read_cgm_load_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
+ Include dependency graph for read_cgm_load_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void read_multiple_test ()
int main (int, char **)
Variables
std::string input_file = "unittest/io/dum.sat"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 12 of file read_cgm_load_test.cpp.
Definition at line 4 of file read_cgm_load_test.cpp.
Function Documentation
int main ( int  ,
char **
Definition at line 38 of file read_cgm_load_test.cpp.
References read_multiple_test(), and RUN_TEST.
    int result = RUN_TEST( read_multiple_test );
    return result;
Definition at line 29 of file read_cgm_load_test.cpp.
References CHECK_ERR, ErrorCode, input_file, moab::Core::load_file(), and mb.
Referenced by main().
    Core mb;
    ErrorCode rval = mb.load_file( input_file.c_str() );CHECK_ERR( rval );
    // second load
Variable Documentation
Definition at line 25 of file read_cgm_load_test.cpp.
