umr_perf.cpp File Reference
#include <iostream>
#include <cassert>
#include <ctime>
#include <vector>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/HalfFacetRep.hpp"
#include "moab/NestedRefine.hpp"
#include "../TestUtil.hpp"
#include "moab/CpuTimer.hpp"
+ Include dependency graph for umr_perf.cpp:
Classes
struct  mesh_mem
Enumerations
enum  OUTTYPE { TIME = 0, MEM, BOTH }
Functions
void handle_error_code (ErrorCode rv, int &number_failed, int &number_successful)
ErrorCode umr_perf_test (Core *mb, int *level_degrees, int num_levels, OUTTYPE output)
ErrorCode create_simple_mesh (Core *mb, EntityType type)
ErrorCode test_mesh (EntityType type, int *level_degrees, int num_level)
ErrorCode test_1D ()
ErrorCode test_2D ()
ErrorCode test_3D ()
ErrorCode perf_inmesh (const char *filename, int *level_degrees, int num_levels, OUTTYPE output)
int main (int argc, char *argv[])
Variables
int number_tests_successful = 0
int number_tests_failed = 0
Enumeration Type Documentation
enum OUTTYPE
Enumerator:
TIME
MEM
BOTH
Definition at line 60 of file umr_perf.cpp.
    TIME = 0,
    MEM,
    BOTH
Function Documentation
ErrorCode create_simple_mesh ( Core mb,
EntityType  type
Definition at line 338 of file umr_perf.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), moab::error(), ErrorCode, mb, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, and MBTRI.
Referenced by test_entities(), and test_mesh().
    ErrorCode error;
    Interface* mbImpl = mb;
    if( type == MBEDGE )
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0,
                                  4, 1, 0, 3, 1, 0, 2, 1, 0, 1, 1, 0, 0, 1, 0 };
        const size_t num_vtx  = sizeof( coords ) / sizeof( double ) / 3;
        const int conn[]       = { 1, 0, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 0 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 2;
        EntityHandle verts[num_vtx], edges[num_elems];
        for( size_t i = 0; i < num_vtx; ++i )
            error = mbImpl->create_vertex( coords + 3 * i, verts[i] );
            if( error != MB_SUCCESS ) return error;
        for( size_t i = 0; i < num_elems; ++i )
            EntityHandle c[2];
            c[0] = verts[conn[2 * i]];
            c[1] = verts[conn[2 * i + 1]];
            error = mbImpl->create_element( MBEDGE, c, 2, edges[i] );
    else if( type == MBTRI )
        const double coords[] = { 0, 0,    0, 1, 0,    0,  2, 0,   0,  2.5, 1,   0,  1.5, 1,   0,  0.5, 1,
                                  0, -0.5, 1, 0, -0.5, -1, 0, 0.5, -1, 0,   1.5, -1, 0,   2.5, -1, 0 };
        const int conn[] = { 0, 5, 6, 0, 1, 5, 1, 4, 5, 1, 2, 4, 2, 3,  4,
                             7, 8, 0, 8, 1, 0, 8, 9, 1, 9, 2, 1, 9, 10, 2 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 3;
        EntityHandle verts[num_vtx], faces[num_elems];
            EntityHandle c[3];
            for( int j = 0; j < 3; j++ )
                c[j] = verts[conn[3 * i + j]];
            error = mbImpl->create_element( MBTRI, c, 3, faces[i] );
    else if( type == MBQUAD )
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 4, 0, 0, 5, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0,
                                  3, 1, 0, 4, 1, 0, 5, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 3, 2, 0, 4, 2, 0, 5, 2, 0 };
        const int conn[] = { 0, 1, 7,  6,  1, 2, 8,  7,  2, 3, 9,  8,  3, 4,  10, 9,  4,  5,  11, 10,
                             6, 7, 13, 12, 7, 8, 14, 13, 8, 9, 15, 14, 9, 10, 16, 15, 10, 11, 17, 16 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 4;
            EntityHandle c[4];
            for( int j = 0; j < 4; j++ )
                c[j] = verts[conn[4 * i + j]];
            error = mbImpl->create_element( MBQUAD, c, 4, faces[i] );
    else if( type == MBTET )
        const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1 };
        const int conn[] = { 0, 1, 2, 5, 3, 0, 2, 5, 4, 1, 0, 5, 4, 0, 3, 5 };
        EntityHandle verts[num_vtx], cells[num_elems];
            EntityHandle c[4];
            error = mbImpl->create_element( MBTET, c, 4, cells[i] );
    else if( type == MBHEX )
        const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0,
                                  0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1 };
        const int conn[]       = { 0, 1, 4, 3, 9,  10, 13, 12, 1, 2, 5, 4, 10, 11, 14, 13,
                             3, 4, 7, 6, 12, 13, 16, 15, 4, 5, 8, 7, 13, 14, 17, 16 };
        const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8;
            EntityHandle c[8];
            for( int j = 0; j < 8; j++ )
                c[j] = verts[conn[8 * i + j]];
            error = mbImpl->create_element( MBHEX, c, 8, cells[i] );
    return MB_SUCCESS;
void handle_error_code ( ErrorCode  rv,
int &  number_failed,
int &  number_successful
Definition at line 67 of file umr_perf.cpp.
References MB_SUCCESS, MPI_COMM_WORLD, and rank.
    if( rv == MB_SUCCESS )
#ifdef MOAB_HAVE_MPI
        int rank = 0;
        MPI_Comm_rank( MPI_COMM_WORLD, &rank );
        if( rank == 0 ) std::cout << "Success";
#else
#endif
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 661 of file umr_perf.cpp.
References ErrorCode, filename, handle_error_code(), MEM, MPI_COMM_WORLD, number_tests_failed, number_tests_successful, output, perf_inmesh(), rank, test_1D(), test_2D(), test_3D(), and TIME.
    MPI_Init( &argc, &argv );
    int nprocs, rank;
    MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
#endif
    if( rank == 0 ) std::cout << " para_umr_perf: ";
#else
    std::cout << "umr_perf:";
#endif
    if( argc == 1 )
        ErrorCode result;
        result = test_1D();
        handle_error_code( result, number_tests_failed, number_tests_successful );
        std::cout << "\n";
        result = test_2D();
        std::cout << "\n";
        result = test_3D();
        std::cout << "\n";
    else if( argc == 2 )
        const char* filename = argv[1];
        ErrorCode result;
        OUTTYPE output = MEM;
        if( output == MEM )
            int deg[3] = { 2, 2, 2 };
            int len    = sizeof( deg ) / sizeof( int );
            result     = perf_inmesh( filename, deg, len, output );
            std::cout << "\n";
            deg[0] = 3;
            deg[1] = 3;
            deg[2] = 3;
            std::cout << "\n";
            /*  deg[0] = 5; deg[1] = 5; deg[2] = 5;
              result = perf_inmesh(filename, deg, len, output);
              handle_error_code(result, number_tests_failed, number_tests_successful);
              std::cout<<"\n";*/
        else if( output == TIME )
            for( int L = 0; L < 3; L++ )
                int* level_degrees = new int[L + 1];
                for( int i = 0; i < L + 1; i++ )
                    level_degrees[i] = 3;
                result = perf_inmesh( filename, level_degrees, L + 1, output );
                std::cout << "\n";
                delete[] level_degrees;
    else
        std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
        return 1;
    MPI_Finalize();
#endif
    return number_tests_failed;
ErrorCode perf_inmesh ( const char *  filename,
int *  level_degrees,
int  num_levels,
OUTTYPE  output
Definition at line 631 of file umr_perf.cpp.
References CHECK_ERR, moab::error(), ErrorCode, moab::Interface::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, read_options, and umr_perf_test().
Referenced by main().
    ErrorCode error;
    Core mb;
    Interface* mbImpl = &mb;
    int procs = 1;
    MPI_Comm_size( MPI_COMM_WORLD, &procs );
    if( procs > 1 )
        read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;";
        error = mbImpl->load_file( filename, 0, read_options.c_str() );CHECK_ERR( error );
    else if( procs == 1 )
#endif
        error = mbImpl->load_file( filename );CHECK_ERR( error );
#endif
    //  OUTTYPE output = MEM;
    error = umr_perf_test( &mb, level_degrees, num_levels, output );
    return MB_SUCCESS;
Definition at line 498 of file umr_perf.cpp.
References moab::error(), ErrorCode, MB_SUCCESS, MBEDGE, and test_mesh().
    ErrorCode error;
    std::cout << std::endl;
    std::cout << "EntityType = MBEDGE" << std::endl;
    std::cout << "Deg = 2" << std::endl;
    int deg[7] = { 5, 5, 2, 2, 2, 2, 2 };
    error      = test_mesh( MBEDGE, deg, len );
    std::cout << "Deg = 3" << std::endl;
    deg[4] = 3;
    deg[5] = 3;
    deg[6] = 3;
    std::cout << "Deg = 5" << std::endl;
    deg[4] = 5;
    deg[5] = 5;
    deg[6] = 5;
    return MB_SUCCESS;
Definition at line 529 of file umr_perf.cpp.
References moab::error(), ErrorCode, MB_SUCCESS, MBQUAD, MBTRI, and test_mesh().
    ErrorCode error;
    EntityType type = MBTRI;
    std::cout << "EntityType = MBTRI" << std::endl;
    int deg[5] = { 5, 2, 2, 2, 2 };
    error      = test_mesh( type, deg, len );
    deg[2] = 3;
    deg[3] = 3;
    deg[4] = 3;
    deg[2] = 5;
    deg[3] = 5;
    deg[4] = 5;
    type = MBQUAD;
    std::cout << "EntityType = MBQUAD" << std::endl;
    deg[2] = 2;
    deg[3] = 2;
    deg[4] = 2;
    deg[2] = 3;
    deg[3] = 3;
    deg[4] = 3;
    deg[2] = 5;
    deg[3] = 5;
    deg[4] = 5;
    return MB_SUCCESS;
Definition at line 588 of file umr_perf.cpp.
References moab::error(), ErrorCode, MB_SUCCESS, MBHEX, MBTET, and test_mesh().
    ErrorCode error;
    EntityType type = MBTET;
    std::cout << "EntityType = MBTET" << std::endl;
    int deg[6] = { 2, 2, 2, 2, 2, 2 };
    deg[3] = 3;
    deg[4] = 3;
    deg[5] = 3;
    type = MBHEX;
    std::cout << "EntityType = MBHEX" << std::endl;
    deg[3] = 2;
    deg[4] = 2;
    deg[5] = 2;
    deg[3] = 3;
    deg[4] = 3;
    deg[5] = 3;
    return MB_SUCCESS;
ErrorCode test_mesh ( EntityType  type,
int  num_level
Definition at line 483 of file umr_perf.cpp.
References BOTH, create_simple_mesh(), moab::error(), ErrorCode, mb, MB_SUCCESS, output, and umr_perf_test().
    ErrorCode error;
    Core mb;
    error = create_simple_mesh( &mb, type );
    OUTTYPE output = BOTH;
    error          = umr_perf_test( &mb, level_degrees, num_level, output );
    return MB_SUCCESS;
ErrorCode umr_perf_test ( Core mb,
int  num_levels,
OUTTYPE  output
Definition at line 87 of file umr_perf.cpp.
References moab::Range::begin(), BOTH, CHECK_ERR, dim, moab::Range::end(), mesh_mem::entity_storage, moab::error(), ErrorCode, moab::Interface::estimated_memory_use(), moab::NestedRefine::generate_mesh_hierarchy(), moab::NestedRefine::get_connectivity(), moab::Interface::get_connectivity(), moab::NestedRefine::get_coordinates(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), mb, MB_SUCCESS, MBVERTEX, MEM, moab::Range::size(), TIME, moab::CpuTimer::time_elapsed(), mesh_mem::total_storage, and mesh_mem::vertex_storage.
Referenced by perf_inmesh(), and test_mesh().
    ErrorCode error;
    mesh_mem* umem = new mesh_mem[num_levels + 2];
    CpuTimer* mt = new CpuTimer;
    double time_start, time_avg, time_total;
    // Create ranges of entities in the initial mesh
    Range inverts, inedges, infaces, incells;
    error = mbImpl->get_entities_by_dimension( 0, 0, inverts );
    error = mbImpl->get_entities_by_dimension( 0, 1, inedges );
    error = mbImpl->get_entities_by_dimension( 0, 2, infaces );
    error = mbImpl->get_entities_by_dimension( 0, 3, incells );
    Range init_ents;
    int dim = 0;
    if( inedges.size() )
        dim       = 1;
        init_ents = inedges;
    else if( infaces.size() )
        dim       = 2;
        init_ents = infaces;
    else if( incells.size() )
        dim       = 3;
        init_ents = incells;
    std::cout << "Initial Mesh Size: "
              << "NV = " << inverts.size() << ", NE = " << init_ents.size() << std::endl;
    if( output == MEM || output == BOTH )
        // Storage Costs before mesh hierarchy generation
        /*     std::cout<<std::endl;
             unsigned long long sTotS, sTAS, sES, sAES, sAS, sAAS, sTS, sATS;
             sTotS = sTAS = sES = sAES = sAS = sAAS = sTS = sATS = 0;
             mbImpl->estimated_memory_use(NULL, 0, &sTotS, &sTAS, &sES, &sAES, &sAS, &sAAS, NULL, 0,
           &sTS, &sATS);
             umem[0].total_storage = sTotS;
             umem[0].amortized_total_storage = sTAS;
             umem[0].entity_storage = sES;
             umem[0].amortized_entity_storage = sAES;
             umem[0].adjacency_storage = sAS;
             umem[0].amortized_adjacency_storage = sAAS;
             umem[0].tag_storage = sTS;
             umem[0].amortized_tag_storage = sATS;*/
        unsigned long long vTotS, vTAS, vES, vAES, vAS, vAAS, vTS, vATS;
        vTotS = vTAS = vES = vAES = vAS = vAAS = vTS = vATS = 0;
        mbImpl->estimated_memory_use( inverts, &vTotS, &vTAS, &vES, &vAES, &vAS, &vAAS, NULL, 0, &vTS, &vATS );
        unsigned long long eTotS, eTAS, eES, eAES, eAS, eAAS, eTS, eATS;
        eTotS = eTAS = eES = eAES = eAS = eAAS = eTS = eATS = 0;
        mbImpl->estimated_memory_use( init_ents, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS );
        umem[0].total_storage  = vTotS + eTotS;
        umem[0].vertex_storage = vES;
        umem[0].entity_storage = eES;
        //  umem[0].tag_storage = vTS+eTS;
        std::cout << "MEMORY STORAGE:: Initial Mesh" << std::endl;
        std::cout << "Total storage = " << umem[0].total_storage << std::endl;
        std::cout << "Vertex storage = " << umem[0].vertex_storage << std::endl;
        std::cout << "Entity storage = " << umem[0].entity_storage << std::endl;
        //  std::cout<<"Tag storage = "<< umem[0].tag_storage<<std::endl;
        /*    std::cout<<"Total storage = "<<umem[0].total_storage<<std::endl;
            std::cout<<"Total amortized storage = "<< umem[0].amortized_total_storage<<std::endl;
            std::cout<<"Entity storage = "<<umem[0].entity_storage<<std::endl;
            std::cout<<"Amortized entity storage = "<<umem[0].amortized_entity_storage<<std::endl;
            std::cout<<"Adjacency storage = "<< umem[0].adjacency_storage <<std::endl;
            std::cout<<"Amortized adjacency storage = "<<umem[0].amortized_adjacency_storage
           <<std::endl; std::cout<<"Tag storage = "<< umem[0].tag_storage<<std::endl;
            std::cout<<"Amortized tag storage = "<<umem[0].amortized_tag_storage <<std::endl;*/
    // Create an hm object and generate the hierarchy
    std::cout << "Creating a hm object" << std::endl;
    NestedRefine uref( mb );
    std::vector< EntityHandle > set;
    std::cout << "Starting hierarchy generation" << std::endl;
    time_start = mt->time_elapsed();
    error      = uref.generate_mesh_hierarchy( num_levels, level_degrees, set );CHECK_ERR( error );
    time_total = mt->time_elapsed() - time_start;
    std::cout << "Finished hierarchy generation" << std::endl;
    if( output == TIME || output == BOTH )
        std::cout << "Total time in secs:: generate mesh hierarchy:: L = " << num_levels << " :: " << time_total
                  << std::endl;
    // Loop over each mesh level and check its topological properties
    for( int l = 0; l < num_levels; l++ )
        // Get the current mesh level using its meshset
        Range verts, ents;
        error = mbImpl->get_entities_by_type( set[l + 1], MBVERTEX, verts );CHECK_ERR( error );
        error = mbImpl->get_entities_by_dimension( set[l + 1], dim, ents );CHECK_ERR( error );
        std::cout << "Mesh size for level " << l + 1 << " :: deg = " << level_degrees[l] << " :: NV = " << verts.size()
                  << ", NE = " << ents.size() << std::endl;
            // Storage Costs
            mbImpl->estimated_memory_use( verts, &vTotS, &vTAS, &vES, &vAES, &vAS, &vAAS, NULL, 0, &vTS, &vATS );
            mbImpl->estimated_memory_use( ents, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS );
            umem[l + 1].total_storage  = vTotS + eTotS;
            umem[l + 1].vertex_storage = vES;
            umem[l + 1].entity_storage = eES;
            //   umem[l+1].tag_storage = vTS+eTS;
            /* umem[l+1].total_storage = vTotS+eTotS;
             umem[l+1].amortized_total_storage = vTAS+eTAS;
             umem[l+1].entity_storage = vES+eES;
             umem[l+1].amortized_entity_storage = vAES+eAES;
             umem[l+1].adjacency_storage = vAS+eAS;
             umem[l+1].amortized_adjacency_storage = vAAS+eAAS;
             umem[l+1].amortized_tag_storage = vATS+eATS;*/
            std::cout << "MEMORY STORAGE:: Mesh level " << l + 1 << std::endl;
            std::cout << "Total storage = " << umem[l + 1].total_storage << std::endl;
            std::cout << "Vertex storage = " << umem[l + 1].vertex_storage << std::endl;
            std::cout << "Entity storage = " << umem[l + 1].entity_storage << std::endl;
            //   std::cout<<"Tag storage = "<< umem[l+1].tag_storage<<std::endl;
            /*  std::cout<<"Total storage = "<<umem[l+1].total_storage<<std::endl;
              umem[l+1].amortized_total_storage<<std::endl; std::cout<<"Entity storage =
              "<<umem[l+1].entity_storage<<std::endl; std::cout<<"Amortized entity storage =
              "<<umem[l+1].amortized_entity_storage<<std::endl; std::cout<<"Adjacency storage = "<<
              umem[l+1].adjacency_storage <<std::endl; std::cout<<"Amortized adjacency storage =
              "<<umem[l+1].amortized_adjacency_storage <<std::endl; std::cout<<"Tag storage = "<<
              umem[l+1].tag_storage<<std::endl; std::cout<<"Amortized tag storage =
              "<<umem[l+1].amortized_tag_storage <<std::endl;*/
        if( output == BOTH )
            // Loop over all vertices and get their coordinates
            for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
                double coords[3];
                EntityHandle vid = *i;
                error            = uref.get_coordinates( &vid, 1, (int)l, &coords[0] );CHECK_ERR( error );
            time_avg   = time_total / (double)verts.size();
            std::cout << "Class NR :: OPERATION:: get_coordinates"
                      << " :: Time_total = " << time_total << " :: Time_avg = " << time_avg << std::endl;
                double coords[3];
                error            = mbImpl->get_coords( &vid, 1, &coords[0] );CHECK_ERR( error );
            std::cout << "Class Core :: OPERATION:: get_coordinates"
            // Loop over all entities and get their connectivity
            for( Range::iterator i = ents.begin(); i != ents.end(); ++i )
                std::vector< EntityHandle > conn;
                error = uref.get_connectivity( *i, l, conn );CHECK_ERR( error );
            time_avg   = time_total / (double)ents.size();
            std::cout << "Class NR :: OPERATION:: get_connectivity"
                error = mbImpl->get_connectivity( &*i, 1, conn );CHECK_ERR( error );
            std::cout << "Class Core :: OPERATION:: get_connectivity"
    /* if (output == MEM || output == BOTH){
       &sTS, &sATS);
         umem[num_levels+1].total_storage = sTotS;
         umem[num_levels+1].amortized_total_storage = sTAS;
         umem[num_levels+1].entity_storage = sES;
         umem[num_levels+1].amortized_entity_storage = sAES;
         umem[num_levels+1].adjacency_storage = sAS;
         umem[num_levels+1].amortized_adjacency_storage = sAAS;
         umem[num_levels+1].tag_storage = sTS;
         umem[num_levels+1].amortized_tag_storage = sATS;
         std::cout<<"MEMORY STORAGE:: WHOLE MESH HIERARCHY"<<std::endl;
         std::cout<<"Total storage = "<<umem[num_levels+1].total_storage<<std::endl;
       umem[num_levels+1].amortized_total_storage<<std::endl; std::cout<<"Entity storage =
       "<<umem[num_levels+1].entity_storage<<std::endl; std::cout<<"Amortized entity storage =
       "<<umem[num_levels+1].amortized_entity_storage<<std::endl; std::cout<<"Adjacency storage =
       "<< umem[num_levels+1].adjacency_storage <<std::endl; std::cout<<"Amortized adjacency storage
       = "<<umem[num_levels+1].amortized_adjacency_storage <<std::endl; std::cout<<"Tag storage =
       "<< umem[num_levels+1].tag_storage<<std::endl; std::cout<<"Amortized tag storage =
       "<<umem[num_levels+1].amortized_tag_storage <<std::endl; std::cout<<std::endl;
    return MB_SUCCESS;
Variable Documentation
Definition at line 29 of file umr_perf.cpp.
Definition at line 28 of file umr_perf.cpp.
