tree_searching_perf.cpp File Reference
#include "moab/Core.hpp"
#include "moab/SpatialLocator.hpp"
#include "moab/Tree.hpp"
#include "moab/HomXform.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/CartVect.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/BVHTree.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/CpuTimer.hpp"
#include <cstdlib>
#include <sstream>
+ Include dependency graph for tree_searching_perf.cpp:
Functions
ErrorCode test_locator (SpatialLocator &sl, int npoints, double &cpu_time, double &percent_outside)
ErrorCode create_hex_mesh (Interface &mb, Range &elems, int n, int dim)
int main (int argc, char **argv)
Function Documentation
ErrorCode create_hex_mesh ( Interface mb,
Range elems,
int  n,
int  dim
int main ( int  argc,
char **  argv
Definition at line 24 of file tree_searching_perf.cpp.
References ProgOptions::addOpt(), create_hex_mesh(), dim, ErrorCode, moab::fail(), ints, mb, MB_SUCCESS, npoints, moab::TreeStats::output_all_stats(), moab::Tree::parse_options(), ProgOptions::parseCommandLine(), test_locator(), tree, and moab::Tree::tree_stats().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#else
    // silence the warning of parameters not used, in serial; there should be a smarter way :(
    argv[0] = argv[argc - argc];
#endif
    int npoints = 100, dim = 3;
    int dints = 1, dleafs = 1, ddeps = 1, csints = 0;
    ProgOptions po;
    po.addOpt< int >( "candidateplaneset,c",
                      "Candidate plane set (0=SUBDIVISION,1=SUBDIV_SNAP,2=VERTEX_MEDIAN,3=VERTEX_SAMPLE", &csints );
    po.addOpt< int >( "ints,i", "Number of doublings of intervals on each side of scd mesh", &dints );
    po.addOpt< int >( "leaf,l", "Number of doublings of maximum number of elements per leaf", &dleafs );
    po.addOpt< int >( "max_depth,m", "Number of 5-intervals on maximum depth of tree", &ddeps );
    po.addOpt< int >( "npoints,n", "Number of query points", &npoints );
    po.addOpt< int >( "dim,d", "Dimension of the mesh", &dim );
    //  po.addOpt<void>( "print,p", "Print tree details", &print_tree);
    po.parseCommandLine( argc, argv );
    std::vector< int > ints, deps, leafs;
    ints.push_back( 10 );
    for( int i = 1; i < dints; i++ )
        ints.push_back( 2 * ints[i - 1] );
    deps.push_back( 30 );
    for( int i = 1; i < ddeps; i++ )
        deps.push_back( deps[i - 1] - 5 );
    leafs.push_back( 6 );
    for( int i = 1; i < dleafs; i++ )
        leafs.push_back( 2 * leafs[i - 1] );
    ErrorCode rval = MB_SUCCESS;
    std::cout << "Tree_type"
              << "Elems_per_leaf"
              << "Tree_depth"
              << "Ints_per_side"
              << "N_elements"
              << "search_time"
              << "perc_outside"
              << "initTime"
              << "nodesVisited"
              << "leavesVisited"
              << "numTraversals"
              << "leafObjectTests" << std::endl;
    // outermost iteration: # elements
    for( std::vector< int >::iterator int_it = ints.begin(); int_it != ints.end(); ++int_it )
        Core mb;
        Range elems;
        rval = create_hex_mesh( mb, elems, *int_it, dim );
        if( MB_SUCCESS != rval ) return rval;
        // iteration: tree depth
        for( std::vector< int >::iterator dep_it = deps.begin(); dep_it != deps.end(); ++dep_it )
            // iteration: tree max elems/leaf
            for( std::vector< int >::iterator leafs_it = leafs.begin(); leafs_it != leafs.end(); ++leafs_it )
                // iteration: tree type
                for( int tree_tp = 0; tree_tp < 2; tree_tp++ )
                    // create tree
                    Tree* tree;
                    if( 0 == tree_tp )
                        tree = new BVHTree( &mb );
                    else
                        tree = new AdaptiveKDTree( &mb );
                    std::ostringstream opts;
                    opts << "MAX_DEPTH=" << *dep_it << ";MAX_PER_LEAF=" << *leafs_it;
                    if( csints )
                        if( opts.str().length() > 0 ) opts << ";";
                        opts << "PLANE_SET=" << csints;
                    FileOptions fo( opts.str().c_str() );
                    rval = tree->parse_options( fo );
                    SpatialLocator sl( &mb, elems, tree );
                    // call evaluation
                    double cpu_time, perc_outside;
                    rval = test_locator( sl, npoints, cpu_time, perc_outside );
                    std::cout << ( tree_tp == 0 ? "BVH" : "KD" ) << " " << *leafs_it << " " << *dep_it << " " << *int_it
                              << " " << ( *int_it ) * ( *int_it ) * ( *int_it ) << " " << cpu_time << " "
                              << perc_outside << " ";
                    tree->tree_stats().output_all_stats();
                }  // tree_tp
            }  // max elems/leaf
        }  // max depth
    }  // # elements
    fail = MPI_Finalize();
#endif
    return 0;
ErrorCode test_locator ( SpatialLocator sl,
int  npoints,
double &  cpu_time,
double &  percent_outside
Definition at line 149 of file tree_searching_perf.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, box(), ErrorCode, moab::SpatialLocator::local_box(), moab::SpatialLocator::locate_points(), MB_SUCCESS, npoints, and moab::CpuTimer::time_elapsed().
    BoundBox box     = sl.local_box();
    CartVect box_del = box.bMax - box.bMin;
    std::vector< CartVect > test_pts( npoints ), test_res( npoints );
    std::vector< EntityHandle > ents( npoints );
    int* is_in = new int[npoints];
    double denom = 1.0 / (double)RAND_MAX;
    for( int i = 0; i < npoints; i++ )
        // generate a small number of random point to test
        double rx = (double)rand() * denom, ry = (double)rand() * denom, rz = (double)rand() * denom;
        test_pts[i] = box.bMin + CartVect( rx * box_del[0], ry * box_del[1], rz * box_del[2] );
    CpuTimer ct;
    // call spatial locator to locate points
    ErrorCode rval = sl.locate_points( test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0] );
        delete[] is_in;
        return rval;
    cpu_time = ct.time_elapsed();
    int num_out     = std::count( is_in, is_in + npoints, false );
    percent_outside = ( (double)num_out ) / npoints;
    delete[] is_in;
    return rval;
