main.cpp File Reference
#include "TestUtil.hpp"
#include "MeshImpl.hpp"
#include "PlanarDomain.hpp"
#include "TriLagrangeShape.hpp"
#include "QuadLagrangeShape.hpp"
#include "IdealShapeTarget.hpp"
#include "TShapeNB1.hpp"
#include "TQualityMetric.hpp"
#include "SteepestDescent.hpp"
#include "SlaveBoundaryVertices.hpp"
#include "PMeanPTemplate.hpp"
#include "InstructionQueue.hpp"
#include "MsqVertex.hpp"
#include "MsqError.hpp"
#include "QualityAssessor.hpp"
#include "PatchData.hpp"
#include <iostream>
#include <algorithm>
#include <cassert>
+ Include dependency graph for test/mesquite/slaved/main.cpp:
Functions
void usage (const char *argv0)
int check_slaved_coords (Mesh &mesh, Settings::HigherOrderSlaveMode mode, std::string &name, bool have_slaved_flag, MsqError &err)
int compare_node_coords (Mesh &mesh1, Mesh &mesh2, MsqError &err)
int check_no_slaved_corners (Mesh &mesh, MsqError &err)
int check_global_patch_slaved (Mesh &mesh, MsqError &err)
void tag_patch_slaved (Mesh &mesh, Settings::HigherOrderSlaveMode mode, MsqError &err)
int main (int argc, char *argv[])
Vector3D get_slaved_coords (Mesh &mesh, Mesh::VertexHandle vertex, MsqError &err)
Variables
std::string DEFAULT_INPUT_FILE = "/input.vtk"
Function Documentation
int check_global_patch_slaved ( Mesh mesh,
MsqError err
Definition at line 464 of file test/mesquite/slaved/main.cpp.
References MBMesquite::PatchData::attach_settings(), error_count, MBMesquite::PatchData::fill_global_patch(), fixed, MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::Instruction::initialize_vertex_byte(), MSQ_ERRZERO, MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::num_nodes(), MBMesquite::PatchData::num_slave_vertices(), MBMesquite::PatchData::set_mesh(), MBMesquite::Settings::set_slaved_ho_node_mode(), MBMesquite::Settings::SLAVE_FLAG, MBMesquite::Mesh::vertices_get_fixed_flag(), and MBMesquite::Mesh::vertices_get_slaved_flag().
Referenced by main().
    Settings s;
    s.set_slaved_ho_node_mode( Settings::SLAVE_FLAG );
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, 0 );
    Instruction::initialize_vertex_byte( &mesh_and_domain, &s, err );
    MSQ_ERRZERO( err );
    PatchData pd;
    pd.attach_settings( &s );
    pd.set_mesh( &mesh );
    pd.fill_global_patch( err );
    MSQ_ERRZERO( err );
    std::vector< bool > fixed, slaved;
    mesh.vertices_get_fixed_flag( pd.get_vertex_handles_array(), fixed, pd.num_nodes(), err );
    MSQ_ERRZERO( err );
    mesh.vertices_get_slaved_flag( pd.get_vertex_handles_array(), slaved, pd.num_nodes(), err );
    MSQ_ERRZERO( err );
    const size_t first_free   = 0;
    const size_t first_slaved = pd.num_free_vertices();
    const size_t first_fixed  = pd.num_free_vertices() + pd.num_slave_vertices();
    int error_count           = 0;
    for( size_t i = first_free; i < first_slaved; ++i )
        if( fixed[i] )
            std::cerr << "Vertex " << (size_t)pd.get_vertex_handles_array()[i]
                      << " is fixed in mesh but free in PatchData" << std::endl;
            ++error_count;
        if( slaved[i] )
                      << " is slaved in mesh but free in PatchData" << std::endl;
            ++error_count;
    for( size_t i = first_slaved; i < first_fixed; ++i )
        if( fixed[i] )
                      << " is fixed in mesh but slaved in PatchData" << std::endl;
            ++error_count;
        else if( !slaved[i] )
                      << " is free in Mesh but slaved in PatchData" << std::endl;
            ++error_count;
    for( size_t i = first_fixed; i < pd.num_nodes(); ++i )
        if( !fixed[i] )
                      << " is not fixed in mesh but is in PatchData" << std::endl;
            ++error_count;
    return 0 == error_count;
int check_no_slaved_corners ( Mesh mesh,
MsqError err
Definition at line 429 of file test/mesquite/slaved/main.cpp.
References MBMesquite::arrptr(), corners, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), error_count, MBMesquite::Mesh::get_all_elements(), MSQ_ERRZERO, n, and MBMesquite::Mesh::vertices_get_slaved_flag().
    std::vector< Mesh::ElementHandle > elems;
    std::vector< Mesh::VertexHandle > verts;
    std::vector< EntityTopology > types;
    std::vector< size_t > offsets;
    mesh.get_all_elements( elems, err );
    MSQ_ERRZERO( err );
    types.resize( elems.size() );
    mesh.elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );
    MSQ_ERRZERO( err );
    mesh.elements_get_attached_vertices( arrptr( elems ), elems.size(), verts, offsets, err );
    MSQ_ERRZERO( err );
    std::vector< bool > slaved;
    mesh.vertices_get_slaved_flag( arrptr( verts ), slaved, verts.size(), err );
    MSQ_ERRZERO( err );
    for( size_t i = 0; i < elems.size(); ++i )
        unsigned n = TopologyInfo::corners( types[i] );
        for( unsigned j = 0; j < n; ++j )
            if( slaved[offsets[i] + j] )
                std::cerr << "Element " << (size_t)elems[i] << " corner " << j << " is slaved" << std::endl;
                ++error_count;
    return error_count == 0;
int check_slaved_coords ( Mesh mesh,
std::string &  name,
MsqError err
Definition at line 265 of file test/mesquite/slaved/main.cpp.
References MBMesquite::arrptr(), corners, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MBMesquite::EPSILON, error_count, fixed, MBMesquite::Mesh::get_all_elements(), get_slaved_coords(), MBMesquite::Vector3D::length(), MSQ_CHKERR, MSQ_ERRZERO, MBMesquite::Settings::SLAVE_ALL, MBMesquite::Settings::SLAVE_NONE, MBMesquite::Mesh::vertices_get_coordinates(), MBMesquite::Mesh::vertices_get_fixed_flag(), and MBMesquite::Mesh::vertices_get_slaved_flag().
    const double EPSILON = 1e-4;
    // We can distinguish between nodes near the boundary and those
    // further inside based on the slaved attribute flag in the
    // the default input file.  The default input file should always
    // have it defined
    if( !have_slaved_flag )
        std::cerr << "slaved flag not specified in input file. Cannot validate results." << std::endl;
        return 1;
    // Get list of all higher-order nodes
    MSQ_ERRZERO( err );
    std::vector< EntityTopology > types( elems.size() );
    MSQ_ERRZERO( err );
    MSQ_ERRZERO( err );
    std::vector< Mesh::VertexHandle >::iterator r, e, w = verts.begin();
        r = verts.begin() + offsets[i] + TopologyInfo::corners( types[i] );
        e = verts.begin() + offsets[i + 1];
        w = std::copy( r, e, w );
    std::sort( verts.begin(), w );
    verts.erase( std::unique( verts.begin(), w ), verts.end() );
    // Get lists of slaved and non-slaved free vertices, where 'slaved'
    // are those vertices far from the boundary that would be slaved if
    // mode == SLAVE_FLAG, not those that were actually slaved during
    // the optimization
    mesh.vertices_get_fixed_flag( arrptr( verts ), fixed, verts.size(), err );
    if( MSQ_CHKERR( err ) )
        return 1;
        return 1;
    std::vector< Mesh::VertexHandle > free, slave;
    for( size_t i = 0; i < verts.size(); ++i )
        if( !fixed[i] && slaved[i] )
            slave.push_back( verts[i] );
        else if( !fixed[i] && !slaved[i] )
            free.push_back( verts[i] );
    // get all coordinates
    std::vector< MsqVertex > free_coords( free.size() ), slave_coords( slave.size() );
    mesh.vertices_get_coordinates( arrptr( free ), arrptr( free_coords ), free.size(), err );
    MSQ_ERRZERO( err );
    mesh.vertices_get_coordinates( arrptr( slave ), arrptr( slave_coords ), slave.size(), err );
    MSQ_ERRZERO( err );
    // Expect vertices near boundary to be at slave vertex positions
    // if mode was SLAVE_ALL
    if( mode == Settings::SLAVE_ALL )
        for( size_t i = 0; i < free.size(); ++i )
            Vector3D exp = get_slaved_coords( mesh, free[i], err );
            MSQ_ERRZERO( err );
            exp -= free_coords[i];
            if( exp.length() > EPSILON )
                std::cerr << "Slaved vertex " << (size_t)free[i] << " not at expected slaved location" << std::endl;
                ++error_count;
    // Otherwise, given the default input mesh, at least some of the
    // vertices should be somewhere other than the slaved position
    else
        int not_at_slaved_count = 0;
            MSQ_ERRZERO( err );
                ++not_at_slaved_count;
        if( 0 == not_at_slaved_count )
            std::cerr << "All non-slaved vertices at slaved vertex locations" << std::endl;
            error_count += free.size();
    // expect all interior vertices to be at roughly the slaved location
    if( mode != Settings::SLAVE_NONE )
        for( size_t i = 0; i < slave.size(); ++i )
            Vector3D exp = get_slaved_coords( mesh, slave[i], err );
            MSQ_ERRZERO( err );
            exp -= slave_coords[i];
                std::cerr << "Interior vertex " << (size_t)slave[i] << " not at expected slaved location" << std::endl;
                ++error_count;
    return error_count;
int compare_node_coords ( Mesh mesh1,
Mesh mesh2,
MsqError err
Definition at line 396 of file test/mesquite/slaved/main.cpp.
References MBMesquite::arrptr(), MBMesquite::EPSILON, error_count, MBMesquite::Mesh::get_all_vertices(), MBMesquite::Vector3D::length(), MSQ_ERRZERO, and MBMesquite::Mesh::vertices_get_coordinates().
    std::vector< Mesh::VertexHandle > verts1, verts2;
    mesh1.get_all_vertices( verts1, err );
    MSQ_ERRZERO( err );
    mesh2.get_all_vertices( verts2, err );
    MSQ_ERRZERO( err );
    std::vector< MsqVertex > coords1( verts1.size() ), coords2( verts2.size() );
    mesh1.vertices_get_coordinates( arrptr( verts1 ), arrptr( coords1 ), verts1.size(), err );
    MSQ_ERRZERO( err );
    mesh2.vertices_get_coordinates( arrptr( verts2 ), arrptr( coords2 ), verts2.size(), err );
    MSQ_ERRZERO( err );
    assert( verts1.size() == verts2.size() );
    for( size_t i = 0; i < verts1.size(); ++i )
        assert( verts1[i] == verts2[i] );
        Vector3D diff = coords1[i] - coords2[i];
        if( diff.length() > EPSILON )
            std::cerr << "Vertex coordinates differ between calculated and flagged "
                         "meshes for vertex "
                      << (size_t)verts1[i] << std::endl;
            ++error_count;
    return error_count;
Vector3D get_slaved_coords ( Mesh mesh,
MsqError err
Definition at line 224 of file test/mesquite/slaved/main.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MSQ_CHKERR, n, moab::sum(), MBMesquite::Mesh::vertices_get_attached_elements(), MBMesquite::Mesh::vertices_get_coordinates(), and vtx().
Referenced by check_slaved_coords().
    std::vector< Mesh::ElementHandle > elem;
    std::vector< size_t > off;
    mesh.vertices_get_attached_elements( &vertex, 1, elem, off, err );
    if( MSQ_CHKERR( err ) ) return Vector3D( 0.0 );
    mesh.elements_get_attached_vertices( arrptr( elem ), 1, verts, off, err );
    EntityTopology type;
    mesh.elements_get_topologies( arrptr( elem ), &type, 1, err );
    size_t idx = std::find( verts.begin(), verts.end(), vertex ) - verts.begin();
    unsigned side_dim, side_num;
    TopologyInfo::side_from_higher_order( type, verts.size(), idx, side_dim, side_num, err );
    // just return the mean of the corner vertices defining the side.
    // this should always be correct for mid-edge nodes but is a bit
    // dubious for mid-face or mid-region nodes.  But our default input
    // file (the only file for which we should be in this function) will
    // have only mid-edge nodes.
    unsigned n;
    const unsigned* side_vtx = TopologyInfo::side_vertices( type, side_dim, side_num, n, err );
    Vector3D sum( 0.0 );
    for( unsigned i = 0; i < n; ++i )
        MsqVertex coords;
        Mesh::VertexHandle vtx = verts[side_vtx[i]];
        mesh.vertices_get_coordinates( &vtx, &coords, 1, err );
        sum += coords;
    return sum / n;
int main ( int  argc,
char *  argv[]
Definition at line 82 of file test/mesquite/slaved/main.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::InstructionQueue::add_quality_assessor(), MBMesquite::InstructionQueue::add_vertex_slaver(), MBMesquite::arrptr(), check_global_patch_slaved(), check_no_slaved_corners(), check_slaved_coords(), MBMesquite::MsqError::clear(), compare_node_coords(), DEFAULT_INPUT_FILE, MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::MeshImpl::get_all_vertices(), MBMesquite::inner(), input_file, MBMesquite::MeshImpl::read_vtk(), MBMesquite::InstructionQueue::remove_vertex_slaver(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::Settings::set_mapping_function(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::Settings::set_slaved_ho_node_mode(), MBMesquite::Settings::SLAVE_ALL, MBMesquite::Settings::SLAVE_CALCULATED, MBMesquite::Settings::SLAVE_FLAG, MBMesquite::Settings::SLAVE_NONE, tag_patch_slaved(), usage, MBMesquite::MeshImpl::vertices_get_slaved_flag(), and MBMesquite::MeshImpl::write_vtk().
    const char* input_file       = DEFAULT_INPUT_FILE.c_str();
    const char* output_file_base = 0;
    bool expect_output_base      = false;
    for( int i = 1; i < argc; ++i )
        if( expect_output_base )
            output_file_base   = argv[i];
        else if( !strcmp( argv[i], "-o" ) )
            expect_output_base = true;
        else if( DEFAULT_INPUT_FILE.compare( input_file ) )
            usage( argv[0] );
        else
            input_file = argv[i];
    if( expect_output_base ) usage( argv[0] );
    MsqPrintError err( std::cerr );
    SlaveBoundaryVertices slaver( 1 );
    TShapeNB1 tmetric;
    IdealShapeTarget target;
    TQualityMetric metric( &target, &tmetric );
    PMeanPTemplate of( 1.0, &metric );
    SteepestDescent improver( &of );
    TerminationCriterion inner;
    inner.add_absolute_vertex_movement( 1e-3 );
    improver.set_inner_termination_criterion( &inner );
    QualityAssessor assess( &metric );
    InstructionQueue q;
    q.set_master_quality_improver( &improver, err );
    q.add_quality_assessor( &assess, err );
    TriLagrangeShape trishape;
    QuadLagrangeShape quadshape;
    q.set_mapping_function( &trishape );
    q.set_mapping_function( &quadshape );
    const int NUM_MODES = 4;
    Settings::HigherOrderSlaveMode modes[NUM_MODES] = { Settings::SLAVE_NONE, Settings::SLAVE_ALL,
                                                        Settings::SLAVE_CALCULATED, Settings::SLAVE_FLAG };
    std::string names[NUM_MODES] = { "NONE", "ALL", "CALCULATED", "FLAG" };
    MeshImpl meshes[NUM_MODES];
    std::vector< MeshDomainAssoc > meshes_and_domains;
    bool have_slaved_flag = true;
    std::vector< bool > flag( 1 );
    for( int i = 0; i < NUM_MODES; ++i )
        std::cout << std::endl
                  << "-----------------------------------------------" << std::endl
                  << "     Mode: " << names[i] << std::endl
                  << "-----------------------------------------------" << std::endl;
        meshes[i].read_vtk( input_file, err );
        if( err ) return 1;
        if( modes[i] == Settings::SLAVE_CALCULATED )
            q.add_vertex_slaver( &slaver, err );
        else if( modes[i] == Settings::SLAVE_FLAG )
            meshes[i].get_all_vertices( verts, err );
            if( err ) return 1;
            meshes[i].vertices_get_slaved_flag( arrptr( verts ), flag, 1, err );
            if( err )
                have_slaved_flag = false;
                std::cout << "Skipped because input file does not contain slaved attribute" << std::endl;
                err.clear();
                continue;
        if( have_slaved_flag && modes[i] == Settings::SLAVE_FLAG )
            if( !check_no_slaved_corners( meshes[i], err ) || err ) return 1;
            if( !check_global_patch_slaved( meshes[i], err ) || err ) return 1;
        PlanarDomain plane;
        plane.fit_vertices( &meshes[i], err );
        if( err ) return 1;
        q.set_slaved_ho_node_mode( modes[i] );
        meshes_and_domains.push_back( MeshDomainAssoc( &meshes[i], &plane ) );
        q.run_instructions( &meshes_and_domains[i], err );
        if( err ) return 1;
            q.remove_vertex_slaver( &slaver, err );
        if( output_file_base )
            tag_patch_slaved( meshes[i], modes[i], err );
            std::string name( output_file_base );
            name += "-";
            name += names[i];
            name += ".vtk";
            meshes[i].write_vtk( name.c_str(), err );
            if( err ) return 1;
    int exit_code = 0;
    if( !DEFAULT_INPUT_FILE.compare( input_file ) )
            exit_code += check_slaved_coords( meshes[i], modes[i], names[i], have_slaved_flag, err );
            if( err ) return 1;
        // flags should correspond to same slaved nodes as calculated,
        // so resulting meshes should be identical.
        if( have_slaved_flag )
            int flag_idx = std::find( modes, modes + NUM_MODES, Settings::SLAVE_FLAG ) - modes;
            int calc_idx = std::find( modes, modes + NUM_MODES, Settings::SLAVE_CALCULATED ) - modes;
            exit_code += compare_node_coords( meshes[flag_idx], meshes[calc_idx], err );
            if( err ) return 1;
    return exit_code;
void usage ( const char *  argv0)
Definition at line 58 of file test/mesquite/slaved/main.cpp.
    std::cout << "Usage: " << argv0 << " [<input_file>] [-o <output_file_base>]" << std::endl;
    exit( 1 );
Variable Documentation
Definition at line 56 of file test/mesquite/slaved/main.cpp.
