about_spatially_equal(Curve *curve_1, Curve *curve_2, CubitSense &relative_sense, double tolerance_factor, int layer=TopologyBridge::MAX_TB_LAYER) | CompositeEngine | |
append_attrib(TopologyBridge *bridge, const CubitSimpleAttrib &attrib) | CompositeEngine | [protected, static] |
attribute_after_imprinting(DLIList< TopologyBridge * > &tb_list, DLIList< Body * > &old_bodies) | CompositeEngine | [virtual] |
clean_out_deactivated_geometry() | CompositeEngine | [virtual] |
combine(CompositeCurve *curve1, CompositeCurve *curve2, CompositePoint *keep_point=0, bool remove_partitions=false) | CompositeEngine | [protected] |
combine_bodies(BodySM *body1, BodySM *body2) | CompositeEngine | |
composite(Curve *survivor, Curve *dead, TBPoint *keep_point=0, bool remove_partitions=false) | CompositeEngine | |
CompositeEngine() | CompositeEngine | [private] |
create_composites(DLIList< BodySM * > &) | CompositeEngine | [protected] |
create_composites(DLIList< Surface * > &) | CompositeEngine | [protected] |
create_composites(DLIList< Curve * > &) | CompositeEngine | [protected] |
create_composites(DLIList< TBPoint * > &) | CompositeEngine | [protected] |
deactivatedList | CompositeEngine | [private] |
delete_instance() | CompositeEngine | [static] |
destroy_point_curve(CompositeCurve *curve) | CompositeEngine | [protected] |
export_geometry(DLIList< TopologyBridge * > &geometry_to_save) | CompositeEngine | [virtual] |
find_attribute_by_name(TopologyBridge *bridge, const CubitString name) | CompositeEngine | [static] |
find_coedges(CompositeSurface *surface, CompositeCurve *curve, CompositePoint *point, CompositeCoEdge *&previous, CompositeCoEdge *&next) | CompositeEngine | [protected, static] |
find_next_point_coedge(CompositeSurface *const surface, CoEdgeSM *const coedge, CompositePoint *point, DLIList< CompositeCoEdge * > &point_coedges) | CompositeEngine | [protected, static] |
get_all_curves_and_points(DLIList< TopologyBridge * > &tb_list, DLIList< Curve * > &curves, DLIList< TBPoint * > &points) | CompositeEngine | |
get_tbs_with_bridge_manager_as_owner(TopologyBridge *source_bridge, DLIList< TopologyBridge * > &tbs) | CompositeEngine | [virtual] |
import_geometry(DLIList< TopologyBridge * > &imported_geometry) | CompositeEngine | [virtual] |
insert_curve(DLIList< Surface * > &surfaces, DLIList< CubitVector * > &polyline, DLIList< Surface * > &new_surfaces, DLIList< Curve * > &new_curves) | CompositeEngine | |
insert_nonmanifold_surfaces(DLIList< CompositeSurface * > &surfs, CompositeShell *shell1, CompositeShell *shell2) | CompositeEngine | [protected] |
insert_point(CompositeCurve *curve, double u) | CompositeEngine | |
insert_point_curve(CompositeSurface *surface, const CubitVector &position) | CompositeEngine | |
inside_shell(CompositeShell *const shell, CompositeSurface *const surf, bool &result) | CompositeEngine | [protected] |
instance_ | CompositeEngine | [protected, static] |
is_composite(TBOwner *bridge_owner) | CompositeEngine | [virtual] |
is_composite(TopologyBridge *bridge) | CompositeEngine | [virtual] |
is_hidden(TopologyBridge *tb) | CompositeEngine | |
is_partition(TBOwner *bridge_owner) | CompositeEngine | [virtual] |
level() const | CompositeEngine | [inline, virtual] |
notify_deactivated(CompositeBody *body) | CompositeEngine | |
notify_deactivated(CompositeLump *volume) | CompositeEngine | |
notify_deactivated(CompositeSurface *surface) | CompositeEngine | |
notify_deactivated(CompositeCurve *curve) | CompositeEngine | |
notify_deactivated(CompositePoint *point) | CompositeEngine | |
notify_transform(TopologyBridge *bridge, const CubitTransformMatrix &xform) | CompositeEngine | [virtual] |
process_curves_after_imprint(Curve *att_bridge, Curve *other_bridge, DLIList< BodySM * > &new_sms) | CompositeEngine | [private] |
process_points_after_imprint(TBPoint *att_bridge, TBPoint *other_bridge, DLIList< BodySM * > &new_sms) | CompositeEngine | [private] |
push_imprint_attributes_before_modify(DLIList< BodySM * > &body_sms) | CompositeEngine | [virtual] |
push_named_attributes_to_curves_and_points(DLIList< TopologyBridge * > &tb_list, const char *name_in) | CompositeEngine | [virtual] |
reflect(CompositeBody *body, const CubitVector &axis) | CompositeEngine | |
reflect(CompositeSurface *surface, const CubitVector &axis) | CompositeEngine | |
reflect(CompositeCurve *curve, const CubitVector &axis) | CompositeEngine | |
remove_attributes(DLIList< TopologyBridge * > &bridge_list) | CompositeEngine | [virtual] |
remove_attributes_from_unmodifed_virtual(DLIList< TopologyBridge * > &bridges) | CompositeEngine | [virtual] |
remove_composite(CompositePoint *point) | CompositeEngine | [protected] |
remove_composite(CompositeCurve *composite) | CompositeEngine | [protected] |
remove_composite(CompositeSurface *composite) | CompositeEngine | [protected] |
remove_composite(CompositeLump *composite) | CompositeEngine | [protected] |
remove_composite(CompositeBody *composite) | CompositeEngine | [protected] |
remove_curve(Curve *dead_curve, bool remove_partitions=false, Surface *survivor=0) | CompositeEngine | |
remove_imprint_attributes_after_modify(DLIList< BodySM * > &old_sms, DLIList< BodySM * > &new_sms) | CompositeEngine | [virtual] |
remove_modified(DLIList< Surface * > &all_surfs, DLIList< Curve * > &all_curves, DLIList< TBPoint * > &all_pts) | CompositeEngine | [virtual] |
remove_partition_curves(CompositeCurve *curve_owner) | CompositeEngine | [protected] |
remove_partition_point(CompositePoint *point_owner) | CompositeEngine | [protected] |
remove_point(TBPoint *dead_point, bool remove_partitions=false, Curve *survivor=0) | CompositeEngine | |
remove_surface(Surface *dead_surf, Surface *stitch_partner=0, bool remove_partitions=false) | CompositeEngine | |
replace_body(BodySM *body) | CompositeEngine | |
replace_curve(Curve *dead_curve) | CompositeEngine | |
replace_lump(Lump *lump) | CompositeEngine | |
replace_point(TBPoint *dead_point) | CompositeEngine | |
replace_surface(Surface *surface) | CompositeEngine | |
restore_curve(Curve *curve) | CompositeEngine | |
restore_point(TBPoint *point) | CompositeEngine | |
restore_point_in_curve(TBPoint *point) | CompositeEngine | |
restore_point_in_surface(TBPoint *point) | CompositeEngine | |
restore_surface(Surface *surface, Surface *&stitch_parnter) | CompositeEngine | |
restore_transform(CompositeBody *body) | CompositeEngine | |
rotate(CompositeBody *body, const CubitVector &axis, double degrees) | CompositeEngine | |
rotate(CompositeSurface *surface, const CubitVector &axis, double degrees) | CompositeEngine | |
rotate(CompositeCurve *curve, const CubitVector &axis, double degrees) | CompositeEngine | |
save(CompositePoint *) | CompositeEngine | [protected] |
save(CompositeCurve *) | CompositeEngine | [protected] |
save(CompositeSurface *) | CompositeEngine | [protected] |
save(CompositeLump *) | CompositeEngine | [protected] |
save(CompositeBody *) | CompositeEngine | [protected] |
scale(CompositeBody *body, const CubitVector &factors) | CompositeEngine | |
scale(CompositeSurface *surface, const CubitVector &factors) | CompositeEngine | |
scale(CompositeCurve *curve, const CubitVector &factors) | CompositeEngine | |
split(CompositeCurve *curve, int after_index, Curve *&result1, Curve *&resutl2) | CompositeEngine | [protected] |
split_body(CompositeBody *body_to_split, DLIList< BodySM * > &resulting_bodies) | CompositeEngine | |
split_lump(CompositeShell *shell_to_split) | CompositeEngine | [private] |
split_shell(CompositeShell *shell) | CompositeEngine | [protected] |
split_surface(CompositeSurface *surf_to_split, CompositeLoop *loop_on_surf, CompositeLoop *new_loop) | CompositeEngine | [private] |
stitch_curves(Curve *curve1, Curve *curve2) | CompositeEngine | |
stitch_points(TBPoint *point1, TBPoint *point2) | CompositeEngine | |
stitch_surfaces(Surface *surf, Surface *surf2) | CompositeEngine | |
strip_attributes(TopologyBridge *bridge) | CompositeEngine | [static] |
translate(CompositeBody *body, const CubitVector &delta) | CompositeEngine | |
translate(CompositeSurface *surface, const CubitVector &delta) | CompositeEngine | |
translate(CompositeCurve *curve, const CubitVector &delta) | CompositeEngine | |
~CompositeEngine() | CompositeEngine | [virtual] |
