MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "Mesquite.hpp"
#include "MeshImpl.hpp"
#include "PlanarDomain.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "MsqError.hpp"
#include "ShapeImprovementWrapper.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "EdgeLengthQualityMetric.hpp"
#include "LPtoPTemplate.hpp"
#include "SteepestDescent.hpp"
#include "ConjugateGradient.hpp"
#include <iostream>
#include <cstdlib>
Functions | |
int | main () |
int main | ( | ) |
Definition at line 70 of file simple_hybrid_test.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::InstructionQueue::add_quality_assessor(), default_file_name, mesh, MBMesquite::print_timing_diagnostics(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::PatchSetUser::use_global_patch(), and MBMesquite::MeshImpl::write_vtk().
{ MBMesquite::MeshImpl mesh; MsqPrintError err( cout ); // create geometry: plane z=0, normal (0,0,1) Vector3D pnt( 0, 0, 0 ); Vector3D s_norm( 0, 0, 1 ); MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); std::string default_file_name = TestDir + "unittest/mesquite/2D/vtk/mixed/untangled/hybrid_3quad_1tri.vtk"; mesh.read_vtk( default_file_name.c_str(), err ); if( err ) return 1; // creates an intruction queue InstructionQueue queue1; // creates a mean ratio quality metric ... IdealWeightInverseMeanRatio mean_ratio( err ); if( err ) return 1; // mean_ratio->set_gradient_type(QualityMetric::NUMERICAL_GRADIENT); // mean_ratio->set_hessian_type(QualityMetric::NUMERICAL_HESSIAN); // mean_ratio->set_averaging_method(QualityMetric::SUM, err); // MSQ_CHKERR(err); // ... and builds an objective function with it LPtoPTemplate obj_func( &mean_ratio, 2, err ); if( err ) return 1; ; // creates the steepest descent, feas newt optimization procedures // ConjugateGradient* pass1 = new ConjugateGradient( &obj_func, err ); SteepestDescent pass1( &obj_func ); pass1.use_global_patch(); if( err ) return 1; ; QualityAssessor qa = QualityAssessor( &mean_ratio ); if( err ) return 1; ; // **************Set termination criterion**************** TerminationCriterion tc_inner; tc_inner.add_iteration_limit( 1 ); //_inner.add_absolute_quality_improvement( OF_value ); // tc_inner.add_absolute_gradient_L2_norm( OF_value ); TerminationCriterion tc_outer; // tc_outer.add_iteration_limit( 1 ); tc_outer.add_iteration_limit( 1 ); pass1.set_inner_termination_criterion( &tc_inner ); pass1.set_outer_termination_criterion( &tc_outer ); queue1.add_quality_assessor( &qa, err ); if( err ) return 1; // adds 1 pass of pass1 to mesh_set1 queue1.set_master_quality_improver( &pass1, err ); if( err ) return 1; queue1.add_quality_assessor( &qa, err ); if( err ) return 1; mesh.write_vtk( "original_mesh.vtk", err ); if( err ) return 1; MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); queue1.run_instructions( &mesh_and_domain, err ); if( err ) return 1; mesh.write_vtk( "smoothed_mesh.vtk", err ); if( err ) return 1; // std::cout<<"\n\nNow running the shape wrapper.\n=n"; // ShapeImprovementWrapper wrap(100); // wrap.run_instructions(mesh_set1, err); MSQ_CHKERR(err); print_timing_diagnostics( cout ); return 0; }
