cgma
CubitUndo.hpp
00001 //- Class:       UndoCommands
00002 //- Description: Provides undo capability for Cubit system
00003 //- Owner:       Ray J. Meyers
00004 //- Checked by:
00005 //- Version: $Id:
00006
00007
00008 #ifndef CUBITUNDO_HPP
00009 #define CUBITUNDO_HPP
00010
00011 #include <stack>
00012 #include "DLIList.hpp"
00013
00014 class UndoCommand;
00015 class CubitString;
00016 class RefEntity;
00017 class Body;
00018 class RefVolume;
00019 class RefFace;
00020 class RefEdge;
00021 class RefVertex;
00022 class MRefEntity;
00023 class MRefVolume;
00024 class MeshEntity;
00025
00026 class CUBIT_UTIL_EXPORT CubitUndo
00027 {
00028   // the one instance of the Cubit Undo object
00029   // creating a second instance will delete and replace the first instance.
00030   static CubitUndo* mInstance;
00031
00032 public:
00033
00034   CubitUndo();
00035   virtual ~CubitUndo();
00036
00037   static void start_undo_group();
00038   static void end_undo_group();
00039   static void set_undo_enabled(bool value);
00040   static bool get_undo_enabled();
00041   static void clear_undo_groups();
00042   static int  execute_undo();
00043   static void set_undo_by_restoring_state();
00044   static void set_undo_by_command(CubitString command);
00045
00046   static void save_state_with_cubit_file( DLIList<Body*> &bodies_to_save,
00047                                           DLIList<RefEntity*> *free_ents_to_save = NULL );
00048   static void save_state_with_cubit_file( DLIList<RefVolume*> &volumes_to_save );
00049   static void save_state_with_cubit_file( DLIList<RefFace*> &faces_to_save );
00050   static void save_state_with_cubit_file( RefFace* face_to_save );
00051   static void save_state_with_cubit_file( RefVolume* volume_to_save );
00052   static void save_state_with_cubit_file( DLIList<MRefVolume*> &volumes_to_save );
00053   static void save_state_with_cubit_file( DLIList<RefEdge*> &edges_to_save );
00054   static void save_state_with_cubit_file( DLIList<RefVertex*> &vertices_to_save,
00055                                           bool save_if_free = false );
00056
00057   static void save_state();
00058   static  int number_undo_groups();
00059   static void note_result_bodies( DLIList<Body*> &bodies_to_delete );
00060   static void note_result_body( Body* body_to_delete );
00061   static void note_result_entities( DLIList<RefEntity*> &entities_to_delete );
00062   static void note_result_entities( DLIList<MRefVolume*> &vols_to_delete );
00063   static void note_result_entity( RefEntity *entity_to_delete );
00064   static void note_result_boundary_conditions( RefEntity *owner_entity );
00065
00066   static void retain_mesh_on_result_bodies( DLIList<Body*> &bodies );
00067   static void retain_mesh_on_result_curves( DLIList<RefEdge*> &curves );
00068   static void retain_mesh_on_result_vertices( DLIList<RefVertex*> &vertices );
00069
00070   static void remove_last_undo();
00071   static void remove_last_undo_group();
00072   static void create_dummy_undo_object();
00073   static bool inside_undo_group();
00074
00075   //meshing data
00076   static void save_mesh_size_data( MRefEntity *entity );
00077   static void save_mesh_scheme_data( MRefEntity *entity );
00078   static void save_smooth_scheme_data( MRefEntity *entity );
00079   static void save_all_mesh_data( MRefEntity *entity );
00080
00081   //merging
00082   static void save_merge_data( DLIList<RefEntity*> &ents, bool merging = true );
00083
00084   //smoothing
00085   static void save_mesh_state_before_smoothing( MRefEntity *entity );
00086   static void save_mesh_state_before_smoothing( DLIList<MRefEntity*> &ents );
00087   static void save_mesh_state_before_smoothing( DLIList<MeshEntity*> &ents );
00088
00089 protected:
00090
00091   virtual void p_start_undo_group() = 0;
00092   virtual void p_end_undo_group() = 0;
00093
00094   virtual void p_set_undo_enabled(bool value)=0;
00095   virtual bool p_get_undo_enabled()=0;
00096   virtual void p_clear_undo_groups()=0;
00097   virtual int p_execute_undo()=0;
00098   virtual void p_set_undo_by_restoring_state()=0;
00099   virtual void p_set_undo_by_command(CubitString command)=0;
00100
00101   virtual void p_save_state_with_cubit_file( DLIList<Body*> &bodies_to_save,
00102                                              DLIList<RefEntity*> *free_ref_ents = NULL )=0;
00103   virtual void p_save_state_with_cubit_file( DLIList<RefVolume*> &volumes_to_save )=0;
00104   virtual void p_save_state_with_cubit_file( DLIList<RefFace*> &faces_to_save )=0;
00105   virtual void p_save_state_with_cubit_file( RefFace *face_to_save )=0;
00106   virtual void p_save_state_with_cubit_file( RefVolume* volume_to_save )=0;
00107   virtual void p_save_state_with_cubit_file( DLIList<MRefVolume*> &volumes_to_save )=0;
00108   virtual void p_save_state_with_cubit_file( DLIList<RefEdge*> &edges_to_save )=0;
00109   virtual void p_save_state_with_cubit_file( DLIList<RefVertex*> &vertices_to_save,
00110                                              bool save_only_if_free = false )=0;
00111
00112   virtual void p_save_state()=0;
00113   virtual  int p_number_undo_groups()=0;
00114   virtual void p_note_result_bodies( DLIList<Body*> &bodies_to_delete )=0;
00115   virtual void p_note_result_body( Body* body_to_delete )=0;
00116   virtual void p_note_result_entities( DLIList<RefEntity*> &entities_to_delete )=0;
00117   virtual void p_note_result_entities( DLIList<MRefVolume*> &vols_to_delete )=0;
00118   virtual void p_note_result_entity( RefEntity *entity_to_delete )=0;
00119   virtual void p_note_result_boundary_conditions( RefEntity *owner_entity )=0;
00120   virtual void p_remove_last_undo_group()=0;
00121   virtual void p_remove_last_undo()=0;
00122   virtual void p_create_dummy_undo_object()=0;
00123   virtual bool p_inside_undo_group()=0;
00124
00125   virtual void p_retain_mesh_on_result_bodies( DLIList<Body*> &bodies )=0;
00126   virtual void p_retain_mesh_on_result_curves( DLIList<RefEdge*> &curves )=0;
00127   virtual void p_retain_mesh_on_result_vertices( DLIList<RefVertex*> &vertices )=0;
00128
00129   //meshing data
00130   virtual void p_save_mesh_size_data( MRefEntity *entity )=0;
00131   virtual void p_save_mesh_scheme_data( MRefEntity *entity )=0;
00132   virtual void p_save_smooth_scheme_data( MRefEntity *entity )=0;
00133   virtual void p_save_all_mesh_data( MRefEntity *entity )=0;
00134
00135   //merging
00136   virtual void p_save_merge_data( DLIList<RefEntity*> &ents, bool merging = true)=0;
00137
00138   //smoothing
00139  virtual void p_save_mesh_state_before_smoothing( DLIList<MRefEntity*> &ents_to_smooth )=0;
00140  virtual void p_save_mesh_state_before_smoothing( DLIList<MeshEntity*> &ents_to_smooth )=0;
00141
00142 };
00143
00144 #endif
00145
00146
00147
00148
