uref_hirec_test_parallel.cpp File Reference
#include <iostream>
#include <string>
#include <sstream>
#include <ctime>
#include <vector>
#include <algorithm>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/NestedRefine.hpp"
#include "moab/DiscreteGeometry/HiReconstruction.hpp"
#include "TestUtil.hpp"
#include "geomObject.cpp"
#include <cmath>
#include <cstdlib>
#include <cassert>
+ Include dependency graph for uref_hirec_test_parallel.cpp:
Defines
#define nsamples   10
Functions
ErrorCode load_meshset_hirec (const char *infile, Interface *mbimpl, EntityHandle &meshset, ParallelComm *&pc, const int degree, const int dim)
ErrorCode closedsurface_uref_hirec_convergence_study (const char *infile, std::vector< int > &degs2fit, bool interp, int dim, geomObject *obj, int &ntestverts, std::vector< double > &geoml1errs, std::vector< double > &geoml2errs, std::vector< double > &geomlinferrs)
void usage ()
int main (int argc, char *argv[])
Define Documentation
#define nsamples   10
Function Documentation
ErrorCode closedsurface_uref_hirec_convergence_study ( const char *  infile,
std::vector< int > &  degs2fit,
bool  interp,
int  dim,
geomObject obj,
int &  ntestverts,
std::vector< double > &  geoml1errs,
std::vector< double > &  geoml2errs,
std::vector< double > &  geomlinferrs
Definition at line 126 of file uref_hirec_test_parallel.cpp.
References moab::Range::begin(), geomObject::compute_projecterror(), moab::Range::end(), moab::error(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::HiReconstruction::hiproj_walf_in_element(), load_meshset_hirec(), MB_CHK_ERR, MBQUAD, MBTRI, MPI_COMM_WORLD, nsamples, geomObject::project_points2geom(), PSTATUS_GHOST, PSTATUS_NOT, rank, moab::HiReconstruction::reconstruct3D_surf_geom(), moab::Interface::set_coords(), moab::Range::size(), moab::sum(), and moab::TYPE_FROM_HANDLE().
Referenced by main().
    Core moab;
    Interface* mbImpl = &moab;
    ParallelComm* pc  = NULL;
    EntityHandle meshset;
#ifdef MOAB_HAVE_MPI
    int nprocs, rank;
    MPI_Comm comm = MPI_COMM_WORLD;
    MPI_Comm_size( comm, &nprocs );
    MPI_Comm_rank( comm, &rank );
#endif
    ErrorCode error;
    // mesh will be loaded and communicator pc will be updated
    int mxdeg = 1;
    for( size_t i = 0; i < degs2fit.size(); ++i )
        mxdeg = std::max( degs2fit[i], mxdeg );
    error = load_meshset_hirec( infile, mbImpl, meshset, pc, mxdeg, dim );MB_CHK_ERR( error );
    Range elems, elems_owned;
    error = mbImpl->get_entities_by_dimension( meshset, dim, elems );MB_CHK_ERR( error );
    if( pc )
        error = pc->filter_pstatus( elems, PSTATUS_GHOST, PSTATUS_NOT, -1, &elems_owned );MB_CHK_ERR( error );
    else
        elems_owned = elems;
#endif
    // std::cout << "Mesh has " << nelems << " elements on Processor " << rank << " in total;";
    // std::cout << elems_owned.size() << " of which are locally owned elements" << std::endl;
#else
    // std::cout << "Mesh has " << nelems << " elements" << std::endl;
#endif
     *   convergence study   *
    // project onto exact geometry since each level with uref has only linear coordinates
    Range verts;
    error = mbImpl->get_entities_by_dimension( meshset, 0, verts );MB_CHK_ERR( error );
    for( Range::iterator ivert = verts.begin(); ivert != verts.end(); ++ivert )
        EntityHandle currvert = *ivert;
        double currcoords[3], exactcoords[3];
        error = mbImpl->get_coords( &currvert, 1, currcoords );MB_CHK_ERR( error );
        obj->project_points2geom( 3, currcoords, exactcoords, NULL );
        error = mbImpl->set_coords( &currvert, 1, exactcoords );MB_CHK_ERR( error );
        // for debug
        /*error = mbImpl->get_coords(&currvert,1,currcoords); MB_CHK_ERR(error);
        assert(currcoords[0]==exactcoords[0]&&currcoords[1]==exactcoords[1]&&currcoords[2]==exactcoords[2]);*/
    // test ahf on mesh with ghost layers
    /*Range verts_owned;
        if(pc){
            error =
    pc->filter_pstatus(verts,PSTATUS_GHOST,PSTATUS_NOT,-1,&verts_owned);MB_CHK_ERR(error); }else{
    verts_owned = verts;
        HalfFacetRep *ahf = new HalfFacetRep(&moab,pc,meshset);
        error = ahf->initialize(); MB_CHK_ERR(error);
        for(int i=0;i<nprocs;++i){
            if(rank==i){
                std::cout << "Processor " << rank << " Local elements: \n";
                for(Range::iterator ielem=elems.begin();ielem!=elems.end();++ielem){
                    EntityHandle currelem = *ielem;
                    std::vector<EntityHandle> conn;
                    error = mbImpl->get_connectivity(&currelem,1,conn); MB_CHK_ERR(error);
                    std::cout << *ielem << ": ";
                    for(size_t k=0;k<conn.size();++k) std::cout << conn[k] << " ";
                    std::cout << std::endl;
                std::cout << "Processor " << rank << " Local owned elements: \n";
                for(Range::iterator ielem=elems_owned.begin();ielem!=elems_owned.end();++ielem){
                std::cout << "Processor " << rank << " Local vertices: ";
                for(Range::iterator ivert=verts.begin();ivert!=verts.end();++ivert){
                    std::cout << *ivert << " ";
                std::cout << "Processor " << rank << " Local owned vertices: ";
                for(Range::iterator ivert=verts_owned.begin();ivert!=verts_owned.end();++ivert){
                    EntityHandle currvid = *ivert;
                    std::cout << "Processor " << rank << " local verts: " << *ivert << " has
    adjfaces: "; std::vector<EntityHandle> adjfaces;
                    //error = ahf->get_up_adjacencies(currvid,2,adjfaces); MB_CHK_ERR(error);
                    error = mbImpl->get_adjacencies(&currvid,1,2,false,adjfaces); MB_CHK_ERR(error);
                    for(size_t k=0;k<adjfaces.size();++k){
                        std::cout << adjfaces[k] << " ";
                    std::cout << "Processor " << rank << " all verts: " << *ivert << " has adjfaces:
                    //error = ahf->get_up_adjacencies(*ivert,2,adjfaces); MB_CHK_ERR(error);
            }else{
                MPI_Barrier(MPI_COMM_WORLD);
        exit(0);
    #endif*/
    // generate random points on each elements, assument 3D coordinates
    int nvpe = TYPE_FROM_HANDLE( *elems.begin() ) == MBTRI ? 3 : 4;
    std::vector< double > testpnts, testnaturalcoords;
    ntestverts = elems_owned.size() * nsamples;
    testpnts.reserve( 3 * elems_owned.size() * nsamples );
    testnaturalcoords.reserve( nvpe * elems_owned.size() * nsamples );
    for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem )
        std::vector< EntityHandle > conn;
        error = mbImpl->get_connectivity( &currelem, 1, conn );MB_CHK_ERR( error );
        std::vector< double > elemcoords( 3 * conn.size() );
        error = mbImpl->get_coords( &( conn[0] ), conn.size(), &( elemcoords[0] ) );MB_CHK_ERR( error );
        EntityType type = TYPE_FROM_HANDLE( currelem );
        for( int s = 0; s < nsamples; ++s )
            if( type == MBTRI )
                double a = (double)rand() / RAND_MAX, b = (double)rand() / RAND_MAX, c = (double)rand() / RAND_MAX, sum;
                sum = a + b + c;
                if( sum < 1e-12 )
                    --s;
                    continue;
                else
                    a /= sum, b /= sum, c /= sum;
                assert( a > 0 && b > 0 && c > 0 && fabs( a + b + c - 1 ) < 1e-12 );
                testpnts.push_back( a * elemcoords[0] + b * elemcoords[3] + c * elemcoords[6] );
                testpnts.push_back( a * elemcoords[1] + b * elemcoords[4] + c * elemcoords[7] );
                testpnts.push_back( a * elemcoords[2] + b * elemcoords[5] + c * elemcoords[8] );
                testnaturalcoords.push_back( a ), testnaturalcoords.push_back( b ), testnaturalcoords.push_back( c );
            else if( type == MBQUAD )
                double xi = (double)rand() / RAND_MAX, eta = (double)rand() / RAND_MAX, N[4];
                xi   = 2 * xi - 1;
                eta  = 2 * eta - 1;
                N[0] = ( 1 - xi ) * ( 1 - eta ) / 4, N[1] = ( 1 + xi ) * ( 1 - eta ) / 4,
                N[2] = ( 1 + xi ) * ( 1 + eta ) / 4, N[3] = ( 1 - xi ) * ( 1 + eta ) / 4;
                testpnts.push_back( N[0] * elemcoords[0] + N[1] * elemcoords[3] + N[2] * elemcoords[6] +
                                    N[3] * elemcoords[9] );
                testpnts.push_back( N[0] * elemcoords[1] + N[1] * elemcoords[4] + N[2] * elemcoords[7] +
                                    N[3] * elemcoords[10] );
                testpnts.push_back( N[0] * elemcoords[2] + N[1] * elemcoords[5] + N[2] * elemcoords[8] +
                                    N[3] * elemcoords[11] );
                testnaturalcoords.push_back( N[0] ), testnaturalcoords.push_back( N[1] ),
                    testnaturalcoords.push_back( N[2] ), testnaturalcoords.push_back( N[3] );
            else
                throw std::invalid_argument( "NOT SUPPORTED ELEMENT TYPE" );
    // Compute error of linear interpolation in PARALLEL
    double l1err, l2err, linferr;
    geoml1errs.clear();
    geoml2errs.clear();
    geomlinferrs.clear();
    obj->compute_projecterror( 3, elems_owned.size() * nsamples, &( testpnts[0] ), l1err, l2err, linferr );
    geoml1errs.push_back( l1err );
    geoml2errs.push_back( l2err );
    geomlinferrs.push_back( linferr );
    /*Perform high order projection and compute error*/
    // initialize
    HiReconstruction hirec( &moab, pc, meshset );
    for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg )
        // High order reconstruction
        error = hirec.reconstruct3D_surf_geom( degs2fit[ideg], interp, true, true );MB_CHK_ERR( error );
        int index = 0;
        // for debug
        /*double maxlinferr=0,elemlinferr=0,eleml1err=0,eleml2err;
        EntityHandle elem_maxerr;*/
        for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem, ++index )
            // Projection
            error =
                hirec.hiproj_walf_in_element( *ielem, nvpe, nsamples, &( testnaturalcoords[nvpe * nsamples * index] ),
                                              &( testpnts[3 * nsamples * index] ) );MB_CHK_ERR( error );
            // for debug
            /*obj->compute_projecterror(3,nsamples,&(testpnts[3*nsamples*index]),eleml1err,eleml2err,elemlinferr);
            if(elemlinferr>maxlinferr){
                maxlinferr = elemlinferr; elem_maxerr = *ielem;
        assert( (size_t)index == elems_owned.size() );
        // Estimate error
        // for debug
        /*std::cout << "Degree " << degs2fit[ideg] << " has L-inf error " << maxlinferr << " at
        element " << elems_owned.index(elem_maxerr) << ":"; std::vector<EntityHandle> conn; error =
        mbImpl->get_connectivity(&elem_maxerr,1,conn); MB_CHK_ERR(error); for(size_t
        ii=0;ii<conn.size();++ii) std::cout << verts.index(conn[ii]) << " "; std::cout << std::endl;
        for(size_t ii=0;ii<conn.size();++ii){
            //assume triangle
            std::vector<double> vertexcoords(3,0);
            error = mbImpl->get_coords(&(conn[ii]),1,&(vertexcoords[0])); MB_CHK_ERR(error);
            std::cout << verts.index(conn[ii]) << ":" << vertexcoords[0] << " "<< vertexcoords[1] <<
        " "<< vertexcoords[2] << "\n"; GEOMTYPE geomtype; std::vector<double> local_coords_system,
        local_coeffs; int deg_out; bool local_interp; bool hasfit =
        hirec.get_fittings_data(conn[ii],geomtype,local_coords_system,deg_out,local_coeffs,local_interp);
        assert(hasfit); std::cout << "Local fitting result: " << std::endl; std::cout << "Geom Type:
        " << geomtype << std::endl; std::cout << "Local coordinates system: " << std::endl;
            std::cout << local_coords_system[0] << "\t" << local_coords_system[1] << "\t" <<
        local_coords_system[2] << std::endl; std::cout << local_coords_system[3] << "\t" <<
        local_coords_system[4] << "\t" << local_coords_system[5] << std::endl; std::cout <<
        local_coords_system[6] << "\t" << local_coords_system[7] << "\t" << local_coords_system[8]
        << std::endl; std::cout << "Fitting degree is " << deg_out << " interp is " << local_interp
        << std::endl; std::cout << "Fitting coefficients are :" << std::endl; for(size_t
        kk=0;kk<local_coeffs.size();++kk) std::cout << local_coeffs[kk] << "\t"; std::cout <<
        std::endl;
    return error;
ErrorCode load_meshset_hirec ( const char *  infile,
Interface mbimpl,
EntityHandle meshset,
ParallelComm *&  pc,
const int  degree,
const int  dim
Definition at line 42 of file uref_hirec_test_parallel.cpp.
References moab::Interface::create_meshset(), moab::error(), ErrorCode, moab::HiReconstruction::estimate_num_ghost_layers(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), MB_CHK_ERR, MB_SET_ERR, MESHSET_SET, MPI_COMM_WORLD, rank, and read_options.
    ErrorCode error;
    error = mbimpl->create_meshset( moab::MESHSET_SET, meshset );MB_CHK_ERR( error );
    int nprocs, rank;
    EntityHandle partnset;
    error = mbimpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error );
    if( nprocs > 1 )
        pc = moab::ParallelComm::get_pcomm( mbimpl, partnset, &comm );
    if( nprocs > 1 )
        int nghlayers = degree > 0 ? HiReconstruction::estimate_num_ghost_layers( degree, true ) : 0;
        assert( nghlayers < 10 );
        if( nghlayers )
            // get ghost layers
            if( dim == 2 )
                read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_"
                               "SHARED_ENTS;PARALLEL_GHOSTS=2.0.";
            else if( dim == 1 )
                               "SHARED_ENTS;PARALLEL_GHOSTS=1.0.";
            else
                MB_SET_ERR( MB_FAILURE, "unsupported dimension" );
            read_options += (char)( '0' + nghlayers );
            // std::cout << "On processor " << rank << " Degree=" << degree << " "<< read_options <<
            // std::endl;
        else
            read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;";
        /*for debug*/
        /*std::string outfile = std::string(infile); std::size_t dotpos = outfile.find_last_of(".");
        std::ostringstream convert; convert << rank;
        std::string localfile = outfile.substr(0,dotpos)+convert.str()+".vtk";
        //write local mesh
        EntityHandle local;
        error = mbimpl->create_meshset(moab::MESHSET_SET,local);CHECK_ERR(error);
        std::string local_options =
        "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; error =
        mbimpl->load_file(infile,&local,local_options.c_str()); MB_CHK_ERR(error); error =
        mbimpl->write_file(localfile.c_str(),0,0,&local,1);*/
        error = mbimpl->load_file( infile, &meshset, read_options.c_str() );MB_CHK_ERR( error );
        /*for debug
        //write local mesh with ghost layers
        localfile = outfile.substr(0,dotpos)+convert.str()+"_ghost.vtk";
        error = mbimpl->write_file(localfile.c_str(),0,0,&meshset,1);*/
    else
        error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error );
#else
    assert( !pc && degree && dim );
#endif
    return error;
int main ( int  argc,
char *  argv[]
Definition at line 420 of file uref_hirec_test_parallel.cpp.
References closedsurface_uref_hirec_convergence_study(), dim, moab::error(), ErrorCode, geom, MB_CHK_ERR, MPI_COMM_WORLD, rank, and usage.
    MPI_Init( &argc, &argv );
    int nprocs, rank;
    MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#endif
    std::string prefix, suffix, istr, iend;
    int dim = 2, geom = 0;
    bool interp = false;
    ErrorCode error;
    if( argc == 1 )
        usage();
        prefix = TestDir + "unittest/sphere_quads_5_ML_";
        suffix = ".h5m";
        istr   = "0";
        iend   = "1";
        std::cout << "Using defaults: MeshFiles/unittest/sphere_quads_5_ML_*.h5m -str 0 -end 1 "
                     "-suffix \".h5m\" -interp 0 -dim 2 -geom s"
                  << std::endl;
    else
        prefix      = std::string( argv[1] );
        bool hasdim = false;
        for( int i = 2; i < argc; ++i )
            if( i + 1 != argc )
                if( std::string( argv[i] ) == "-suffix" )
                    suffix = std::string( argv[++i] );
                else if( std::string( argv[i] ) == "-str" )
                    istr = std::string( argv[++i] );
                else if( std::string( argv[i] ) == "-end" )
                    iend = std::string( argv[++i] );
                else if( std::string( argv[i] ) == "-interp" )
                    interp = atoi( argv[++i] );
                else if( std::string( argv[i] ) == "-dim" )
                    dim    = atoi( argv[++i] );
                    hasdim = true;
                else if( std::string( argv[i] ) == "-geom" )
                    geom = std::string( argv[++i] ) == "s" ? 0 : 1;
                else
                    if( 0 == rank )
                        usage();
                    MPI_Finalize();
#else
                    usage();
#endif
                    return 0;
        if( !hasdim )
            if( 0 == rank )
                std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl;
#else
#endif
            return 0;
        if( dim > 2 || dim <= 0 )
            if( 0 == rank )
                std::cout << "Input dimesion should be positive and less than 3;" << std::endl;
#else
#endif
            return 0;
        if( 0 == rank )
            std::cout << "Testing on " << prefix + istr + "-" + iend + suffix << " with dimension " << dim << "\n";
            std::string opts = interp ? "interpolation" : "least square fitting";
            std::cout << "High order reconstruction in " << opts << std::endl;
#else
#endif
    geomObject* obj;
    if( geom == 0 )
        obj = new sphere();
    else
        obj = new torus();
    std::vector< int > degs2fit;
    for( int d = 1; d <= 6; ++d )
        degs2fit.push_back( d );
    int begin = atoi( istr.c_str() ), end = atoi( iend.c_str() ) + 1;
    std::vector< std::vector< double > > geoml1errs_global, geoml2errs_global, geomlinferrs_global;
    if( rank == 0 )
        geoml1errs_global =
            std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) );
        geoml2errs_global =
        geomlinferrs_global =
#else
    std::vector< std::vector< double > > geoml1errs_global( 1 + degs2fit.size(),
    std::vector< std::vector< double > > geoml2errs_global( 1 + degs2fit.size(),
    std::vector< std::vector< double > > geomlinferrs_global( 1 + degs2fit.size(),
#endif
    for( int i = begin; i < end; ++i )
        convert << i;
        std::string infile = prefix + convert.str() + suffix;
        int ntestverts;
        std::vector< double > geoml1errs, geoml2errs, geomlinferrs;
        std::cout << "Processor " << rank << " is working on file " << infile << std::endl;
#endif
        error = closedsurface_uref_hirec_convergence_study( infile.c_str(), degs2fit, interp, dim, obj, ntestverts,
                                                            geoml1errs, geoml2errs, geomlinferrs );MB_CHK_ERR( error );
        assert( geoml1errs.size() == 1 + degs2fit.size() && geoml2errs.size() == 1 + degs2fit.size() &&
                geomlinferrs.size() == 1 + degs2fit.size() );
        if( nprocs > 1 )
            int ntestverts_global = 0;
            MPI_Reduce( &ntestverts, &ntestverts_global, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
            for( size_t d = 0; d < degs2fit.size() + 1; ++d )
                double local_l1err = ntestverts * geoml1errs[d],
                       local_l2err = geoml2errs[d] * ( geoml2errs[d] * ntestverts ), local_linferr = geomlinferrs[d];
                std::cout << "On Processor " << rank << " with mesh " << i
                          << " Degree = " << ( d == 0 ? 0 : degs2fit[d - 1] ) << " L1:" << geoml1errs[d]
                          << " L2:" << geoml2errs[d] << " Li:" << geomlinferrs[d] << std::endl;
                double global_l1err = 0, global_l2err = 0, global_linferr = 0;
                MPI_Reduce( &local_l1err, &global_l1err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD );
                MPI_Reduce( &local_l2err, &global_l2err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD );
                MPI_Reduce( &local_linferr, &global_linferr, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD );
                if( rank == 0 )
                    geoml1errs_global[d][i - begin]   = global_l1err / ntestverts_global;
                    geoml2errs_global[d][i - begin]   = sqrt( global_l2err / ntestverts_global );
                    geomlinferrs_global[d][i - begin] = global_linferr;
        else
                geoml1errs_global[d][i - begin]   = geoml1errs[d];
                geoml2errs_global[d][i - begin]   = geoml2errs[d];
                geomlinferrs_global[d][i - begin] = geomlinferrs[d];
#else
#endif
    if( rank == 0 )
        std::cout << "Degrees: 0 ";
            std::cout << degs2fit[ideg] << " ";
        std::cout << "L1-norm error: \n";
        for( size_t i = 0; i < geoml1errs_global.size(); ++i )
            for( size_t j = 0; j < geoml1errs_global[i].size(); ++j )
                std::cout << geoml1errs_global[i][j] << " ";
        std::cout << "L2-norm error: \n";
        for( size_t i = 0; i < geoml2errs_global.size(); ++i )
            for( size_t j = 0; j < geoml2errs_global[i].size(); ++j )
                std::cout << geoml2errs_global[i][j] << " ";
        std::cout << "Linf-norm error: \n";
        for( size_t i = 0; i < geomlinferrs_global.size(); ++i )
            for( size_t j = 0; j < geomlinferrs_global[i].size(); ++j )
                std::cout << geomlinferrs_global[i][j] << " ";
#else
#endif
    MPI_Finalize();
#endif
void usage ( )
Definition at line 412 of file uref_hirec_test_parallel.cpp.
    std::cout << "usage: mpirun -np <number of processors> ./uref_hirec_test_parallel <prefix of "
                 "files> -str <first number> -end <lastnumber> -suffix <suffix> -interp <0=least "
                 "square, 1=interpolation> -dim <mesh dimension> -geom <s=sphere,t=torus>"
              << std::endl;
