sets.c
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include <H5Tpublic.h>
00017 #include <H5Dpublic.h>
00018 #include <H5Gpublic.h>
00019 #include <H5Spublic.h>
00020 #include <H5Ppublic.h>
00021 #include "mhdf.h"
00022 #include "util.h"
00023 #include "file-handle.h"
00024 #include "status.h"
00025 #include "names-and-paths.h"
00026
00027 int mhdf_haveSets( mhdf_FileHandle file, int* have_data, int* have_child, int* have_parent, mhdf_Status* status )
00028 {
00029     FileHandle* file_ptr = (FileHandle*)file;
00030     hid_t root_id, set_id;
00031     int result;
00032     API_BEGIN;
00033
00034     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00035
00036 #if defined( H5Gopen_vers ) && H5Gopen_vers > 1
00037     root_id = H5Gopen2( file_ptr->hdf_handle, ROOT_GROUP, H5P_DEFAULT );
00038 #else
00039     root_id = H5Gopen( file_ptr->hdf_handle, ROOT_GROUP );
00040 #endif
00041     if( root_id < 0 )
00042     {
00043         mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.", ROOT_GROUP );
00044         return -1;
00045     }
00046
00047     result = mhdf_is_in_group( root_id, SET_GROUP_NAME, status );
00048     if( result < 1 )
00049     {
00050         H5Gclose( root_id );
00051         return result;
00052     }
00053
00054 #if defined( H5Gopen_vers ) && H5Gopen_vers > 1
00055     set_id = H5Gopen2( root_id, SET_GROUP_NAME, H5P_DEFAULT );
00056 #else
00057     set_id  = H5Gopen( root_id, SET_GROUP_NAME );
00058 #endif
00059     H5Gclose( root_id );
00060     if( set_id < 0 )
00061     {
00062         mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.", SET_GROUP );
00063         return -1;
00064     }
00065
00066     result = mhdf_is_in_group( set_id, SET_META_NAME, status );
00067     if( result < 0 )
00068     {
00069         H5Gclose( set_id );
00070         return result;
00071     }
00072
00073     if( have_data )
00074     {
00075         *have_data = mhdf_is_in_group( set_id, SET_DATA_NAME, status );
00076         if( *have_data < 0 )
00077         {
00078             H5Gclose( set_id );
00079             return *have_data;
00080         }
00081     }
00082
00083     if( have_child )
00084     {
00085         *have_child = mhdf_is_in_group( set_id, SET_CHILD_NAME, status );
00086         if( *have_child < 0 )
00087         {
00088             H5Gclose( set_id );
00089             return *have_child;
00090         }
00091     }
00092
00093     if( have_parent )
00094     {
00095         *have_parent = mhdf_is_in_group( set_id, SET_PARENT_NAME, status );
00096         if( *have_parent < 0 )
00097         {
00098             H5Gclose( set_id );
00099             return *have_parent;
00100         }
00101     }
00102
00103     mhdf_setOkay( status );
00104     H5Gclose( set_id );
00105     API_END;
00106     return result;
00107 }
00108
00109 hid_t mhdf_createSetMeta( mhdf_FileHandle file, long num_sets, long* first_id_out, mhdf_Status* status )
00110 {
00111     FileHandle* file_ptr = (FileHandle*)file;
00112     hid_t table_id;
00113     hsize_t dims[2];
00114     long first_id;
00115     API_BEGIN;
00116
00117     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00118
00119     dims[0]  = (hsize_t)num_sets;
00120     dims[1]  = (hsize_t)4;
00121     table_id = mhdf_create_table( file_ptr->hdf_handle, SET_META_PATH, MHDF_INDEX_TYPE, 2, dims, status );
00122     if( table_id < 0 ) return -1;
00123
00124     first_id = file_ptr->max_id + 1;
00125     if( !mhdf_create_scalar_attrib( table_id, START_ID_ATTRIB, H5T_NATIVE_LONG, &first_id, status ) )
00126     {
00127         H5Dclose( table_id );
00128         return -1;
00129     }
00130
00131     *first_id_out = first_id;
00132     file_ptr->max_id += num_sets;
00133     if( !mhdf_write_max_id( file_ptr, status ) )
00134     {
00135         H5Dclose( table_id );
00136         return -1;
00137     }
00138     file_ptr->open_handle_count++;
00139     mhdf_setOkay( status );
00140
00141     API_END_H( 1 );
00142     return table_id;
00143 }
00144
00145 hid_t mhdf_openSetMeta( mhdf_FileHandle file, long* num_sets, long* first_id_out, mhdf_Status* status )
00146 {
00147     FileHandle* file_ptr = (FileHandle*)file;
00148     hid_t table_id;
00149     hsize_t dims[2];
00150     API_BEGIN;
00151
00152     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00153
00154     table_id = mhdf_open_table2( file_ptr->hdf_handle, SET_META_PATH, 2, dims, first_id_out, status );
00155     if( table_id < 0 ) return -1;
00156
00157     /* If dims[1] == 3, then old format of table.
00158      * Deal with it in mhdf_readSetMeta and mhdf_writeSetMeta
00159      */
00160     if( dims[1] != 4 && dims[1] != 3 )
00161     {
00162         mhdf_setFail( status, "Invalid format for meshset table.\n" );
00163         H5Dclose( table_id );
00164         return -1;
00165     }
00166
00167     *num_sets = dims[0];
00168     file_ptr->open_handle_count++;
00169     mhdf_setOkay( status );
00170     API_END_H( 1 );
00171     return table_id;
00172 }
00173
00174 hid_t mhdf_openSetMetaSimple( mhdf_FileHandle file, mhdf_Status* status )
00175 {
00176     FileHandle* file_ptr = (FileHandle*)file;
00177     hid_t table_id;
00178     API_BEGIN;
00179
00180     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00181
00182     table_id = mhdf_open_table_simple( file_ptr->hdf_handle, SET_META_PATH, status );
00183     if( table_id < 0 ) return -1;
00184
00185     file_ptr->open_handle_count++;
00186     mhdf_setOkay( status );
00187     API_END_H( 1 );
00188     return table_id;
00189 }
00190
00191 static int mhdf_readwriteSetMeta( hid_t table_id,
00192                                   int read,
00193                                   long offset,
00194                                   long count,
00195                                   hid_t type,
00196                                   void* data,
00197                                   hid_t prop,
00198                                   mhdf_Status* status )
00199 {
00200     hid_t slab_id, sslab_id, smem_id, mem_id;
00201     hsize_t offsets[2], counts[2], mcounts[2], moffsets[2] = { 0, 0 };
00202     herr_t rval = 0;
00203     int dims, i;
00204     const int fill_val = -1;
00205     const hsize_t one  = 1;
00206
00207     mcounts[0] = count;
00208     mcounts[1] = 4;
00209     if( offset < 0 || count < 0 )
00210     {
00211         mhdf_setFail( status,
00212                       "Invalid input for %s: "
00213                       "offset = %ld, count = %ld\n",
00214                       read ? "read" : "write", offset, count );
00215         return 0;
00216     }
00217
00218     slab_id = H5Dget_space( table_id );
00219     if( slab_id < 0 )
00220     {
00221         mhdf_setFail( status, "Internal error calling H5Dget_space." );
00222         return 0;
00223     }
00224
00225     dims = H5Sget_simple_extent_ndims( slab_id );
00226     if( dims != 2 )
00227     {
00228         H5Sclose( slab_id );
00229         mhdf_setFail( status, "Internal error: unexpected dataset rank: %d.", dims );
00230         return 0;
00231     }
00232
00233     dims = H5Sget_simple_extent_dims( slab_id, counts, NULL );
00234     if( dims < 0 )
00235     {
00236         H5Sclose( slab_id );
00237         mhdf_setFail( status, "Internal error calling H5Sget_simple_extend_dims." );
00238         return 0;
00239     }
00240
00241     if( (unsigned long)( offset + count ) > counts[0] )
00242     {
00243         H5Sclose( slab_id );
00244         mhdf_setFail( status, "Requested %s of rows %ld to %ld of a %ld row table.\n", read ? "read" : "write", offset,
00245                       offset + count - 1, (long)counts[dims - 1] );
00246         return 0;
00247     }
00248     counts[0]  = (hsize_t)count;
00249     offsets[0] = (hsize_t)offset;
00250
00251     if( count )
00252         mem_id = H5Screate_simple( dims, mcounts, NULL );
00253     else
00254     { /* special case for 'NULL' read during collective parallel IO */
00255         mem_id = H5Screate_simple( 1, &one, NULL );
00256         if( mem_id && 0 > H5Sselect_none( mem_id ) )
00257         {
00258             H5Sclose( mem_id );
00259             mem_id = -1;
00260         }
00261     }
00262     if( mem_id < 0 )
00263     {
00264         mhdf_setFail( status, "Internal error calling H5Screate_simple." );
00265         return 0;
00266     }
00267
00268     /* Normal table: 4 columns */
00269     if( counts[1] == 4 )
00270     {
00271         offsets[1] = 0;
00272         if( count )
00273             rval = H5Sselect_hyperslab( slab_id, H5S_SELECT_SET, offsets, NULL, counts, NULL );
00274         else /* special case for 'NULL' read during collective parallel IO */
00275             rval = H5Sselect_none( slab_id );
00276         if( rval < 0 )
00277         {
00278             H5Sclose( mem_id );
00279             H5Sclose( slab_id );
00280             mhdf_setFail( status, "Internal error calling H5Sselect_hyperslab." );
00281             return 0;
00282         }
00283
00284         if( read )
00285             rval = H5Dread( table_id, type, mem_id, slab_id, prop, data );
00286         else
00287             rval = H5Dwrite( table_id, type, mem_id, slab_id, prop, data );
00288     }
00289     /* Old table: 3 columns, no parent link counts */
00290     else if( counts[1] == 3 )
00291     {
00292         rval = 0;
00293         for( i = 0; i < 3 && rval >= 0; ++i )
00294         {
00295             smem_id  = H5Scopy( mem_id );
00296             sslab_id = H5Scopy( slab_id );
00297             if( smem_id < 0 || sslab_id < 0 )
00298             {
00299                 if( smem_id >= 0 ) H5Sclose( smem_id );
00300                 mhdf_setFail( status, "Internal error calling H5Scopy." );
00301                 return 0;
00302             }
00303
00304             counts[1]  = 1;
00305             offsets[1] = i;
00306             if( count )
00307                 rval = H5Sselect_hyperslab( sslab_id, H5S_SELECT_SET, offsets, NULL, counts, NULL );
00308             else
00309                 rval = H5Sselect_none( sslab_id );
00310             if( rval < 0 )
00311             {
00312                 H5Sclose( slab_id );
00313                 H5Sclose( mem_id );
00314                 mhdf_setFail( status, "Internal error calling H5Sselect_hyperslab." );
00315                 return 0;
00316             }
00317
00318             mcounts[1]  = 1;
00319             moffsets[1] = ( i == 2 ) ? 3 : i;
00320             rval        = H5Sselect_hyperslab( smem_id, H5S_SELECT_SET, moffsets, NULL, mcounts, NULL );
00321             if( rval < 0 )
00322             {
00323                 H5Sclose( sslab_id );
00324                 H5Sclose( slab_id );
00325                 H5Sclose( mem_id );
00326                 mhdf_setFail( status, "Internal error calling H5Sselect_hyperslab." );
00327                 return 0;
00328             }
00329
00330             if( read )
00331                 rval = H5Dread( table_id, type, smem_id, sslab_id, prop, data );
00332             else
00333                 rval = H5Dwrite( table_id, type, smem_id, sslab_id, prop, data );
00334
00335             H5Sclose( sslab_id );
00336             H5Sclose( smem_id );
00337         }
00338
00339         if( read && rval >= 0 )
00340         {
00341             mcounts[1]  = 1;
00342             moffsets[1] = 2;
00343             H5Sselect_hyperslab( mem_id, H5S_SELECT_SET, moffsets, NULL, mcounts, NULL );
00344             rval = H5Dfill( &fill_val, H5T_NATIVE_INT, data, type, mem_id );
00345         }
00346     }
00347     else
00348     {
00349         H5Sclose( mem_id );
00350         H5Sclose( slab_id );
00351         mhdf_setFail( status, "Invalid dimension for meshset metadata table." );
00352         return 0;
00353     }
00354
00355     H5Sclose( slab_id );
00356     H5Sclose( mem_id );
00357     if( rval < 0 )
00358     {
00359         mhdf_setFail( status, "Internal error calling H5D%s.", read ? "read" : "write" );
00360         return 0;
00361     }
00362
00363     mhdf_setOkay( status );
00364     return 1;
00365 }
00366
00367 void mhdf_readSetMeta( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status )
00368 {
00369     API_BEGIN;
00370     mhdf_readwriteSetMeta( table_id, 1, offset, count, type, data, H5P_DEFAULT, status );
00371     API_END;
00372 }
00373 void mhdf_readSetMetaWithOpt( hid_t table_id,
00374                               long offset,
00375                               long count,
00376                               hid_t type,
00377                               void* data,
00378                               hid_t prop,
00379                               mhdf_Status* status )
00380 {
00381     API_BEGIN;
00382     mhdf_readwriteSetMeta( table_id, 1, offset, count, type, data, prop, status );
00383     API_END;
00384 }
00385
00386 void mhdf_writeSetMeta( hid_t table_id, long offset, long count, hid_t type, const void* data, mhdf_Status* status )
00387 {
00388     API_BEGIN;
00389     mhdf_readwriteSetMeta( table_id, 0, offset, count, type, (void*)data, H5P_DEFAULT, status );
00390     API_END;
00391 }
00392 void mhdf_writeSetMetaWithOpt( hid_t table_id,
00393                                long offset,
00394                                long count,
00395                                hid_t type,
00396                                const void* data,
00397                                hid_t prop,
00398                                mhdf_Status* status )
00399 {
00400     API_BEGIN;
00401     mhdf_readwriteSetMeta( table_id, 0, offset, count, type, (void*)data, prop, status );
00402     API_END;
00403 }
00404
00405 enum SetMetaCol
00406 {
00407     CONTENT  = 0,
00408     CHILDREN = 1,
00409     PARENTS  = 2,
00410     FLAGS    = 3
00411 };
00412
00413 static int mhdf_readSetMetaColumn( hid_t table_id,
00414                                    enum SetMetaCol column,
00415                                    long offset,
00416                                    long count,
00417                                    hid_t type,
00418                                    void* data,
00419                                    hid_t prop,
00420                                    mhdf_Status* status )
00421 {
00422     hid_t slab_id, mem_id;
00423     hsize_t offsets[2], counts[2], mcount = count;
00424     herr_t rval = 0;
00425     int dims;
00426     const int fill_val = -1;
00427
00428     if( offset < 0 || count < 0 )
00429     {
00430         mhdf_setFail( status,
00431                       "Invalid input for reading set description column: "
00432                       "offset = %ld, count = %ld\n",
00433                       offset, count );
00434         return 0;
00435     }
00436
00437     /* Get dimensions of table, and check against requested count and offset */
00438
00439     slab_id = H5Dget_space( table_id );
00440     if( slab_id < 0 )
00441     {
00442         mhdf_setFail( status, "Internal error calling H5Dget_space." );
00443         return 0;
00444     }
00445
00446     dims = H5Sget_simple_extent_ndims( slab_id );
00447     if( dims != 2 )
00448     {
00449         H5Sclose( slab_id );
00450         mhdf_setFail( status, "Internal error: unexpected dataset rank: %d.", dims );
00451         return 0;
00452     }
00453
00454     dims = H5Sget_simple_extent_dims( slab_id, counts, NULL );
00455     if( dims < 0 )
00456     {
00457         H5Sclose( slab_id );
00458         mhdf_setFail( status, "Internal error calling H5Sget_simple_extend_dims." );
00459         return 0;
00460     }
00461
00462     if( (unsigned long)( offset + count ) > counts[0] )
00463     {
00464         H5Sclose( slab_id );
00465         mhdf_setFail( status, "Requested read of rows %ld to %ld of a %ld row table.\n", offset, offset + count - 1,
00466                       (long)counts[0] );
00467         return 0;
00468     }
00469
00470     /* Create a slab definition for the block of memory we're reading into */
00471
00472     mem_id = H5Screate_simple( 1, &mcount, NULL );
00473     if( mem_id < 0 )
00474     {
00475         H5Sclose( slab_id );
00476         mhdf_setFail( status, "Internal error calling H5Screate_simple." );
00477         return 0;
00478     }
00479
00480     /* Old, 3-column table.
00481      * New table is {contents, children, parents, flags}
00482      * Old table is {contents, children, flags}
00483      * If asking for parents, just return zeros.
00484      * If asking for flags, fix column value.
00485      */
00486     offsets[1] = column;
00487     if( counts[1] == 3 )
00488     {
00489         if( column == PARENTS )
00490         {
00491             rval = H5Dfill( &fill_val, H5T_NATIVE_INT, data, type, mem_id );
00492             H5Sclose( mem_id );
00493             H5Sclose( slab_id );
00494             if( rval < 0 )
00495             {
00496                 mhdf_setFail( status, "Internal error calling H5Dfill" );
00497                 return 0;
00498             }
00499             else
00500             {
00501                 mhdf_setOkay( status );
00502                 return 1;
00503             }
00504         }
00505         else if( column == FLAGS )
00506             --offsets[1];
00507     }
00508     else if( counts[1] != 4 )
00509     {
00510         H5Sclose( mem_id );
00511         H5Sclose( slab_id );
00512         mhdf_setFail( status, "Invalid dimension for meshset metadata table." );
00513         return 0;
00514     }
00515
00516     /* Create a slab defintion for the portion of the table we want to read. */
00517
00518     /* offsets[1] was initialized in the above block of code. */
00519     offsets[0] = (hsize_t)offset;
00520     counts[0]  = (hsize_t)count;
00521     counts[1]  = 1; /* one column */
00522     if( count )
00523         rval = H5Sselect_hyperslab( slab_id, H5S_SELECT_SET, offsets, NULL, counts, NULL );
00524     else
00525         rval = H5Sselect_none( slab_id );
00526     if( rval < 0 )
00527     {
00528         H5Sclose( mem_id );
00529         H5Sclose( slab_id );
00530         mhdf_setFail( status, "Internal error calling H5Sselect_hyperslab." );
00531         return 0;
00532     }
00533
00534     /* Read the data */
00535
00536     rval = H5Dread( table_id, type, mem_id, slab_id, prop, data );
00537     H5Sclose( mem_id );
00538     H5Sclose( slab_id );
00539     if( rval < 0 )
00540     {
00541         mhdf_setFail( status, "Internal error calling H5Dread." );
00542         return 0;
00543     }
00544
00545     mhdf_setOkay( status );
00546     return 1;
00547 }
00548
00549 void mhdf_readSetFlags( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status )
00550 {
00551     API_BEGIN;
00552     mhdf_readSetMetaColumn( table_id, FLAGS, offset, count, type, data, H5P_DEFAULT, status );
00553     API_END;
00554 }
00555 void mhdf_readSetFlagsWithOpt( hid_t table_id,
00556                                long offset,
00557                                long count,
00558                                hid_t type,
00559                                void* data,
00560                                hid_t prop,
00561                                mhdf_Status* status )
00562 {
00563     API_BEGIN;
00564     mhdf_readSetMetaColumn( table_id, FLAGS, offset, count, type, data, prop, status );
00565     API_END;
00566 }
00567
00568 void mhdf_readSetContentEndIndices( hid_t table_id,
00569                                     long offset,
00570                                     long count,
00571                                     hid_t type,
00572                                     void* data,
00573                                     mhdf_Status* status )
00574 {
00575     API_BEGIN;
00576     mhdf_readSetMetaColumn( table_id, CONTENT, offset, count, type, data, H5P_DEFAULT, status );
00577     API_END;
00578 }
00579 void mhdf_readSetContentEndIndicesWithOpt( hid_t table_id,
00580                                            long offset,
00581                                            long count,
00582                                            hid_t type,
00583                                            void* data,
00584                                            hid_t prop,
00585                                            mhdf_Status* status )
00586 {
00587     API_BEGIN;
00588     mhdf_readSetMetaColumn( table_id, CONTENT, offset, count, type, data, prop, status );
00589     API_END;
00590 }
00591
00592 void mhdf_readSetChildEndIndices( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status )
00593 {
00594     API_BEGIN;
00595     mhdf_readSetMetaColumn( table_id, CHILDREN, offset, count, type, data, H5P_DEFAULT, status );
00596     API_END;
00597 }
00598 void mhdf_readSetChildEndIndicesWithOpt( hid_t table_id,
00599                                          long offset,
00600                                          long count,
00601                                          hid_t type,
00602                                          void* data,
00603                                          hid_t prop,
00604                                          mhdf_Status* status )
00605 {
00606     API_BEGIN;
00607     mhdf_readSetMetaColumn( table_id, CHILDREN, offset, count, type, data, prop, status );
00608     API_END;
00609 }
00610
00611 void mhdf_readSetParentEndIndices( hid_t table_id,
00612                                    long offset,
00613                                    long count,
00614                                    hid_t type,
00615                                    void* data,
00616                                    mhdf_Status* status )
00617 {
00618     API_BEGIN;
00619     mhdf_readSetMetaColumn( table_id, PARENTS, offset, count, type, data, H5P_DEFAULT, status );
00620     API_END;
00621 }
00622 void mhdf_readSetParentEndIndicesWithOpt( hid_t table_id,
00623                                           long offset,
00624                                           long count,
00625                                           hid_t type,
00626                                           void* data,
00627                                           hid_t prop,
00628                                           mhdf_Status* status )
00629 {
00630     API_BEGIN;
00631     mhdf_readSetMetaColumn( table_id, PARENTS, offset, count, type, data, prop, status );
00632     API_END;
00633 }
00634
00635 hid_t mhdf_createSetData( mhdf_FileHandle file_handle, long data_list_size, mhdf_Status* status )
00636 {
00637     FileHandle* file_ptr;
00638     hid_t table_id;
00639     hsize_t dim = (hsize_t)data_list_size;
00640     API_BEGIN;
00641
00642     file_ptr = (FileHandle*)( file_handle );
00643     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00644
00645     if( data_list_size < 1 )
00646     {
00647         mhdf_setFail( status, "Invalid argument.\n" );
00648         return -1;
00649     }
00650
00651     table_id = mhdf_create_table( file_ptr->hdf_handle, SET_DATA_PATH, file_ptr->id_type, 1, &dim, status );
00652
00653     API_END_H( 1 );
00654     return table_id;
00655 }
00656
00657 hid_t mhdf_openSetData( mhdf_FileHandle file_handle, long* data_list_size_out, mhdf_Status* status )
00658 {
00659     FileHandle* file_ptr;
00660     hid_t table_id;
00661     hsize_t dim;
00662     API_BEGIN;
00663
00664     file_ptr = (FileHandle*)( file_handle );
00665     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00666
00667     if( !data_list_size_out )
00668     {
00669         mhdf_setFail( status, "Invalid argument.\n" );
00670         return -1;
00671     }
00672
00673     table_id = mhdf_open_table( file_ptr->hdf_handle, SET_DATA_PATH, 1, &dim, status );
00674
00675     *data_list_size_out = (long)dim;
00676     API_END_H( 1 );
00677     return table_id;
00678 }
00679
00680 void mhdf_writeSetData( hid_t table_id, long offset, long count, hid_t type, const void* data, mhdf_Status* status )
00681 {
00682     API_BEGIN;
00683     mhdf_write_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
00684     API_END;
00685 }
00686 void mhdf_writeSetDataWithOpt( hid_t table_id,
00687                                long offset,
00688                                long count,
00689                                hid_t type,
00690                                const void* data,
00691                                hid_t prop,
00692                                mhdf_Status* status )
00693 {
00694     API_BEGIN;
00695     mhdf_write_data( table_id, offset, count, type, data, prop, status );
00696     API_END;
00697 }
00698
00699 void mhdf_readSetData( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status )
00700 {
00701     API_BEGIN;
00702     mhdf_read_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
00703     API_END;
00704 }
00705 void mhdf_readSetDataWithOpt( hid_t table_id,
00706                               long offset,
00707                               long count,
00708                               hid_t type,
00709                               void* data,
00710                               hid_t prop,
00711                               mhdf_Status* status )
00712 {
00713     API_BEGIN;
00714     mhdf_read_data( table_id, offset, count, type, data, prop, status );
00715     API_END;
00716 }
00717
00718 hid_t mhdf_createSetChildren( mhdf_FileHandle file_handle, long child_list_size, mhdf_Status* status )
00719 {
00720     FileHandle* file_ptr;
00721     hid_t table_id;
00722     hsize_t dim = (hsize_t)child_list_size;
00723     API_BEGIN;
00724
00725     file_ptr = (FileHandle*)( file_handle );
00726     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00727
00728     if( child_list_size < 1 )
00729     {
00730         mhdf_setFail( status, "Invalid argument.\n" );
00731         return -1;
00732     }
00733
00734     table_id = mhdf_create_table( file_ptr->hdf_handle, SET_CHILD_PATH, file_ptr->id_type, 1, &dim, status );
00735
00736     API_END_H( 1 );
00737     return table_id;
00738 }
00739
00740 hid_t mhdf_openSetChildren( mhdf_FileHandle file_handle, long* child_list_size, mhdf_Status* status )
00741 {
00742     FileHandle* file_ptr;
00743     hid_t table_id;
00744     hsize_t dim;
00745     API_BEGIN;
00746
00747     file_ptr = (FileHandle*)( file_handle );
00748     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00749
00750     if( !child_list_size )
00751     {
00752         mhdf_setFail( status, "Invalid argument.\n" );
00753         return -1;
00754     }
00755
00756     table_id = mhdf_open_table( file_ptr->hdf_handle, SET_CHILD_PATH, 1, &dim, status );
00757
00758     *child_list_size = (long)dim;
00759     API_END_H( 1 );
00760     return table_id;
00761 }
00762
00763 hid_t mhdf_createSetParents( mhdf_FileHandle file_handle, long parent_list_size, mhdf_Status* status )
00764 {
00765     FileHandle* file_ptr;
00766     hid_t table_id;
00767     hsize_t dim = (hsize_t)parent_list_size;
00768     API_BEGIN;
00769
00770     file_ptr = (FileHandle*)( file_handle );
00771     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00772
00773     if( parent_list_size < 1 )
00774     {
00775         mhdf_setFail( status, "Invalid argument.\n" );
00776         return -1;
00777     }
00778
00779     table_id = mhdf_create_table( file_ptr->hdf_handle, SET_PARENT_PATH, file_ptr->id_type, 1, &dim, status );
00780
00781     API_END_H( 1 );
00782     return table_id;
00783 }
00784
00785 hid_t mhdf_openSetParents( mhdf_FileHandle file_handle, long* parent_list_size, mhdf_Status* status )
00786 {
00787     FileHandle* file_ptr;
00788     hid_t table_id;
00789     hsize_t dim;
00790     API_BEGIN;
00791
00792     file_ptr = (FileHandle*)( file_handle );
00793     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00794
00795     if( !parent_list_size )
00796     {
00797         mhdf_setFail( status, "Invalid argument.\n" );
00798         return -1;
00799     }
00800
00801     table_id = mhdf_open_table( file_ptr->hdf_handle, SET_PARENT_PATH, 1, &dim, status );
00802
00803     *parent_list_size = (long)dim;
00804     API_END_H( 1 );
00805     return table_id;
00806 }
00807
00808 void mhdf_writeSetParentsChildren( hid_t table_id,
00809                                    long offset,
00810                                    long count,
00811                                    hid_t type,
00812                                    const void* data,
00813                                    mhdf_Status* status )
00814 {
00815     API_BEGIN;
00816     mhdf_write_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
00817     API_END;
00818 }
00819 void mhdf_writeSetParentsChildrenWithOpt( hid_t table_id,
00820                                           long offset,
00821                                           long count,
00822                                           hid_t type,
00823                                           const void* data,
00824                                           hid_t prop,
00825                                           mhdf_Status* status )
00826 {
00827     API_BEGIN;
00828     mhdf_write_data( table_id, offset, count, type, data, prop, status );
00829     API_END;
00830 }
00831
00832 void mhdf_readSetParentsChildren( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status )
00833 {
00834     API_BEGIN;
00835     mhdf_read_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
00836     API_END;
00837 }
00838 void mhdf_readSetParentsChildrenWithOpt( hid_t table_id,
00839                                          long offset,
00840                                          long count,
00841                                          hid_t type,
00842                                          void* data,
00843                                          hid_t prop,
00844                                          mhdf_Status* status )
00845 {
00846     API_BEGIN;
00847     mhdf_read_data( table_id, offset, count, type, data, prop, status );
00848     API_END;
00849 }
