stat_set Struct Reference
Public Member Functions
 stat_set ()
void add (double val)
void add (const stat_set &stats)
void clear ()
Public Attributes
double sum
double sqr
double min
double max
long count
Detailed Description
Definition at line 67 of file size.cpp.
stat_set::stat_set ( ) [inline]
Definition at line 75 of file size.cpp.
: sum( 0 ), sqr( 0 ), min( HUGE_VAL ), max( 0 ), count( 0 ) {}
Member Function Documentation
void stat_set::add ( double  val) [inline]
Definition at line 77 of file size.cpp.
References moab::sum().
Referenced by gather_set_stats().
        if( val < min ) min = val;
        if( val > max ) max = val;
        sum += val;
        sqr += val * val;
        ++count;
void stat_set::add ( const stat_set stats) [inline]
Definition at line 86 of file size.cpp.
References count, max, min, sqr, sum, and moab::sum().
        if( stats.min < min ) min = stats.min;
        if( stats.max > max ) max = stats.max;
        sum += stats.sum;
        sqr += stats.sqr;
        count += stats.count;
void stat_set::clear ( ) [inline]
Definition at line 95 of file size.cpp.
        sum = sqr = 0.0;
        max = count = 0;
        min         = HUGE_VAL;
Member Data Documentation
Definition at line 73 of file size.cpp.
Referenced by add(), and print_stats().
double stat_set::max
Definition at line 72 of file size.cpp.
double stat_set::min
Definition at line 71 of file size.cpp.
double stat_set::sqr
Definition at line 70 of file size.cpp.
double stat_set::sum
Definition at line 69 of file size.cpp.
List of all members.
The documentation for this struct was generated from the following file:
