cgma
CADeferredAttrib Member List
This is the complete list of members for CADeferredAttrib, including all inherited members.
actuate()CADeferredAttrib [virtual]
actuate_after_geom_changes()CubitAttrib [inline]
actuate_in_constructor()CubitAttrib [inline]
actuate_list(DLIList< RefEntity * >)CubitAttrib [virtual]
add_attribute()CubitAttrib [protected, virtual]
add_unactuated_ca(CubitAttrib *ca_ptr)CADeferredAttrib [static]
allCADeferredAttribsCADeferredAttrib [private, static]
assign_to_owner(CubitAttribUser *owner=NULL)CADeferredAttrib [private]
att_internal_name()CubitAttrib [inline]
attrib_owner()CubitAttrib [inline]
attrib_owner(RefEntity *new_attrib_owner)CubitAttrib [inline]
attribOwnerEntityCubitAttrib [protected]
auto_actuate_flag(CubitBoolean value)CubitAttrib [inline]
auto_actuate_flag()CubitAttrib [inline]
auto_read_flag(CubitBoolean value)CubitAttrib
auto_read_flag()CubitAttrib
auto_update_flag(CubitBoolean value)CubitAttrib
auto_update_flag()CubitAttrib
auto_write_flag(CubitBoolean value)CubitAttrib
auto_write_flag()CubitAttrib
CADeferredAttrib(RefEntity *, const CubitSimpleAttrib &)CADeferredAttrib
cleanup_cadas(const CubitBoolean from_constructor, const CubitBoolean after_geom_changes)CADeferredAttrib [static]
cleanup_cadas_private(const CubitBoolean from_constructor, const CubitBoolean after_geom_changes)CADeferredAttrib [private, static]
csa_from_dcsa(const CubitSimpleAttrib &csa_ptr, const int uid=0)CADeferredAttrib [private, static]
cubit_simple_attrib()CADeferredAttrib [virtual]
CubitAttrib(RefEntity *attrib_owner)CubitAttrib
delete_attrib(CubitBoolean set_remove)CubitAttrib [inline]
delete_attrib()CubitAttrib [inline]
deleteAttribCubitAttrib [protected]
equivalent(const CubitSimpleAttrib &csa_ptr)CubitAttrib
get_deferred_attribs(const int uid, std::vector< CADeferredAttrib * > &cada_list)CADeferredAttrib [private, static]
get_unactuated_deferred_attribs()CADeferredAttrib [inline, static]
has_actuated()CubitAttrib [inline]
has_actuated(CubitBoolean set_has_actuated)CubitAttrib [inline]
has_updated()CubitAttrib [inline]
has_updated(CubitBoolean set_has_updated)CubitAttrib [inline]
has_written() const CubitAttrib [virtual]
has_written(CubitBoolean set_has_written)CubitAttrib [virtual]
hasActuatedCubitAttrib [protected]
hasUpdatedCubitAttrib [protected]
hasWrittenCubitAttrib [protected]
init_csa(const CubitSimpleAttrib &csa_ptr)CADeferredAttrib [private]
int_attrib_type()CADeferredAttrib [inline, private, virtual]
merge_owner(CubitAttrib *deletable_ca_ptr)CubitAttrib [inline, virtual]
next_attrib()CubitAttrib [inline]
nextAttribCubitAttrib [protected]
owner_created(RefEntity *new_owner, const int uid)CADeferredAttrib [static]
print()CubitAttrib [virtual]
remove_attribute()CubitAttrib [protected, virtual]
remove_unactuated_ca(CubitAttrib *ca_ptr)CADeferredAttrib [static]
reset()CADeferredAttrib [virtual]
set_next_attrib(CubitAttrib *next_attrib_ptr)CubitAttrib [inline]
split_owner()CubitAttrib [inline, virtual]
thisCSACADeferredAttrib [private]
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor)CubitAttrib [inline, virtual]
unactuatedCAsCADeferredAttrib [private, static]
unique_id()CADeferredAttrib [inline]
unique_id(int id)CADeferredAttrib [inline]
uniqueIdCADeferredAttrib [private]
update()CADeferredAttrib [virtual]
~CADeferredAttrib()CADeferredAttrib [virtual]
~CubitAttrib()CubitAttrib [virtual]
