ChollaMesh() | ChollaMesh | |
convert_from_facet(FacetEntity *f) | ChollaMesh | |
convert_from_point(CubitPoint *p) | ChollaMesh | |
convert_to_facet(SMD::SMDElement elem) | ChollaMesh | |
convert_to_point(SMD::SMDNode node) | ChollaMesh | |
create_elements(SMD::ElementType type, unsigned int num_nodes, const SMD::SMDNode node_handle_array[], unsigned int num_elements, unsigned int num_nodes_per_element, const unsigned int connectivity[], SMD::SMeshOwner new_entities_owner, SMD::SMDElement *created_element_handles) | ChollaMesh | |
create_nodes(unsigned int num_nodes, const SMD::Real coords[][3], SMD::SMeshOwner owner, SMD::SMDNode node_handles[]) | ChollaMesh | |
create_nodes(unsigned int num_nodes, const SMD::Real *coords, SMD::SMeshOwner owner, SMD::SMDNode node_handles[]) | ChollaMesh | [inline] |
delete_element(SMD::SMDElement element) | ChollaMesh | |
delete_node(SMD::SMDNode node) | ChollaMesh | |
find_element(SMD::ElementType type, unsigned int num_pts, const SMD::SMDNode nodes[], SMD::SMDElement &found_element) | ChollaMesh | |
get_connectivity(int num_elems, const SMD::SMDElement elements[], int &node_array_size, SMD::SMDNode node_handles[]) | ChollaMesh | |
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], float coords[][3]) | ChollaMesh | |
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], double coords[][3]) | ChollaMesh | |
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], SMD::Real x_coords[], SMD::Real y_coords[], SMD::Real z_coords[]) | ChollaMesh | |
get_element_area(SMD::SMDElement elem_handle, double &area) | ChollaMesh | |
get_element_centroid(SMD::SMDElement elem_handle, double centroid[3]) | ChollaMesh | |
get_element_dimensions(int num_elems, const SMD::SMDElement elem_handle_array[], int dimensions[]) | ChollaMesh | |
get_element_handle(SMD::ElementType type, int id, SMD::SMDElement &elem) | ChollaMesh | |
get_element_length(SMD::SMDElement elem_handle, double &length) | ChollaMesh | |
get_element_normal(SMD::SMDElement elem_handle, double normal_vector[3]) | ChollaMesh | |
get_element_types(int num_elems, const SMD::SMDElement elem_handle_array[], SMD::ElementType type_array[], bool *same_type) | ChollaMesh | |
get_expanded_connectivity(int num_elems, const SMD::SMDElement elements[], unsigned int nodes_per_elem, int node_array_size, SMD::SMDNode node_handles[]) | ChollaMesh | |
get_expanded_connectivity(SMD::SMDElement elements, unsigned int &nodes_per_elem, int node_array_size, SMD::SMDNode node_handles[]) | ChollaMesh | |
get_ids(size_t num, const SMD::SMDNode nodes[], int ids[]) | ChollaMesh | |
get_ids(size_t num, const SMD::SMDElement elems[], int ids[]) | ChollaMesh | |
get_node_handle(int id, SMD::SMDNode &node) | ChollaMesh | |
reverse_element_connectivity(SMD::SMDElement element) | ChollaMesh | |
~ChollaMesh() | ChollaMesh | |
