moab::SimpleStat< T > Struct Template Reference
Public Member Functions
 SimpleStat ()
void add (T value)
double avg () const
double rms () const
double dev () const
Public Attributes
T min
T max
T sum
T sqr
size_t count
Detailed Description
template<typename T>
struct moab::SimpleStat< T >
Definition at line 2093 of file AdaptiveKDTree.cpp.
template<typename T >
SimpleStat< T >::SimpleStat ( )
Definition at line 2116 of file AdaptiveKDTree.cpp.
    : min( std::numeric_limits< T >::max() ), max( std::numeric_limits< T >::min() ), sum( 0 ), sqr( 0 ), count( 0 )
Member Function Documentation
void SimpleStat< T >::add ( T  value)
Definition at line 2122 of file AdaptiveKDTree.cpp.
References moab::sum().
Referenced by moab::AdaptiveKDTree::print().
    if( value < min ) min = value;
    if( value > max ) max = value;
    sum += value;
    sqr += value * value;
    ++count;
double moab::SimpleStat< T >::avg ( ) const [inline]
Definition at line 2099 of file AdaptiveKDTree.cpp.
        return (double)sum / count;
double moab::SimpleStat< T >::dev ( ) const [inline]
Definition at line 2107 of file AdaptiveKDTree.cpp.
        return ( count > 1
                     ? sqrt( ( count * (double)sqr - (double)sum * (double)sum ) / ( (double)count * ( count - 1 ) ) )
                     : 0.0 );
double moab::SimpleStat< T >::rms ( ) const [inline]
Definition at line 2103 of file AdaptiveKDTree.cpp.
        return sqrt( (double)sqr / count );
Member Data Documentation
T moab::SimpleStat< T >::max
Definition at line 2095 of file AdaptiveKDTree.cpp.
T moab::SimpleStat< T >::min
T moab::SimpleStat< T >::sqr
Referenced by SimpleStat< T >::dev(), and SimpleStat< T >::rms().
T moab::SimpleStat< T >::sum
List of all members.
The documentation for this struct was generated from the following files:
