tstt_perf.cpp File Reference
#include <sys/resource.h>
#include <cstdlib>
#include <cstdio>
#include <iostream>
#include "TSTT_MOAB.hh"
#include "TSTT.hh"
#include "TSTTM.hh"
+ Include dependency graph for tstt_perf.cpp:
Defines
#define IMPLEMENTATION_CLASS   TSTT_MOAB::MoabMesh
#define CAST_INTERFACE(var_in, var_out, iface)
#define CAST_MINTERFACE(var_in, var_out, iface)
#define ARRAY_PTR(array, type)   ( reinterpret_cast< ( type )* >( ( array )._get_ior()->d_firstElement ) )
#define HANDLE_ARRAY_PTR(array)   ( reinterpret_cast< Entity_Handle* >( ( array )._get_ior()->d_firstElement ) )
#define ARRAY_SIZE(array)   ( ( array )._is_nil() ? 0 : ( array ).upper( 0 ) - ( array ).lower( 0 ) + 1 )
#define CHECK_SIZE(array, size)
#define VINDEX(i, j, k)   ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
Typedefs
typedef void * Entity_Handle
Functions
void query_vert_to_elem (TSTTM::Mesh &mesh)
void query_elem_to_vert (TSTTM::Mesh &mesh)
void print_time (const bool print_em, double &tot_time, double &utime, double &stime)
void build_connect (const int nelem, const int vstart, int *&connect)
void testB (TSTTM::Mesh &mesh, const int nelem, sidl::array< double > &coords, const int *connect)
void testC (TSTTM::Mesh &mesh, const int nelem, sidl::array< double > &coords)
void compute_edge (double *start, const int nelem, const double xint, const int stride)
void compute_face (double *a, const int nelem, const double xint, const int stride1, const int stride2)
void build_coords (const int nelem, sidl::array< double > &coords)
int main (int argc, char *argv[])
Variables
double LENGTH = 1.0
Define Documentation
#define ARRAY_PTR (   array,
  type
Definition at line 82 of file tstt_perf.cpp.
Referenced by build_coords(), query_elem_to_vert(), and testC().
#define ARRAY_SIZE (   array)    ( ( array )._is_nil() ? 0 : ( array ).upper( 0 ) - ( array ).lower( 0 ) + 1 )
Definition at line 84 of file tstt_perf.cpp.
Referenced by query_elem_to_vert().
#define CAST_INTERFACE (   var_in,
  var_out,
  iface
Value:
TSTT::iface var_out;                                                   \
    try        \
        ( var_out ) = var_in;                                              \
    catch( TSTT::Error )                                                   \
        cerr << "Error: current interface doesn't support iface." << endl; \
        return;                                                            \
Definition at line 49 of file tstt_perf.cpp.
#define CAST_MINTERFACE (   var_in,
  var_out,
  iface
Value:
TSTTM::iface var_out;                                                  \
    try        \
        return;                                                            \
Definition at line 61 of file tstt_perf.cpp.
Referenced by query_elem_to_vert(), query_vert_to_elem(), testB(), and testC().
#define CHECK_SIZE (   array,
  size
Value:
if( ( array )._is_nil() || ARRAY_SIZE( array ) == 0 )             \
        ( array ) = ( array ).create1d( size );                       \
    else if( ARRAY_SIZE( array ) < ( size ) )                         \
        cerr << "Array passed in is non-zero but too short." << endl; \
        assert( false );                                              \
Definition at line 85 of file tstt_perf.cpp.
Referenced by build_coords(), testB(), and testC().
#define HANDLE_ARRAY_PTR (   array)    ( reinterpret_cast< Entity_Handle* >( ( array )._get_ior()->d_firstElement ) )
Definition at line 83 of file tstt_perf.cpp.
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. TSTT Mesh Interface brick mesh performance test
This program tests TSTT mesh interface functions used to create a square structured mesh. Boilerplate taken from tstt mesh interface test in MOAB and performance test in MOAB
Definition at line 46 of file tstt_perf.cpp.
#define VINDEX (   i,
  j,
#define VINDEX (   i,
  j,
Typedef Documentation
typedef void* Entity_Handle
Definition at line 78 of file tstt_perf.cpp.
Function Documentation
void build_connect ( const int  nelem,
const int  vstart,
int *&  connect
Definition at line 679 of file tstt_perf.cpp.
References VINDEX.
    // allocate the memory
    int nume_tot = nelem * nelem * nelem;
    connect      = new int[8 * nume_tot];
    int vijk;
    int numv    = nelem + 1;
    int numv_sq = numv * numv;
    int idx     = 0;
    for( int i = 0; i < nelem; i++ )
        for( int j = 0; j < nelem; j++ )
            for( int k = 0; k < nelem; k++ )
                vijk           = vstart + VINDEX( i, j, k );
                connect[idx++] = vijk;
                connect[idx++] = vijk + 1;
                connect[idx++] = vijk + 1 + numv;
                connect[idx++] = vijk + numv;
                connect[idx++] = vijk + numv * numv;
                connect[idx++] = vijk + 1 + numv * numv;
                connect[idx++] = vijk + 1 + numv + numv * numv;
                connect[idx++] = vijk + numv + numv * numv;
                assert( i <= numv * numv * numv );
void build_coords ( const int  nelem,
sidl::array< double > &  coords
Definition at line 517 of file tstt_perf.cpp.
References ARRAY_PTR, CHECK_SIZE, compute_edge(), compute_face(), LENGTH, print_time(), and VINDEX.
    double ttime0, ttime1, utime1, stime1;
    print_time( false, ttime0, utime1, stime1 );
    int tot_numv = numv * numv * numv;
    CHECK_SIZE( coords, 3 * tot_numv );
    double* coords_ptr = ARRAY_PTR( coords, double );
// use FORTRAN-like indexing
#define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
    int idx;
    double scale1, scale2, scale3;
    // use these to prevent optimization on 1-scale, etc (real map wouldn't have
    // all these equal)
    scale1 = LENGTH / nelem;
    scale2 = LENGTH / nelem;
    scale3 = LENGTH / nelem;
#ifdef REALTFI
    // use a real TFI xform to compute coordinates
    // initialize positions of 8 corners
    coords_ptr[VINDEX( 0, 0, 0 )]                         = coords_ptr[VINDEX( 0, 0, 0 ) + nelem + 1] =
        coords_ptr[VINDEX( 0, 0, 0 ) + 2 * ( nelem + 1 )] = 0.0;
    coords_ptr[VINDEX( 0, nelem, 0 )] = coords_ptr[VINDEX( 0, nelem, 0 ) + 2 * ( nelem + 1 )] = 0.0;
    coords_ptr[VINDEX( 0, nelem, 0 ) + nelem + 1]                                             = LENGTH;
    coords_ptr[VINDEX( 0, 0, nelem )] = coords_ptr[VINDEX( 0, 0, nelem ) + nelem + 1] = 0.0;
    coords_ptr[VINDEX( 0, 0, nelem ) + 2 * ( nelem + 1 )]                             = LENGTH;
    coords_ptr[VINDEX( 0, nelem, nelem )]                                             = 0.0;
    coords_ptr[VINDEX( 0, nelem, nelem ) + nelem + 1] = coords_ptr[VINDEX( 0, nelem, nelem ) + 2 * ( nelem + 1 )] =
        LENGTH;
    coords_ptr[VINDEX( nelem, 0, 0 )]             = LENGTH;
    coords_ptr[VINDEX( nelem, 0, 0 ) + nelem + 1] = coords_ptr[VINDEX( nelem, 0, 0 ) + 2 * ( nelem + 1 )] = 0.0;
    coords_ptr[VINDEX( nelem, 0, nelem )] = coords_ptr[VINDEX( nelem, 0, nelem ) + 2 * ( nelem + 1 )] = LENGTH;
    coords_ptr[VINDEX( nelem, 0, nelem ) + nelem + 1]                                                 = 0.0;
    coords_ptr[VINDEX( nelem, nelem, 0 )] = coords_ptr[VINDEX( nelem, nelem, 0 ) + nelem + 1] = LENGTH;
    coords_ptr[VINDEX( nelem, nelem, 0 ) + 2 * ( nelem + 1 )]                                 = 0.0;
    coords_ptr[VINDEX( nelem, nelem, nelem )] = coords_ptr[VINDEX( nelem, nelem, nelem ) + nelem + 1] =
        coords_ptr[VINDEX( nelem, nelem, nelem ) + 2 * ( nelem + 1 )] = LENGTH;
    // compute edges
    // i (stride=1)
    compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1 );
    compute_edge( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, 1 );
    compute_edge( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, 1 );
    compute_edge( &coords_ptr[VINDEX( 0, nelem, nelem )], nelem, scale1, 1 );
    // j (stride=numv)
    compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv );
    compute_edge( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv );
    compute_edge( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, numv );
    compute_edge( &coords_ptr[VINDEX( nelem, 0, nelem )], nelem, scale1, numv );
    // k (stride=numv^2)
    compute_edge( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv_sq );
    compute_edge( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv_sq );
    compute_edge( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, numv_sq );
    compute_edge( &coords_ptr[VINDEX( nelem, nelem, 0 )], nelem, scale1, numv_sq );
    // compute faces
    // i=0, nelem
    compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, numv, numv_sq );
    compute_face( &coords_ptr[VINDEX( nelem, 0, 0 )], nelem, scale1, numv, numv_sq );
    // j=0, nelem
    compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv_sq );
    compute_face( &coords_ptr[VINDEX( 0, nelem, 0 )], nelem, scale1, 1, numv_sq );
    // k=0, nelem
    compute_face( &coords_ptr[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv );
    compute_face( &coords_ptr[VINDEX( 0, 0, nelem )], nelem, scale1, 1, numv );
    // initialize corner indices
    int i000 = VINDEX( 0, 0, 0 );
    int ia00 = VINDEX( nelem, 0, 0 );
    int i0t0 = VINDEX( 0, nelem, 0 );
    int iat0 = VINDEX( nelem, nelem, 0 );
    int i00g = VINDEX( 0, 0, nelem );
    int ia0g = VINDEX( nelem, 0, nelem );
    int i0tg = VINDEX( 0, nelem, nelem );
    int iatg = VINDEX( nelem, nelem, nelem );
    double cX, cY, cZ;
    int adaInts   = nelem;
    int tseInts   = nelem;
    int gammaInts = nelem;
    for( int i = 1; i < nelem; i++ )
        for( int j = 1; j < nelem; j++ )
            for( int k = 1; k < nelem; k++ )
                // idx = VINDEX(i,j,k);
                double tse   = i * scale1;
                double ada   = j * scale2;
                double gamma = k * scale3;
                double tm1   = 1.0 - tse;
                double am1   = 1.0 - ada;
                double gm1   = 1.0 - gamma;
                cX = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) +
                             ada * ( tm1 * coords_ptr[ia00] + tse * coords_ptr[iat0] ) ) +
                     gamma * ( am1 * ( tm1 * coords_ptr[i00g] + tse * coords_ptr[i0tg] ) +
                               ada * ( tm1 * coords_ptr[ia0g] + tse * coords_ptr[iatg] ) );
                cY = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) +
                cZ = gm1 * ( am1 * ( tm1 * coords_ptr[i000] + tse * coords_ptr[i0t0] ) +
                double* ai0k = &coords_ptr[VINDEX( k, 0, i )];
                double* aiak = &coords_ptr[VINDEX( k, adaInts, i )];
                double* a0jk = &coords_ptr[VINDEX( k, j, 0 )];
                double* atjk = &coords_ptr[VINDEX( k, j, tseInts )];
                double* aij0 = &coords_ptr[VINDEX( 0, j, i )];
                double* aijg = &coords_ptr[VINDEX( gammaInts, j, i )];
                coords_ptr[VINDEX( i, j, k )] = ( am1 * ai0k[0] + ada * aiak[0] + tm1 * a0jk[0] + tse * atjk[0] +
                                                  gm1 * aij0[0] + gamma * aijg[0] ) /
                                                    2.0 -
                                                cX / 2.0;
                coords_ptr[nelem + 1 + VINDEX( i, j, k )] =
                    ( am1 * ai0k[nelem + 1] + ada * aiak[nelem + 1] + tm1 * a0jk[nelem + 1] + tse * atjk[nelem + 1] +
                      gm1 * aij0[nelem + 1] + gamma * aijg[nelem + 1] ) /
                        2.0 -
                    cY / 2.0;
                coords_ptr[2 * ( nelem + 1 ) + VINDEX( i, j, k )] =
                    ( am1 * ai0k[2 * ( nelem + 1 )] + ada * aiak[2 * ( nelem + 1 )] + tm1 * a0jk[2 * ( nelem + 1 )] +
                      tse * atjk[2 * ( nelem + 1 )] + gm1 * aij0[2 * ( nelem + 1 )] +
                      gamma * aijg[2 * ( nelem + 1 )] ) /
                        2.0 -
                    cZ / 2.0;
#else
    for( int i = 0; i < numv; i++ )
        for( int j = 0; j < numv; j++ )
            for( int k = 0; k < numv; k++ )
                idx = VINDEX( i, j, k );
                // blocked coordinate ordering
                coords_ptr[idx]                = i * scale1;
                coords_ptr[tot_numv + idx]     = j * scale2;
                coords_ptr[2 * tot_numv + idx] = k * scale3;
#endif
    print_time( false, ttime1, utime1, stime1 );
    std::cout << "TSTT/MOAB: TFI time = " << ttime1 - ttime0 << " sec" << std::endl;
void compute_edge ( double *  start,
const int  nelem,
const double  xint,
const int  stride
void compute_face ( double *  a,
const int  nelem,
const double  xint,
const int  stride1,
const int  stride2
int main ( int  argc,
char *  argv[]
Definition at line 108 of file tstt_perf.cpp.
References build_connect(), build_coords(), mesh, testB(), and testC().
    int nelem = 20;
    if( argc < 3 )
        std::cout << "Usage: " << argv[0] << " <ints_per_side> <A|B|C>" << std::endl;
        return 1;
    char which_test = '\0';
    sscanf( argv[1], "%d", &nelem );
    sscanf( argv[2], "%c", &which_test );
    if( which_test != 'B' && which_test != 'C' )
        std::cout << "Must indicate B or C for test." << std::endl;
        return 1;
    std::cout << "number of elements: " << nelem << "; test " << which_test << std::endl;
    // pre-build the coords array
    sidl::array< double > coords;
    build_coords( nelem, coords );
    assert( NULL != coords );
    int* connect = NULL;
    build_connect( nelem, 1, connect );
    // create an implementation
    TSTTM::Mesh mesh = IMPLEMENTATION_CLASS::_create();
    switch( which_test )
        case 'B':
            // test B: create mesh using bulk interface
            testB( mesh, nelem, coords, connect );
            break;
        case 'C':
            // test C: create mesh using individual interface
            testC( mesh, nelem, coords );
            break;
    return 0;
void print_time ( const bool  print_em,
double &  tot_time,
double &  utime,
double &  stime
void query_elem_to_vert ( TSTTM::Mesh &  mesh)
Definition at line 342 of file tstt_perf.cpp.
References ARRAY_PTR, ARRAY_SIZE, CAST_MINTERFACE, and HANDLE_ARRAY_PTR.
    sidl::array< Entity_Handle > all_hexes;
    int all_hexes_size;
    CAST_MINTERFACE( mesh, mesh_ent, Entity );
    // get all the hex elements
    try
        mesh.getEntities( 0, TSTTM::EntityType_REGION, TSTTM::EntityTopology_HEXAHEDRON, all_hexes, all_hexes_size );
    catch( TSTT::Error& /* err */ )
        cerr << "Couldn't get all hex elements in query_mesh" << endl;
        return;
    try
        // set up some tmp arrays and array ptrs
        Entity_Handle* all_hexes_ptr = HANDLE_ARRAY_PTR( all_hexes );
        // now loop over elements
        for( int i = 0; i < all_hexes_size; i++ )
            sidl::array< int > dum_offsets;
            sidl::array< Entity_Handle > dum_connect;
            int dum_connect_size = 0;
            // get the connectivity of this element; will allocate space on 1st iteration,
            // but will have correct size on subsequent ones
            mesh_ent.getEntAdj( all_hexes_ptr[i], TSTTM::EntityType_VERTEX, dum_connect, dum_connect_size );
            // get vertex coordinates; ; will allocate space on 1st iteration,
            sidl::array< double > dum_coords;
            int dum_coords_size       = 0;
            TSTTM::StorageOrder order = TSTTM::StorageOrder_UNDETERMINED;
            mesh.getVtxArrCoords( dum_connect, dum_connect_size, order, dum_coords, dum_coords_size );
            assert( 24 == dum_coords_size && ARRAY_SIZE( dum_coords ) == 24 );
            double* dum_coords_ptr = ARRAY_PTR( dum_coords, double );
            double centroid[3]     = { 0.0, 0.0, 0.0 };
            if( order == TSTTM::StorageOrder_BLOCKED )
                for( int j = 0; j < 8; j++ )
                    centroid[0] += dum_coords_ptr[j];
                    centroid[1] += dum_coords_ptr[8 + j];
                    centroid[2] += dum_coords_ptr[16 + j];
                    centroid[0] += dum_coords.get( j );
                    centroid[1] += dum_coords.get( 8 + j );
                    centroid[2] += dum_coords.get( 16 + j );
            else
                    centroid[0] += dum_coords_ptr[3 * j];
                    centroid[1] += dum_coords_ptr[3 * j + 1];
                    centroid[2] += dum_coords_ptr[3 * j + 2];
        cerr << "Problem getting connectivity or vertex coords." << endl;
        return;
void query_vert_to_elem ( TSTTM::Mesh &  mesh)
Definition at line 414 of file tstt_perf.cpp.
References CAST_MINTERFACE, and HANDLE_ARRAY_PTR.
    sidl::array< Entity_Handle > all_verts;
    int all_verts_size;
    // get all the vertices elements
    try
        mesh.getEntities( 0, TSTTM::EntityType_VERTEX, TSTTM::EntityTopology_POINT, all_verts, all_verts_size );
        cerr << "Couldn't get all vertices in query_vert_to_elem" << endl;
        return;
    try
        Entity_Handle* all_verts_ptr = HANDLE_ARRAY_PTR( all_verts );
        // now loop over vertices
        for( int i = 0; i < all_verts_size; i++ )
            sidl::array< Entity_Handle > dum_hexes;
            int dum_hexes_size;
            // get the connectivity of this element; will have to allocate space on every
            // iteration, since size can vary
            mesh_ent.getEntAdj( all_verts_ptr[i], TSTTM::EntityType_REGION, dum_hexes, dum_hexes_size );
        return;
void testB ( TSTTM::Mesh &  mesh,
const int  nelem,
sidl::array< double > &  coords,
const int *  connect
Definition at line 157 of file tstt_perf.cpp.
References CAST_MINTERFACE, CHECK_SIZE, HANDLE_ARRAY_PTR, print_time(), query_elem_to_vert(), and query_vert_to_elem().
    double utime, stime, ttime0, ttime1, ttime2, ttime3;
    print_time( false, ttime0, utime, stime );
    int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 );
    int num_elems = nelem * nelem * nelem;
    // create vertices as a block
    CAST_MINTERFACE( mesh, mesh_arrmod, ArrMod );
    sidl::array< Entity_Handle > sidl_vertices, dum_handles;
    CHECK_SIZE( dum_handles, num_verts );
    int sidl_vertices_size;
    try
        mesh_arrmod.createVtxArr( num_verts, TSTTM::StorageOrder_BLOCKED, coords, 3 * num_verts, sidl_vertices,
                                  sidl_vertices_size );
        cerr << "Couldn't create vertices in bulk call" << endl;
        return;
    // need to explicitly fill connectivity array, since we don't know
    // the format of entity handles
    sidl::array< Entity_Handle > sidl_connect;
    int sidl_connect_size = 8 * num_elems;
    CHECK_SIZE( sidl_connect, 8 * num_elems );
    Entity_Handle* sidl_connect_ptr = HANDLE_ARRAY_PTR( sidl_connect );
    Entity_Handle* sidl_vertices_ptr = HANDLE_ARRAY_PTR( sidl_vertices );
    for( int i = 0; i < sidl_connect_size; i++ )
        // use connect[i]-1 because we used starting vertex index (vstart) of 1
        assert( connect[i] - 1 < num_verts );
        sidl_connect_ptr[i] = sidl_vertices_ptr[connect[i] - 1];
    // create the entities
    sidl::array< Entity_Handle > new_hexes;
    int new_hexes_size;
    sidl::array< TSTTM::CreationStatus > status;
    int status_size;
    try
        mesh_arrmod.createEntArr( TSTTM::EntityTopology_HEXAHEDRON, sidl_connect, sidl_connect_size, new_hexes,
                                  new_hexes_size, status, status_size );
        cerr << "Couldn't create hex elements in bulk call" << endl;
        return;
    print_time( false, ttime1, utime, stime );
    // query the mesh 2 ways
    query_elem_to_vert( mesh );
    print_time( false, ttime2, utime, stime );
    query_vert_to_elem( mesh );
    print_time( false, ttime3, utime, stime );
    std::cout << "TSTT/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = " << nelem << ", "
              << ttime1 - ttime0 << ", " << ttime2 - ttime1 << ", " << ttime3 - ttime2 << " seconds" << std::endl;
void testC ( TSTTM::Mesh &  mesh,
const int  nelem,
Definition at line 229 of file tstt_perf.cpp.
References ARRAY_PTR, CAST_MINTERFACE, CHECK_SIZE, HANDLE_ARRAY_PTR, print_time(), query_elem_to_vert(), query_vert_to_elem(), and VINDEX.
    // need some dimensions
    int num_verts = numv * numv * numv;
    // array to hold vertices created individually
    sidl::array< Entity_Handle > sidl_vertices;
    // int sidl_vertices_size = num_verts;
    CHECK_SIZE( sidl_vertices, num_verts );
    // temporary array to hold vertex positions for single vertex
    sidl::array< double > tmp_coords;
    int tmp_coords_size = 3;
    CHECK_SIZE( tmp_coords, 3 );
    double* dum_coords = ARRAY_PTR( tmp_coords, double );
    // get direct pointer to coordinate array
    for( int i = 0; i < num_verts; i++ )
        // temporary array to hold (single) vertices
        sidl::array< Entity_Handle > tmp_vertices;
        int tmp_vertices_size = 0;
        // create the vertex
        dum_coords[0] = coords_ptr[i];
        dum_coords[1] = coords_ptr[num_verts + i];
        dum_coords[2] = coords_ptr[2 * num_verts + i];
        try
            mesh_arrmod.createVtxArr( 1, TSTTM::StorageOrder_BLOCKED, tmp_coords, tmp_coords_size, tmp_vertices,
                                      tmp_vertices_size );
            cerr << "Couldn't create vertex in individual call" << endl;
            return;
        // assign into permanent vertex array
        sidl_vertices.set( i, tmp_vertices.get( 0 ) );
    // get vertex array pointer for reading into tmp_conn
    Entity_Handle* tmp_sidl_vertices = HANDLE_ARRAY_PTR( sidl_vertices );
                sidl::array< Entity_Handle > tmp_conn;
                int tmp_conn_size = 8;
                CHECK_SIZE( tmp_conn, 8 );
                int vijk = VINDEX( i, j, k );
                tmp_conn.set( 0, tmp_sidl_vertices[vijk] );
                tmp_conn.set( 1, tmp_sidl_vertices[vijk + 1] );
                tmp_conn.set( 2, tmp_sidl_vertices[vijk + 1 + numv] );
                tmp_conn.set( 3, tmp_sidl_vertices[vijk + numv] );
                tmp_conn.set( 4, tmp_sidl_vertices[vijk + numv * numv] );
                tmp_conn.set( 5, tmp_sidl_vertices[vijk + 1 + numv * numv] );
                tmp_conn.set( 6, tmp_sidl_vertices[vijk + 1 + numv + numv * numv] );
                tmp_conn.set( 7, tmp_sidl_vertices[vijk + numv + numv * numv] );
                // create the entity
                sidl::array< Entity_Handle > new_hex;
                int new_hex_size = 0;
                int status_size = 0;
                try
                    mesh_arrmod.createEntArr( TSTTM::EntityTopology_HEXAHEDRON, tmp_conn, tmp_conn_size, new_hex,
                                              new_hex_size, status, status_size );
                    cerr << "Couldn't create hex element in individual call" << endl;
                    return;
    std::cout << "TSTT/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = " << nelem << ", "
Variable Documentation
double LENGTH = 1.0
Definition at line 94 of file tstt_perf.cpp.
