cgma
Main Page
Related Pages
Modules
Namespaces
Classes
Files
Class List
Class Index
Class Hierarchy
Class Members
ChollaSurface Member List
This is the complete list of members for
ChollaSurface
, including all inherited members.
add_curve
(ChollaCurve *bcm_ptr)
ChollaSurface
[inline]
add_curve_unique
ChollaSurface
[inline]
add_facet
(FacetEntity *exterior_face)
ChollaSurface
[inline]
add_mesh_unique
ChollaSurface
[inline]
add_preexisting_feature_edges
(DLIList< CubitFacetEdge * > &feature_edge_list)
ChollaSurface
add_volume
(ChollaVolume *cholla_vol_ptr)
ChollaSurface
[inline]
add_volume_unique
ChollaSurface
[inline]
assign_eval_tool
(FacetEvalTool *eval_tool_ptr)
ChollaSurface
[inline]
assign_geometric_surface
(void *surf)
ChollaSurface
[inline]
blockId
ChollaSurface
[private]
check_faceting
ChollaSurface
[private]
ChollaEntity
ChollaEntity
ChollaSurface
(int block_id)
ChollaSurface
clean_features
ChollaSurface
curveList
ChollaSurface
[private]
debug_draw
ChollaSurface
feature_angle
(double min_dot, DLIList< CubitFacetEdge * > &feature_edge_list)
ChollaSurface
flip_facets
ChollaSurface
get_adj_facets
(FacetEntity *start_face_ptr, DLIList< FacetEntity * > &face_list, int mydebug=0, bool bound_check=false, bool feature_edge_check=true)
ChollaSurface
get_block_id
ChollaSurface
[inline]
get_curves
(DLIList< ChollaCurve * > &bcm_list)
ChollaSurface
[inline]
get_eval_tool
ChollaSurface
[inline]
get_facet_list
ChollaSurface
[inline]
get_facet_list_ptr
ChollaSurface
[inline]
get_facets
(DLIList< FacetEntity * > &surface_facets)
ChollaSurface
[inline]
get_flag
ChollaSurface
[inline]
get_geometric_surface
ChollaSurface
[inline]
get_id
ChollaSurface
[inline]
get_loop_edges
ChollaSurface
get_points
(DLIList< CubitPoint * > &point_list)
ChollaSurface
get_vertices
(DLIList< ChollaPoint * > &chpt_list)
ChollaSurface
get_volumes
(DLIList< ChollaVolume * > &cholla_vol_list)
ChollaSurface
[inline]
id
ChollaSurface
[private]
init_hit_flags
ChollaSurface
is_adjacent
(ChollaSurface *other_surf)
ChollaSurface
is_contain
(FacetEntity *facet)
ChollaSurface
is_in_volume
(ChollaVolume *chvol_ptr)
ChollaSurface
merge_partner
ChollaSurface
[inline]
myEvalTool
ChollaSurface
[private]
myFlag
ChollaSurface
[private]
myMergePartner
ChollaSurface
[private]
mySurface
ChollaSurface
[private]
non_manifold_edges
ChollaSurface
num_volumes
ChollaSurface
[inline]
remove_curve
ChollaSurface
[inline]
remove_facet
ChollaSurface
[inline]
remove_volume
ChollaSurface
[inline]
reset_facet_flags
ChollaSurface
set_block_id
(int flag)
ChollaSurface
[inline]
set_flag
(CubitBoolean stat)
ChollaSurface
[inline]
set_merge_partner
(ChollaSurface *merge_partner)
ChollaSurface
[inline]
split_surface
(DLIList< ChollaSurface * > &block_surface_list)
ChollaSurface
surfaceElemList
ChollaSurface
[private]
update_boundary_tool_data
ChollaSurface
volList
ChollaSurface
[private]
~ChollaEntity
ChollaEntity
[virtual]
~ChollaSurface
ChollaSurface
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Defines
Generated on Tue Jun 30 2020 12:02:51 for cgma by
1.7.6.1
