test_boundbox.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/BoundBox.hpp"
#include "moab/ScdInterface.hpp"
#include <iostream>
+ Include dependency graph for test_boundbox.cpp:
Functions
void test_bound_box ()
 test add_entities, get_entities, num_entities
int main ()
Function Documentation
int main ( )
Definition at line 13 of file test_boundbox.cpp.
References RUN_TEST, and test_bound_box().
    int err = 0;
    err += RUN_TEST( test_bound_box );
    if( !err )
        printf( "ALL TESTS PASSED\n" );
    else
        printf( "%d TESTS FAILED\n", err );
    return err;
void test_bound_box ( )
Definition at line 27 of file test_boundbox.cpp.
References moab::CartVect::array(), box(), center(), CHECK, CHECK_ERR, CHECK_REAL_EQUAL, moab::BoundBox::compute_center(), moab::ScdInterface::construct_box(), moab::BoundBox::contains_point(), moab::BoundBox::diagonal_length(), moab::BoundBox::diagonal_squared(), moab::BoundBox::distance(), moab::BoundBox::distance_squared(), ErrorCode, moab::Core::get_coords(), moab::BoundBox::intersects_box(), length(), mb, moab::ScdBox::num_elements(), moab::Interface::query_interface(), moab::ScdBox::start_element(), moab::ScdBox::start_vertex(), moab::BoundBox::update(), moab::BoundBox::update_max(), and moab::BoundBox::update_min().
Referenced by main().
    BoundBox box;
    CartVect vec( 0.0 );
    double tol = 0.0;
    std::vector< double > vals( 6, 0.0 );
    BoundBox other_box( &vals[0] );
    // test for contains point failure
    bool result = box.contains_point( vec.array(), tol );
    CHECK( !result );
    result = box.intersects_box( other_box, tol );
    CHECK( !result );
    box = other_box;
    tol = 1.0e-10;
    // test for success
    result = box.contains_point( &vals[0], tol );
    CHECK( result );
    CHECK( result );
    // check update functions
    CartVect three( 3.0 );
    box.update_max( three.array() );
    result = box.contains_point( three.array(), tol );
    CHECK( result );
    result = box.contains_point( ( three * 1.1 ).array(), tol );
    CHECK( !result );
    result = box.intersects_box( BoundBox( three, three ), tol );
    CHECK( result );
    result = box.intersects_box( BoundBox( 1.1 * three, 3.0 * three ), tol );
    CHECK( !result );
    CartVect negthree( -3.0 );
    box.update_min( negthree.array() );
    result = box.contains_point( negthree.array(), tol );
    CHECK( result );
    result = box.contains_point( ( negthree * 1.1 ).array(), tol );
    CHECK( !result );
    result = box.intersects_box( BoundBox( negthree, negthree ), tol );
    CHECK( result );
    result = box.intersects_box( BoundBox( 3.0 * negthree, 1.1 * negthree ), tol );
    CHECK( !result );
    for( int i = 0; i < 3; i++ )
        vals[i]     = -4.0;
        vals[3 + i] = 4.0;
    box.update( &vals[0] );
    CHECK( result );
    result = box.contains_point( ( CartVect( &vals[0] ) * 1.1 ).array(), tol );
    CHECK( !result );
    result = box.intersects_box( BoundBox( &vals[0] ), tol );
    CHECK( result );
    result = box.intersects_box( BoundBox( 1.2 * CartVect( &vals[0] ), 1.1 * CartVect( &vals[0] ) ), tol );
    CHECK( !result );
    // check length functions
    tol = 1.0e-6;
    // box should be 8 on a side, or 3*(2^3)^2 or 192 for diag length squared
    double diagsq = box.diagonal_squared();
    CHECK_REAL_EQUAL( diagsq, 192.0, tol );
    double diag = box.diagonal_length();
    CHECK_REAL_EQUAL( diag, sqrt( 3.0 ) * 8.0, tol );
    // check distance function
    // face-centered
    vals[0] = vals[1] = 0.0;
    vals[2]           = 6.0;
    double dist       = box.distance_squared( CartVect( &vals[0] ).array() );
    CHECK_REAL_EQUAL( dist, 4.0, tol );
    dist = box.distance( CartVect( &vals[0] ).array() );
    CHECK_REAL_EQUAL( dist, 2.0, tol );
    // edge-centered
    vals[0] = 0.0;
    vals[1] = vals[2] = 6.0;
    CHECK_REAL_EQUAL( dist, 8.0, tol );
    CHECK_REAL_EQUAL( dist, sqrt( 8.0 ), tol );
    // vertex-centered
    vals[0] = vals[1] = vals[2] = 6.0;
    CHECK_REAL_EQUAL( dist, 12.0, tol );
    CHECK_REAL_EQUAL( dist, sqrt( 12.0 ), tol );
    // check entity-based functions
    Core mb;
    ScdInterface* scdi;
    ErrorCode rval = mb.query_interface( scdi );CHECK_ERR( rval );
    ScdBox* scd_box;
    // create a 10x10x10 box
    rval = scdi->construct_box( HomCoord( 0, 0, 0 ), HomCoord( 10, 10, 10 ), NULL, 0, scd_box );CHECK_ERR( rval );
    EntityHandle vert = scd_box->start_vertex(), elem = scd_box->start_element();
    rval = box.update( mb, vert );CHECK_ERR( rval );
    rval = mb.get_coords( &vert, 1, &vals[0] );CHECK_ERR( rval );
    tol    = 1.0e-10;
    CHECK( result );
    rval = box.update( mb, elem );CHECK_ERR( rval );
    rval = mb.get_coords( &elem, 1, &vals[0] );CHECK_ERR( rval );
    CHECK( result );
    Range all_elems( elem, elem + scd_box->num_elements() - 1 );
    rval = box.update( mb, all_elems );CHECK_ERR( rval );
    CartVect center;
    box.compute_center( center );
    tol = 1.0e-6;
    CHECK_REAL_EQUAL( ( center - CartVect( 5.0, 5.0, 5.0 ) ).length(), 0.0, tol );
