cgma
TDDelaunay.hpp
00001 //-------------------------------------------------------------------------
00002 // Class:       TDDelaunay
00003 // Description: Support for TriDelaunayTool.  Maintains circumcircle
00004 //              info at the triangles.  Do it up template style
00005 // Author:      chynes
00006 // Date:        6/3/2002
00007 //-------------------------------------------------------------------------
00008
00009 #ifndef TD_DELAUNAY_HPP
00010 #define TD_DELAUNAY_HPP
00011
00012 #include "ToolData.hpp"
00013 #include "CubitVector.hpp"
00014 #include "MemoryManager.hpp"
00015 #include "CastTo.hpp"
00016
00017 template< class TRIA, class NODE >
00018 class TDDelaunay : public virtual ToolData
00019 {
00020 private:
00021
00022 //  static MemoryManager memoryManager;
00023 //   //- memory management object
00024
00025   CubitVector mCenter;
00026   double mRadius;
00027   int visitFlag;
00028   int sortIndex;
00029
00030 public:
00031
00032   TDDelaunay<TRIA, NODE>();
00033   virtual ~TDDelaunay<TRIA, NODE>();
00034    //-constructor and destructor
00035
00036   static int is_delaunay(const ToolData* td)
00037      {return (CAST_TO(td, const TDDelaunay) != NULL);}
00038
00039   void reset();
00040     // reset members to default
00041
00042   CubitVector &circumcenter2d( TRIA *tri_ptr );
00043   double radius2d( TRIA *tri_ptr );
00044    //- compute radius and circumcircle info for a 2D triangle
00045
00046   CubitVector &circumcenter( TRIA *tri_ptr );
00047   double radius( TRIA *tri_ptr );
00048    //- compute radius and circumcircle info for a 2D triangle
00049
00050   int circumsphere( TRIA *tet_ptr, CubitVector &center, double &rad );
00051    //- compute the radius and circumsphere of a tet
00052
00053   int visit_flag( ) {return visitFlag;};
00054   void visit_flag( int visit ) {visitFlag = visit;};
00055    //- get and set the visites flag
00056
00057   int tri_sort_list( ) {return sortIndex;};
00058   void tri_sort_list( int index ) {sortIndex = index;};
00059    //- get and set the index of the sorting array used for
00060    //- prioritizing which tris will be processed first
00061
00062 //  SetDynamicMemoryAllocation(memoryManager)
00063 //   //- class specific new and delete operators
00064 //
00065 //  static void set_memory_allocation_increment(int increment = 0)
00066 //                {memoryManager.set_memory_allocation_increment(increment);}
00067 //   //- set block memory size increment
00068 //
00069 //  static void destroy_memory()
00070 //                {memoryManager.destroy_memory();}
00071 //   //- destroy all memory allocted to this object*/
00072 };
00073
00074 #include "TDDelaunay.cpp"
00075
00076 #endif // TD_DELAUNAY_HPP
00077
