cgma
00001 /* 00002 A C-program for MT19937, with initialization improved 2002/2/10. 00003 Coded by Takuji Nishimura and Makoto Matsumoto. 00004 This is a faster version by taking Shawn Cokus's optimization, 00005 Matthe Bellew's simplification, Isaku Wada's real version. 00006 00007 Before using, initialize the state by using init_genrand(seed) 00008 or init_by_array(init_key, key_length). 00009 00010 Copyright (C) 1997 - 2002, Makoto Matsumoto and Takuji Nishimura, 00011 All rights reserved. 00012 00013 Redistribution and use in source and binary forms, with or without 00014 modification, are permitted provided that the following conditions 00015 are met: 00016 00017 1. Redistributions of source code must retain the above copyright 00018 notice, this list of conditions and the following disclaimer. 00019 00020 2. Redistributions in binary form must reproduce the above copyright 00021 notice, this list of conditions and the following disclaimer in the 00022 documentation and/or other materials provided with the distribution. 00023 00024 3. The names of its contributors may not be used to endorse or promote 00025 products derived from this software without specific prior written 00026 permission. 00027 00028 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 00029 "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT 00030 LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR 00031 A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR 00032 CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, 00033 EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, 00034 PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR 00035 PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF 00036 LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING 00037 NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS 00038 SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. 00039 00040 00041 Any feedback is very welcome. 00042 http://www.math.keio.ac.jp/matumoto/emt.html 00043 email: matumoto@math.keio.ac.jp 00044 */ 00045 00046 #include "RandomMersenne.hpp" 00047 00048 /* Period parameters */ 00049 #define MIXBITS(u,v) ( ((u) & UMASK) | ((v) & LMASK) ) 00050 #define TWIST(u,v) ((MIXBITS(u,v) >> 1) ^ ((v)&1UL ? MATRIX_A : 0UL)) 00051 00052 /* initializes state[N] with a seed */ 00053 void RandomMersenne::init_genrand(unsigned long s) 00054 { 00055 mt[0]= s & 0xffffffffUL; 00056 for (mti=1; mti<N; mti++) { 00057 mt[mti] = 00058 (1812433253UL * (mt[mti-1] ^ (mt[mti-1] >> 30)) + mti); 00059 /* See Knuth TAOCP Vol2. 3rd Ed. P.106 for multiplier. */ 00060 /* In the previous versions, MSBs of the seed affect */ 00061 /* only MSBs of the array mt[]. */ 00062 /* 2002/01/09 modified by Makoto Matsumoto */ 00063 mt[mti] &= 0xffffffffUL; 00064 /* for >32 bit machines */ 00065 } 00066 } 00067 00068 /* initialize by an array with array-length */ 00069 /* init_key is the array for initializing keys */ 00070 /* key_length is its length */ 00071 void RandomMersenne::init_by_array(unsigned long init_key[], unsigned long key_length) 00072 { 00073 unsigned long i, j, k; 00074 const unsigned long n = (unsigned long)N; 00075 init_genrand(19650218UL); 00076 i=1UL; j=0UL; 00077 k = (n>key_length ? n : key_length); 00078 for (; k; k--) { 00079 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1664525UL)) 00080 + init_key[j] + j; /* non linear */ 00081 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */ 00082 i++; j++; 00083 if (i>=n) { mt[0] = mt[n-1]; i=1; } 00084 if (j>=key_length) j=0; 00085 } 00086 for (k=n-1; k; k--) { 00087 mt[i] = (mt[i] ^ ((mt[i-1] ^ (mt[i-1] >> 30)) * 1566083941UL)) 00088 - i; /* non linear */ 00089 mt[i] &= 0xffffffffUL; /* for WORDSIZE > 32 machines */ 00090 i++; 00091 if (i>=n) { mt[0] = mt[n-1]; i=1; } 00092 } 00093 00094 mt[0] = 0x80000000UL; /* MSB is 1; assuring non-zero initial array */ 00095 } 00096 00097 unsigned long RandomMersenne::genrand_int32() 00098 { 00099 unsigned long y; 00100 static unsigned long mag01[2]={0x0UL, MATRIX_A}; 00101 /* mag01[x] = x * MATRIX_A for x=0,1 */ 00102 00103 if (mti >= N) { /* generate N words at one time */ 00104 unsigned kk; 00105 00106 //if (mti == N+1) /* if init_genrand() has not been called, */ 00107 //init_genrand(5489UL); /* a default initial seed is used */ 00108 00109 for (kk=0;kk<N-M;kk++) { 00110 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK); 00111 mt[kk] = mt[kk+M] ^ (y >> 1) ^ mag01[y & 0x1UL]; 00112 } 00113 for (;kk<N-1;kk++) { 00114 y = (mt[kk]&UPPER_MASK)|(mt[kk+1]&LOWER_MASK); 00115 mt[kk] = mt[kk+(M-N)] ^ (y >> 1) ^ mag01[y & 0x1UL]; 00116 } 00117 y = (mt[N-1]&UPPER_MASK)|(mt[0]&LOWER_MASK); 00118 mt[N-1] = mt[M-1] ^ (y >> 1) ^ mag01[y & 0x1UL]; 00119 00120 mti = 0; 00121 } 00122 00123 y = mt[mti++]; 00124 00125 /* Tempering */ 00126 y ^= (y >> 11); 00127 y ^= (y << 7) & 0x9d2c5680UL; 00128 y ^= (y << 15) & 0xefc60000UL; 00129 y ^= (y >> 18); 00130 00131 return y; 00132 } 00133 00134 #ifdef TEST_RANDOM 00135 00136 #include <cstdio> 00137 00138 int main(void) 00139 { 00140 int i; 00141 unsigned long init[4]={0x123, 0x234, 0x345, 0x456}, length=4; 00142 RandomMersenne rm(init, length); 00143 printf("1000 outputs of genrand_int32()\n"); 00144 for (i=0; i<1000; i++) { 00145 printf("%10lu ", rm.genrand_int32()); 00146 if (i%5==4) printf("\n"); 00147 } 00148 printf("\n1000 outputs of genrand_real2()\n"); 00149 for (i=0; i<1000; i++) { 00150 printf("%10.8f ", rm.genrand_real2()); 00151 if (i%5==4) printf("\n"); 00152 } 00153 return 0; 00154 } 00155 #endif 00156
