entity ids
00035 int geom_id_by_handle( Interface* moab, const EntityHandle set );
00036
00037 // Function for checking retrieved group data
00038 void check_group_data( std::vector< int >& group_ids,
00039                        std::vector< std::string >& group_names,
00040 #ifdef HAVE_OCC_STEP
00041                        std::vector< int >& );
00042 #else
00043                        std::vector< int >& group_ent_ids );
00044 #endif
00045
00046 // Function for loading all reference data
00047 void load_group_references( std::vector< int >& ids, std::vector< std::string >& names, std::vector< int >& ent_ids );
00048
00049 // List of tests in this file
00050 void read_cylcube_groups_test();
00051
00052 int main( int /* argc */, char** /* argv */ )
00053 {
00054     int result = 0;
00055
00056     result += RUN_TEST( read_cylcube_groups_test );
00057
00058     return result;
00059 }
00060
00061 void read_file( Interface* moab, const char* input_file )
00062 {
00063     InitCGMA::initialize_cgma();
00064     GeometryQueryTool::instance()->delete_geometry();
00065
00066     ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval );
00067 }
00068
00069 // Checks that group information is being read correctly if MOAB is
00070 // being build with CGM. If MOAB is built with OCC, it makes sure
00071 // no erroneous group data is loaded as STEP files do not hold
00072 // information about groups.
00073 void read_cylcube_groups_test()
00074 {
00075
00076     ErrorCode rval;
00077     // Open the test file
00078     Core moab;
00079     Interface* mb = &moab;
00080     read_file( mb, input_cylcube.c_str() );
00081
00082     // Get (or create) the name and category tags
00083     Tag name_tag, category_tag;
00084
00085     rval = mb->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, name_tag,
00086                                moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );CHECK_ERR( rval );
00087
00088     rval = mb->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag,
00089                                moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );CHECK_ERR( rval );
00090
00091     // Get the group entity handles
00092     Range group_sets;
00093     char query[CATEGORY_TAG_SIZE] = "Group\0";
00094     // Has to be this way because of the way tags are created
00095     void* val[] = { &query };
00096     rval        = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &category_tag, val, 1, group_sets );CHECK_ERR( rval );
00097     // Get group names and IDs
00098     std::vector< int > g_ids;
00099     std::vector< std::string > g_names;
00100     std::vector< int > g_ent_ids;
00101
00102     for( Range::iterator i = group_sets.begin(); i != group_sets.end(); ++i )
00103     {
00104         int group_id = geom_id_by_handle( mb, *i );
00105         g_ids.push_back( group_id );
00106         // Get the group name
00107         char group_name[NAME_TAG_SIZE + 1];
00108         rval = mb->tag_get_data( name_tag, &( *i ), 1, &group_name );CHECK_ERR( rval );
00109         // Store group name
00110         std::string temp( group_name );
00111         g_names.push_back( temp );
00112         // Get all entities in the group
00113         Range group_ents;
00114         rval = mb->get_entities_by_type( *i, MBENTITYSET, group_ents, false );CHECK_ERR( rval );
00115         if( group_ents.size() != 1 ) CHECK( false );
00116         int grp_ent_id = geom_id_by_handle( mb, group_ents[0] );
00117         g_ent_ids.push_back( grp_ent_id );
00118     }
00119     check_group_data( g_ids, g_names, g_ent_ids );
00120 }
00121
00122 void check_group_data( std::vector< int >& group_ids,
00123                        std::vector< std::string >& group_names,
00124 #ifdef HAVE_OCC_STEP
00125                        std::vector< int >& /*group_ent_ids*/ )
00126 #else
00127                        std::vector< int >& group_ent_ids )
00128 #endif
00129 {
00130     // Step files do not contain group data, MOAB shouldn't return errors when trying to access
00131     // this data but there shouldn't be any found.
00132 #ifdef HAVE_OCC_STEP
00133     int num_g_ids   = group_ids.size();
00134     int num_g_names = group_names.size();
00135
00136     CHECK_EQUAL( 0, num_g_ids );
00137     CHECK_EQUAL( 0, num_g_names );
00138 #else
00139
00140     // Initialize reference data
00141     std::vector< int > group_ref_ids;
00142     std::vector< std::string > group_ref_names;
00143     std::vector< int > group_ref_ent_ids;
00144     load_group_references( group_ref_ids, group_ref_names, group_ref_ent_ids );
00145
00146     // check that the correct number of entities were found
00147     CHECK_EQUAL( group_ref_ids.size(), group_ids.size() );
00148     CHECK_EQUAL( group_ref_names.size(), group_names.size() );
00149     CHECK_EQUAL( group_ref_ent_ids.size(), group_ent_ids.size() );
00150
00151     // now make sure that each group has a matching group
00152     for( unsigned int i = 0; i < group_ids.size(); i++ )
00153     {
00154         for( unsigned int j = 0; j < group_ref_ids.size(); j++ )
00155         {
00156             if( group_ids[i] == group_ref_ids[j] && group_names[i] == group_ref_names[j] &&
00157                 group_ent_ids[i] == group_ref_ent_ids[j] )
00158             {
00159                 group_ref_ids.erase( group_ref_ids.begin() + j );
00160                 group_ref_names.erase( group_ref_names.begin() + j );
00161                 group_ref_ent_ids.erase( group_ref_ent_ids.begin() + j );
00162                 continue;
00163             }
00164         }
00165     }
00166
00167     // Check sizes of reference vectors after matching
00168     // (all should be zero)
00169     int leftovers = group_ref_ids.size();
00170     CHECK_EQUAL( 0, leftovers );
00171     leftovers = group_ref_names.size();
00172     CHECK_EQUAL( 0, leftovers );
00173     leftovers = group_ref_ent_ids.size();
00174     CHECK_EQUAL( 0, leftovers );
00175 #endif
00176 }
00177
00178 void load_group_references( std::vector< int >& ids, std::vector< std::string >& names, std::vector< int >& ent_ids )
00179 {
00180     // First set of group info
00181     names.push_back( "Group 3" );
00182     ids.push_back( 3 );
00183     ent_ids.push_back( 2 );
00184
00185     // Second set of group info
00186     names.push_back( "Group 2" );
00187     ids.push_back( 2 );
00188     ent_ids.push_back( 1 );
00189 }
00190
00191 int geom_id_by_handle( Interface* moab, const EntityHandle set )
00192 {
00193     ErrorCode rval;
00194     // Get the id_tag handle
00195     Tag id_tag = moab->globalId_tag();
00196     // Load the ID for the EntHandle given to the function
00197     int id;
00198     rval = moab->tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval );
00199     return id;
00200 }
