moab::serial_tag_data Struct Reference
Public Member Functions
size_t len () const
void * default_value ()
const void * default_value () const
void set_default_value (const void *val)
Static Public Member Functions
static size_t pad (size_t len)
static size_t def_val_bytes (int def_val_len, DataType type)
static size_t len (int name_len, int def_val_len, DataType type)
Public Attributes
TagType storage
DataType type
int size
int name_len
int def_val_len
char name [sizeof(unsigned long)]
Detailed Description
Definition at line 524 of file WriteHDF5Parallel.cpp.
Member Function Documentation
static size_t moab::serial_tag_data::def_val_bytes ( int  def_val_len,
DataType  type
) [inline, static]
Definition at line 541 of file WriteHDF5Parallel.cpp.
References def_val_len, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, and MB_TYPE_OPAQUE.
Referenced by len(), and set_default_value().
        switch( type )
            case MB_TYPE_BIT:
                return def_val_len ? 1 : 0;
            case MB_TYPE_OPAQUE:
                return def_val_len;
            case MB_TYPE_INTEGER:
                return def_val_len * sizeof( int );
            case MB_TYPE_DOUBLE:
                return def_val_len * sizeof( double );
            case MB_TYPE_HANDLE:
                return def_val_len * sizeof( EntityHandle );
        return 0;
const void* moab::serial_tag_data::default_value ( ) const [inline]
Definition at line 572 of file WriteHDF5Parallel.cpp.
References default_value().
        return const_cast< serial_tag_data* >( this )->default_value();
static size_t moab::serial_tag_data::len ( int  name_len,
int  def_val_len,
DataType  type
) [inline, static]
Definition at line 559 of file WriteHDF5Parallel.cpp.
References def_val_bytes(), and pad().
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data().
        return sizeof( serial_tag_data ) + pad( name_len + def_val_bytes( def_val_len, type ) ) -
               sizeof( unsigned long );
size_t moab::serial_tag_data::len ( ) const [inline]
Definition at line 564 of file WriteHDF5Parallel.cpp.
References def_val_len, name_len, and type.
Referenced by moab::WriteHDF5Parallel::append_serial_tag_data(), and pad().
        return len( name_len, def_val_len, type );
static size_t moab::serial_tag_data::pad ( size_t  len) [inline, static]
Definition at line 533 of file WriteHDF5Parallel.cpp.
References len().
Referenced by len().
        if( len % sizeof( unsigned long ) )
            return len + sizeof( unsigned long ) - len % sizeof( unsigned long );
        else
            return len;
void moab::serial_tag_data::set_default_value ( const void *  val) [inline]
Member Data Documentation
List of all members.
The documentation for this struct was generated from the following file:
