untangle.cpp File Reference
tast untangle wrapper More...
#include "TestUtil.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "MsqVertex.hpp"
#include "PlanarDomain.hpp"
#include "UntangleWrapper.hpp"
#include "QualityAssessor.hpp"
#include <iostream>
#include <cstdlib>
+ Include dependency graph for untangle.cpp:
Functions
int uwt (bool skip, UntangleWrapper::UntangleMetric metric, const char *input_file, int expected_number_of_remaining_inverted_elems, bool flip_domain=false)
void usage (const char *argv0)
void help (const char *argv0)
int main (int argc, char *argv[])
const char * tostr (UntangleWrapper::UntangleMetric m)
Variables
std::string VTK_2D_DIR = "unittest/mesquite/2D/vtk/"
bool brief_output = false
bool write_output = false
double mu_sigma = -1
double beta = -1
Detailed Description
Author:
Jason Kraftcheck
Definition in file untangle.cpp.
Function Documentation
void help ( const char *  argv0)
Definition at line 67 of file untangle.cpp.
    std::cout << "Usage: " << argv0 << " [-<flags>] [-c <sigma>] [-b <beta>]" << std::endl
              << "Flags: -q : brief output" << std::endl
              << "       -w : write result meshes" << std::endl
              << "       -B : skip tests using untangle beta target metric" << std::endl
              << "       -Z : skip tests using size untangle target metric" << std::endl
              << "       -P : skip tests using shapesize untangle target metric" << std::endl
              << "       -H : skip tests using 'tangled_horse1.vtk' as input" << std::endl
              << "       -Q : skip tests using 'hole_in_square_tanglap.vtk' as input" << std::endl
              << "       -I : skip tests using 'inverted-hole-2.vtk' as input" << std::endl
              << "       -S : skip tests using 'shest_grid32.vtk' as input" << std::endl
              << "       -c : specify sigma value for untangle metrics" << std::endl
              << "       -b : specify beta value for untangle beta metric" << std::endl
              << std::endl;
int main ( int  argc,
char *  argv[]
Definition at line 84 of file untangle.cpp.
References MBMesquite::UntangleWrapper::BETA, beta, brief_output, help(), mu_sigma, MBMesquite::UntangleWrapper::SHAPESIZE, MBMesquite::UntangleWrapper::SIZE, usage, uwt(), and write_output.
    bool skip_beta  = false;
    bool skip_size  = false;
    bool skip_shape = false;
    bool skip_horse = false;
    bool skip_hole  = false;
    bool skip_invrt = false;
    bool skip_shest = false;
    std::list< double* > expected;
    for( int i = 1; i < argc; ++i )
        if( !expected.empty() )
            char* endptr;
            *expected.front() = strtod( argv[i], &endptr );
            if( *endptr || *expected.front() <= 0 )
                std::cerr << "Expected positive number, found \"" << argv[i] << '"' << std::endl;
                usage( argv[0] );
                return 1;
            expected.pop_front();
        else if( argv[i][0] == '-' && argv[i][1] )
            for( int j = 1; argv[i][j]; ++j )
                switch( argv[i][j] )
                    case 'q':
                        brief_output = true;
                        break;
                    case 'w':
                        write_output = true;
                        break;
                    case 'B':
                        skip_beta = true;
                        break;
                    case 'Z':
                        skip_size = true;
                        break;
                    case 'P':
                        skip_shape = true;
                        break;
                    case 'H':
                        skip_horse = true;
                        break;
                    case 'Q':
                        skip_hole = true;
                        break;
                    case 'I':
                        skip_invrt = true;
                        break;
                    case 'S':
                        skip_shest = true;
                        break;
                    case 'c':
                        expected.push_back( &mu_sigma );
                        break;
                    case 'b':
                        expected.push_back( &beta );
                        break;
                    case 'h':
                        help( argv[0] );
                        return 0;
                    default:
                        std::cerr << "Invalid flag: -" << argv[i][j] << std::endl;
                        usage( argv[0] );
                        return 1;
        else
            std::cerr << "Unexpected argument: \"" << argv[i] << '"' << std::endl;
            usage( argv[0] );
            return 1;
    int result = 0;
    result += uwt( skip_beta || skip_horse, UntangleWrapper::BETA, "quads/tangled/tangled_horse1.vtk", 0 );
    result += uwt( skip_beta || skip_hole, UntangleWrapper::BETA, "quads/tangled/hole_in_square_tanglap.vtk", 0, true );
    result += uwt( skip_beta || skip_invrt, UntangleWrapper::BETA, "quads/tangled/inverted-hole-2.vtk", 0 );
    result += uwt( skip_beta || skip_shest, UntangleWrapper::BETA, "quads/untangled/shest_grid32.vtk", 0 );
    result += uwt( skip_size || skip_horse, UntangleWrapper::SIZE, "quads/tangled/tangled_horse1.vtk", 0 );
    result += uwt( skip_size || skip_hole, UntangleWrapper::SIZE, "quads/tangled/hole_in_square_tanglap.vtk", 6, true );
    result += uwt( skip_size || skip_invrt, UntangleWrapper::SIZE, "quads/tangled/inverted-hole-2.vtk", 0 );
    result += uwt( skip_size || skip_shest, UntangleWrapper::SIZE, "quads/untangled/shest_grid32.vtk", 0 );
    result += uwt( skip_shape || skip_horse, UntangleWrapper::SHAPESIZE, "quads/tangled/tangled_horse1.vtk", 0 );
    result +=
        uwt( skip_shape || skip_hole, UntangleWrapper::SHAPESIZE, "quads/tangled/hole_in_square_tanglap.vtk", 0, true );
    result += uwt( skip_shape || skip_invrt, UntangleWrapper::SHAPESIZE, "quads/tangled/inverted-hole-2.vtk", 8 );
    result += uwt( skip_shape || skip_shest, UntangleWrapper::SHAPESIZE, "quads/untangled/shest_grid32.vtk", 0 );
    return result;
Definition at line 187 of file untangle.cpp.
References MBMesquite::UntangleWrapper::BETA, MBMesquite::BETA, MBMesquite::UntangleWrapper::SHAPESIZE, and MBMesquite::UntangleWrapper::SIZE.
Referenced by uwt().
    static const char BETA[]      = "BETA";
    static const char SIZE[]      = "SIZE";
    static const char SHAPESIZE[] = "SHAPESIZE";
    switch( m )
        case UntangleWrapper::BETA:
            return BETA;
        case UntangleWrapper::SIZE:
            return SIZE;
        case UntangleWrapper::SHAPESIZE:
            return SHAPESIZE;
    return 0;
void usage ( const char *  argv0)
Definition at line 62 of file untangle.cpp.
    std::cerr << "Usage: " << argv0 << " [-<flags>] [-c <sigma>] [-b <beta>]" << std::endl
              << "       " << argv0 << " -h" << std::endl;
int uwt ( bool  skip,
const char *  input_file,
bool  flip_domain = false
Definition at line 204 of file untangle.cpp.
References MBMesquite::arrptr(), MBMesquite::UntangleWrapper::BETA, beta, brief_output, MBMesquite::MsqError::clear(), MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::MeshImpl::get_all_vertices(), MBMesquite::QualityAssessor::get_inverted_element_count(), input_file, mesh, mu_sigma, MBMesquite::Wrapper::quality_assessor(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::UntangleWrapper::set_metric_constant(), MBMesquite::UntangleWrapper::set_vertex_movement_limit_factor(), tostr(), MBMesquite::MeshImpl::vertices_get_coordinates(), VTK_2D_DIR, write_output, and MBMesquite::MeshImpl::write_vtk().
Referenced by main().
    if( skip ) return 0;
    if( !brief_output ) std::cout << std::endl << "**********************************************" << std::endl;
    std::cout << "Running \"" << input_file_base << "\" for " << tostr( metric ) << std::endl;
    if( !brief_output ) std::cout << "**********************************************" << std::endl << std::endl;
    // get mesh
    MsqError err;
    MeshImpl mesh;
    std::string input_file( VTK_2D_DIR );
    input_file += input_file_base;
    mesh.read_vtk( input_file.c_str(), err );
    if( err )
        std::cerr << err << std::endl;
        std::cerr << "ERROR: " << input_file << " : failed to read file" << std::endl;
        return 1;
    // get domain
    std::vector< Mesh::VertexHandle > verts;
    mesh.get_all_vertices( verts, err );
    if( err || verts.empty() ) abort();
    MsqVertex coords;
    mesh.vertices_get_coordinates( arrptr( verts ), &coords, 1, err );
    if( err ) abort();
    Vector3D norm( 0, 0, flip_domain ? -1 : 1 );
    PlanarDomain domain( norm, coords );
    // run wrapper
    UntangleWrapper wrapper( metric );
    wrapper.set_vertex_movement_limit_factor( 0.005 );
    double constant = ( metric == UntangleWrapper::BETA ) ? beta : mu_sigma;
    if( constant > 0 ) wrapper.set_metric_constant( constant );
    if( brief_output ) wrapper.quality_assessor().disable_printing_results();
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &domain );
    wrapper.run_instructions( &mesh_and_domain, err );
    if( err )
        std::cerr << "ERROR: optimization failed" << std::endl;
        return 1;
    // write output file
    if( write_output )
        std::string result_file( tostr( metric ) );
        result_file += "-";
        result_file += input_file_base;
        mesh.write_vtk( result_file.c_str(), err );
        if( err )
            std::cerr << "ERROR: " << result_file << " : failed to write file" << std::endl;
            err.clear();
        else
            std::cerr << "Wrote file: " << result_file << std::endl;
    // test number of inverted elements
    int count, junk;
    wrapper.quality_assessor().get_inverted_element_count( count, junk, err );
    if( err ) abort();
    if( count < expected )
        std::cout << "WARNING: expected " << expected << " inverted elements but finished with only " << count
                  << std::endl
                  << "Test needs to be updated?" << std::endl
                  << std::endl;
        return 0;
    else if( count == expected )
        std::cout << "Completed with " << count << " inverted elements remaining" << std::endl << std::endl;
        return 0;
    else
        std::cerr << "ERROR: expected " << expected << " inverted elements but finished with " << count << std::endl
                  << std::endl;
        return 1;
Variable Documentation
Definition at line 57 of file untangle.cpp.
Definition at line 59 of file untangle.cpp.
Referenced by main(), and uwt().
Definition at line 47 of file untangle.cpp.
Definition at line 58 of file untangle.cpp.
