cgma
MCNPInput.hpp
00001 #ifndef MCNP_INPUT_FORMAT_H
00002 #define MCNP_INPUT_FORMAT_H
00003
00004 #include <vector>
00005 #include <map>
00006 #include <iosfwd>
00007 #include <string>
00008
00009 typedef std::vector< std::string > token_list_t;
00010
00011 #include "dataref.hpp"
00012 #include "geometry.hpp"
00013
00014 class InputDeck;
00015
00019 class Card{
00020 protected:
00021   InputDeck& parent_deck;
00022
00023   Card( InputDeck& deck_p ):
00024     parent_deck(deck_p)
00025   {}
00026
00027   virtual ~Card(){}
00028
00029 public:
00030   InputDeck& getDeck() { return parent_deck; }
00031
00032 };
00033
00034 // forward defs
00035 class Transform;
00036 class Fill;
00037
00041 class CellCard : public Card {
00042
00043 public:
00044   enum geom_token_t {INTERSECT, UNION, COMPLEMENT, LPAREN, RPAREN, CELLNUM, SURFNUM, MBODYFACET};
00045   // for CELLNUM and SURFNUM the second item in the geom_list_entry is the given number
00046   // (possibly negative for surfaces)
00047   // for MBODYFACET it is  (cell number*10 + facet number) * sense (where sense=1 or -1)
00048   typedef std::pair<enum geom_token_t, int> geom_list_entry_t;
00049   typedef std::vector<geom_list_entry_t> geom_list_t;
00050
00051   enum lattice_type_t { NONE = 0, HEXAHEDRAL = 1, HEXAGONAL = 2 };
00052
00053 protected:
00054
00055   CellCard( InputDeck& deck );
00056
00057 private:
00058   // never defined and should never be called
00059   CellCard( const CellCard& c );
00060   CellCard& operator=( const CellCard& c );
00061
00062 public:
00063
00064   virtual int getIdent() const = 0;
00065   virtual const geom_list_t getGeom() const = 0;
00066
00067   virtual const DataRef<Transform>& getTrcl() const = 0;
00068
00069   virtual int getUniverse() const = 0;
00070   virtual bool hasFill() const = 0;
00071   virtual const Fill& getFill() const = 0;
00072
00073   virtual bool isLattice() const = 0;
00074   virtual lattice_type_t getLatticeType() const = 0;
00075   virtual const Lattice& getLattice() const = 0;
00076
00077   virtual int getMat() const = 0;
00078   virtual double getRho() const = 0;
00079   virtual const std::map<char,double>& getImportances() const = 0;
00080
00081   virtual void print( std::ostream& s ) const = 0;
00082
00083 };
00084
00085 std::ostream& operator<<(std::ostream& str, const CellCard::geom_list_entry_t& t );
00086
00087
00091 class SurfaceCard : public Card {
00092 protected:
00093   int ident;
00094   DataRef<Transform> *coord_xform;
00095   std::string mnemonic;
00096   std::vector<double> args;
00097
00098 public:
00099   SurfaceCard( InputDeck& deck, const token_list_t tokens );
00100
00101   int getIdent() const { return ident; }
00102   void print( std::ostream& s ) const ;
00103
00104   const DataRef<Transform>& getTransform() const ;
00105   const std::string& getMnemonic() const { return mnemonic; }
00106   const std::vector<double>& getArgs() const { return args; }
00107
00108
00109   std::pair<Vector3d,double> getPlaneParams() const;
00110   std::vector< std::pair<Vector3d, double> > getMacrobodyPlaneParams() const;
00111 };
00112
00117 class DataCard : public Card {
00118
00119 public:
00120   typedef enum { TR, OTHER } kind;
00121   typedef std::pair< kind, int > id_t;
00122
00123   DataCard( InputDeck& deck ) : Card( deck ) {}
00124
00125   virtual void print( std::ostream& str ) = 0;
00126   virtual kind getKind(){ return OTHER; }
00127
00128 };
00129
00130
00134 class InputDeck{
00135
00136 public:
00137   typedef std::vector< CellCard* > cell_card_list;
00138   typedef std::vector< SurfaceCard* > surface_card_list;
00139   typedef std::vector< DataCard* > data_card_list;
00140
00141 protected:
00142   class LineExtractor;
00143
00144   cell_card_list cells;
00145   surface_card_list surfaces;
00146   data_card_list datacards;
00147
00148   std::map<int, CellCard*> cell_map;
00149   std::map<int, SurfaceCard*> surface_map;
00150   std::map< DataCard::id_t, DataCard*> datacard_map;
00151
00152   bool do_line_continuation( LineExtractor& lines, token_list_t& token_buffer );
00153   void parseTitle( LineExtractor& lines );
00154   void parseCells( LineExtractor& lines );
00155   void parseSurfaces( LineExtractor& lines );
00156   void parseDataCards( LineExtractor& lines );
00157
00158 public:
00159
00160   ~InputDeck();
00161
00162   cell_card_list& getCells() { return cells; }
00163   surface_card_list& getSurfaces() { return surfaces; }
00164   data_card_list& getDataCards(){ return datacards; }
00165
00166   cell_card_list getCellsOfUniverse( int universe );
00167
00168   CellCard* lookup_cell_card(int ident);
00169   SurfaceCard* lookup_surface_card(int ident);
00170   DataCard* lookup_data_card( const DataCard::id_t& ident );
00171
00172   DataCard* lookup_data_card( DataCard::kind k, int ident ){
00173     return lookup_data_card( std::make_pair( k, ident ) );
00174   }
00175
00176   static InputDeck& build( std::istream& input );
00177
00178
00179 };
00180
00181 template < class T >
00182 std::ostream& operator<<( std::ostream& out, const std::vector<T>& list );
00183
00184 #endif /* MCNP_INPUT_FORMAT_H */
