spatial_locator_test.cpp File Reference
#include "moab/Core.hpp"
#include "moab/SpatialLocator.hpp"
#include "moab/Tree.hpp"
#include "moab/HomXform.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/CartVect.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/BVHTree.hpp"
#include "moab/ElemEvaluator.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/CpuTimer.hpp"
#include "TestUtil.hpp"
#include <cstdlib>
#include <sstream>
+ Include dependency graph for spatial_locator_test.cpp:
Functions
void test_kd_tree ()
void test_bvh_tree ()
void test_locator (SpatialLocator *sl)
ErrorCode create_hex_mesh (Interface &mb, Range &elems, int n, int dim)
int main (int argc, char **argv)
Variables
int max_depth = 30
int npoints = 1000
int leaf = 6
bool print_tree = false
int ints = 10
Function Documentation
ErrorCode create_hex_mesh ( Interface mb,
Range elems,
int  n,
int  dim
int main ( int  argc,
char **  argv
Definition at line 36 of file spatial_locator_test.cpp.
References ProgOptions::addOpt(), moab::fail(), ints, leaf, max_depth, npoints, ProgOptions::parseCommandLine(), print_tree, RUN_TEST, test_bvh_tree(), and test_kd_tree().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#else
    // silence the warning of parameters not used, in serial; there should be a smarter way :(
    argv[0] = argv[argc - argc];
#endif
    ProgOptions po( "spatial_locator_test options" );
    po.addOpt< int >( "ints,i", "Number of intervals on each side of scd mesh", &ints );
    po.addOpt< int >( "leaf,l", "Maximum number of elements per leaf", &leaf );
    po.addOpt< int >( "max_depth,m", "Maximum depth of tree", &max_depth );
    po.addOpt< int >( "npoints,n", "Number of query points", &npoints );
    po.addOpt< void >( "print,p", "Print tree details", &print_tree );
    po.parseCommandLine( argc, argv );
    RUN_TEST( test_kd_tree );
    RUN_TEST( test_bvh_tree );
    fail = MPI_Finalize();
#endif
    return 0;
void test_bvh_tree ( )
void test_kd_tree ( )
void test_locator ( SpatialLocator sl)
Variable Documentation
int ints = 10
Definition at line 34 of file spatial_locator_test.cpp.
int leaf = 6
Definition at line 32 of file spatial_locator_test.cpp.
int max_depth = 30
Definition at line 30 of file spatial_locator_test.cpp.
int npoints = 1000
Definition at line 31 of file spatial_locator_test.cpp.
Definition at line 33 of file spatial_locator_test.cpp.
